path: root/fs/ocfs2/alloc.c
2011-05-23ocfs2: Add trace event for trim.Tao Ma
Add the corresponding trace event for trim. Signed-off-by: Tao Ma <boyu.mt@taobao.com> Signed-off-by: Joel Becker <jlbec@evilplan.org>
2011-05-23ocfs2: Add ocfs2_trim_fs for SSD trim support.Tao Ma
Add ocfs2_trim_fs to support trimming freed clusters in the volume. A range will be given and all the freed clusters greater than minlen will be discarded to the block layer. Signed-off-by: Tao Ma <boyu.mt@taobao.com> Signed-off-by: Joel Becker <jlbec@evilplan.org>
2011-02-22ocfs2: Remove DISK_ALLOC from masklog.Tao Ma
Since all 4 files, localalloc.c, suballoc.c, alloc.c and resize.c, which use DISK_ALLOC are changed to trace events, Remove masklog DISK_ALLOC totally. Signed-off-by: Tao Ma <boyu.mt@taobao.com>
2011-02-22ocfs2: Remove mlog(0) from fs/ocfs2/alloc.cTao Ma
This is the first try of replacing debug mlog(0,...) to trace events. Wengang has did some work in his original patch http://oss.oracle.com/pipermail/ocfs2-devel/2009-November/005513.html But he didn't finished it. So this patch removes all mlog(0,...) from alloc.c and adds the corresponding trace events. Different mlogs have different solutions. 1. Some are replaced with trace event directly. 2. Some are replaced and some new parameters are added since I think we need to know the btree owner in that case. 3. Some are combined into one trace events. 4. Some redundant mlogs are removed. What's more, it defines some event classes so that we can use them later. Cc: Wengang Wang <wen.gang.wang@oracle.com> Signed-off-by: Tao Ma <boyu.mt@taobao.com>
2011-03-07ocfs2: Remove EXIT from masklog.Tao Ma
mlog_exit is used to record the exit status of a function. But because it is added in so many functions, if we enable it, the system logs get filled up quickly and cause too much I/O. So actually no one can open it for a production system or even for a test. This patch just try to remove it or change it. So: 1. if all the error paths already use mlog_errno, it is just removed. Otherwise, it will be replaced by mlog_errno. 2. if it is used to print some return value, it is replaced with mlog(0,...). mlog_exit_ptr is changed to mlog(0. All those mlog(0,...) will be replaced with trace events later. Signed-off-by: Tao Ma <boyu.mt@taobao.com>
2011-02-21ocfs2: Remove ENTRY from masklog.Tao Ma
ENTRY is used to record the entry of a function. But because it is added in so many functions, if we enable it, the system logs get filled up quickly and cause too much I/O. So actually no one can open it for a production system or even for a test. So for mlog_entry_void, we just remove it. for mlog_entry(...), we replace it with mlog(0,...), and they will be replace by trace event later. Signed-off-by: Tao Ma <boyu.mt@taobao.com>
2011-01-07ocfs2: Remove unused truncate function from alloc.cTao Ma
Tristan Ye has done some refactoring against our truncate process, so some functions like ocfs2_prepare_truncate and ocfs2_free_truncate_context are no use and we'd better remove them. Signed-off-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: Joel Becker <joel.becker@oracle.com>
2010-12-16ocfs2: Try to free truncate log when meeting ENOSPC in write.Tao Ma
Recently, one of our colleagues meet with a problem that if we write/delete a 32mb files repeatly, we will get an ENOSPC in the end. And the corresponding bug is 1288. http://oss.oracle.com/bugzilla/show_bug.cgi?id=1288 The real problem is that although we have freed the clusters, they are in truncate log and they will be summed up so that we can free them once in a whole. So this patch just try to resolve it. In case we see -ENOSPC in ocfs2_write_begin_no_lock, we will check whether the truncate log has enough clusters for our need, if yes, we will try to flush the truncate log at that point and try again. This method is inspired by Mark Fasheh <mfasheh@suse.com>. Thanks. Cc: Mark Fasheh <mfasheh@suse.com> Signed-off-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: Joel Becker <joel.becker@oracle.com>
2010-09-08ocfs2: Fix deadlock when allocating pageJan Kara
