path: root/fs/ntfs/runlist.h
2005-09-08NTFS: Add ntfs_rl_punch_nolock() which punches a caller specified hole into ↵Anton Altaparmakov
a runlist. Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2005-06-25NTFS: Add an extra parameter @last_vcn to ntfs_get_size_for_mapping_pairs()Anton Altaparmakov
and ntfs_mapping_pairs_build() to allow the runlist encoding to be partial which is desirable when filling holes in sparse attributes. Update all callers. Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2005-05-05NTFS: Fix compilation when configured read-only.Anton Altaparmakov
- Add ifdef NTFS_RW around write specific code if fs/ntfs/runlist.[hc] and fs/ntfs/attrib.[hc]. - Minor bugfix to fs/ntfs/attrib.c::ntfs_attr_make_non_resident() where the runlist was not freed in all error cases. - Add fs/ntfs/runlist.[hc]::ntfs_rl_find_vcn_nolock(). Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
2005-05-05NTFS: - Fix bug in fs/ntfs/attrib.c::ntfs_find_vcn_nolock() where afterAnton Altaparmakov
dropping the read lock and taking the write lock we were not checking whether someone else did not already do the work we wanted to do. - Rename ntfs_find_vcn_nolock() to ntfs_attr_find_vcn_nolock(). - Tidy up some comments in fs/ntfs/runlist.c. - Add LCN_ENOMEM and LCN_EIO definitions to fs/ntfs/runlist.h. Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
