path: root/fs/ntfs/inode.c
2011-07-20fs: kill i_alloc_semChristoph Hellwig
i_alloc_sem is a rather special rw_semaphore. It's the last one that may be released by a non-owner, and it's write side is always mirrored by real exclusion. It's intended use it to wait for all pending direct I/O requests to finish before starting a truncate. Replace it with a hand-grown construct: - exclusion for truncates is already guaranteed by i_mutex, so it can simply fall way - the reader side is replaced by an i_dio_count member in struct inode that counts the number of pending direct I/O requests. Truncate can't proceed as long as it's non-zero - when i_dio_count reaches non-zero we wake up a pending truncate using wake_up_bit on a new bit in i_flags - new references to i_dio_count can't appear while we are waiting for it to read zero because the direct I/O count always needs i_mutex (or an equivalent like XFS's i_iolock) for starting a new operation. This scheme is much simpler, and saves the space of a spinlock_t and a struct list_head in struct inode (typically 160 bits on a non-debug 64-bit system). Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-24fs: rename inode_lock to inode_hash_lockDave Chinner
All that remains of the inode_lock is protecting the inode hash list manipulation and traversals. Rename the inode_lock to inode_hash_lock to reflect it's actual function. Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-07fs: icache RCU free inodesNick Piggin
RCU free the struct inode. This will allow: - Subsequent store-free path walking patch. The inode must be consulted for permissions when walking, so an RCU inode reference is a must. - sb_inode_list_lock to be moved inside i_lock because sb list walkers who want to take i_lock no longer need to take sb_inode_list_lock to walk the list in the first place. This will simplify and optimize locking. - Could remove some nested trylock loops in dcache code - Could potentially simplify things a bit in VM land. Do not need to take the page lock to follow page->mapping. The downsides of this is the performance cost of using RCU. In a simple creat/unlink microbenchmark, performance drops by about 10% due to inability to reuse cache-hot slab objects. As iterations increase and RCU freeing starts kicking over, this increases to about 20%. In cases where inode lifetimes are longer (ie. many inodes may be allocated during the average life span of a single inode), a lot of this cache reuse is not applicable, so the regression caused by this patch is smaller. The cache-hot regression could largely be avoided by using SLAB_DESTROY_BY_RCU, however this adds some complexity to list walking and store-free path walking, so I prefer to implement this at a later date, if it is shown to be a win in real situations. I haven't found a regression in any non-micro benchmark so I doubt it will be a problem. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2010-08-09convert remaining ->clear_inode() to ->evict_inode()Al Viro
2010-08-09remove inode_setattrChristoph Hellwig
Replace inode_setattr with opencoded variants of it in all callers. This moves the remaining call to vmtruncate into the filesystem methods where it can be replaced with the proper truncate sequence. In a few cases it was obvious that we would never end up calling vmtruncate so it was left out in the opencoded variant: spufs: explicitly checks for ATTR_SIZE earlier btrfs,hugetlbfs,logfs,dlmfs: explicitly clears ATTR_SIZE earlier ufs: contains an opencoded simple_seattr + truncate that sets the filesize just above In addition to that ncpfs called inode_setattr with handcrafted iattrs, which allowed to trim down the opencoded variant. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-03-05pass writeback_control to ->write_inodeChristoph Hellwig
This gives the filesystem more information about the writeback that is happening. Trond requested this for the NFS unstable write handling, and other filesystems might benefit from this too by beeing able to distinguish between the different callers in more detail. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-17kill I_LOCKChristoph Hellwig
After I_SYNC was split from I_LOCK the leftover is always used together with I_NEW and thus superflous. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-16ntfs: use is_power_of_2() function for clarity.Robert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Cc: Anton Altaparmakov <aia21@cantab.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01ntfs: remove private wrapper of endian helpersHarvey Harrison
The base versions handle constant folding now and are shorter than these private wrappers, use them directly. Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Anton Altaparmakov <aia21@cantab.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-05ntfs: don't NULL i_opAl Viro
it's already set to empty table (and no, ntfs doesn't have any explicit checks for NULL ->i_op or NULL ->i_fop) Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2007-10-12NTFS: Fix a mount time deadlock.Anton Altaparmakov
Big thanks go to Mathias Kolehmainen for reporting the bug, providing debug output and testing the patches I sent him to get it working. The fix was to stop calling ntfs_attr_set() at mount time as that causes balance_dirty_pages_ratelimited() to be called which on systems with little memory actually tries to go and balance the dirty pages which tries to take the s_umount semaphore but because we are still in fill_super() across which the VFS holds s_umount for writing this results in a deadlock. We now do the dirty work by hand by submitting individual buffers. This has the annoying "feature" that mounting can take a few seconds if the journal is large as we have clear it all. One day someone should improve on this by deferring the journal clearing to a helper kernel thread so it can be done in the background but I don't have time for this at the moment and the current solution works fine so I am leaving it like this for now. Signed-off-by: Anton Altaparmakov <aia21@cantab.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-31ntfs_init_locked_inode(): fix array indexingAndrew Morton
Local variable `i' is a byte-counter. Don't use it as an index into an array of le32's. Reported-by: "young dave" <hidave.darkstar@gmail.com> Cc: "Christoph Lameter" <clameter@sgi.com> Acked-by: Anton Altaparmakov <aia21@cantab.net> Cc: <stable@kernel.org> Cc: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-18NTFS: 2.1.28 - Fix deadlock reported by Sergey Vlasov due to ntfs_put_inode().Anton Altaparmakov
