Removing the local node configuration out from underneath a running
heartbeat is "bad". Provide an API in the ocfs2 nodemanager to request
a configfs dependancy on the local node, then use it in heartbeat.
Signed-off-by: Joel Becker <joel.becker@oracle.com>
Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
ocfs2 mounts require a heartbeat region. Use the new configfs_depend_item()
facility to actually depend on them so they can't go away from under us.
First, teach cluster/nodemanager.c to depend an item on the o2cb subsystem.
Then teach o2hb_register_callbacks to take a UUID and depend on the
appropriate region. Finally, teach all users of o2hb to pass a UUID or
NULL if they don't require a pin.
Convert the su_sem member of struct configfs_subsystem to a struct
mutex, as that's what it is. Also convert all the users and update
Documentation/configfs.txt and Documentation/configfs_example.c
accordingly.
[ Conflict in fs/dlm/config.c with commit
3168b0780d06ace875696f8a648d04d6089654e5 manually resolved. --Mark ]
Inspired-by: Satyam Sharma <ssatyam@cse.iitk.ac.in>
The semantic effect of insert_at_head is that it would allow new registered
sysctl entries to override existing sysctl entries of the same name. Which is
pain for caching and the proc interface never implemented.
I have done an audit and discovered that none of the current users of
register_sysctl care as (excpet for directories) they do not register
duplicate sysctl entries.
So this patch simply removes the support for overriding existing entries in
the sys_sysctl interface since no one uses it or cares and it makes future
enhancments harder.
Acked-by: Ralf Baechle <ralf@linux-mips.org>
Acked-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
Cc: "Luck, Tony" <tony.luck@intel.com>
Cc: Andi Kleen <ak@muc.de>
Cc: Corey Minyard <minyard@acm.org>
Cc: Neil Brown <neilb@suse.de>
Cc: "John W. Linville" <linville@tuxdriver.com>
Cc: James Bottomley <James.Bottomley@steeleye.com>
Cc: Jan Kara <jack@ucw.cz>
Cc: Trond Myklebust <trond.myklebust@fys.uio.no>
Cc: Mark Fasheh <mark.fasheh@oracle.com>
Cc: David Chinner <dgc@sgi.com>
Cc: Patrick McHardy <kaber@trash.net>
ocfs2 was did not have the binary number it uses under CTL_FS registered in
sysctl.h. Register it to avoid future conflicts, and change the name of the
definition to be in line with the rest of the sysctl numbers.
Acked-by: Mark Fasheh <mark.fasheh@oracle.com>
All kcalloc() calls of the form "kcalloc(1,...)" are converted to the
equivalent kzalloc() calls, and a few kcalloc() calls with the incorrect
ordering of the first two arguments are fixed.
Signed-off-by: Robert P. J. Day <rpjday@mindspring.com>
Cc: Jeff Garzik <jeff@garzik.org>
Cc: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Dominik Brodowski <linux@dominikbrodowski.net>
Cc: Adam Belay <ambx1@neo.rr.com>
Cc: Greg KH <greg@kroah.com>
Modify the OCFS2 handshake to ensure essential timeouts are configured
identically on all nodes.
Only allow changes when there are no connected peers
Improves the logic in o2net_advance_rx() which broke now that
sizeof(struct o2net_handshake) is greater than sizeof(struct o2net_msg)
Included is the field for userspace-heartbeat timeout to avoid the need for
further protocol changes.
Uses a global spinlock to ensure the decisions to update configfs entries
are made on the correct value. The region covered by the spinlock when
incrementing the counter is much larger as this is the more critical case.
Small cleanup contributed by Adrian Bunk <bunk@stusta.de>
Signed-off-by: Andrew Beekhof <abeekhof@suse.de>
Allow configuration of OCFS2 timeouts from userspace via configfs
Subsequent patches (namely userspace heartbeat and configurable timeouts)
require access to the o2nm_cluster struct. This patch does the necessary
shuffling.
This patch deletes redundant memcmp() while looking up in rb tree.
Signed-off-by: Akinbou Mita <akinobu.mita@gmail.com>
This patch finishes cleaning up the node manager allocations if it fails
to initialize.
Signed-off-by: Jeff Mahoney <jeffm@suse.com>
This patch converts the inode semaphore to a mutex. I have tested it on
XFS and compiled as much as one can consider on an ia64. Anyway your
luck with it might be different.
Modified-by: Ingo Molnar <mingo@elte.hu>
(finished the conversion)
Signed-off-by: Jes Sorensen <jes@sgi.com>
A simple node information service, filled and updated from
userspace. The rest of the stack queries this service for simple node
information.
Signed-off-by: Kurt Hackel <kurt.hackel@oracle.com>
