path: root/fs/notify/inotify/Kconfig
2010-07-28inotify: remove inotify in kernel interfaceEric Paris
nothing uses inotify in the kernel, drop it! Signed-off-by: Eric Paris <eparis@redhat.com>
2010-04-30Inotify: Fix build failure in inotify user supportRalf Baechle
CONFIG_INOTIFY_USER defined but CONFIG_ANON_INODES undefined will result in the following build failure: LD vmlinux fs/built-in.o: In function 'sys_inotify_init1': (.text.sys_inotify_init1+0x22c): undefined reference to 'anon_inode_getfd' fs/built-in.o: In function `sys_inotify_init1': (.text.sys_inotify_init1+0x22c): relocation truncated to fit: R_MIPS_26 against 'anon_inode_getfd' make[2]: *** [vmlinux] Error 1 make[1]: *** [sub-make] Error 2 make: *** [all] Error 2 Signed-off-by: Ralf Baechle <ralf@linux-mips.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-07-21fsnotify: use def_bool in kconfig instead of letting the user chooseEric Paris
fsnotify doens't give the user anything. If someone chooses inotify or dnotify it should build fsnotify, if they don't select one it shouldn't be built. This patch changes fsnotify to be a def_bool=n and makes everything else select it. Also fixes the issue people complained about on lwn where gdm hung because they didn't have inotify and they didn't get the inotify build option..... Signed-off-by: Eric Paris <eparis@redhat.com>
2009-06-11inotify: reimplement inotify using fsnotifyEric Paris
Reimplement inotify_user using fsnotify. This should be feature for feature exactly the same as the original inotify_user. This does not make any changes to the in kernel inotify feature used by audit. Those patches (and the eventual removal of in kernel inotify) will come after the new inotify_user proves to be working correctly. Signed-off-by: Eric Paris <eparis@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de>
2008-12-31filesystem notification: create fs/notify to contain all fs notificationEric Paris
Creating a generic filesystem notification interface, fsnotify, which will be used by inotify, dnotify, and eventually fanotify is really starting to clutter the fs directory. This patch simply moves inotify and dnotify into fs/notify/inotify and fs/notify/dnotify respectively to make both current fs/ and future notification tidier. Signed-off-by: Eric Paris <eparis@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