- Fix deadlock in fs/ntfs/inode.c::ntfs_put_inode(). Thanks to Sergey Vlasov for the report and detailed analysis of the deadlock. The fix involved getting rid of ntfs_put_inode() altogether and hence NTFS no longer has a ->put_inode super operation. Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2006-12-07[PATCH] slab: remove SLAB_NOFSChristoph Lameter
SLAB_NOFS is an alias of GFP_NOFS. Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] fs/ntfs: Conversion to generic booleanRichard Knutsson
Conversion of booleans to: generic-boolean.patch (2006-08-23) Signed-off-by: Richard Knutsson <ricknu-0@student.ltu.se> Signed-off-by: Anton Altaparmakov <aia21@cantab.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-09-27[PATCH] fs: Removing useless castsPanagiotis Issaris
* Removing useless casts * Removing useless wrapper * Conversion from kmalloc+memset to kzalloc Signed-off-by: Panagiotis Issaris <takis@issaris.org> Acked-by: Dave Kleikamp <shaggy@austin.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-03[PATCH] lockdep: annotate NTFS locking rulesIngo Molnar
NTFS uses lots of type-opaque objects which acquire their true identity runtime - so the lock validator needs to be helped in a couple of places to figure out object types. Many thanks to Anton Altaparmakov for giving lots of explanations about NTFS locking rules. Has no effect on non-lockdep kernels. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Anton Altaparmakov <aia21@cantab.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23NTFS: Semaphore to mutex conversion.Ingo Molnar
The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2006-03-23NTFS: Add a missing call to flush_dcache_mft_record_page() inAnton Altaparmakov
fs/ntfs/inode.c::ntfs_write_inode(). Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2006-03-23NTFS: Fix a bug in fs/ntfs/inode.c::ntfs_read_locked_index_inode() where weAnton Altaparmakov
forgot to update a temporary variable so loading index inodes which have an index allocation attribute failed. Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2006-03-23NTFS: Add support for sparse files which have a compression unit of 0.Anton Altaparmakov
2006-02-24NTFS: - Cope with attribute list attribute having invalid flags.Anton Altaparmakov
Windows copes with this and even chkdsk does not detect or fix this so we have to cope with it, too. Thanks to Pawel Kot for reporting the problem. - Miscellaneous updates to layout.h. Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2006-01-10[PATCH] replace inode_update_time with file_update_timeChristoph Hellwig
To allow various options to work per-mount instead of per-sb we need a struct vfsmount when updating ctime and mtime. This preparation patch replaces the inode_update_time routine with a file_update_atime routine so we can easily get at the vfsmount. (and the file makes more sense in this context anyway). Also get rid of the unused second argument - we always want to update the ctime when calling this routine. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@ftp.linux.org.uk> Cc: Anton Altaparmakov <aia21@cantab.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09[PATCH] mutex subsystem, semaphore to mutex: VFS, ->i_semJes Sorensen
This patch converts the inode semaphore to a mutex. I have tested it on XFS and compiled as much as one can consider on an ia64. Anyway your luck with it might be different. Modified-by: Ingo Molnar <mingo@elte.hu> (finished the conversion) Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2005-10-04NTFS: Enable ATTR_SIZE attribute changes in ntfs_setattr(). This completesAnton Altaparmakov
the initial implementation of file truncation. Now both open(2)ing a file with the O_TRUNC flag and the {,f}truncate(2) system calls will resize a file appropriately. The limitations are that only uncompressed and unencrypted files are supported. Also, there is only very limited support for highly fragmented files (the ones whose $DATA attribute is split into multiple attribute extents). Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2005-10-04NTFS: Implement fs/ntfs/inode.[hc]::ntfs_truncate(). It only supportsAnton Altaparmakov
uncompressed and unencrypted files. Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2005-09-19NTFS: Fix ntfs_{read,write}page() to cope with concurrent truncates better.Anton Altaparmakov
2005-09-08NTFS: Fixup handling of sparse, compressed, and encrypted attributes inAnton Altaparmakov
fs/ntfs/inode.c::ntfs_read_locked_{,attr_,index_}inode(). Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2005-09-08NTFS: Truncate {a,c,m}time to the ntfs supported time granularity whenAnton Altaparmakov
updating the times in the inode in ntfs_setattr(). Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2005-05-27NTFS: Remove spurious void pointer casts from fs/ntfs/.Pekka Enberg
Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2005-05-05NTFS: Correct sparse file handling. The compressed values need to beAnton Altaparmakov
checked and set in the ntfs inode as done for compressed files and the compressed size needs to be used for vfs inode->i_blocks instead of the allocated size, again, as done for compressed files. Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2005-05-05NTFS: Fix printk format warnings on ia64. (Randy Dunlap)Randy Dunlap
Signed-off-by: Randy Dunlap <rddunlap@osdl.org> Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2005-05-05NTFS: - Set the ntfs_inode->allocated_size to the real allocated size in theAnton Altaparmakov
mft record for resident attributes (fs/ntfs/inode.c). - Small readability cleanup to use "a" instead of "ctx->attr" everywhere (fs/ntfs/inode.c). Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2005-05-05NTFS: - Add disable_sparse mount option together with a per volume sparseAnton Altaparmakov
enable bit which is set appropriately and a per inode sparse disable bit which is preset on some system file inodes as appropriate. - Enforce that sparse support is disabled on NTFS volumes pre 3.0. Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2005-05-05NTFS: Use i_size_read() in fs/ntfs/inode.c once and then use the cached valueAnton Altaparmakov
afterwards when reading the size of the bitmap inode. Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2005-05-05NTFS: - In fs/ntfs/compress.c, use i_size_read() at the start and then use theAnton Altaparmakov
cached value everywhere. Cache the initialized_size in the same way and protect the critical region where the two sizes are read using the new size_lock of the ntfs inode. - Add the new size_lock to the ntfs_inode structure (fs/ntfs/inode.h) and initialize it (fs/ntfs/inode.c). Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
