path: root/fs/nilfs2/page.c
2011-05-10nilfs2: use mark_buffer_dirty to mark btnode or meta data dirtyRyusuke Konishi
This replaces nilfs_mdt_mark_buffer_dirty and nilfs_btnode_mark_dirty macros with mark_buffer_dirty and gets rid of nilfs_mark_buffer_dirty, an own mark buffer dirty function. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2011-05-10nilfs2: always set back pointer to host inode in mapping->hostRyusuke Konishi
In the current nilfs, page cache for btree nodes and meta data files do not set a valid back pointer to the host inode in mapping->host. This will change it so that every address space in nilfs uses mapping->host to hold its host inode. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2011-05-10nilfs2: get rid of private page allocatorRyusuke Konishi
Previously, nilfs was cloning pages for mmapped region to freeze their data and ensure consistency of checksum during writeback cycles. A private page allocator was used for this page cloning. But, we no longer need to do that since clear_page_dirty_for_io function sets up pte so that vm_ops->page_mkwrite function is called right before the mmapped pages are modified and nilfs_page_mkwrite function can safely wait for the pages to be written back to disk. So, this stops making a copy of mmapped pages during writeback, and eliminates the private page allocation and deallocation functions from nilfs. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2011-04-05fs: export empty_aopsJens Axboe
With the ->sync_page() hook gone, we have a few users that add their own static address_space_operations without any functions defined. fs/inode.c already has an empty_aops that it uses for init purposes. Lets export that and use it in the places where an otherwise empty aops was defined. Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-30nilfs2: fix oops due to a bad aops initializationRyusuke Konishi
Nilfs in 2.6.39-rc1 hit the following oops: BUG: unable to handle kernel NULL pointer dereference at 0000000000000048 IP: [<ffffffff810ac235>] try_to_release_page+0x2a/0x3d PGD 234cb6067 PUD 234c72067 PMD 0 Oops: 0000 [#1] SMP <snip> Process truncate (pid: 10995, threadinfo ffff8802353c2000, task ffff880234cfa000) Stack: ffff8802333c77b8 ffffffff810b64b0 0000000000003802 ffffffffa0052cca 0000000000000000 ffff8802353c3b58 0000000000000000 ffff8802353c3b58 0000000000000001 0000000000000000 ffffea0007b92308 ffffea0007b92308 Call Trace: [<ffffffff810b64b0>] ? invalidate_inode_pages2_range+0x15f/0x273 [<ffffffffa0052cca>] ? nilfs_palloc_get_block+0x2d/0xaf [nilfs2] [<ffffffff810589e7>] ? bit_waitqueue+0x14/0xa1 [<ffffffff81058ab1>] ? wake_up_bit+0x10/0x20 [<ffffffffa00433fd>] ? nilfs_forget_buffer+0x66/0x7a [nilfs2] [<ffffffffa00467b8>] ? nilfs_btree_concat_left+0x5c/0x77 [nilfs2] [<ffffffffa00471fc>] ? nilfs_btree_delete+0x395/0x3cf [nilfs2] [<ffffffffa00449a3>] ? nilfs_bmap_do_delete+0x6e/0x79 [nilfs2] [<ffffffffa0045845>] ? nilfs_btree_last_key+0x14b/0x15e [nilfs2] [<ffffffffa00449dd>] ? nilfs_bmap_truncate+0x2f/0x83 [nilfs2] [<ffffffffa0044ab2>] ? nilfs_bmap_last_key+0x35/0x62 [nilfs2] [<ffffffffa003e99b>] ? nilfs_truncate_bmap+0x6b/0xc7 [nilfs2] [<ffffffffa003ee4a>] ? nilfs_truncate+0x79/0xe4 [nilfs2] [<ffffffff810b6c00>] ? vmtruncate+0x33/0x3b [<ffffffffa003e8f1>] ? nilfs_setattr+0x4d/0x8c [nilfs2] [<ffffffff81026106>] ? do_page_fault+0x31b/0x356 [<ffffffff810f9d61>] ? notify_change+0x17d/0x262 [<ffffffff810e5046>] ? do_truncate+0x65/0x80 [<ffffffff810e52af>] ? sys_ftruncate+0xf1/0xf6 [<ffffffff8132c012>] ? system_call_fastpath+0x16/0x1b Code: c3 48 83 ec 08 48 8b 17 48 8b 47 18 80 e2 01 75 04 0f 0b eb fe 48 8b 17 80 e6 20 74 05 31 c0 41 59 c3 48 85 c0 74 11 48 8b 40 58 8b 40 48 48 85 c0 74 04 41 58 ff e0 59 e9 b1 b5 05 00 41 54 RIP [<ffffffff810ac235>] try_to_release_page+0x2a/0x3d RSP <ffff8802353c3b08> CR2: 0000000000000048 This oops was brought in by the change "block: remove per-queue plugging" (commit: 7eaceaccab5f40bb). It initializes mapping->a_ops with a NULL pointer for some pages in nilfs (e.g. btree node pages), but mm code doesn't NULL pointer checks against mapping->a_ops. (the check is done for each callback function) This corrects the aops initialization and fixes the oops. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Acked-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-10Merge branch 'for-2.6.39/stack-plug' into for-2.6.39/coreJens Axboe
