path: root/fs/nfsd
2011-07-25Merge branch 'for-3.1' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-3.1' of git://linux-nfs.org/~bfields/linux: nfsd: don't break lease on CLAIM_DELEGATE_CUR locks: rename lock-manager ops nfsd4: update nfsv4.1 implementation notes nfsd: turn on reply cache for NFSv4 nfsd4: call nfsd4_release_compoundargs from pc_release nfsd41: Deny new lock before RECLAIM_COMPLETE done fs: locks: remove init_once nfsd41: check the size of request nfsd41: error out when client sets maxreq_sz or maxresp_sz too small nfsd4: fix file leak on open_downgrade nfsd4: remember to put RW access on stateid destruction NFSD: Added TEST_STATEID operation NFSD: added FREE_STATEID operation svcrpc: fix list-corrupting race on nfsd shutdown rpc: allow autoloading of gss mechanisms svcauth_unix.c: quiet sparse noise svcsock.c: include sunrpc.h to quiet sparse noise nfsd: Remove deprecated nfsctl system call and related code. NFSD: allow OP_DESTROY_CLIENTID to be only op in COMPOUND Fix up trivial conflicts in Documentation/feature-removal-schedule.txt
2011-07-23nfsd: don't break lease on CLAIM_DELEGATE_CURCasey Bodley
CLAIM_DELEGATE_CUR is used in response to a broken lease; allowing it to break the lease and return EAGAIN leaves the client unable to make progress in returning the delegation nfs4_get_vfs_file() now takes struct nfsd4_open for access to the claim type, and calls nfsd_open() with NFSD_MAY_NOT_BREAK_LEASE when claim type is CLAIM_DELEGATE_CUR Signed-off-by: Casey Bodley <cbodley@citi.umich.edu> Cc: stable@kernel.org Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-07-20locks: rename lock-manager opsJ. Bruce Fields
Both the filesystem and the lock manager can associate operations with a lock. Confusingly, one of them (fl_release_private) actually has the same name in both operation structures. It would save some confusion to give the lock-manager ops different names. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-07-20nfsd4_list_rec_dir(): don't bother with reopening rec_fileAl Viro
just rewind it to the beginning before vfs_readdir() and be done with that... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-18nfsd: turn on reply cache for NFSv4J. Bruce Fields
It's sort of ridiculous that we've never had a working reply cache for NFSv4. On the other hand, we may still not: our current reply cache is likely not very good, especially in the TCP case (which is the only case that matters for v4). What we really need here is some serious testing. Anyway, here's a start. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-07-18nfsd4: call nfsd4_release_compoundargs from pc_releaseJ. Bruce Fields
This simplifies cleanup a bit. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-07-15nfsd41: Deny new lock before RECLAIM_COMPLETE doneMi Jinlong
Before nfs41 client's RECLAIM_COMPLETE done, nfs server should deny any new locks or opens. rfc5661: " Whenever a client establishes a new client ID and before it does the first non-reclaim operation that obtains a lock, it MUST send a RECLAIM_COMPLETE with rca_one_fs set to FALSE, even if there are no locks to reclaim. If non-reclaim locking operations are done before the RECLAIM_COMPLETE, an NFS4ERR_GRACE error will be returned. " Signed-off-by: Mi Jinlong <mijinlong@cn.fujitsu.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-07-15nfsd41: check the size of requestMi Jinlong
Check in SEQUENCE that the request doesn't exceed maxreq_sz for the given session. Signed-off-by: Mi Jinlong <mijinlong@cn.fujitsu.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-07-15nfsd41: error out when client sets maxreq_sz or maxresp_sz too smallMi Jinlong
