commit 1e2e547a93a00ebc21582c06ca3c6cfea2a309ee upstream.
For anything NFS-exported we do _not_ want to unlock new inode
before it has grown an alias; original set of fixes got the
ordering right, but missed the nasty complication in case of
lockdep being enabled - unlock_new_inode() does
lockdep_annotate_inode_mutex_key(inode)
which can only be done before anyone gets a chance to touch
->i_mutex. Unfortunately, flipping the order and doing
unlock_new_inode() before d_instantiate() opens a window when
mkdir can race with open-by-fhandle on a guessed fhandle, leading
to multiple aliases for a directory inode and all the breakage
that follows from that.
Correct solution: a new primitive (d_instantiate_new())
combining these two in the right order - lockdep annotate, then
d_instantiate(), then the rest of unlock_new_inode(). All
combinations of d_instantiate() with unlock_new_inode() should
be converted to that.
Cc: stable@kernel.org # 2.6.29 and later
Tested-by: Mike Marshall <hubcap@omnibond.com>
Reviewed-by: Andreas Dilger <adilger@dilger.ca>
commit 31ccb1f7ba3cfe29631587d451cf5bb8ab593550 upstream.
There is a race condition between nilfs_dirty_inode() and
nilfs_set_file_dirty().
When a file is opened, nilfs_dirty_inode() is called to update the
access timestamp in the inode. It calls __nilfs_mark_inode_dirty() in a
separate transaction. __nilfs_mark_inode_dirty() caches the ifile
buffer_head in the i_bh field of the inode info structure and marks it
as dirty.
After some data was written to the file in another transaction, the
function nilfs_set_file_dirty() is called, which adds the inode to the
ns_dirty_files list.
Then the segment construction calls nilfs_segctor_collect_dirty_files(),
which goes through the ns_dirty_files list and checks the i_bh field.
If there is a cached buffer_head in i_bh it is not marked as dirty
again.
Since nilfs_dirty_inode() and nilfs_set_file_dirty() use separate
transactions, it is possible that a segment construction that writes out
the ifile occurs in-between the two. If this happens the inode is not
on the ns_dirty_files list, but its ifile block is still marked as dirty
and written out.
In the next segment construction, the data for the file is written out
and nilfs_bmap_propagate() updates the b-tree. Eventually the bmap root
is written into the i_bh block, which is not dirty, because it was
written out in another segment construction.
As a result the bmap update can be lost, which leads to file system
corruption. Either the virtual block address points to an unallocated
DAT block, or the DAT entry will be reused for something different.
The error can remain undetected for a long time. A typical error
message would be one of the "bad btree" errors or a warning that a DAT
entry could not be found.
This bug can be reproduced reliably by a simple benchmark that creates
and overwrites millions of 4k files.
Link: http://lkml.kernel.org/r/1509367935-3086-2-git-send-email-konishi.ryusuke@lab.ntt.co.jp
Signed-off-by: Andreas Rohner <andreas.rohner@gmx.net>
Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
Tested-by: Andreas Rohner <andreas.rohner@gmx.net>
Tested-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
Pull mount flag updates from Al Viro:
"Another chunk of fmount preparations from dhowells; only trivial
conflicts for that part. It separates MS_... bits (very grotty
mount(2) ABI) from the struct super_block ->s_flags (kernel-internal,
only a small subset of MS_... stuff).