We cannot call grab_cache_page() when holding filesystem locks or with a transaction started as grab_cache_page() calls page allocation with GFP_KERNEL flag and thus page reclaim can recurse back into the filesystem causing deadlocks or various assertion failures. We have to use find_or_create_page() instead and pass it GFP_NOFS as we do with other allocations. Acked-by: Mark Fasheh <mfasheh@suse.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Tao Ma <tao.ma@oracle.com>
2010-05-18Merge branch 'discontig-bg' of git://oss.oracle.com/git/tma/linux-2.6 into ↵Joel Becker
ocfs2-merge-window
2010-05-18Ocfs2: Make ocfs2_find_cpos_for_left_leaf() public.Tristan Ye
The original idea to pull ocfs2_find_cpos_for_left_leaf() out of alloc.c is to benefit punching-holes optimization patch, it however, can also be referred by other funcs in the future who want to do the same job. Signed-off-by: Tristan Ye <tristan.ye@oracle.com> Acked-by: Mark Fasheh <mfasheh@suse.com> Signed-off-by: Joel Becker <joel.becker@oracle.com>
2010-05-18Ocfs2: Optimize ocfs2 truncate to use ocfs2_remove_btree_range() instead.Tristan Ye
Truncate is just a special case of punching holes(from new i_size to end), we therefore could take advantage of the existing ocfs2_remove_btree_range() to reduce the comlexity and redundancy in alloc.c. The goal here is to make truncate more generic and straightforward. Several functions only used by ocfs2_commit_truncate() will smiply be removed. ocfs2_remove_btree_range() was originally used by the hole punching code, which didn't take refcount trees into account (definitely a bug). We therefore need to change that func a bit to handle refcount trees. It must take the refcount lock, calculate and reserve blocks for refcount tree changes, and decrease refcounts at the end. We replace ocfs2_lock_allocators() here by adding a new func ocfs2_reserve_blocks_for_rec_trunc() which accepts some extra blocks to reserve. This will not hurt any other code using ocfs2_remove_btree_range() (such as dir truncate and hole punching). I merged the following steps into one patch since they may be logically doing one thing, though I know it looks a little bit fat to review. 1). Remove redundant code used by ocfs2_commit_truncate(), since we're moving to ocfs2_remove_btree_range anyway. 2). Add a new func ocfs2_reserve_blocks_for_rec_trunc() for purpose of accepting some extra blocks to reserve. 3). Change ocfs2_prepare_refcount_change_for_del() a bit to fit our needs. It's safe to do this since it's only being called by truncate. 4). Change ocfs2_remove_btree_range() a bit to take refcount case into account. 5). Finally, we change ocfs2_commit_truncate() to call ocfs2_remove_btree_range() in a proper way. The patch has been tested normally for sanity check, stress tests with heavier workload will be expected. Based on this patch, fixing the punching holes bug will be fairly easy. Signed-off-by: Tristan Ye <tristan.ye@oracle.com> Acked-by: Mark Fasheh <mfasheh@suse.com> Signed-off-by: Joel Becker <joel.becker@oracle.com>
2010-05-05ocfs2: Make ocfs2_extend_trans() really extend.Tao Ma
In ocfs2, we use ocfs2_extend_trans() to extend a journal handle's blocks. But if jbd2_journal_extend() fails, it will only restart with the the new number of blocks. This tends to be awkward since in most cases we want additional reserved blocks. It makes our code harder to mantain since the caller can't be sure all the original blocks will not be accessed and dirtied again. There are 15 callers of ocfs2_extend_trans() in fs/ocfs2, and 12 of them have to add h_buffer_credits before they call ocfs2_extend_trans(). This makes ocfs2_extend_trans() really extend atop the original block count. Signed-off-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: Joel Becker <joel.becker@oracle.com>
2010-05-05ocfs2: use allocation reservations during file writeMark Fasheh
Add a per-inode reservations structure and pass it through to the reservations code. Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2010-05-05ocfs2: Make ocfs2_journal_dirty() void.Joel Becker
jbd[2]_journal_dirty_metadata() only returns 0. It's been returning 0 since before the kernel moved to git. There is no point in checking this error. ocfs2_journal_dirty() has been faithfully returning the status since the beginning. All over ocfs2, we have blocks of code checking this can't fail status. In the past few years, we've tried to avoid adding these checks, because they are pointless. But anyone who looks at our code assumes they are needed. Finally, ocfs2_journal_dirty() is made a void function. All error checking is removed from other files. We'll BUG_ON() the status of jbd2_journal_dirty_metadata() just in case they change it someday. They won't. Signed-off-by: Joel Becker <joel.becker@oracle.com>
