commit 72094e43e3af5020510f920321d71f1798fa896d upstream.
le16, not le32...
Cc: Mark Fasheh <mfasheh@suse.com>
commit 28748b325dc2d730ccc312830a91c4ae0c0d9379 upstream.
le16, not le32...
commit e1bf4cc620fd143766ddfcee3b004a1d1bb34fd0 upstream.
it's le16, not le32 or le64...
commit 3a251f04fe97c3d335b745c98e4b377e3c3899f2 upstream.
It's le16, not le32...
Caching "we have already removed suid/caps" was overenthusiastic as merged.
On network filesystems we might have had suid/caps set on another client,
silently picked by this client on revalidate, all of that *without* clearing
the S_NOSEC flag.
AFAICS, the only reasonably sane way to deal with that is
* new superblock flag; unless set, S_NOSEC is not going to be set.
* local block filesystems set it in their ->mount() (more accurately,
mount_bdev() does, so does btrfs ->mount(), users of mount_bdev() other than
local block ones clear it)
* if any network filesystem (or a cluster one) wants to use S_NOSEC,
it'll need to set MS_NOSEC in sb->s_flags *AND* take care to clear S_NOSEC when
inode attribute changes are picked from other clients.
It's not an earth-shattering hole (anybody that can set suid on another client
will almost certainly be able to write to the file before doing that anyway),
but it's a bug that needs fixing.
git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2
* 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2:
Ocfs2/move_extents: Validate moving goal after the adjustment.
Ocfs2/move_extents: Avoid doing division in extent moving.
ocfs2-merge-window
though the goal_to_be_moved will be validated again in following moving, it's
still a good idea to validate it after adjustment at the very beginning, instead
of validating it before adjustment.
Signed-off-by: Tristan Ye <tristan.ye@oracle.com>
It's not wise enough to do a 64bits division anywhere in kernside, replace it
with a decent helper or proper shifts.
* 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jlbec/ocfs2: (28 commits)
Ocfs2: Teach local-mounted ocfs2 to handle unwritten_extents correctly.
ocfs2/dlm: Do not migrate resource to a node that is leaving the domain
ocfs2/dlm: Add new dlm message DLM_BEGIN_EXIT_DOMAIN_MSG
Ocfs2/move_extents: Set several trivial constraints for threshold.
Ocfs2/move_extents: Let defrag handle partial extent moving.
Ocfs2/move_extents: move/defrag extents within a certain range.
Ocfs2/move_extents: helper to calculate the defraging length in one run.
Ocfs2/move_extents: move entire/partial extent.
Ocfs2/move_extents: helpers to update the group descriptor and global bitmap inode.
Ocfs2/move_extents: helper to probe a proper region to move in an alloc group.
Ocfs2/move_extents: helper to validate and adjust moving goal.
Ocfs2/move_extents: find the victim alloc group, where the given #blk fits.
Ocfs2/move_extents: defrag a range of extent.
Ocfs2/move_extents: move a range of extent.
Ocfs2/move_extents: lock allocators and reserve metadata blocks and data clusters for extents moving.
Ocfs2/move_extents: Add basic framework and source files for extent moving.
Ocfs2/move_extents: Adding new ioctl code 'OCFS2_IOC_MOVE_EXT' to ocfs2.
Ocfs2/refcounttree: Publicize couple of funcs from refcounttree.c
Ocfs2: Add a new code 'OCFS2_INFO_FREEFRAG' for o2info ioctl.
Ocfs2: Add a new code 'OCFS2_INFO_FREEINODE' for o2info ioctl.
git://git.kernel.org/pub/scm/linux/kernel/git/djm/tmem
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/djm/tmem:
xen: cleancache shim to Xen Transcendent Memory
ocfs2: add cleancache support
ext4: add cleancache support
btrfs: add cleancache support
ext3: add cleancache support
mm/fs: add hooks to support cleancache
mm: cleancache core ops functions and config
fs: add field to superblock to support cleancache
mm/fs: cleancache documentation
Fix up trivial conflict in fs/btrfs/extent_io.c due to includes
This eighth patch of eight in this cleancache series "opts-in"
cleancache for ocfs2. Clustered filesystems must explicitly enable
cleancache by calling cleancache_init_shared_fs anytime an instance
of the filesystem is mounted. Ocfs2 is currently the only user of
the clustered filesystem interface but nevertheless, the cleancache
hooks in the VFS layer are sufficient for ocfs2 including the matching
cleancache_flush_fs hook which must be called on unmount.
