path: root/fs/ocfs2/ioctl.c
2011-05-25Merge branch 'move_extents' of git://oss.oracle.com/git/tye/linux-2.6 into ↵Joel Becker
ocfs2-merge-window Conflicts: fs/ocfs2/ioctl.c
2011-05-25Ocfs2/move_extents: move/defrag extents within a certain range.Tristan Ye
the basic logic of moving extents for a file is pretty like punching-hole sequence, walk the extents within the range as user specified, calculating an appropriate len to defrag/move, then let ocfs2_defrag/move_extent() to do the actual moving. This func ends up setting 'OCFS2_MOVE_EXT_FL_COMPLETE' to userpace if operation gets done successfully. Signed-off-by: Tristan Ye <tristan.ye@oracle.com>
2011-05-25Ocfs2: Add a new code 'OCFS2_INFO_FREEFRAG' for o2info ioctl.Tristan Ye
This new code is a bit more complicated than former ones, the goal is to show user all statistics required to take a deep insight into filesystem on how the disk is being fragmentaed. The goal is achieved by scaning global bitmap from (cluster)group to group to figure out following factors in the filesystem: - How many free chunks in a fixed size as user requested. - How many real free chunks in all size. - Min/Max/Avg size(in) clusters of free chunks. - How do free chunks distribute(in size) in terms of a histogram, just like following: --------------------------------------------------------- Extent Size Range : Free extents Free Clusters Percent 32K... 64K- : 1 1 0.00% 1M... 2M- : 9 288 0.03% 8M... 16M- : 2 831 0.09% 32M... 64M- : 1 2047 0.23% 128M... 256M- : 1 8191 0.92% 256M... 512M- : 2 21706 2.43% 512M... 1024M- : 27 858623 96.29% --------------------------------------------------------- Userspace ioctl() call eventually gets the above info returned by passing a 'struct ocfs2_info_freefrag' with the chunk_size being specified first. Signed-off-by: Tristan Ye <tristan.ye@oracle.com>
2011-05-25Ocfs2: Add a new code 'OCFS2_INFO_FREEINODE' for o2info ioctl.Tristan Ye
The new code is dedicated to calculate free inodes number of all inode_allocs, then return the info to userpace in terms of an array. Specially, flag 'OCFS2_INFO_FL_NON_COHERENT', manipulated by '--cluster-coherent' from userspace, is now going to be involved. setting the flag on means no cluster coherency considered, usually, userspace tools choose none-coherency strategy by default for the sake of performace. Signed-off-by: Tristan Ye <tristan.ye@oracle.com>
2011-05-25Ocfs2: Using inline funcs to set/clear *FILLED* flags in info handler.Tristan Ye
It just removes some macros for the sake of typechecking gains. Signed-off-by: Tristan Ye <tristan.ye@oracle.com>
2011-05-23ocfs2: Add FITRIM ioctl.Tao Ma
Add the corresponding ioctl function for FITRIM. Signed-off-by: Tao Ma <boyu.mt@taobao.com> Signed-off-by: Joel Becker <jlbec@evilplan.org>
2011-03-28Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2 * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2: (39 commits) Treat writes as new when holes span across page boundaries fs,ocfs2: Move o2net_get_func_run_time under CONFIG_OCFS2_FS_STATS. ocfs2/dlm: Move kmalloc() outside the spinlock ocfs2: Make the left masklogs compat. ocfs2: Remove masklog ML_AIO. ocfs2: Remove masklog ML_UPTODATE. ocfs2: Remove masklog ML_BH_IO. ocfs2: Remove masklog ML_JOURNAL. ocfs2: Remove masklog ML_EXPORT. ocfs2: Remove masklog ML_DCACHE. ocfs2: Remove masklog ML_NAMEI. ocfs2: Remove mlog(0) from fs/ocfs2/dir.c ocfs2: remove NAMEI from symlink.c ocfs2: Remove masklog ML_QUOTA. ocfs2: Remove mlog(0) from quota_local.c. ocfs2: Remove masklog ML_RESERVATIONS. ocfs2: Remove masklog ML_XATTR. ocfs2: Remove masklog ML_SUPER. ocfs2: Remove mlog(0) from fs/ocfs2/heartbeat.c ocfs2: Remove mlog(0) from fs/ocfs2/slot_map.c ... Fix up trivial conflict in fs/ocfs2/super.c
2011-03-28Merge branch 'mlog_replace_for_39' of git://repo.or.cz/taoma-kernel into ↵Joel Becker
ocfs2-merge-window-fix
2011-03-23userns: rename is_owner_or_cap to inode_owner_or_capableSerge E. Hallyn