2010-03-22ocfs2: Free block to the right block group.Tao Ma
In case the block we are going to free is allocated from a discontiguous block group, we have to use suballoc_loc to be the right group. Signed-off-by: Tao Ma <tao.ma@oracle.com>
2010-03-26ocfs2: Set suballoc_loc on allocated metadata.Joel Becker
Get the suballoc_loc from ocfs2_claim_new_inode() or ocfs2_claim_metadata(). Store it on the appropriate field of the block we just allocated. Signed-off-by: Joel Becker <joel.becker@oracle.com>
2010-05-06ocfs2: ocfs2_claim_*() don't need an ocfs2_super argument.Joel Becker
They all take an ocfs2_alloc_context, which has the allocation inode. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Tao Ma <tao.ma@oracle.com>
2010-03-05Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: (33 commits) quota: stop using QUOTA_OK / NO_QUOTA dquot: cleanup dquot initialize routine dquot: move dquot initialization responsibility into the filesystem dquot: cleanup dquot drop routine dquot: move dquot drop responsibility into the filesystem dquot: cleanup dquot transfer routine dquot: move dquot transfer responsibility into the filesystem dquot: cleanup inode allocation / freeing routines dquot: cleanup space allocation / freeing routines ext3: add writepage sanity checks ext3: Truncate allocated blocks if direct IO write fails to update i_size quota: Properly invalidate caches even for filesystems with blocksize < pagesize quota: generalize quota transfer interface quota: sb_quota state flags cleanup jbd: Delay discarding buffers in journal_unmap_buffer ext3: quota_write cross block boundary behaviour quota: drop permission checks from xfs_fs_set_xstate/xfs_fs_set_xquota quota: split out compat_sys_quotactl support from quota.c quota: split out netlink notification support from quota.c quota: remove invalid optimization from quota_sync_all ... Fixed trivial conflicts in fs/namei.c and fs/ufs/inode.c
2010-03-05dquot: cleanup space allocation / freeing routinesChristoph Hellwig
Get rid of the alloc_space, free_space, reserve_space, claim_space and release_rsv dquot operations - they are always called from the filesystem and if a filesystem really needs their own (which none currently does) it can just call into it's own routine directly. Move shared logic into the common __dquot_alloc_space, dquot_claim_space_nodirty and __dquot_free_space low-level methods, and rationalize the wrappers around it to move as much as possible code into the common block for CONFIG_QUOTA vs not. Also rename all these helpers to be named dquot_* instead of vfs_dq_*. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-02-26ocfs2: add extent block stealing for ocfs2 v5Tiger Yang
This patch add extent block (metadata) stealing mechanism for extent allocation. This mechanism is same as the inode stealing. if no room in slot specific extent_alloc, we will try to allocate extent block from the next slot. Signed-off-by: Tiger Yang <tiger.yang@oracle.com> Acked-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: Joel Becker <joel.becker@oracle.com>
2009-12-23Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2 * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2: ocfs2: Set i_nlink properly during reflink. ocfs2: Add reflinked file's inode to inode hash eariler. ocfs2: refcounttree.c cleanup. ocfs2: Find proper end cpos for a leaf refcount block.
2009-12-16ocfs: stop using do_sync_mapping_rangeChristoph Hellwig
do_sync_mapping_range(..., SYNC_FILE_RANGE_WRITE) is a very awkward way to perform a filemap_fdatawrite_range. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-12-02ocfs2: Find proper end cpos for a leaf refcount block.Tao Ma