Details and a FAQ can be found in Documentation/vm/cleancache.txt
[v8: trivial merge conflict update]
[v5: jeremy@goop.org: simplify init hook and any future fs init changes]
Signed-off-by: Dan Magenheimer <dan.magenheimer@oracle.com>
Signed-off-by: Joel Becker <joel.becker@oracle.com>
Reviewed-by: Jeremy Fitzhardinge <jeremy@goop.org>
Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
Cc: Al Viro <viro@ZenIV.linux.org.uk>
Cc: Matthew Wilcox <matthew@wil.cx>
Cc: Nick Piggin <npiggin@kernel.dk>
Cc: Rik Van Riel <riel@redhat.com>
Cc: Jan Beulich <JBeulich@novell.com>
Cc: Chris Mason <chris.mason@oracle.com>
Cc: Andreas Dilger <adilger@sun.com>
Cc: Ted Tso <tytso@mit.edu>
Cc: Nitin Gupta <ngupta@vflare.org>
ocfs2-merge-window
fs/ocfs2/ioctl.c
Oops, local-mounted of 'ocfs2_fops_no_plocks' is just missing the support
of unwritten_extents/punching-hole due to no func pointer was given correctly
to '.follocate' field.
During dlm domain shutdown, o2dlm has to free all the lock resources. Ones that
have no locks and references are freed. Ones that have locks and/or references
are migrated to another node.
The first task in migration is finding a target. Currently we scan the lock
resource and find one node that either has a lock or a reference. This is not
very efficient in a parallel umount case as we might end up migrating the
lock resource to a node which itself may have to migrate it to a third node.
The patch scans the dlm->exit_domain_map to ensure the target node is not
leaving the domain. If no valid target node is found, o2dlm does not migrate
the resource but instead waits for the unlock and deref messages that will
allow it to free the resource.
Signed-off-by: Sunil Mushran <sunil.mushran@oracle.com>
Signed-off-by: Joel Becker <jlbec@evilplan.org>
This patch adds a new dlm message DLM_BEGIN_EXIT_DOMAIN_MSG and ups the dlm
protocol to 1.2.
o2dlm sends this new message in dlm_unregister_domain() to mark the beginning
of the exit domain. This message is sent to all nodes in the domain.
Currently o2dlm has no way of informing other nodes of its impending exit.
This information is useful as the other nodes could disregard the exiting
node in certain operations. For example, in resource migration. If two or
more nodes were umounting in parallel, it would be more efficient if o2dlm
were to choose a non-exiting node to be the new master node rather than an
exiting one.
Reviewed-by: Mark Fasheh <mfasheh@suse.com>
The threshold should be greater than clustersize and less than i_size.
We're going to support partial extent moving, which may split entire extent
movement into pieces to compromise the insuffice allocations, it eases the
'ENSPC' pain and makes the whole moving much less likely to fail, the downside
is it may make the fs even more fragmented before moving, just let the userspace
make a trade-off here.
the basic logic of moving extents for a file is pretty like punching-hole
sequence, walk the extents within the range as user specified, calculating
an appropriate len to defrag/move, then let ocfs2_defrag/move_extent() to
do the actual moving.
This func ends up setting 'OCFS2_MOVE_EXT_FL_COMPLETE' to userpace if operation
gets done successfully.
The helper is to calculate the defrag length in one run according to a threshold,
it will proceed doing defragmentation until the threshold was meet, and skip a
LARGE extent if any.
ocfs2_move_extent() logic will validate the goal_offset_in_block,
where extents to be moved, what's more, it also compromises a bit
to probe the appropriate region around given goal_offset when the
original goal is not able to fit the movement.
inode.