This does *not* convert the filesystems to new constants; only the
infrastructure is done here. The next step in that series is where the
conflicts would be; that's the conversion of filesystems. It's purely
mechanical and it's better done after the merge, so if you could run
something like
list=$(for i in MS_RDONLY MS_NOSUID MS_NODEV MS_NOEXEC MS_SYNCHRONOUS MS_MANDLOCK MS_DIRSYNC MS_NOATIME MS_NODIRATIME MS_SILENT MS_POSIXACL MS_KERNMOUNT MS_I_VERSION MS_LAZYTIME; do git grep -l $i fs drivers/staging/lustre drivers/mtd ipc mm include/linux; done|sort|uniq|grep -v '^fs/namespace.c$')
sed -i -e 's/\<MS_RDONLY\>/SB_RDONLY/g' \
-e 's/\<MS_NOSUID\>/SB_NOSUID/g' \
-e 's/\<MS_NODEV\>/SB_NODEV/g' \
-e 's/\<MS_NOEXEC\>/SB_NOEXEC/g' \
-e 's/\<MS_SYNCHRONOUS\>/SB_SYNCHRONOUS/g' \
-e 's/\<MS_MANDLOCK\>/SB_MANDLOCK/g' \
-e 's/\<MS_DIRSYNC\>/SB_DIRSYNC/g' \
-e 's/\<MS_NOATIME\>/SB_NOATIME/g' \
-e 's/\<MS_NODIRATIME\>/SB_NODIRATIME/g' \
-e 's/\<MS_SILENT\>/SB_SILENT/g' \
-e 's/\<MS_POSIXACL\>/SB_POSIXACL/g' \
-e 's/\<MS_KERNMOUNT\>/SB_KERNMOUNT/g' \
-e 's/\<MS_I_VERSION\>/SB_I_VERSION/g' \
-e 's/\<MS_LAZYTIME\>/SB_LAZYTIME/g' \
$list
and commit it with something along the lines of 'convert filesystems
away from use of MS_... constants' as commit message, it would save a
quite a bit of headache next cycle"
* 'work.mount' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
VFS: Differentiate mount flags (MS_*) from internal superblock flags
VFS: Convert sb->s_flags & MS_RDONLY to sb_rdonly(sb)
vfs: Add sb_rdonly(sb) to query the MS_RDONLY flag on s_flags
Pull block layer updates from Jens Axboe:
"This is the first pull request for 4.14, containing most of the code
changes. It's a quiet series this round, which I think we needed after
the churn of the last few series. This contains:
- Fix for a registration race in loop, from Anton Volkov.
- Overflow complaint fix from Arnd for DAC960.
- Series of drbd changes from the usual suspects.
- Conversion of the stec/skd driver to blk-mq. From Bart.
- A few BFQ improvements/fixes from Paolo.
- CFQ improvement from Ritesh, allowing idling for group idle.
- A few fixes found by Dan's smatch, courtesy of Dan.
- A warning fixup for a race between changing the IO scheduler and
device remova. From David Jeffery.
- A few nbd fixes from Josef.
- Support for cgroup info in blktrace, from Shaohua.
- Also from Shaohua, new features in the null_blk driver to allow it
to actually hold data, among other things.
- Various corner cases and error handling fixes from Weiping Zhang.
- Improvements to the IO stats tracking for blk-mq from me. Can
drastically improve performance for fast devices and/or big
machines.
- Series from Christoph removing bi_bdev as being needed for IO
submission, in preparation for nvme multipathing code.
- Series from Bart, including various cleanups and fixes for switch
fall through case complaints"
* 'for-4.14/block' of git://git.kernel.dk/linux-block: (162 commits)
kernfs: checking for IS_ERR() instead of NULL
drbd: remove BIOSET_NEED_RESCUER flag from drbd_{md_,}io_bio_set
drbd: Fix allyesconfig build, fix recent commit
drbd: switch from kmalloc() to kmalloc_array()
drbd: abort drbd_start_resync if there is no connection
drbd: move global variables to drbd namespace and make some static
drbd: rename "usermode_helper" to "drbd_usermode_helper"
drbd: fix race between handshake and admin disconnect/down
drbd: fix potential deadlock when trying to detach during handshake
drbd: A single dot should be put into a sequence.
drbd: fix rmmod cleanup, remove _all_ debugfs entries
drbd: Use setup_timer() instead of init_timer() to simplify the code.
drbd: fix potential get_ldev/put_ldev refcount imbalance during attach
drbd: new disk-option disable-write-same
drbd: Fix resource role for newly created resources in events2
drbd: mark symbols static where possible
drbd: Send P_NEG_ACK upon write error in protocol != C
drbd: add explicit plugging when submitting batches
drbd: change list_for_each_safe to while(list_first_entry_or_null)
drbd: introduce drbd_recv_header_maybe_unplug
All users of pagevec_lookup() and pagevec_lookup_range() now pass
PAGEVEC_SIZE as a desired number of pages.
