path: root/fs/nilfs2/segment.h
2011-05-10nilfs2: get rid of private page allocatorRyusuke Konishi
Previously, nilfs was cloning pages for mmapped region to freeze their data and ensure consistency of checksum during writeback cycles. A private page allocator was used for this page cloning. But, we no longer need to do that since clear_page_dirty_for_io function sets up pte so that vm_ops->page_mkwrite function is called right before the mmapped pages are modified and nilfs_page_mkwrite function can safely wait for the pages to be written back to disk. So, this stops making a copy of mmapped pages during writeback, and eliminates the private page allocation and deallocation functions from nilfs. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2011-03-09nilfs2: get rid of nilfs_sb_info structureRyusuke Konishi
This directly uses sb->s_fs_info to keep a nilfs filesystem object and fully removes the intermediate nilfs_sb_info structure. With this change, the hierarchy of on-memory structures of nilfs will be simplified as follows: Before: super_block -> nilfs_sb_info -> the_nilfs -> cptree --+-> nilfs_root (current file system) +-> nilfs_root (snapshot A) +-> nilfs_root (snapshot B) : -> nilfs_sc_info (log writer structure) After: super_block -> the_nilfs -> cptree --+-> nilfs_root (current file system) +-> nilfs_root (snapshot A) +-> nilfs_root (snapshot B) : -> nilfs_sc_info (log writer structure) The reason why we didn't design so from the beginning is because the initial shape also differed from the above. The early hierachy was composed of "per-mount-point" super_block -> nilfs_sb_info pairs and a shared nilfs object. On the kernel 2.6.37, it was changed to the current shape in order to unify super block instances into one per device, and this cleanup became applicable as the result. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2011-03-09nilfs2: use sb instance instead of nilfs_sb_info structRyusuke Konishi
This replaces sbi uses with direct reference to sb instance. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2011-03-09nilfs2: get rid of sc_sbi back pointerRyusuke Konishi
Removes sci->sc_sbi which is a back pointer to nilfs_sb_info struct from log writer object (nilfs_sc_info). Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2010-10-23nilfs2: use root object to get ifileRyusuke Konishi
This rewrites functions using ifile so that they get ifile from nilfs_root object, and will remove sbi->s_ifile. Some functions that don't know the root object are extended to receive it from caller. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2010-10-23nilfs2: keep zero value in i_cno except for gc-inodesRyusuke Konishi
On-memory inode structures of nilfs have a member "i_cno" which stores a checkpoint number related to the inode. For gc-inodes, this field indicates version of data each gc-inode caches for GC. Log writer temporarily uses "i_cno" to transfer the latest checkpoint number. This stops the latter use and lets only gc-inodes use it. The purpose of this patch is to allow the successive change use "i_cno" for inode lookup. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2010-07-23nilfs2: rename nilfs_recover_logical_segments functionRyusuke Konishi
The function name of nilfs_recover_logical_segments makes no sense. This changes the name into nilfs_salvage_orphan_logs to clarify the role of the function. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2010-07-23nilfs2: refactor recovery logic routinesRyusuke Konishi
Most functions in recovery code take an argument of a super block instance or a nilfs_sb_info struct for convenience sake. This replaces them aggressively with a nilfs object by applying __bread and __breadahead against routines using sb_bread and sb_breadahead. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2010-05-31nilfs2: remove obsolete declarations of cache constructor and destructorRyusuke Konishi
The commit 41c88bd7 ("nilfs2: cleanup multi kmem_cache_{create,destroy} code") consolidated slab constructors and destructors used in nilfs, but it left some declarations in header files. This gets rid of the obsolete declarations. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2010-05-10nilfs2: change sc_timer from a pointer to an embedded one in struct ↵Li Hong
nilfs_sc_info In nilfs_segctor_thread(), timer is a local variable allocated on stack. Its address can't be set to sci->sc_timer and passed in several procedures. It works now by chance, just because other procedures are called by nilfs_segctor_thread() directly or indirectly and the stack hasn't been deallocated yet. Signed-off-by: Li Hong <lihong.hi@gmail.com> Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2010-05-10nilfs2: cleanup multi kmem_cache_{create,destroy} codeLi Hong