According to RFC5661, 18.36.3, "if the client selects a value for ca_maxresponsesize such that a replier on a channel could never send a response,the server SHOULD return NFS4ERR_TOOSMALL in the CREATE_SESSION reply." So, error out when the client sets a maxreq_sz less than the minimum possible SEQUENCE request size, or sets a maxresp_sz less than the minimum possible SEQUENCE reply size. Signed-off-by: Mi Jinlong <mijinlong@cn.fujitsu.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-07-15nfsd4: fix file leak on open_downgradeJ. Bruce Fields
Stateid's hold a read reference for a read open, a write reference for a write open, and an additional one of each for each read+write open. The latter wasn't getting put on a downgrade, so something like: open RW open R downgrade to R was resulting in a file leak. Also fix an imbalance in an error path. Regression from 7d94784293096c0a46897acdb83be5abd9278ece "nfsd4: fix downgrade/lock logic". Cc: stable@kernel.org Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-07-15nfsd4: remember to put RW access on stateid destructionJ. Bruce Fields
Without this, for example, open read open read+write close will result in a struct file leak. Regression from 7d94784293096c0a46897acdb83be5abd9278ece "nfsd4: fix downgrade/lock logic". Cc: stable@kernel.org Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-07-15NFSD: Added TEST_STATEID operationBryan Schumaker
This operation is used by the client to check the validity of a list of stateids. Signed-off-by: Bryan Schumaker <bjschuma@netapp.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-07-15NFSD: added FREE_STATEID operationBryan Schumaker
This operation is used by the client to tell the server to free a stateid. Signed-off-by: Bryan Schumaker <bjschuma@netapp.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-07-15nfsd: Remove deprecated nfsctl system call and related code.NeilBrown
As promised in feature-removal-schedule.txt it is time to remove the nfsctl system call. Userspace has perferred to not use this call throughout 2.6 and it has been excluded in the default configuration since 2.6.36 (9 months ago). So this patch removes all the code that was being compiled out. There are still references to sys_nfsctl in various arch systemcall tables and related code. These should be cleaned out too, probably in the next merge window. Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-07-15NFSD: allow OP_DESTROY_CLIENTID to be only op in COMPOUNDBenny Halevy
DESTROY_CLIENTID MAY be preceded with a SEQUENCE operation as long as the client ID derived from the session ID of SEQUENCE is not the same as the client ID to be destroyed. If the client IDs are the same, then the server MUST return NFS4ERR_CLIENTID_BUSY. (that's not implemented yet) If DESTROY_CLIENTID is not prefixed by SEQUENCE, it MUST be the only operation in the COMPOUND request (otherwise, the server MUST return NFS4ERR_NOT_ONLY_OP). This fixes the error return; before, we returned NFS4ERR_OP_NOT_IN_SESSION; after this patch, we return NFS4ERR_NOTSUPP. Signed-off-by: Benny Halevy <benny@tonian.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-06-20nfsd4: fix break_lease flags on nfsd openJ. Bruce Fields
Thanks to Casey Bodley for pointing out that on a read open we pass 0, instead of O_RDONLY, to break_lease, with the result that a read open is treated like a write open for the purposes of lease breaking! Reported-by: Casey Bodley <cbodley@citi.umich.edu> Cc: stable@kernel.org Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-06-06nfsd: link returns nfserr_delay when breaking leaseCasey Bodley
fix for commit 4795bb37effb7b8fe77e2d2034545d062d3788a8, nfsd: break lease on unlink, link, and rename if the LINK operation breaks a delegation, it returns NFS4ERR_NOENT (which is not a valid error in rfc 5661) instead of NFS4ERR_DELAY. the return value of nfsd_break_lease() in nfsd_link() must be converted from host_err to err Signed-off-by: Casey Bodley <cbodley@citi.umich.edu> Cc: stable@kernel.org Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-06-06nfsd: v4 support requires CRYPTORandy Dunlap