Just drop the argument.
Link: http://lkml.kernel.org/r/20170726114704.7626-11-jack@suse.cz
Make pagevec_lookup() (and underlying find_get_pages()) update index to
the next page where iteration should continue. Most callers want this
and also pagevec_lookup_tag() already does this.
Link: http://lkml.kernel.org/r/20170726114704.7626-3-jack@suse.cz
This way we don't need a block_device structure to submit I/O. The
block_device has different life time rules from the gendisk and
request_queue and is usually only available when the block device node
is open. Other callers need to explicitly create one (e.g. the lightnvm
passthrough code, or the new nvme multipathing code).
For the actual I/O path all that we need is the gendisk, which exists
once per block device. But given that the block layer also does
partition remapping we additionally need a partition index, which is
used for said remapping in generic_make_request.
Note that all the block drivers generally want request_queue or
sometimes the gendisk, so this removes a layer of indirection all
over the stack.
Firstly by applying the following with coccinelle's spatch:
@@ expression SB; @@
-SB->s_flags & MS_RDONLY
+sb_rdonly(SB)
to effect the conversion to sb_rdonly(sb), then by applying:
@@ expression A, SB; @@
-(!sb_rdonly(SB)) && A
+!sb_rdonly(SB) && A
-A != (sb_rdonly(SB))
+A != sb_rdonly(SB)
-A == (sb_rdonly(SB))
+A == sb_rdonly(SB)
-!(sb_rdonly(SB))
+!sb_rdonly(SB)
-A && (sb_rdonly(SB))
+A && sb_rdonly(SB)
-A || (sb_rdonly(SB))
+A || sb_rdonly(SB)
-(sb_rdonly(SB)) != A
+sb_rdonly(SB) != A
-(sb_rdonly(SB)) == A
+sb_rdonly(SB) == A
-(sb_rdonly(SB)) && A
+sb_rdonly(SB) && A
-(sb_rdonly(SB)) || A
+sb_rdonly(SB) || A
@@ expression A, B, SB; @@
-(sb_rdonly(SB)) ? 1 : 0
+sb_rdonly(SB)
-(sb_rdonly(SB)) ? A : B
+sb_rdonly(SB) ? A : B
to remove left over excess bracketage and finally by applying:
-(A & MS_RDONLY) != sb_rdonly(SB)
+(bool)(A & MS_RDONLY) != sb_rdonly(SB)
-(A & MS_RDONLY) == sb_rdonly(SB)
+(bool)(A & MS_RDONLY) == sb_rdonly(SB)
to make comparisons against the result of sb_rdonly() (which is a bool)
work correctly.
Pull scheduler updates from Ingo Molnar:
"The main changes in this cycle were:
- Add the SYSTEM_SCHEDULING bootup state to move various scheduler
debug checks earlier into the bootup. This turns silent and
sporadically deadly bugs into nice, deterministic splats. Fix some
of the splats that triggered. (Thomas Gleixner)
- A round of restructuring and refactoring of the load-balancing and
topology code (Peter Zijlstra)
- Another round of consolidating ~20 of incremental scheduler code
history: this time in terms of wait-queue nomenclature. (I didn't
get much feedback on these renaming patches, and we can still
easily change any names I might have misplaced, so if anyone hates
a new name, please holler and I'll fix it.) (Ingo Molnar)
- sched/numa improvements, fixes and updates (Rik van Riel)
- Another round of x86/tsc scheduler clock code improvements, in hope
of making it more robust (Peter Zijlstra)
- Improve NOHZ behavior (Frederic Weisbecker)
- Deadline scheduler improvements and fixes (Luca Abeni, Daniel
Bristot de Oliveira)
- Simplify and optimize the topology setup code (Lauro Ramos
Venancio)
- Debloat and decouple scheduler code some more (Nicolas Pitre)
- Simplify code by making better use of llist primitives (Byungchul
Park)
- ... plus other fixes and improvements"
* 'sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (103 commits)
sched/cputime: Refactor the cputime_adjust() code
sched/debug: Expose the number of RT/DL tasks that can migrate
sched/numa: Hide numa_wake_affine() from UP build
sched/fair: Remove effective_load()
sched/numa: Implement NUMA node level wake_affine()
sched/fair: Simplify wake_affine() for the single socket case