Conflicts: block/blk-core.c block/blk-flush.c drivers/md/raid1.c drivers/md/raid10.c drivers/md/raid5.c fs/nilfs2/btnode.c fs/nilfs2/mdt.c Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-10block: remove per-queue pluggingJens Axboe
Code has been converted over to the new explicit on-stack plugging, and delay users have been converted to use the new API for that. So lets kill off the old plugging along with aops->sync_page(). Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-02-23mm: prevent concurrent unmap_mapping_range() on the same inodeMiklos Szeredi
Michael Leun reported that running parallel opens on a fuse filesystem can trigger a "kernel BUG at mm/truncate.c:475" Gurudas Pai reported the same bug on NFS. The reason is, unmap_mapping_range() is not prepared for more than one concurrent invocation per inode. For example: thread1: going through a big range, stops in the middle of a vma and stores the restart address in vm_truncate_count. thread2: comes in with a small (e.g. single page) unmap request on the same vma, somewhere before restart_address, finds that the vma was already unmapped up to the restart address and happily returns without doing anything. Another scenario would be two big unmap requests, both having to restart the unmapping and each one setting vm_truncate_count to its own value. This could go on forever without any of them being able to finish. Truncate and hole punching already serialize with i_mutex. Other callers of unmap_mapping_range() do not, and it's difficult to get i_mutex protection for all callers. In particular ->d_revalidate(), which calls invalidate_inode_pages2_range() in fuse, may be called with or without i_mutex. This patch adds a new mutex to 'struct address_space' to prevent running multiple concurrent unmap_mapping_range() on the same mapping. [ We'll hopefully get rid of all this with the upcoming mm preemptibility series by Peter Zijlstra, the "mm: Remove i_mmap_mutex lockbreak" patch in particular. But that is for 2.6.39 ] Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Reported-by: Michael Leun <lkml20101129@newton.leun.net> Reported-by: Gurudas Pai <gurudas.pai@oracle.com> Tested-by: Gurudas Pai <gurudas.pai@oracle.com> Acked-by: Hugh Dickins <hughd@google.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-10nilfs2: fix a checkpatch error in page.cRyusuke Konishi
Will correct the following checkpatch error: ERROR: trailing whitespace #494: FILE: page.c:494: + $ Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2011-01-10nilfs2: fiemap supportRyusuke Konishi
This adds fiemap to nilfs. Two new functions, nilfs_fiemap and nilfs_find_uncommitted_extent are added. nilfs_fiemap() implements the fiemap inode operation, and nilfs_find_uncommitted_extent() helps to get a range of data blocks whose physical location has not been determined. nilfs_fiemap() collects extent information by looping through nilfs_bmap_lookup_contig and nilfs_find_uncommitted_extent routines. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2010-10-23nilfs2: get rid of GCDAT inodeRyusuke Konishi
This applies prepared rollback function and redirect function of metadata file to DAT file, and eliminates GCDAT inode. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2010-10-23nilfs2: add routines to redirect access to buffers of DAT fileRyusuke Konishi
During garbage collection (GC), DAT file, which converts virtual block number to real block number, may return disk block number that is not yet written to the device. To avoid access to unwritten blocks, the current implementation stores changes to the caches of GCDAT during GC and atomically commit the changes into the DAT file after they are written to the device. This patch, instead, adds a function that makes a copy of specified buffer and stores it in nilfs_shadow_map, and a function to get the backup copy as needed (nilfs_mdt_freeze_buffer and nilfs_mdt_get_frozen_buffer respectively). Before DAT changes block number in an entry block, it makes a copy and redirect access to the buffer so that address conversion function (i.e. nilfs_dat_translate) refers to the old address saved in the copy. This patch gives requisites for such redirection. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2010-10-23nilfs2: add routines to roll back state of DAT fileRyusuke Konishi