nfsd V4 support uses crypto interfaces, so select CRYPTO to fix build errors in 2.6.39: ERROR: "crypto_destroy_tfm" [fs/nfsd/nfsd.ko] undefined! ERROR: "crypto_alloc_base" [fs/nfsd/nfsd.ko] undefined! Reported-by: Wakko Warner <wakko@animx.eu.org> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: stable@kernel.org Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-06-06nfsd: fix dependency of nfsd on auth_rpcgssJ. Bruce Fields
Commit b0b0c0a26e84 "nfsd: add proc file listing kernel's gss_krb5 enctypes" added an nunnecessary dependency of nfsd on the auth_rpcgss module. It's a little ad hoc, but since the only piece of information nfsd needs from rpcsec_gss_krb5 is a single static string, one solution is just to share it with an include file. Cc: stable@kernel.org Reported-by: Michael Guntsche <mike@it-loops.com> Cc: Kevin Coffman <kwc@citi.umich.edu> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-05-29Merge branch 'for-2.6.40' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.40' of git://linux-nfs.org/~bfields/linux: (22 commits) nfsd: make local functions static NFSD: Remove unused variable from nfsd4_decode_bind_conn_to_session() NFSD: Check status from nfsd4_map_bcts_dir() NFSD: Remove setting unused variable in nfsd_vfs_read() nfsd41: error out on repeated RECLAIM_COMPLETE nfsd41: compare request's opcnt with session's maxops at nfsd4_sequence nfsd v4.1 lOCKT clientid field must be ignored nfsd41: add flag checking for create_session nfsd41: make sure nfs server process OPEN with EXCLUSIVE4_1 correctly nfsd4: fix wrongsec handling for PUTFH + op cases nfsd4: make fh_verify responsibility of nfsd_lookup_dentry caller nfsd4: introduce OPDESC helper nfsd4: allow fh_verify caller to skip pseudoflavor checks nfsd: distinguish functions of NFSD_MAY_* flags svcrpc: complete svsk processing on cb receive failure svcrpc: take advantage of tcp autotuning SUNRPC: Don't wait for full record to receive tcp data svcrpc: copy cb reply instead of pages svcrpc: close connection if client sends short packet svcrpc: note network-order types in svc_process_calldir ...
2011-05-18nfsd: make local functions staticDaniel Mack
This also fixes a number of sparse warnings. Signed-off-by: Daniel Mack <zonque@gmail.com> Cc: Trond Myklebust <Trond.Myklebust@netapp.com> Cc: J. Bruce Fields <bfields@fieldses.org> Cc: Neil Brown <neilb@suse.de> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-05-10treewide: fix a few typos in commentsJustin P. Mattock
- kenrel -> kernel - whetehr -> whether - ttt -> tt - sss -> ss Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-04-29NFSD: Remove unused variable from nfsd4_decode_bind_conn_to_session()Bryan Schumaker
Compiling gave me this warning: fs/nfsd/nfs4xdr.c: In function ‘nfsd4_decode_bind_conn_to_session’: fs/nfsd/nfs4xdr.c:427:6: warning: variable ‘dummy’ set but not used [-Wunused-but-set-variable] The local variable "dummy" wasn't being used past the READ32() macro that set it. READ_BUF() should ensure that the xdr buffer is pushed past the data read into dummy already, so nothing needs to be read in. Signed-off-by: Bryan Schumaker <bjschuma@netapp.com> [bfields@redhat.com: minor comment fixup.] Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-04-29NFSD: Check status from nfsd4_map_bcts_dir()Bryan Schumaker
Compiling gave me this warning: fs/nfsd/nfs4state.c: In function ‘nfsd4_bind_conn_to_session’: fs/nfsd/nfs4state.c:1623:9: warning: variable ‘status’ set but not used [-Wunused-but-set-variable] The local variable "status" was being set by nfsd4_map_bcts_dir() and then ignored before calling nfsd4_new_conn(). Signed-off-by: Bryan Schumaker <bjschuma@netapp.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-04-29NFSD: Remove setting unused variable in nfsd_vfs_read()Bryan Schumaker