sched/numa: Override part of migrate_degrades_locality() when idle balancing
sched/rt: Move RT related code from sched/core.c to sched/rt.c
sched/deadline: Move DL related code from sched/core.c to sched/deadline.c
sched/cpuset: Only offer CONFIG_CPUSETS if SMP is enabled
sched/fair: Spare idle load balancing on nohz_full CPUs
nohz: Move idle balancer registration to the idle path
sched/loadavg: Generalize "_idle" naming to "_nohz"
sched/core: Drop the unused try_get_task_struct() helper function
sched/fair: WARN() and refuse to set buddy when !se->on_rq
sched/debug: Fix SCHED_WARN_ON() to return a value on !CONFIG_SCHED_DEBUG as well
sched/wait: Disambiguate wq_entry->task_list and wq_head->task_list naming
sched/wait: Move bit_wait_table[] and related functionality from sched/core.c to sched/wait_bit.c
sched/wait: Split out the wait_bit*() APIs from <linux/wait.h> into <linux/wait_bit.h>
sched/wait: Re-adjust macro line continuation backslashes in <linux/wait.h>
So I've noticed a number of instances where it was not obvious from the
code whether ->task_list was for a wait-queue head or a wait-queue entry.
Furthermore, there's a number of wait-queue users where the lists are
not for 'tasks' but other entities (poll tables, etc.), in which case
the 'task_list' name is actively confusing.
To clear this all up, name the wait-queue head and entry list structure
fields unambiguously:
struct wait_queue_head::task_list => ::head
struct wait_queue_entry::task_list => ::entry
For example, this code:
rqw->wait.task_list.next != &wait->task_list
... is was pretty unclear (to me) what it's doing, while now it's written this way:
rqw->wait.head.next != &wait->entry
... which makes it pretty clear that we are iterating a list until we see the head.
Other examples are:
list_for_each_entry_safe(pos, next, &x->task_list, task_list) {
list_for_each_entry(wq, &fence->wait.task_list, task_list) {
... where it's unclear (to me) what we are iterating, and during review it's
hard to tell whether it's trying to walk a wait-queue entry (which would be
a bug), while now it's written as:
list_for_each_entry_safe(pos, next, &x->head, entry) {
list_for_each_entry(wq, &fence->wait.head, entry) {
Rename:
wait_queue_t => wait_queue_entry_t
'wait_queue_t' was always a slight misnomer: its name implies that it's a "queue",
but in reality it's a queue *entry*. The 'real' queue is the wait queue head,
which had to carry the name.
Start sorting this out by renaming it to 'wait_queue_entry_t'.
This also allows the real structure name 'struct __wait_queue' to
lose its double underscore and become 'struct wait_queue_entry',
which is the more canonical nomenclature for such data types.
Replace bi_error with a new bi_status to allow for a clear conversion.
Note that device mapper overloaded bi_error with a private value, which
we'll have to keep arround at least for now and thus propagate to a
proper blk_status_t value.
Signed-off-by: Jens Axboe <axboe@fb.com>
Now that all bdi structures filesystems use are properly refcounted, we
can remove the SB_I_DYNBDI flag.
Similarly to set_bdev_super() NILFS2 just used block device reference to
bdi. Convert it to properly getting bdi reference. The reference will
get automatically dropped on superblock destruction.
CC: linux-nilfs@vger.kernel.org
Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
<linux/sched.h> into <linux/sched/signal.h>
Fix up affected files that include this signal functionality via sched.h.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Since i_blocksize() helper has been defined in fs.h, use it instead of
open-coding.
Link: http://lkml.kernel.org/r/1485184655-3895-3-git-send-email-konishi.ryusuke@lab.ntt.co.jp
Signed-off-by: Geliang Tang <geliangtang@gmail.com>
Use nilfs_btree_node_size() instead of open-coding.