And give it a kernel-doc comment. [akpm@linux-foundation.org: btrfs changed in linux-next] Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Daniel Lezcano <daniel.lezcano@free.fr> Acked-by: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-02-21ocfs2: remove INODE from unused files.Tao Ma
As there are no such debug information in fs/ocfs2/ioctl.c, fs/ocfs2/locks.c and fs/ocfs2/sysfile.c, ML_INODE are also removed. Signed-off-by: Tao Ma <boyu.mt@taobao.com>
2011-03-07ocfs2: Remove EXIT from masklog.Tao Ma
mlog_exit is used to record the exit status of a function. But because it is added in so many functions, if we enable it, the system logs get filled up quickly and cause too much I/O. So actually no one can open it for a production system or even for a test. This patch just try to remove it or change it. So: 1. if all the error paths already use mlog_errno, it is just removed. Otherwise, it will be replaced by mlog_errno. 2. if it is used to print some return value, it is replaced with mlog(0,...). mlog_exit_ptr is changed to mlog(0. All those mlog(0,...) will be replaced with trace events later. Signed-off-by: Tao Ma <boyu.mt@taobao.com>
2011-02-20Ocfs2: Using macro to set/clear *FILLED* flags in info handler.Tristan Ye
It's a best-effort attempt to simplize duplicated codes here. Signed-off-by: Tristan Ye <tristan.ye@oracle.com> Signed-off-by: Joel Becker <jlbec@evilplan.org>
2010-09-10Ocfs2: Add new OCFS2_IOC_INFO ioctl for ocfs2 v8.Tristan Ye
The reason why we need this ioctl is to offer the none-privileged end-user a possibility to get filesys info gathering. We use OCFS2_IOC_INFO to manipulate the new ioctl, userspace passes a structure to kernel containing an array of request pointers and request count, such as, * From userspace: struct ocfs2_info_blocksize oib = { .ib_req = { .ir_magic = OCFS2_INFO_MAGIC, .ir_code = OCFS2_INFO_BLOCKSIZE, ... } ... } struct ocfs2_info_clustersize oic = { ... } uint64_t reqs[2] = {(unsigned long)&oib, (unsigned long)&oic}; struct ocfs2_info info = { .oi_requests = reqs, .oi_count = 2, } ret = ioctl(fd, OCFS2_IOC_INFO, &info); * In kernel: Get the request pointers from *info*, then handle each request one bye one. Idea here is to make the spearated request small enough to guarantee a better backward&forward compatibility since a small piece of request would be less likely to be broken if filesys on raw disk get changed. Currently, the following 7 requests are supported per the requirement from userspace tool o2info, and I believe it will grow over time:-) OCFS2_INFO_CLUSTERSIZE OCFS2_INFO_BLOCKSIZE OCFS2_INFO_MAXSLOTS OCFS2_INFO_LABEL OCFS2_INFO_UUID OCFS2_INFO_FS_FEATURES OCFS2_INFO_JOURNAL_SIZE This ioctl is only specific to OCFS2. Signed-off-by: Tristan Ye <tristan.ye@oracle.com> Signed-off-by: Joel Becker <joel.becker@oracle.com>
2010-02-02ocfs2: Use compat_ptr in reflink_arguments.Tao Ma
Although we use u64 to pass userspace pointers to the kernel to avoid compat_ioctl, it doesn't work in some ppc platform. So wrap them with compat_ptr and add compat_ioctl. The detailed discussion about compat_ptr can be found in thread http://lkml.org/lkml/2009/10/27/423. We indeed met with a bug when testing on ppc(-EFAULT is returned when using old_path). This patch try to fix this. I have tested in ppc64(with 32 bit reflink) and x86_64(with i686 reflink), both works. Signed-off-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: Joel Becker <joel.becker@oracle.com>