These helpers were actually borrowed from alloc.c, which may be publicized
later.
Before doing the movement of extents, we'd better probe the alloc group from
'goal_blk' for searching a contiguous region to fit the wanted movement, we
even will have a best-effort try by compromising to a threshold around the
given goal.
First best-effort attempt to validate and adjust the goal (physical address in
block), while it can't guarantee later operation can succeed all the time since
global_bitmap may change a bit over time.
This function tries locate the right alloc group, where a given physical block
resides, it returns the caller a buffer_head of victim group descriptor, and also
the offset of block in this group, by passing the block number.
It's a relatively complete function to accomplish defragmentation for entire
or partial extent, one journal handle was kept during the operation, it was
logically doing one more thing than ocfs2_move_extent() acutally, yes, it's
claiming the new clusters itself;-)
The moving range of __ocfs2_move_extent() was within one extent always, it
consists following parts:
1. Duplicates the clusters in pages to new_blkoffset, where extent to be moved.
2. Split the original extent with new extent, coalecse the nearby extents if possible.
3. Append old clusters to truncate log, or decrease_refcount if the extent was refcounted.
ocfs2_lock_allocators_move_extents() was like the common ocfs2_lock_allocators(),
to lock metadata and data alloctors during extents moving, reserve appropriate
metadata blocks and data clusters, also performa a best- effort to calculate the
credits for journal transaction in one run of movement.
Adding new files move_extents.[c|h] and fill it with nothing but
only a context structure.
Patch also manages to add a manipulative struture for this ioctl.
The original goal of commonizing these funcs is to benefit defraging/extent_moving
codes in the future, based on the fact that reflink and defragmentation having
the same Copy-On-Wrtie mechanism.
This new code is a bit more complicated than former ones, the goal is to
show user all statistics required to take a deep insight into filesystem
on how the disk is being fragmentaed.
The goal is achieved by scaning global bitmap from (cluster)group to group
to figure out following factors in the filesystem:
- How many free chunks in a fixed size as user requested.
- How many real free chunks in all size.
- Min/Max/Avg size(in) clusters of free chunks.
- How do free chunks distribute(in size) in terms of a histogram,
just like following:
Extent Size Range : Free extents Free Clusters Percent
32K... 64K- : 1 1 0.00%
1M... 2M- : 9 288 0.03%
8M... 16M- : 2 831 0.09%
32M... 64M- : 1 2047 0.23%
128M... 256M- : 1 8191 0.92%
256M... 512M- : 2 21706 2.43%
512M... 1024M- : 27 858623 96.29%
Userspace ioctl() call eventually gets the above info returned by passing
a 'struct ocfs2_info_freefrag' with the chunk_size being specified first.
The new code is dedicated to calculate free inodes number of all inode_allocs,
then return the info to userpace in terms of an array.
Specially, flag 'OCFS2_INFO_FL_NON_COHERENT', manipulated by '--cluster-coherent'
from userspace, is now going to be involved. setting the flag on means no cluster
coherency considered, usually, userspace tools choose none-coherency strategy by
default for the sake of performace.
It just removes some macros for the sake of typechecking gains.
Change function param_set_dlmfs_capabilities from 'extern' to 'static' since
function param_get_dlmfs_capabilities is also 'static'.
Signed-off-by: Robin Dong <sanbai@taobao.com>
Patch cleans up the gunk added by commit 388c4bcb4e63e88fb1f312a2f5f9eb2623afcf5b.
dlm_is_lockres_migrateable() now returns 1 if lockresource is deemed
migrateable and 0 if not.
Add the corresponding trace event for trim.
Signed-off-by: Tao Ma <boyu.mt@taobao.com>
Add the corresponding ioctl function for FITRIM.
Add ocfs2_trim_fs to support trimming freed clusters in the
volume. A range will be given and all the freed clusters greater
than minlen will be discarded to the block layer.
It is obsoleted since Dec 2005.
Signed-off-by: WANG Cong <amwang@redhat.com>
As ocfs2 supports relatime and strictatime, we need update the
relative document. Atime_quantum need work with strictatime, so only
show it in procfs when mount with strictatime.