Link: http://lkml.kernel.org/r/1485184655-3895-2-git-send-email-konishi.ryusuke@lab.ntt.co.jp
Replace all 1 << inode->i_blkbits and (1 << inode->i_blkbits) in fs
branch.
This patch also fixes multiple checkpatch warnings: WARNING: Prefer
'unsigned int' to bare use of 'unsigned'
Thanks to Andrew Morton for suggesting more appropriate function instead
of macro.
[geliangtang@gmail.com: truncate: use i_blocksize()]
Link: http://lkml.kernel.org/r/9c8b2cd83c8f5653805d43debde9fa8817e02fc4.1484895804.git.geliangtang@gmail.com
Link: http://lkml.kernel.org/r/1481319905-10126-1-git-send-email-fabf@skynet.be
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Cc: Ross Zwisler <ross.zwisler@linux.intel.com>
->fault(), ->page_mkwrite(), and ->pfn_mkwrite() calls do not need to
take a vma and vmf parameter when the vma already resides in vmf.
Remove the vma parameter to simplify things.
[arnd@arndb.de: fix ARM build]
Link: http://lkml.kernel.org/r/20170125223558.1451224-1-arnd@arndb.de
Link: http://lkml.kernel.org/r/148521301778.19116.10840599906674778980.stgit@djiang5-desk3.ch.intel.com
Signed-off-by: Dave Jiang <dave.jiang@intel.com>
Reviewed-by: Ross Zwisler <ross.zwisler@linux.intel.com>
Cc: Theodore Ts'o <tytso@mit.edu>
Cc: Darrick J. Wong <darrick.wong@oracle.com>
Cc: Matthew Wilcox <mawilcox@microsoft.com>
Cc: Jan Kara <jack@suse.com>
Cc: Dan Williams <dan.j.williams@intel.com>
We will want to have struct backing_dev_info allocated separately from
struct request_queue. As the first step add pointer to backing_dev_info
to request_queue and convert all users touching it. No functional
changes in this patch.
git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs
Pull partial readlink cleanups from Miklos Szeredi.
This is the uncontroversial part of the readlink cleanup patch-set that
simplifies the default readlink handling.
Miklos and Al are still discussing the rest of the series.
* git://git.kernel.org/pub/scm/linux/kernel/git/mszeredi/vfs:
vfs: make generic_readlink() static
vfs: remove ".readlink = generic_readlink" assignments
vfs: default to generic_readlink()
vfs: replace calling i_op->readlink with vfs_readlink()
proc/self: use generic_readlink
ecryptfs: use vfs_get_link()
bad_inode: add missing i_op initializers
If .readlink == NULL implies generic_readlink().
Generated by:
to_del="\.readlink.*=.*generic_readlink"
for i in `git grep -l $to_del`; do sed -i "/$to_del"/d $i; done
Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
Remove the WRITE_* and READ_SYNC wrappers, and just use the flags
directly. Where applicable this also drops usage of the
bio_set_op_attrs wrapper.
Pull more vfs updates from Al Viro:
">rename2() work from Miklos + current_time() from Deepa"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
fs: Replace current_fs_time() with current_time()
fs: Replace CURRENT_TIME_SEC with current_time() for inode timestamps
fs: Replace CURRENT_TIME with current_time() for inode timestamps
fs: proc: Delete inode time initializations in proc_alloc_inode()
vfs: Add current_time() api
vfs: add note about i_op->rename changes to porting
fs: rename "rename2" i_op to "rename"
vfs: remove unused i_op->rename
fs: make remaining filesystems use .rename2
libfs: support RENAME_NOREPLACE in simple_rename()
fs: support RENAME_NOREPLACE for local filesystems
ncpfs: fix unused variable warning
CURRENT_TIME macro is not appropriate for filesystems as it
doesn't use the right granularity for filesystem timestamps.
Use current_time() instead.
CURRENT_TIME is also not y2038 safe.
This is also in preparation for the patch that transitions
vfs timestamps to use 64 bit time and hence make them
y2038 safe. As part of the effort current_time() will be
extended to do range checks. Hence, it is necessary for all
file system timestamps to use current_time(). Also,
current_time() will be transitioned along with vfs to be
y2038 safe.