Compiling gave me this warning: fs/nfsd/vfs.c: In function ‘nfsd_vfs_read’: fs/nfsd/vfs.c:880:16: warning: variable ‘inode’ set but not used [-Wunused-but-set-variable] I discovered that a local variable "inode" was being set towards the beginning of nfsd_vfs_read() and then ignored for the rest of the function. Signed-off-by: Bryan Schumaker <bjschuma@netapp.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-04-29nfsd41: error out on repeated RECLAIM_COMPLETEMi Jinlong
Servers are supposed to return nfserr_complete_already to clients that attempt to send multiple RECLAIM_COMPLETEs. Signed-off-by: Mi Jinlong <mijinlong@cn.fujitsu.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-04-29nfsd41: compare request's opcnt with session's maxops at nfsd4_sequenceMi Jinlong
Make sure nfs server errors out if request contains more ops than channel allows. Signed-off-by: Mi Jinlong <mijinlong@cn.fujitsu.com> [bfields@redhat.com: use helper function] Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-04-29nfsd v4.1 lOCKT clientid field must be ignoredAndy Adamson
RFC 5661 Section 18.11.3 The clientid field of the owner MAY be set to any value by the client and MUST be ignored by the server. The reason the server MUST ignore the clientid field is that the server MUST derive the client ID from the session ID from the SEQUENCE operation of the COMPOUND request. Signed-off-by: Andy Adamson <andros@netapp.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-04-29nfsd41: add flag checking for create_sessionMi Jinlong
Teach the NFS server to reject invalid create_session flags. Also do some minor formatting adjustments. Signed-off-by: Mi Jinlong <mijinlong@cn.fujitsu.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-04-29nfsd41: make sure nfs server process OPEN with EXCLUSIVE4_1 correctlyMi Jinlong
The NFS server uses nfsd_create_v3 to handle EXCLUSIVE4_1 opens, but that function is not prepared to handle them. Rename nfsd_create_v3() to do_nfsd_create(), and add handling of EXCLUSIVE4_1. Signed-off-by: Mi Jinlong <mijinlong@cn.fujitsu.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-04-29nfsd4: fix wrongsec handling for PUTFH + op casesJ. Bruce Fields
When PUTFH is followed by an operation that uses the filehandle, and when the current client is using a security flavor that is inconsistent with the given filehandle, we have a choice: we can return WRONGSEC either when the current filehandle is set using the PUTFH, or when the filehandle is first used by the following operation. Follow the recommendations of RFC 5661 in making this choice. (Our current behavior prevented the client from doing security negotiation by returning WRONGSEC on PUTFH+SECINFO_NO_NAME.) Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-04-20Open with O_CREAT flag set fails to open existing files on non writable ↵Sachin Prabhu
directories An open on a NFS4 share using the O_CREAT flag on an existing file for which we have permissions to open but contained in a directory with no write permissions will fail with EACCES. A tcpdump shows that the client had set the open mode to UNCHECKED which indicates that the file should be created if it doesn't exist and encountering an existing flag is not an error. Since in this case the file exists and can be opened by the user, the NFS server is wrong in attempting to check create permissions on the parent directory. The patch adds a conditional statement to check for create permissions only if the file doesn't exist. Signed-off-by: Sachin S. Prabhu <sprabhu@redhat.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-04-19nfsd4: Fix filp leakOGAWA Hirofumi
23fcf2ec93fb8573a653408316af599939ff9a8e (nfsd4: fix oops on lock failure) The above patch breaks free path for stp->st_file. If stp was inserted into sop->so_stateids, we have to free stp->st_file refcount. Because stp->st_file refcount itself is taken whether or not any refcounts are taken on the stp->st_file->fi_fds[]. Signed-off-by: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: stable@kernel.org Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-04-18nfsd4: fix struct file leak on delegationJ. Bruce Fields