Signed-off-by: Tiger Yang <tiger.yang@oracle.com>
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (39 commits)
b43: fix comment typo reqest -> request
Haavard Skinnemoen has left Atmel
cris: typo in mach-fs Makefile
Kconfig: fix copy/paste-ism for dell-wmi-aio driver
doc: timers-howto: fix a typo ("unsgined")
perf: Only include annotate.h once in tools/perf/util/ui/browsers/annotate.c
md, raid5: Fix spelling error in comment ('Ofcourse' --> 'Of course').
treewide: fix a few typos in comments
regulator: change debug statement be consistent with the style of the rest
Revert "arm: mach-u300/gpio: Fix mem_region resource size miscalculations"
audit: acquire creds selectively to reduce atomic op overhead
rtlwifi: don't touch with treewide double semicolon removal
treewide: cleanup continuations and remove logging message whitespace
ath9k_hw: don't touch with treewide double semicolon removal
include/linux/leds-regulator.h: fix syntax in example code
tty: fix typo in descripton of tty_termios_encode_baud_rate
xtensa: remove obsolete BKL kernel option from defconfig
m68k: fix comment typo 'occcured'
arch:Kconfig.locks Remove unused config option.
treewide: remove extra semicolons
During resource migration, if the target node were to die, the thread doing
the migration spins until the target node is not removed from the domain map.
This patch slows the spin by making the thread wait for the recovery to kick in.
Patch skips mount recovery for hard-ro mounts which otherwise leads to an oops.
Acked-by: Mark Fasheh <mfasheh@suse.com>
If o2hb finds unexpected values in the heartbeat slot, it prints a message
"ERROR: Device "dm-6": another node is heartbeating in our slot!"
This message could be misleading. This patch adds two more messages to
help users better diagnose the problem.
We have seen isolated cases (very few, I might add) of o2hb not detecting all
live nodes on startup. One plausible reasoning for it is that other node had
a hb io delay at the same time. The live threshold set at 2 (as low as it can
be) could be increased to ameliorate the situation.
But increasing the threshold directly affects mount time. Currently it takes
around 5 secs to mount a volume in o2cb cluster with local heartbeat. Increasing
the threshold will make mounts even slower. As the issue itself is rare, we have
left things as they are for the local heartbeat mode.
However we can improve the situation for global heartbeat mode as in that mode,
we start the heartbeat much before the mount.
This patch doubles the live threshold for the start of the first region in
global heartbeat mode.
Addresses internal Oracle bug#10635585.
Patch fixes a bug in the o2dlm protocol negotiation in that it is using
the builtin version rather than the negotiated version during the domain
join. This causes join errors when a node having kernel >= 2.6.37 joins
a cluster with nodes having kernels < 2.6.37.
This only affects the o2cb cluster stack.
Reported-by: Jacek Stepniewski <Jacek.Stepniewski@agora.pl>
codes.
In the case of removing a partial extent record which covers a hole, current
punching-hole logic will try to remove more than the length of whole extent
record, which leads to the failure of following assert(fs/ocfs2/alloc.c):
5507 BUG_ON(cpos < le32_to_cpu(rec->e_cpos) || trunc_range > rec_range);
This patch tries to skip existing hole at the last attempt of removing a partial
extent record, what's more, it also adds some necessary comments for better
understanding of punching-hole codes.
CLANG found that there is a path that has data_ac uninitialized,
this place
2917 /* This gets us the dx_root */
2918 ret = ocfs2_reserve_new_metadata_blocks(osb, 1, &meta_ac);
2919 if (ret) {
3
Taking true branch
2920 mlog_errno(ret);
2921 goto out;
4
Control jumps to line 3168
2922 }
Goes to the out: label without data_ac being initialized.
Ciao, Marcus
Signed-Off-By: Marcus Meissner <meissner@suse.de>
Signed-off-by: Mark Fasheh <mfasheh@suse.com>
These changes were incorrectly fixed by codespell. They were now
manually corrected.