Note that whenever a single call to current_time() is used
to change timestamps in different inodes, it is because they
share the same time granularity.
Signed-off-by: Deepa Dinamani <deepa.kernel@gmail.com>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
Acked-by: Felipe Balbi <balbi@kernel.org>
Acked-by: Steven Whitehouse <swhiteho@redhat.com>
Acked-by: David Sterba <dsterba@suse.com>
Generated patch:
sed -i "s/\.rename2\t/\.rename\t\t/" `git grep -wl rename2`
sed -i "s/\brename2\b/rename/g" `git grep -wl rename2`
This is trivial to do:
- add flags argument to foo_rename()
- check if flags doesn't have any other than RENAME_NOREPLACE
- assign foo_rename() to .rename2 instead of .rename
Filesystems converted:
affs, bfs, exofs, ext2, hfs, hfsplus, jffs2, jfs, logfs, minix, msdos,
nilfs2, omfs, reiserfs, sysvfs, ubifs, udf, ufs, vfat.
Acked-by: Boaz Harrosh <ooo@electrozaur.com>
Acked-by: Richard Weinberger <richard@nod.at>
Acked-by: Bob Copeland <me@bobcopeland.com>
Acked-by: Jan Kara <jack@suse.cz>
Cc: Jaegeuk Kim <jaegeuk@kernel.org>
Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
Cc: Mikulas Patocka <mpatocka@redhat.com>
Cc: Dave Kleikamp <shaggy@kernel.org>
Cc: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
inode_change_ok() will be resposible for clearing capabilities and IMA
extended attributes and as such will need dentry. Give it as an argument
to inode_change_ok() instead of an inode. Also rename inode_change_ok()
to setattr_prepare() to better relect that it does also some
modifications in addition to checks.
The header file "include/linux/nilfs2_fs.h" is composed of parts for
ioctl and disk format, and both are intended to be shared with user
space programs.
This moves them to the uapi directory "include/uapi/linux" splitting the
file to "nilfs2_api.h" and "nilfs2_ondisk.h". The following minor
changes are accompanied by this migration:
- nilfs_direct_node struct in nilfs2/direct.h is converged to
nilfs2_ondisk.h because it's an on-disk structure.
- inline functions nilfs_rec_len_from_disk() and
nilfs_rec_len_to_disk() are moved to nilfs2/dir.c.
Link: http://lkml.kernel.org/r/1465825507-3407-4-git-send-email-konishi.ryusuke@lab.ntt.co.jp
Replace bit shifts by BIT macro for clarity.
Link: http://lkml.kernel.org/r/1465825507-3407-3-git-send-email-konishi.ryusuke@lab.ntt.co.jp
Variables ns_seg_seq, ns_segnum, ns_nextnum, ns_pseg_offset, ns_cno,
ns_ctime, ns_nongc_ctime, and ns_ndirtyblks, are protected by
ns_segctor_sem, but ns_sem is wrongly used by the nilfs sysfs code when
reading these variables. This fixes the misuse and clarifies which
semaphore protects them in the comment of the_nilfs struct.
Link: http://lkml.kernel.org/r/1465825507-3407-2-git-send-email-konishi.ryusuke@lab.ntt.co.jp
Move parser of snapshot mount option to a separate function
nilfs_parse_snapshot_option(), replace simple_strtoull() with
kstrtoull() to avoid checkpatch.pl warning "WARNING: simple_strtoull is
obsolete, use kstrtoull instead", and refine the error message of the
parser.
Link: http://lkml.kernel.org/r/1464875891-5443-9-git-send-email-konishi.ryusuke@lab.ntt.co.jp
Use cond_resched() instead of yield() in the loop of
nilfs_transaction_lock() since the usage corresponds to the "be nice for
others" case that the comment of yield() says.