This cleanup patch gives several improvements: - Moving all kmem_cache_{create_destroy} calls into one place, which removes some small function calls, cleans up error check code and clarify the logic. - Mark all initial code in __init section. - Remove some very obvious comments. - Adjust some declarations. - Fix some space-tab issues. Signed-off-by: Li Hong <lihong.hi@gmail.com> Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2010-05-10nilfs2: move pointer to super root block into logsRyusuke Konishi
This moves a pointer to buffer storing super root block to each log buffer from nilfs_sc_info struct for simplicity. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2010-03-14nilfs2: remove spaces before tabsRyusuke Konishi
This kills the following checkpatch warnings: WARNING: please, no space before tabs #74: FILE: segment.h:74: +^Iunsigned ^I^Iflags;$ WARNING: please, no space before tabs #35: FILE: segbuf.c:35: +^Iint ^I^I^Istart, end; /* The region to be submitted */$ Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2010-03-14nilfs2: fix various typos in commentsRyusuke Konishi
This fixes various typos I found in comments of nilfs2. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2010-02-13nilfs2: get rid of nilfs_segctor_req structRyusuke Konishi
This will clean up nilfs_segctor_req struct and the obscure request argument passed among private methods of segment constructor. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-11-30nilfs2: separate wait function from nilfs_segctor_writeRyusuke Konishi
This separates wait function for submitted logs from the write function nilfs_segctor_write(). A new list of segment buffers "sc_write_logs" is added to hold logs under writing, and double buffering is partially applied to hide io latency. At this point, the double buffering is disabled for blocksize < pagesize because page dirty flag is turned off during write and dirty buffers are not properly collected for pages crossing over segments. To receive full benefit of the double buffering, further refinement is needed to move the io wait outside the lock section of log writer. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-06-10nilfs2: remove header file for segment list operationsRyusuke Konishi
This will eliminate obsolete list operations of nilfs_segment_entry structure which has been used to handle mutiple segment numbers. The patch ("nilfs2: remove list of freeing segments") removed use of the structure from the segment constructor code, and this patch simplifies the remaining code by integrating it into recovery.c. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-06-10nilfs2: eliminate removal list of segmentsRyusuke Konishi
This will clean up the removal list of segments and the related functions from segment.c and ioctl.c, which have hurt code readability. This elimination is applied by using nilfs_sufile_updatev() previously introduced in the patch ("nilfs2: add sufile function that can modify multiple segment usages"). Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-05-11nilfs2: fix lock order reversal in nilfs_clean_segments ioctlRyusuke Konishi
This is a companion patch to ("nilfs2: fix possible circular locking for get information ioctls"). This corrects lock order reversal between mm->mmap_sem and nilfs->ns_segctor_sem in nilfs_clean_segments() which was detected by lockdep check: ======================================================= [ INFO: possible circular locking dependency detected ] 2.6.30-rc3-nilfs-00003-g360bdc1 #7 ------------------------------------------------------- mmap/5294 is trying to acquire lock: (&nilfs->ns_segctor_sem){++++.+}, at: [<d0d0e846>] nilfs_transaction_begin+0xb6/0x10c [nilfs2] but task is already holding lock: (&mm->mmap_sem){++++++}, at: [<c043700a>] do_page_fault+0x1d8/0x30a which lock already depends on the new lock. the existing dependency chain (in reverse order) is: -> #1 (&mm->mmap_sem){++++++}: [<c01470a5>] __lock_acquire+0x1066/0x13b0 [<c01474a9>] lock_acquire+0xba/0xdd [<c01836bc>] might_fault+0x68/0x88 [<c023c61d>] copy_from_user+0x2a/0x111 [<d0d120d0>] nilfs_ioctl_prepare_clean_segments+0x1d/0xf1 [nilfs2] [<d0d0e2aa>] nilfs_clean_segments+0x6d/0x1b9 [nilfs2] [<d0d11f68>] nilfs_ioctl+0x2ad/0x318 [nilfs2] [<c01a3be7>] vfs_ioctl+0x22/0x69 [<c01a408e>] do_vfs_ioctl+0x460/0x499 [<c01a4107>] sys_ioctl+0x40/0x5a [<c01031a4>] sysenter_do_call+0x12/0x38 [<ffffffff>] 0xffffffff -> #0 (&nilfs->ns_segctor_sem){++++.