path: root/fs/ocfs2/stack_o2cb.c
2013-02-21ocfs2: remove kfree() redundant null checksTim Gardner
smatch analysis indicates a number of redundant NULL checks before calling kfree(), eg: fs/ocfs2/alloc.c:6138 ocfs2_begin_truncate_log_recovery() info: redundant null check on *tl_copy calling kfree() fs/ocfs2/alloc.c:6755 ocfs2_zero_range_for_truncate() info: redundant null check on pages calling kfree() etc.... [akpm@linux-foundation.org: revert dubious change in ocfs2_begin_truncate_log_recovery()] Signed-off-by: Tim Gardner <tim.gardner@canonical.com> Cc: Mark Fasheh <mfasheh@suse.com> Acked-by: Joel Becker <jlbec@evilplan.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-24ocfs2/cluster: Cluster up now includes network connections tooSunil Mushran
The cluster up check only checks to see if the node is heartbeating or not. If yes it continues assuming that the node is connected to all the nodes. But if that is not the case, the cluster join aborts with a stack of errors that are not easy to comprehend. This patch adds the network connect check upfront and prints the nodes that the node is not yet connected to, before aborting. Signed-off-by: Sunil Mushran <sunil.mushran@oracle.com>
2011-07-24ocfs2: Clean up messages in stack_o2cb.cSunil Mushran
o2cb messages needed a facelift. Signed-off-by: Sunil Mushran <sunil.mushran@oracle.com>
2010-10-06ocfs2: Print message if user mounts without starting global heartbeatSunil Mushran
In global heartbeat mode, the heartbeat is started by the user. This patch prints an error if the user attempts to mount a volume without starting the heartbeat. Signed-off-by: Sunil Mushran <sunil.mushran@oracle.com>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-02-26ocfs2: Hang the locking proto on the cluster conn and use it in asts.Joel Becker
With the ocfs2_cluster_connection hanging off of the ocfs2_dlm_lksb, we have access to it in the ast and bast wrapper functions. Attach the ocfs2_locking_protocol to the conn. Now, instead of refering to a static variable for ast/bast pointers, the wrappers can look at the connection. This means different connections can have different ast/bast pointers, and it reduces the need for the static pointer. Signed-off-by: Joel Becker <joel.becker@oracle.com>
2010-02-26ocfs2: Attach the connection to the lksbJoel Becker
We're going to want it in the ast functions, so we convert union ocfs2_dlm_lksb to struct ocfs2_dlm_lksb and let it carry the connection. Signed-off-by: Joel Becker <joel.becker@oracle.com>
2010-02-26ocfs2: Pass lksbs back from stackglue ast/bast functions.Joel Becker
The stackglue ast and bast functions tried to maintain the fiction that their arguments were void pointers. In reality, stack_user.c had to know that the argument was an ocfs2_lock_res in order to get the status off of the lksb. That's ugly. This changes stackglue to always pass the lksb as the argument to ast and bast functions. The caller can always use container_of() to get the ocfs2_lock_res or user_dlm_lock_res. The net effect to the caller is zero. They still get back the lockres in their ast. stackglue gets cleaner, and now can use the lksb itself. Signed-off-by: Joel Becker <joel.becker@oracle.com>
2010-01-25ocfs2: fix a misleading variable nameWengang Wang
a local variable "dlm_version" is used as a fs locking version. rename it fs_version. Signed-off-by: Wengang Wang <wen.gang.wang@oracle.com> Signed-off-by: Joel Becker <joel.becker@oracle.com>
2009-08-07ocfs2: keep index within status_map[]Roel Kluin
Do not exceed array status_map[] Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Cc: Mark Fasheh <mfasheh@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Joel Becker <joel.becker@oracle.com>
2009-06-22ocfs2: Provide the ocfs2_dlm_lvb_valid() stack API.Joel Becker
The Lock Value Block (LVB) of a DLM lock can be lost when nodes die and the DLM cannot reconstruct its state. Clients of the DLM need to know this. ocfs2's internal DLM, o2dlm, explicitly zeroes out the LVB when it loses track of the state. This is not a standard behavior, but ocfs2 has always relied on it. Thus, an o2dlm LVB is always "valid". ocfs2 now supports both o2dlm and fs/dlm via the stack glue. When fs/dlm loses track of an LVBs state, it sets a flag (DLM_SBF_VALNOTVALID) on the Lock Status Block (LKSB). The contents of the LVB may be garbage or merely stale. ocfs2 doesn't want to try to guess at the validity of the stale LVB. Instead, it should be checking the VALNOTVALID flag. As this is the 'standard' way of treating LVBs, we will promote this behavior. We add a stack glue API ocfs2_dlm_lvb_valid(). It returns non-zero when the LVB is valid. o2dlm will always return valid, while fs/dlm will check VALNOTVALID. Signed-off-by: Joel Becker <joel.becker@oracle.com> Acked-by: Mark Fasheh <mfasheh@suse.com>
2008-06-16ocfs2: Remove ->hangup() from stack glue operations.Joel Becker
The ->hangup() call was only used to execute ocfs2_hb_ctl. Now that the generic stack glue code handles this, the underlying stack drivers don't need to know about it. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-06-16ocfs2: Move the call of ocfs2_hb_ctl into the stack glue.Joel Becker
Take o2hb_stop() out of the o2cb code and make it part of the generic stack glue as ocfs2_leave_group(). This also allows us to remove the ocfs2_get_hb_ctl_path() function - everything to do with hb_ctl is now part of stackglue.c. o2cb no longer needs a ->hangup() function. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-06-16ocfs2: Move the hb_ctl_path sysctl into the stack glue.Joel Becker
ocfs2 needs to call out to the hb_ctl program at unmount for all cluster stacks. The first step is to move the hb_ctl_path sysctl out of the o2cb code and into the generic stack glue. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-04-30ocfs2: make struct o2cb_stack_ops staticAdrian Bunk
This patch makes the needlessly global struct o2cb_stack_ops static. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
2008-04-18ocfs2: Break out stackglue into modules.Joel Becker
We define the ocfs2_stack_plugin structure to represent a stack driver. The o2cb stack code is split into stack_o2cb.c. This becomes the ocfs2_stack_o2cb.ko module. The stackglue generic functions are similarly split into the ocfs2_stackglue.ko module. This module now provides an interface to register drivers. The ocfs2_stack_o2cb driver registers itself. As part of this interface, ocfs2_stackglue can load drivers on demand. This is accomplished in ocfs2_cluster_connect(). ocfs2_cluster_disconnect() is now notified when a _hangup() is pending. If a hangup is pending, it will not release the driver module and will let _hangup() do that. Signed-off-by: Joel Becker <joel.becker@oracle.com>
2008-04-18ocfs2: Create ocfs2_stack_operations and split out the o2cb stack.Joel Becker
Define the ocfs2_stack_operations structure. Build o2cb_stack_ops from all of the o2cb-specific stack functions. Change the generic stack glue functions to call the stack_ops instead of the o2cb functions directly. The o2cb functions are moved to stack_o2cb.c. The headers are cleaned up to where only needed headers are included. In this code, stackglue.c and stack_o2cb.c refer to some shared extern variables. When they become modules, that will change. Signed-off-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Mark Fasheh <mfasheh@suse.com>