This removes the following checkpatch.pl warning:
"WARNING: Using yield() is generally wrong. See yield() kernel-doc
(sched/core.c)"
Link: http://lkml.kernel.org/r/1464875891-5443-8-git-send-email-konishi.ryusuke@lab.ntt.co.jp
When nilfs returned -EIO as an error code, it's not always clear if it
came from the underlying block device or not. This will mend the issue
by having low level I/O routines of nilfs output an error message when
they detected an I/O error.
Link: http://lkml.kernel.org/r/1464875891-5443-7-git-send-email-konishi.ryusuke@lab.ntt.co.jp
Use nilfs_msg() to output warning messages and get rid of
nilfs_warning() function. This also removes function names from the
messages unless we embed them explicitly in format strings. Instead,
some messages are revised to clarify the context.
[arnd@arndb.de: avoid warning about unused variables]
Link: http://lkml.kernel.org/r/20160615201945.3348205-1-arnd@arndb.de
Link: http://lkml.kernel.org/r/1464875891-5443-6-git-send-email-konishi.ryusuke@lab.ntt.co.jp
Replace most use of printk() in nilfs2 implementation with nilfs_msg(),
and reduce the following checkpatch.pl warning:
"WARNING: Prefer [subsystem eg: netdev]_crit([subsystem]dev, ...
then dev_crit(dev, ... then pr_crit(... to printk(KERN_CRIT ..."
This patch also fixes a minor checkpatch warning "WARNING: quoted string
split across lines" that often accompanies the prior warning, and amends
message format as needed.
Link: http://lkml.kernel.org/r/1464875891-5443-5-git-send-email-konishi.ryusuke@lab.ntt.co.jp
Insert a back pointer to super block instance in nilfs object so that
functions of nilfs2 easily refer to the super block instance. This
simplifies replacement of printk() in the successive change.
Link: http://lkml.kernel.org/r/1464875891-5443-4-git-send-email-konishi.ryusuke@lab.ntt.co.jp
Define an own output routine to replace bare use of printk() function.
The output routine is implemented with a macro and a helper function,
which are named nilfs_msg() and __nilfs_msg(), respectively.
__nilfs_msg() formats a message like "NILFS (<device-name>): <message>",
prefixing it with a given log level, and terminates the statement with a
newline. The "device-name" is optional to make it available in early
stages; it will be omitted if a NULL pointer is passed to super block
instance argument. nilfs_msg() wraps __nilfs_msg() and is removed if
CONFIG_PRINTK is not set.
Link: http://lkml.kernel.org/r/1464875891-5443-3-git-send-email-konishi.ryusuke@lab.ntt.co.jp
Simplify nilfs_error(), an output function used to report critical
issues in file system. This renames the original nilfs_error() function
to __nilfs_error() and redefines it as a macro to hide its function name
argument within the macro.
Every call site of nilfs_error() is changed to strip __func__ argument
except nilfs_bmap_convert_error(); nilfs_bmap_convert_error() directly
calls __nilfs_error() because it inherits caller's function name.
Link: http://lkml.kernel.org/r/1464875891-5443-2-git-send-email-konishi.ryusuke@lab.ntt.co.jp
Pull core block updates from Jens Axboe:
- the big change is the cleanup from Mike Christie, cleaning up our
uses of command types and modified flags. This is what will throw
some merge conflicts
- regression fix for the above for btrfs, from Vincent
- following up to the above, better packing of struct request from
Christoph
- a 2038 fix for blktrace from Arnd
- a few trivial/spelling fixes from Bart Van Assche
- a front merge check fix from Damien, which could cause issues on
SMR drives
- Atari partition fix from Gabriel
- convert cfq to highres timers, since jiffies isn't granular enough
for some devices these days. From Jan and Jeff
- CFQ priority boost fix idle classes, from me
- cleanup series from Ming, improving our bio/bvec iteration
- a direct issue fix for blk-mq from Omar
- fix for plug merging not involving the IO scheduler, like we do for
other types of merges. From Tahsin
- expose DAX type internally and through sysfs. From Toshi and Yigal
* 'for-4.8/core' of git://git.kernel.dk/linux-block: (76 commits)
block: Fix front merge check
block: do not merge requests without consulting with io scheduler
block: Fix spelling in a source code comment
block: expose QUEUE_FLAG_DAX in sysfs
block: add QUEUE_FLAG_DAX for devices to advertise their DAX support
Btrfs: fix comparison in __btrfs_map_block()
block: atari: Return early for unsupported sector size
Doc: block: Fix a typo in queue-sysfs.txt
cfq-iosched: Charge at least 1 jiffie instead of 1 ns
cfq-iosched: Fix regression in bonnie++ rewrite performance
cfq-iosched: Convert slice_resid from u64 to s64
block: Convert fifo_time from ulong to u64
blktrace: avoid using timespec
block/blk-cgroup.c: Declare local symbols static
block/bio-integrity.c: Add #include "blk.h"
block/partition-generic.c: Remove a set-but-not-used variable
block: bio: kill BIO_MAX_SIZE
cfq-iosched: temporarily boost queue priority for idle classes
block: drbd: avoid to use BIO_MAX_SIZE
block: bio: remove BIO_MAX_SECTORS
The value `bytes' comes from the filesystem which is about to be
mounted. We cannot trust that the value is always in the range we
expect it to be.
