path: root/fs/ocfs2/super.h
2010-05-10ocfs2: Wrap signal blocking in void functions.Joel Becker
ocfs2 sometimes needs to block signals around dlm operations, but it currently does it with sigprocmask(). Even worse, it's checking the error code of sigprocmask(). The in-kernel sigprocmask() can only error if you get the SIG_* argument wrong. We don't. Wrap the sigprocmask() calls with ocfs2_[un]block_signals(). These functions are void, but they will BUG() if somehow sigprocmask() returns an error. Signed-off-by: Joel Becker <joel.becker@oracle.com>
2007-08-09ocfs2: use s_maxbytes directly in ocfs2_change_file_space()Mark Fasheh
There's no need to recalculate things via ocfs2_max_file_offset() as we've already done that to fill s_maxbytes, so use that instead. We can also un-export ocfs2_max_file_offset() then. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-07-10ocfs2: Support xfs style space reservation ioctlsMark Fasheh
We re-use the RESVSP/UNRESVSP ioctls from xfs which allow the user to allocate and deallocate regions to a file without zeroing data or changing i_size. Though renamed, the structure passed in from user is identical to struct xfs_flock64. The three fields that are actually used right now are l_whence, l_start and l_len. This should get ocfs2 immediate compatibility with userspace software using the pre-existing xfs ioctls. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-03-24ocfs2: use __attribute__ formatMark Fasheh
Use the "format" attribute on ocfs2_error() and ocfs2_abort() so that the compiler will warn when we get calls to those functions wrong. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2006-01-03[PATCH] OCFS2: The Second Oracle Cluster FilesystemMark Fasheh
The OCFS2 file system module. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Kurt Hackel <kurt.hackel@oracle.com>
