commit 33496c3c3d7b88dcbe5e55aa01288b05646c6aca upstream.
Configfs is the interface for ocfs2-tools to set configure to kernel and
$configfs_dir/cluster/$clustername/heartbeat/dead_threshold is the one
used to configure heartbeat dead threshold. Kernel has a default value
of it but user can set O2CB_HEARTBEAT_THRESHOLD in /etc/sysconfig/o2cb
to override it.
Commit 45b997737a80 ("ocfs2/cluster: use per-attribute show and store
methods") changed heartbeat dead threshold name while ocfs2-tools did
not, so ocfs2-tools won't set this configurable and the default value is
always used. So revert it.
Fixes: 45b997737a80 ("ocfs2/cluster: use per-attribute show and store methods")
Link: http://lkml.kernel.org/r/1490665245-15374-1-git-send-email-junxiao.bi@oracle.com
Signed-off-by: Junxiao Bi <junxiao.bi@oracle.com>
Acked-by: Joseph Qi <jiangqi903@gmail.com>
Cc: Mark Fasheh <mfasheh@versity.com>
commit 93407472a21b82f39c955ea7787e5bc7da100642 upstream.
Replace all 1 << inode->i_blkbits and (1 << inode->i_blkbits) in fs
branch.
This patch also fixes multiple checkpatch warnings: WARNING: Prefer
'unsigned int' to bare use of 'unsigned'
Thanks to Andrew Morton for suggesting more appropriate function instead
of macro.
[geliangtang@gmail.com: truncate: use i_blocksize()]
Link: http://lkml.kernel.org/r/9c8b2cd83c8f5653805d43debde9fa8817e02fc4.1484895804.git.geliangtang@gmail.com
Link: http://lkml.kernel.org/r/1481319905-10126-1-git-send-email-fabf@skynet.be
Signed-off-by: Fabian Frederick <fabf@skynet.be>
Signed-off-by: Geliang Tang <geliangtang@gmail.com>
Cc: Ross Zwisler <ross.zwisler@linux.intel.com>
commit e7ee2c089e94067d68475990bdeed211c8852917 upstream.
The crash happens rather often when we reset some cluster nodes while
nodes contend fiercely to do truncate and append.
The crash backtrace is below:
dlm: C21CBDA5E0774F4BA5A9D4F317717495: dlm_recover_grant 1 locks on 971 resources
dlm: C21CBDA5E0774F4BA5A9D4F317717495: dlm_recover 9 generation 5 done: 4 ms
ocfs2: Begin replay journal (node 318952601, slot 2) on device (253,18)
ocfs2: End replay journal (node 318952601, slot 2) on device (253,18)
ocfs2: Beginning quota recovery on device (253,18) for slot 2
ocfs2: Finishing quota recovery on device (253,18) for slot 2
(truncate,30154,1):ocfs2_truncate_file:470 ERROR: bug expression: le64_to_cpu(fe->i_size) != i_size_read(inode)
(truncate,30154,1):ocfs2_truncate_file:470 ERROR: Inode 290321, inode i_size = 732 != di i_size = 937, i_flags = 0x1
kernel BUG at /usr/src/linux/fs/ocfs2/file.c:470!
invalid opcode: 0000 [#1] SMP
Modules linked in: ocfs2_stack_user(OEN) ocfs2(OEN) ocfs2_nodemanager ocfs2_stackglue(OEN) quota_tree dlm(OEN) configfs fuse sd_mod iscsi_tcp libiscsi_tcp libiscsi scsi_transport_iscsi af_packet iscsi_ibft iscsi_boot_sysfs softdog xfs libcrc32c ppdev parport_pc pcspkr parport joydev virtio_balloon virtio_net i2c_piix4 acpi_cpufreq button processor ext4 crc16 jbd2 mbcache ata_generic cirrus virtio_blk ata_piix drm_kms_helper ahci syscopyarea libahci sysfillrect sysimgblt fb_sys_fops ttm floppy libata drm virtio_pci virtio_ring uhci_hcd virtio ehci_hcd usbcore serio_raw usb_common sg dm_multipath dm_mod scsi_dh_rdac scsi_dh_emc scsi_dh_alua scsi_mod autofs4
Supported: No, Unsupported modules are loaded
CPU: 1 PID: 30154 Comm: truncate Tainted: G OE N 4.4.21-69-default #1
Hardware name: QEMU Standard PC (i440FX + PIIX, 1996), BIOS rel-1.8.1-0-g4adadbd-20151112_172657-sheep25 04/01/2014
task: ffff88004ff6d240 ti: ffff880074e68000 task.ti: ffff880074e68000
RIP: 0010:[<ffffffffa05c8c30>] [<ffffffffa05c8c30>] ocfs2_truncate_file+0x640/0x6c0 [ocfs2]
RSP: 0018:ffff880074e6bd50 EFLAGS: 00010282
RAX: 0000000000000074 RBX: 000000000000029e RCX: 0000000000000000
RDX: 0000000000000001 RSI: 0000000000000246 RDI: 0000000000000246
RBP: ffff880074e6bda8 R08: 000000003675dc7a R09: ffffffff82013414
R10: 0000000000034c50 R11: 0000000000000000 R12: ffff88003aab3448
R13: 00000000000002dc R14: 0000000000046e11 R15: 0000000000000020
FS: 00007f839f965700(0000) GS:ffff88007fc80000(0000) knlGS:0000000000000000
CS: 0010 DS: 0000 ES: 0000 CR0: 000000008005003b
CR2: 00007f839f97e000 CR3: 0000000036723000 CR4: 00000000000006e0
Call Trace:
ocfs2_setattr+0x698/0xa90 [ocfs2]
notify_change+0x1ae/0x380
do_truncate+0x5e/0x90
do_sys_ftruncate.constprop.11+0x108/0x160
entry_SYSCALL_64_fastpath+0x12/0x6d
Code: 24 28 ba d6 01 00 00 48 c7 c6 30 43 62 a0 8b 41 2c 89 44 24 08 48 8b 41 20 48 c7 c1 78 a3 62 a0 48 89 04 24 31 c0 e8 a0 97 f9 ff <0f> 0b 3d 00 fe ff ff 0f 84 ab fd ff ff 83 f8 fc 0f 84 a2 fd ff
RIP [<ffffffffa05c8c30>] ocfs2_truncate_file+0x640/0x6c0 [ocfs2]
It's because ocfs2_inode_lock() get us stale LVB in which the i_size is
not equal to the disk i_size. We mistakenly trust the LVB because the
underlaying fsdlm dlm_lock() doesn't set lkb_sbflags with
DLM_SBF_VALNOTVALID properly for us. But, why?