ocfs2 refcount tree is stored as an extent tree while the leaf ocfs2_refcount_rec points to a refcount block. The following step can trip a kernel panic. mkfs.ocfs2 -b 512 -C 1M --fs-features=refcount $DEVICE mount -t ocfs2 $DEVICE $MNT_DIR FILE_NAME=$RANDOM FILE_NAME_1=$RANDOM FILE_REF="${FILE_NAME}_ref" FILE_REF_1="${FILE_NAME}_ref_1" for((i=0;i<305;i++)) do # /mnt/1048576 is a file with 1048576 sizes. cat /mnt/1048576 >> $MNT_DIR/$FILE_NAME cat /mnt/1048576 >> $MNT_DIR/$FILE_NAME_1 done for((i=0;i<3;i++)) do cat /mnt/1048576 >> $MNT_DIR/$FILE_NAME done for((i=0;i<2;i++)) do cat /mnt/1048576 >> $MNT_DIR/$FILE_NAME cat /mnt/1048576 >> $MNT_DIR/$FILE_NAME_1 done cat /mnt/1048576 >> $MNT_DIR/$FILE_NAME for((i=0;i<11;i++)) do cat /mnt/1048576 >> $MNT_DIR/$FILE_NAME cat /mnt/1048576 >> $MNT_DIR/$FILE_NAME_1 done reflink $MNT_DIR/$FILE_NAME $MNT_DIR/$FILE_REF # write_f is a program which will write some bytes to a file at offset. # write_f -f file_name -l offset -w write_bytes. ./write_f -f $MNT_DIR/$FILE_REF -l $[310*1048576] -w 4096 ./write_f -f $MNT_DIR/$FILE_REF -l $[306*1048576] -w 4096 ./write_f -f $MNT_DIR/$FILE_REF -l $[311*1048576] -w 4096 ./write_f -f $MNT_DIR/$FILE_NAME -l $[310*1048576] -w 4096 ./write_f -f $MNT_DIR/$FILE_NAME -l $[311*1048576] -w 4096 reflink $MNT_DIR/$FILE_NAME $MNT_DIR/$FILE_REF_1 ./write_f -f $MNT_DIR/$FILE_NAME -l $[311*1048576] -w 4096 #kernel panic here. The reason is that if the ocfs2_extent_rec is the last record in a leaf extent block, the old solution fails to find the suitable end cpos. So this patch try to walk through the b-tree, find the next sub root and get the c_pos the next sub-tree starts from. btw, I have runned tristan's test case against the patched kernel for several days and this type of kernel panic never happens again. Signed-off-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: Joel Becker <joel.becker@oracle.com>
2009-09-22ocfs2: Make transaction extend more efficient.Tao Ma
In ocfs2_extend_rotate_transaction, op_credits is the orignal credits in the handle and we only want to extend the credits for the rotation, but the old solution always double it. It is harmless for some minor operations, but for actions like reflink we may rotate tree many times and cause the credits increase dramatically. So this patch try to only increase the desired credits. Signed-off-by: Tao Ma <tao.ma@oracle.com>
2009-09-22ocfs2: CoW refcount tree improvement.Tao Ma
During CoW, if the old extent record is refcounted, we allocate som new clusters and do CoW. Actually we can have some improvement here. If the old extent has refcount=1, that means now it is only used by this file. So we don't need to allocate new clusters, just remove the refcounted flag and it is OK. We also have to remove it from the refcount tree while not deleting it. Signed-off-by: Tao Ma <tao.ma@oracle.com>
2009-09-22ocfs2: Add CoW support.Tao Ma
This patch try CoW support for a refcounted record. the whole process will be: 1. Calculate how many clusters we need to CoW and where we start. Extents that are not completely encompassed by the write will be broken on 1MB boundaries. 2. Do CoW for the clusters with the help of page cache. 3. Change the b-tree structure with the new allocated clusters. Signed-off-by: Tao Ma <tao.ma@oracle.com>
2009-09-22ocfs2: Decrement refcount when truncating refcounted extents.Tao Ma
Add 'Decrement refcount for delete' in to the normal truncate process. So for a refcounted extent record, call refcount rec decrementation instead of cluster free. Signed-off-by: Tao Ma <tao.ma@oracle.com>
2009-09-22ocfs2: Add functions for extents refcounted.Tao Ma
Add function ocfs2_mark_extent_refcounted which can mark an extent refcounted. Signed-off-by: Tao Ma <tao.ma@oracle.com>
2009-09-22ocfs2: Add support of decrementing refcount for delete.Tao Ma
Given a physical cpos and length, decrement the refcount in the tree. If the refcount for any portion of the extent goes to zero, that portion is queued for freeing. Signed-off-by: Tao Ma <tao.ma@oracle.com>
2009-09-22ocfs2: move tree path functions to alloc.h.Tao Ma
Now fs/ocfs2/alloc.c has more than 7000 lines. It contains our basic b-tree operation. Although we have already make our b-tree operation generic, the basic structrue ocfs2_path which is used to iterate one b-tree branch is still static and limited to only used in alloc.c. As refcount tree need them and I don't want to add any more b-tree unrelated code to alloc.c, export them out. Signed-off-by: Tao Ma <tao.ma@oracle.com>
2009-09-22ocfs2: Add refcount b-tree as a new extent tree.Tao Ma
Add refcount b-tree as a new extent tree so that it can use the b-tree to store and maniuplate ocfs2_refcount_rec. Signed-off-by: Tao Ma <tao.ma@oracle.com>