2009-09-23Merge branch 'upstream-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2 * 'upstream-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2: (85 commits) ocfs2: Use buffer IO if we are appending a file. ocfs2: add spinlock protection when dealing with lockres->purge. dlmglue.c: add missed mlog lines ocfs2: __ocfs2_abort() should not enable panic for local mounts ocfs2: Add ioctl for reflink. ocfs2: Enable refcount tree support. ocfs2: Implement ocfs2_reflink. ocfs2: Add preserve to reflink. ocfs2: Create reflinked file in orphan dir. ocfs2: Use proper parameter for some inode operation. ocfs2: Make transaction extend more efficient. ocfs2: Don't merge in 1st refcount ops of reflink. ocfs2: Modify removing xattr process for refcount. ocfs2: Add reflink support for xattr. ocfs2: Create an xattr indexed block if needed. ocfs2: Call refcount tree remove process properly. ocfs2: Attach xattr clusters to refcount tree. ocfs2: Abstract ocfs2 xattr tree extend rec iteration process. ocfs2: Abstract the creation of xattr block. ocfs2: Remove inode from ocfs2_xattr_bucket_get_name_value. ...
2009-09-22ocfs2: Add ioctl for reflink.Tao Ma
The ioctl will take 3 parameters: old_path, new_path and preserve and call vfs_reflink. It is useful when we backport reflink features to old kernels. Signed-off-by: Tao Ma <tao.ma@oracle.com>
2009-07-12headers: smp_lock.h reduxAlexey Dobriyan
* Remove smp_lock.h from files which don't need it (including some headers!) * Add smp_lock.h to files which do need it * Make smp_lock.h include conditional in hardirq.h It's needed only for one kernel_locked() usage which is under CONFIG_PREEMPT This will make hardirq.h inclusion cheaper for every PREEMPT=n config (which includes allmodconfig/allyesconfig, BTW) Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13ocfs2: Don't check for NULL before brelse()Mark Fasheh
This is pointless as brelse() already does the check. Signed-off-by: Mark Fasheh
2008-04-19[PATCH] r/o bind mounts: elevate write count for ioctls()Dave Hansen
Some ioctl()s can cause writes to the filesystem. Take these, and make them use mnt_want/drop_write() instead. [AV: updated] Acked-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-18ocfs2: Convert ocfs2 over to unlocked_ioctlAndi Kleen
As far as I can see there is nothing in ocfs2_ioctl that requires the BKL, so use unlocked_ioctl Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-04-18ocfs2: Move o2hb functionality into the stack glue.Joel Becker
The last bit of classic stack used directly in ocfs2 code is o2hb. Specifically, the check for heartbeat during mount and the call to ocfs2_hb_ctl during unmount. We create an extra API, ocfs2_cluster_hangup(), to encapsulate the call to ocfs2_hb_ctl. Other stacks will just leave hangup() empty. The check for heartbeat is moved into ocfs2_cluster_connect(). It will be matched by a similar check for other stacks. With this change, only stackglue.c includes cluster/ headers. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-01-25ocfs2: Add missing permission checksMark Fasheh
Check that an online resize is being driven by a user with permission to change system resource limits. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2008-01-25[PATCH 2/2] ocfs2: Implement group add for online resizeTao Ma
This patch adds the ability for a userspace program to request that a properly formatted cluster group be added to the main allocation bitmap for an Ocfs2 file system. The request is made via an ioctl, OCFS2_IOC_GROUP_ADD. On a high level, this is similar to ext3, but we use a different ioctl as the structure which has to be passed through is different. During an online resize, tunefs.ocfs2 will format any new cluster groups which must be added to complete the resize, and call OCFS2_IOC_GROUP_ADD on each one. Kernel verifies that the core cluster group information is valid and then does the work of linking it into the global allocation bitmap. Signed-off-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2008-01-25[PATCH 1/2] ocfs2: Add group extend for online resizeTao Ma