This adds optional function to metadata files which makes a copy of bmap, page caches, and b-tree node cache, and rolls back to the copy as needed. This enhancement is intended to displace gcdat inode that provides a similar function in a different way. In this patch, nilfs_shadow_map structure is added to store a copy of the foregoing states. nilfs_mdt_setup_shadow_map relates this structure to a metadata file. And, nilfs_mdt_save_to_shadow_map() and nilfs_mdt_restore_from_shadow_map() provides save and restore functions respectively. Finally, nilfs_mdt_clear_shadow_map() clears states of nilfs_shadow_map. The copy of b-tree node cache and page cache is made by duplicating only dirty pages into corresponding caches in nilfs_shadow_map. Their restoration is done by clearing dirty pages from original caches and by copying dirty pages back from nilfs_shadow_map. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2010-07-23nilfs2: introduce check flag to btree node bufferRyusuke Konishi
nilfs_btree_get_block() now may return untested buffer due to read-ahead. This adds a new flag for buffer heads so that the btree code can check whether the buffer is already verified or not. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-14nilfs2: fix various typos in commentsRyusuke Konishi
This fixes various typos I found in comments of nilfs2. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-05-10nilfs2: ensure to clear dirty state when deleting metadata file blockRyusuke Konishi
This would fix the following failure during GC: nilfs_cpfile_delete_checkpoints: cannot delete block NILFS: GC failed during preparation: cannot delete checkpoints: err=-2 The problem was caused by a break in state consistency between page cache and btree; the above block was removed from the btree but the page buffering the block was remaining in the page cache in dirty state. This resolves the inconsistency by ensuring to clear dirty state of the page buffering the deleted block. Reported-by: David Arendt <admin@prnet.org> Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-04-07nilfs2: replace BUG_ON and BUG calls triggerable from ioctlRyusuke Konishi
Pekka Enberg advised me: > It would be nice if BUG(), BUG_ON(), and panic() calls would be > converted to proper error handling using WARN_ON() calls. The BUG() > call in nilfs_cpfile_delete_checkpoints(), for example, looks to be > triggerable from user-space via the ioctl() system call. This will follow the comment and keep them to a minimum. Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07nilfs2: buffer and page operationsRyusuke Konishi
This adds common routines for buffer/page operations used in B-tree node caches, meta data files, or segment constructor (log writer). NILFS uses copy functions for buffers and pages due to the following reasons: 1) Relocation required for COW Since NILFS changes address of on-disk blocks, moving buffers in page cache is needed for the buffers which are not addressed by a file offset. If buffer size is smaller than page size, this involves partial copy of pages. 2) Freezing mmapped pages NILFS calculates checksums for each log to ensure its validity. If page data changes after the checksum calculation, this validity check will not work correctly. To avoid this failure for mmaped pages, NILFS freezes their data by copying. 3) Copy-on-write for DAT pages NILFS makes clones of DAT page caches in a copy-on-write manner during GC processes, and this ensures atomicity and consistency of the DAT in the transient state. In addition, NILFS uses two obsolete functions, nilfs_mark_buffer_dirty() and nilfs_clear_page_dirty() respectively. * nilfs_mark_buffer_dirty() was required to avoid NULL pointer dereference faults: Since the page cache of B-tree node pages or data page cache of pseudo inodes does not have a valid mapping->host, calling mark_buffer_dirty() for their buffers causes the fault; it calls __mark_inode_dirty(NULL) through __set_page_dirty(). * nilfs_clear_page_dirty() was needed in the two cases: 1) For B-tree node pages and data pages of the dat/gcdat, NILFS2 clears page dirty flags when it copies back pages from the cloned cache (gcdat->{i_mapping,i_btnode_cache}) to its original cache (dat->{i_mapping,i_btnode_cache}). 2) Some B-tree operations like insertion or deletion may dispose buffers in dirty state, and this needs to cancel the dirty state of their pages. clear_page_dirty_for_io() caused faults because it does not clear the dirty tag on the page cache. Signed-off-by: Seiji Kihara <kihara.seiji@lab.ntt.co.jp> Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