2009-09-22ocfs2: Abstract extent split process.Tao Ma
ocfs2_mark_extent_written actually does the following things: 1. check the parameters. 2. initialize the left_path and split_rec. 3. call __ocfs2_mark_extent_written. it will do: 1) check the flags of unwritten 2) do the real split work. The whole process is packed tightly somehow. So this patch will abstract 2 different functions so that future b-tree operation can work with it. 1. __ocfs2_split_extent will accept path and split_rec and do the real split work. 2. ocfs2_change_extent_flag will accept a new flag and initialize path and split_rec. So now ocfs2_mark_extent_written will do: 1. check the parameters. 2. call ocfs2_change_extent_flag. 1) initalize the left_path and split_rec. 2) check whether the new flags conflict with the old one. 3) call __ocfs2_split_extent to do the split. Signed-off-by: Tao Ma <tao.ma@oracle.com>
2009-09-22ocfs2: Wrap ocfs2_extent_contig in ocfs2_extent_tree.Tao Ma
Add a new operation eo_ocfs2_extent_contig int the extent tree's operations vector. So that with the new refcount tree, We want this so that refcount trees can always return CONTIG_NONE and prevent extent merging. Signed-off-by: Tao Ma <tao.ma@oracle.com>
2009-09-04ocfs2: Pass ocfs2_caching_info into ocfs_init_*_extent_tree().Joel Becker
With this commit, extent tree operations are divorced from inodes and rely on ocfs2_caching_info. Phew! Signed-off-by: Joel Becker <joel.becker@oracle.com>
2009-09-04ocfs2: __ocfs2_mark_extent_written() doesn't need struct inode.Joel Becker
We only allow unwritten extents on data, so the toplevel ocfs2_mark_extent_written() can use an inode all it wants. But the subfunction isn't even using the inode argument. Signed-off-by: Joel Becker <joel.becker@oracle.com>
2009-09-04ocfs2: Teach ocfs2_replace_extent_rec() to use an extent_tree.Joel Becker
Don't use a struct inode anymore. Signed-off-by: Joel Becker <joel.becker@oracle.com>
2009-09-04ocfs2: ocfs2_split_and_insert() no longer needs struct inode.Joel Becker
It already has an extent_tree. Signed-off-by: Joel Becker <joel.becker@oracle.com>
2009-09-04ocfs2: ocfs2_remove_extent() no longer needs struct inode.Joel Becker
One more generic btree function that is isolated from struct inode. Signed-off-by: Joel Becker <joel.becker@oracle.com>
2009-09-04ocfs2: ocfs2_add_clusters_in_btree() no longer needs struct inode.Joel Becker
One more function that doesn't need a struct inode to pass to its children. Signed-off-by: Joel Becker <joel.becker@oracle.com>
2009-09-04ocfs2: ocfs2_insert_extent() no longer needs struct inode.Joel Becker
One more function down, no inode in the entire insert-extent chain. Signed-off-by: Joel Becker <joel.becker@oracle.com>
2009-09-04ocfs2: Make extent map insertion an extent_tree_operation.Joel Becker
ocfs2_insert_extent() wants to insert a record into the extent map if it's an inode data extent. But since many btrees can call that function, let's make it an op on ocfs2_extent_tree. Other tree types can leave it empty. Signed-off-by: Joel Becker <joel.becker@oracle.com>
2009-09-04ocfs2: ocfs2_figure_insert_type() no longer needs struct inode.Joel Becker
It's not using it, so remove it from the parameter list. Signed-off-by: Joel Becker <joel.becker@oracle.com>
2009-09-04ocfs2: Remove inode from ocfs2_figure_extent_contig().Joel Becker
It already has an ocfs2_extent_tree and doesn't need the inode. Signed-off-by: Joel Becker <joel.becker@oracle.com>
2009-09-04ocfs2: Swap inode for extent_tree in ocfs2_figure_merge_contig_type().Joel Becker
We don't want struct inode in generic btree operations. Signed-off-by: Joel Becker <joel.becker@oracle.com>
2009-09-04ocfs2: ocfs2_extent_contig() only requires the superblock.Joel Becker
Don't pass the inode in. We don't want it around for generic btree operations. Signed-off-by: Joel Becker <joel.becker@oracle.com>
2009-09-04ocfs2: ocfs2_do_insert_extent() and ocfs2_insert_path() no longer need an inode.Joel Becker
They aren't using it, so remove it from their parameter lists. Signed-off-by: Joel Becker <joel.becker@oracle.com>
2009-09-04ocfs2: Give ocfs2_split_record() an extent_tree instead of an inode.Joel Becker
Another on the way to generic btree functions. Signed-off-by: Joel Becker <joel.becker@oracle.com>