Introduced by acfdf5c383b38f7f4dddae41b97c97f1ae058f49. Cc: stable@kernel.org Reported-by: Gerhard Heift <ml-nfs-linux-20110412-ef47@gheift.de> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-04-11Merge branch 'for-2.6.39' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.39' of git://linux-nfs.org/~bfields/linux: nfsd4: fix oops on lock failure nfsd: fix auth_domain reference leak on nlm operations
2011-04-11nfsd4: make fh_verify responsibility of nfsd_lookup_dentry callerJ. Bruce Fields
The secinfo caller actually won't want this. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-04-11nfsd4: introduce OPDESC helperJ. Bruce Fields
2011-04-11nfsd4: allow fh_verify caller to skip pseudoflavor checksJ. Bruce Fields
2011-04-11nfsd: distinguish functions of NFSD_MAY_* flagsJ. Bruce Fields
Most of the NFSD_MAY_* flags actually request permissions, but over the years we've accreted a few that modify the behavior of the permission or open code in other ways. Distinguish the two cases a little more. In particular, allow the shortcut at the start of nfsd_permission to ignore the non-permission-requesting bits. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-04-10nfsd4: fix oops on lock failureJ. Bruce Fields
Lock stateid's can have access_bmap 0 if they were only partially initialized (due to a failed lock request); handle that case in free_generic_stateid. ------------[ cut here ]------------ kernel BUG at fs/nfsd/nfs4state.c:380! invalid opcode: 0000 [#1] SMP last sysfs file: /sys/kernel/mm/ksm/run Modules linked in: nfs fscache md4 nls_utf8 cifs ip6table_filter ip6_tables ebtable_nat ebtables ipt_MASQUERADE iptable_nat nf_nat bridge stp llc nfsd lockd nfs_acl auth_rpcgss sunrpc ipv6 ppdev parport_pc parport pcnet32 mii pcspkr microcode i2c_piix4 BusLogic floppy [last unloaded: mperf] Pid: 1468, comm: nfsd Not tainted 2.6.38+ #120 VMware, Inc. VMware Virtual Platform/440BX Desktop Reference Platform EIP: 0060:[<e24f180d>] EFLAGS: 00010297 CPU: 0 EIP is at nfs4_access_to_omode+0x1c/0x29 [nfsd] EAX: ffffffff EBX: dd758120 ECX: 00000000 EDX: 00000004 ESI: dd758120 EDI: ddfe657c EBP: dd54dde0 ESP: dd54dde0 DS: 007b ES: 007b FS: 00d8 GS: 00e0 SS: 0068 Process nfsd (pid: 1468, ti=dd54c000 task=ddc92580 task.ti=dd54c000) Stack: dd54ddf0 e24f19ca 00000000 ddfe6560 dd54de08 e24f1a5d dd758130 deee3a20 ddfe6560 31270000 dd54df1c e24f52fd 0000000f dd758090 e2505dd0 0be304cf dbb51d68 0000000e ddfe657c ddcd8020 dd758130 dd758128 dd7580d8 dd54de68 Call Trace: [<e24f19ca>] free_generic_stateid+0x1c/0x3e [nfsd] [<e24f1a5d>] release_lockowner+0x71/0x8a [nfsd] [<e24f52fd>] nfsd4_lock+0x617/0x66c [nfsd] [<e24e57b6>] ? nfsd_setuser+0x199/0x1bb [nfsd] [<e24e056c>] ? nfsd_setuser_and_check_port+0x65/0x81 [nfsd] [<c07a0052>] ? _cond_resched+0x8/0x1c [<c04ca61f>] ? slab_pre_alloc_hook.clone.33+0x23/0x27 [<c04cac01>] ? kmem_cache_alloc+0x1a/0xd2 [<c04835a0>] ? __call_rcu+0xd7/0xdd [<e24e0dfb>] ? fh_verify+0x401/0x452 [nfsd] [<e24f0b61>] ? nfsd4_encode_operation+0x52/0x117 [nfsd] [<e24ea0d7>] ? nfsd4_putfh+0x33/0x3b [nfsd] [<e24f4ce6>] ? nfsd4_delegreturn+0xd4/0xd4 [nfsd] [<e24ea2c9>] nfsd4_proc_compound+0x1ea/0x33e [nfsd] [<e24de6ee>] nfsd_dispatch+0xd1/0x1a5 [nfsd] [<e1d6e1c7>] svc_process_common+0x282/0x46f [sunrpc] [<e1d6e578>] svc_process+0xdc/0xfa [sunrpc] [<e24de0fa>] nfsd+0xd6/0x115 [nfsd] [<e24de024>] ? nfsd_shutdown+0x24/0x24 [nfsd] [<c0454322>] kthread+0x62/0x67 [<c04542c0>] ? kthread_worker_fn+0x114/0x114 [<c07a6ebe>] kernel_thread_helper+0x6/0x10 Code: eb 05 b8 00 00 27 4f 8d 65 f4 5b 5e 5f 5d c3 83 e0 03 55 83 f8 02 89 e5 74 17 83 f8 03 74 05 48 75 09 eb 09 b8 