path: root/fs/nls/nls_iso8859-13.c
2007-10-17add consts where appropriate in fs/nls/*Denys Vlasenko
Add const modifiers to a few struct nls_table's member pointers in include/linux/nls.h and adds a lot of const's in fs/nls/*.c files. Resulting changes as visible by size: text data bss dec hex filename 113612 481216 2368 597196 91ccc nls.org/built-in.o 593548 3296 288 597132 91c8c nls/built-in.o Apparently compiler managed to optimize code a bit better because of const-ness. No other changes are made. Signed-off-by: Denys Vlasenko <vda.linux@googlemail.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-10-03fix file specification in commentsUwe Zeisberger
Many files include the filename at the beginning, serveral used a wrong one. Signed-off-by: Uwe Zeisberger <Uwe_Zeisberger@digi.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