Check its value before using it to calculate the length for the crc32_le
call. It value must be larger (or equal) sumoff + 4.
This fixes a kernel bug when accidentially mounting an image file which
had the nilfs2 magic value 0x3434 at the right offset 0x406 by chance.
The bytes 0x01 0x00 were stored at 0x408 and were interpreted as a
s_bytes value of 1. This caused an underflow when substracting sumoff +
4 (20) in the call to crc32_le.
BUG: unable to handle kernel paging request at ffff88021e600000
IP: crc32_le+0x36/0x100
Call Trace:
nilfs_valid_sb.part.5+0x52/0x60 [nilfs2]
nilfs_load_super_block+0x142/0x300 [nilfs2]
init_nilfs+0x60/0x390 [nilfs2]
nilfs_mount+0x302/0x520 [nilfs2]
mount_fs+0x38/0x160
vfs_kern_mount+0x67/0x110
do_mount+0x269/0xe00
SyS_mount+0x9f/0x100
entry_SYSCALL_64_fastpath+0x16/0x71
Link: http://lkml.kernel.org/r/1466778587-5184-2-git-send-email-konishi.ryusuke@lab.ntt.co.jp
Signed-off-by: Torsten Hilbrich <torsten.hilbrich@secunet.com>
Tested-by: Torsten Hilbrich <torsten.hilbrich@secunet.com>
Cc: <stable@vger.kernel.org>
Separate the op from the rq_flag_bits and have nilfs
set/get the bio using bio_set_op_attrs/bio_op.
Signed-off-by: Mike Christie <mchristi@redhat.com>
Reviewed-by: Hannes Reinecke <hare@suse.com>
This has submit_bh users pass in the operation and flags separately,
so submit_bh_wbc can setup the bio op and bi_rw flags on the bio that
is submitted.
This has callers of submit_bio/submit_bio_wait set the bio->bi_rw
instead of passing it in. This makes that use the same as
generic_make_request and how we set the other bio fields.
Fixed up fs/ext4/crypto.c
This fixes block comments with proper formatting to eliminate the
following checkpatch.pl warnings:
"WARNING: Block comments use * on subsequent lines"
"WARNING: Block comments use a trailing */ on a separate line"
Link: http://lkml.kernel.org/r/1462886671-3521-8-git-send-email-konishi.ryusuke@lab.ntt.co.jp
This fixes checkpatch.pl warning "WARNING: Single statement macros
should not use a do {} while (0) loop".
Link: http://lkml.kernel.org/r/1462886671-3521-7-git-send-email-konishi.ryusuke@lab.ntt.co.jp
This fixes the checkpatch.pl warning that suggests else is not
generally useful after a break or return.
Link: http://lkml.kernel.org/r/1462886671-3521-6-git-send-email-konishi.ryusuke@lab.ntt.co.jp
This fixes checkpatch.pl warning "WARNING: Prefer 'unsigned int' to
bare use of 'unsigned'".
Link: http://lkml.kernel.org/r/1462886671-3521-5-git-send-email-konishi.ryusuke@lab.ntt.co.jp