02 00 00 00 eb 0b <0f> 0b 31 c0 eb 05 b8 01 00 00 00 5d c3 55 89 e5 57 56 89 d6 8d EIP: [<e24f180d>] nfs4_access_to_omode+0x1c/0x29 [nfsd] SS:ESP 0068:dd54dde0 ---[ end trace 2b0bf6c6557cb284 ]--- The trace route is: -> nfsd4_lock() -> if (lock->lk_is_new) { -> alloc_init_lock_stateid() 3739: stp->st_access_bmap = 0; ->if (status && lock->lk_is_new && lock_sop) -> release_lockowner() -> free_generic_stateid() -> nfs4_access_bmap_to_omode() -> nfs4_access_to_omode() 380: BUG(); ***** This problem was introduced by 0997b173609b9229ece28941c118a2a9b278796e. Reported-by: Mi Jinlong <mijinlong@cn.fujitsu.com> Tested-by: Mi Jinlong <mijinlong@cn.fujitsu.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-04-07Merge branch 'for-2.6.39' into for-2.6.40J. Bruce Fields
2011-03-24nfsd: fix auth_domain reference leak on nlm operationsJ. Bruce Fields
This was noticed by users who performed more than 2^32 lock operations and hence made this counter overflow (eventually leading to use-after-free's). Setting rq_client to NULL here means that it won't later get auth_domain_put() when it should be. Appears to have been introduced in 2.5.42 by "[PATCH] kNFSd: Move auth domain lookup into svcauth" which moved most of the rq_client handling to common svcauth code, but left behind this one line. Cc: Neil Brown <neilb@suse.de> Cc: stable@kernel.org Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-03-24Merge branch 'for-2.6.39' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
* 'for-2.6.39' of git://linux-nfs.org/~bfields/linux: SUNRPC: Remove resource leak in svc_rdma_send_error() nfsd: wrong index used in inner loop nfsd4: fix comment and remove unused nfsd4_file fields nfs41: make sure nfs server return right ca_maxresponsesize_cached nfsd: fix compile error svcrpc: fix bad argument in unix_domain_find nfsd4: fix struct file leak nfsd4: minor nfs4state.c reshuffling svcrpc: fix rare race on unix_domain creation nfsd41: modify the members value of nfsd4_op_flags nfsd: add proc file listing kernel's gss_krb5 enctypes gss:krb5 only include enctype numbers in gm_upcall_enctypes NFSD, VFS: Remove dead code in nfsd_rename() nfsd: kill unused macro definition locks: use assign_type()
2011-03-18don't pass 'mounting_here' flag to follow_down()Al Viro
it's always false now Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-17nfsd: wrong index used in inner loopMi Jinlong
We must not use dummy for index. After the first index, READ32(dummy) will change dummy!!!! Signed-off-by: Mi Jinlong <mijinlong@cn.fujitsu.com> [bfields@redhat.com: Trond points out READ_BUF alone is sufficient.] Cc: stable@kernel.org Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-03-17Merge create_session decoding fix into for-2.6.39J. Bruce Fields
This needs a further fixup!
2011-03-17nfsd4: fix comment and remove unused nfsd4_file fieldsJ. Bruce Fields
A couple fields here were left over from a previous version of a patch, and are no longer used. Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-03-16nfs41: make sure nfs server return right ca_maxresponsesize_cachedMi Jinlong
According to rfc5661, ca_maxresponsesize_cached: Like ca_maxresponsesize, but the maximum size of a reply that will be stored in the reply cache (Section 2.10.6.1). For each channel, the server MAY decrease this value, but MUST NOT increase it. the latest kernel(2.6.38-rc8) may increase the value for ignoring request's ca_maxresponsesize_cached value. We should not ignore it. Signed-off-by: Mi Jinlong <mijinlong@cn.fujitsu.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2011-03-14nfsd: fix compile errorJ. Bruce Fields
"fs/built-in.o: In function `supported_enctypes_show': nfsctl.c:(.text+0x7beb0): undefined reference to `gss_mech_get_by_name' nfsctl.c:(.text+0x7bebc): undefined reference to `gss_mech_put' " Reported-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
