path: root/fs/ntfs/upcase.c
2008-05-24ntfs: le*_add_cpu conversionMarcin Slusarz
replace all: little_endian_variable = cpu_to_leX(leX_to_cpu(little_endian_variable) + expression_in_cpu_byteorder); with: leX_add_cpu(&little_endian_variable, expression_in_cpu_byteorder); generated with semantic patch Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Acked-by: Anton Altaparmakov <aia21@cantab.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-02-24NTFS: Do more detailed reporting of why we cannot mount read-write byAnton Altaparmakov
special casing the VOLUME_MODIFIED_BY_CHKDSK flag. Signed-off-by: Anton Altaparmakov <aia21@cantab.net>