This patch adds the ability for a userspace program to request an extend of last cluster group on an Ocfs2 file system. The request is made via ioctl, OCFS2_IOC_GROUP_EXTEND. This is derived from EXT3_IOC_GROUP_EXTEND, but is obviously Ocfs2 specific. tunefs.ocfs2 would call this for an online-resize operation if the last cluster group isn't full. Signed-off-by: Tao Ma <tao.ma@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2008-01-25ocfs2: Rename ocfs2_meta_[un]lockMark Fasheh
Call this the "inode_lock" now, since it covers both data and meta data. This patch makes no functional changes. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-07-17Introduce is_owner_or_cap() to wrap CAP_FOWNER use with fsuid checkSatyam Sharma
Introduce is_owner_or_cap() macro in fs.h, and convert over relevant users to it. This is done because we want to avoid bugs in the future where we check for only effective fsuid of the current task against a file's owning uid, without simultaneously checking for CAP_FOWNER as well, thus violating its semantics. [ XFS uses special macros and structures, and in general looked ... untouchable, so we leave it alone -- but it has been looked over. ] The (current->fsuid != inode->i_uid) check in generic_permission() and exec_permission_lite() is left alone, because those operations are covered by CAP_DAC_OVERRIDE and CAP_DAC_READ_SEARCH. Similarly operations falling under the purview of CAP_CHOWN and CAP_LEASE are also left alone. Signed-off-by: Satyam Sharma <ssatyam@cse.iitk.ac.in> Cc: Al Viro <viro@ftp.linux.org.uk> Acked-by: Serge E. Hallyn <serge@hallyn.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-10ocfs2: Support xfs style space reservation ioctlsMark Fasheh
We re-use the RESVSP/UNRESVSP ioctls from xfs which allow the user to allocate and deallocate regions to a file without zeroing data or changing i_size. Though renamed, the structure passed in from user is identical to struct xfs_flock64. The three fields that are actually used right now are l_whence, l_start and l_len. This should get ocfs2 immediate compatibility with userspace software using the pre-existing xfs ioctls. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-05-02[PATCH] Copy i_flags to ocfs2 inode flags on writeJan Kara
Propagate flags such as S_APPEND, S_IMMUTABLE, etc. from i_flags into ocfs2-specific ip_attr. Hence, when someone sets these flags via a different interface than ioctl, they are stored correctly. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-05-02ocfs2: Implement compat_ioctl()Mark Fasheh
We need this to support 32 bit system calls on 64 bit kernels. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-12-01ocfs2: Remove struct ocfs2_journal_handle in favor of handle_tMark Fasheh
This is mostly a search and replace as ocfs2_journal_handle is now no more than a container for a handle_t pointer. ocfs2_commit_trans() becomes very straight forward, and we remove some out of date comments / code. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-12-01ocfs2: remove handle argument to ocfs2_start_trans()Mark Fasheh
All callers either pass in NULL directly, or a local variable that is already set to NULL. The internals of ocfs2_start_trans() get a nice cleanup as a result. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-12-01ocfs2: pass ocfs2_super * into ocfs2_commit_trans()Mark Fasheh
This sets us up to remove handle->journal. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-12-01ocfs2: remove unused handle argument from ocfs2_meta_lock_full()Mark Fasheh
Now that this is unused and all callers pass NULL, we can safely remove it. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-09-20[PATCH] fs/ocfs2/ioctl.c should #include "ioctl.h"Adrian Bunk
Every file should #include the headers containing the prototypes for its global functions. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-09-20ocfs2: add ext2 attributesHerbert Poetzl
Support immutable, and other attributes. Some renaming and other minor fixes done by myself. Signed-off-by: Herbert Poetzl <herbert@13thfloor.at> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
