path: root/fs/nls/mac-celtic.c
2014-01-25nls: have register_nls() set ->ownerAl Viro
pass owner explicitly to __register_nls(), make register_nls() a macro passing THIS_MODULE as the owner argument to __register_nls(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-06-01nls: fix (and rename) mac NLS table files and config optionsLinus Torvalds
The config options in the Kconfig file (with _CODEPAGE_ in the name) didn't match the config option name in the Makefile (no _CODEPAGE_). And both of them were of the hard-to-read MACXYZZY variety, which made them hard to parse for normal humans: MACROMAN easily reads as "macro man", not as "Mac Roman". So rename the options to be consistent, and be NLS_MAC_xyzzy. Rename the files to be mac-xyzzy.c too, and drop the "nls" part entirely (it's already in the directory name). Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