+}: [<c0146e0b>] __lock_acquire+0xdcc/0x13b0 [<c01474a9>] lock_acquire+0xba/0xdd [<c0433f1d>] down_read+0x2a/0x3e [<d0d0e846>] nilfs_transaction_begin+0xb6/0x10c [nilfs2] [<d0cfe0e5>] nilfs_page_mkwrite+0xe7/0x154 [nilfs2] [<c0183b0b>] __do_fault+0x165/0x376 [<c01855cd>] handle_mm_fault+0x287/0x5d1 [<c043712d>] do_page_fault+0x2fb/0x30a [<c0435462>] error_code+0x72/0x78 [<ffffffff>] 0xffffffff where nilfs_clean_segments() holds: nilfs->ns_segctor_sem -> copy_from_user() --> page fault -> mm->mmap_sem And, page fault path may hold: page fault -> mm->mmap_sem --> nilfs_page_mkwrite() -> nilfs->ns_segctor_sem Even though nilfs_clean_segments() does not perform write access on given user pages, it may cause deadlock because nilfs->ns_segctor_sem is shared per device and mm->mmap_sem can be shared with other tasks. To avoid this problem, this patch moves all calls of copy_from_user() outside the nilfs->ns_segctor_sem lock in the ioctl. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
2009-04-07nilfs2: introduce secondary super blockRyusuke Konishi
The former versions didn't have extra super blocks. This improves the weak point by introducing another super block at unused region in tail of the partition. This doesn't break disk format compatibility; older versions just ingore the secondary super block, and new versions just recover it if it doesn't exist. The partition created by an old mkfs may not have unused region, but in that case, the secondary super block will not be added. This doesn't make more redundant copies of the super block; it is a future work. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07nilfs2: simplify handling of active state of segmentsRyusuke Konishi
will reduce some lines of segment constructor. Previously, the state was complexly controlled through a list of segments in order to keep consistency in meta data of usage state of segments. Instead, this presents ``calculated'' active flags to userland cleaner program and stop maintaining its real flag on disk. Only by this fake flag, the cleaner cannot exactly know if each segment is reclaimable or not. However, the recent extension of nilfs_sustat ioctl struct (nilfs2-extend-nilfs_sustat-ioctl-struct.patch) can prevent the cleaner from reclaiming in-use segment wrongly. So, now I can apply this for simplification. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07nilfs2: mark minor flag for checkpoint created by internal operationRyusuke Konishi
Nilfs creates checkpoints even for garbage collection or metadata updates such as checkpoint mode change. So, user often sees checkpoints created only by such internal operations. This is inconvenient in some situations. For example, application that monitors checkpoints and changes them to snapshots, will fall into an infinite loop because it cannot distinguish internally created checkpoints. This patch solves this sort of problem by adding a flag to checkpoint for identification. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07nilfs2: clean up sketch fileRyusuke Konishi
The sketch file is a file to mark checkpoints with user data. It was experimentally introduced in the original implementation, and now obsolete. The file was handled differently with regular files; the file size got truncated when a checkpoint was created. This stops the special treatment and will treat it as a regular file. Most users are not affected because mkfs.nilfs2 no longer makes this file. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07nilfs2: fix missed-sync issue for do_sync_mapping_range()Ryusuke Konishi
Chris Mason pointed out that there is a missed sync issue in nilfs_writepages(): On Wed, 17 Dec 2008 21:52:55 -0500, Chris Mason wrote: > It looks like nilfs_writepage ignores WB_SYNC_NONE, which is used by > do_sync_mapping_range(). where WB_SYNC_NONE in do_sync_mapping_range() was replaced with WB_SYNC_ALL by Nick's patch (commit: ee53a891f47444c53318b98dac947ede963db400). This fixes the problem by letting nilfs_writepages() write out the log of file data within the range if sync_mode is WB_SYNC_ALL. This involves removal of nilfs_file_aio_write() which was previously needed to ensure O_SYNC sync writes. Cc: Chris Mason <chris.mason@oracle.com> Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07nilfs2: segment constructorRyusuke Konishi
This adds the segment constructor (also called log writer). The segment constructor collects dirty buffers for every dirty inode, makes summaries of the buffers, assigns disk block addresses to the buffers, and then submits BIOs for the buffers. Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