The current code tries to downconvert lock without DLM_LKF_VALBLK flag
to tell o2cb don't update RSB's LVB if it's a PR->NULL conversion, even
if the lock resource type needs LVB. This is not the right way for
fsdlm.
The fsdlm plugin behaves different on DLM_LKF_VALBLK, it depends on
DLM_LKF_VALBLK to decide if we care about the LVB in the LKB. If
DLM_LKF_VALBLK is not set, fsdlm will skip recovering RSB's LVB from
this lkb and set the right DLM_SBF_VALNOTVALID appropriately when node
failure happens.
The following diagram briefly illustrates how this crash happens:
RSB1 is inode metadata lock resource with LOCK_TYPE_USES_LVB;
The 1st round:
Node1 Node2
RSB1: PR
RSB1(master): NULL->EX
ocfs2_downconvert_lock(PR->NULL, set_lvb==0)
ocfs2_dlm_lock(no DLM_LKF_VALBLK)
convert_lock(overwrite lkb->lkb_exflags
with no DLM_LKF_VALBLK)
RSB1: NULL RSB1: EX
reset Node2
dlm_recover_rsbs()
recover_lvb()
/* The LVB is not trustable if the node with EX fails and
* no lock >= PR is left. We should set RSB_VALNOTVALID for RSB1.
if(!(kb_exflags & DLM_LKF_VALBLK)) /* This means we miss the chance to
return; * to invalid the LVB here.
The 2nd round:
Node 1 Node2
RSB1(become master from recovery)
ocfs2_setattr()
ocfs2_inode_lock(NULL->EX)
/* dlm_lock() return the stale lvb without setting DLM_SBF_VALNOTVALID */
ocfs2_meta_lvb_is_trustable() return 1 /* so we don't refresh inode from disk */
ocfs2_truncate_file()
mlog_bug_on_msg(disk isize != i_size_read(inode)) /* crash! */
The fix is quite straightforward. We keep to set DLM_LKF_VALBLK flag
for dlm_lock() if the lock resource type needs LVB and the fsdlm plugin
is uesed.
Link: http://lkml.kernel.org/r/1481275846-6604-1-git-send-email-zren@suse.com
Signed-off-by: Eric Ren <zren@suse.com>
Reviewed-by: Joseph Qi <jiangqi903@gmail.com>
Cc: Junxiao Bi <junxiao.bi@oracle.com>
commit 073931017b49d9458aa351605b43a7e34598caef upstream.
When file permissions are modified via chmod(2) and the user is not in
the owning group or capable of CAP_FSETID, the setgid bit is cleared in
inode_change_ok(). Setting a POSIX ACL via setxattr(2) sets the file
permissions as well as the new ACL, but doesn't clear the setgid bit in
a similar way; this allows to bypass the check in chmod(2). Fix that.
References: CVE-2016-7097
Reviewed-by: Jeff Layton <jlayton@redhat.com>
Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com>
commit d21c353d5e99c56cdd5b5c1183ffbcaf23b8b960 upstream.
If we punch a hole on a reflink such that following conditions are met:
1. start offset is on a cluster boundary
2. end offset is not on a cluster boundary
3. (end offset is somewhere in another extent) or
(hole range > MAX_CONTIG_BYTES(1MB)),
we dont COW the first cluster starting at the start offset. But in this
case, we were wrongly passing this cluster to
ocfs2_zero_range_for_truncate() to zero out. This will modify the
cluster in place and zero it in the source too.
Fix this by skipping this cluster in such a scenario.
To reproduce:
1. Create a random file of say 10 MB
xfs_io -c 'pwrite -b 4k 0 10M' -f 10MBfile
2. Reflink it
reflink -f 10MBfile reflnktest
3. Punch a hole at starting at cluster boundary with range greater that
1MB. You can also use a range that will put the end offset in another
extent.
fallocate -p -o 0 -l 1048615 reflnktest
4. sync
5. Check the first cluster in the source file. (It will be zeroed out).
dd if=10MBfile iflag=direct bs=<cluster size> count=1 | hexdump -C
Link: http://lkml.kernel.org/r/1470957147-14185-1-git-send-email-ashish.samant@oracle.com
Signed-off-by: Ashish Samant <ashish.samant@oracle.com>
Reported-by: Saar Maoz <saar.maoz@oracle.com>
Reviewed-by: Srinivas Eeda <srinivas.eeda@oracle.com>
Cc: Mark Fasheh <mfasheh@suse.de>
Cc: Joseph Qi <joseph.qi@huawei.com>
Cc: Eric Ren <zren@suse.com>
commit e6f0c6e6170fec175fe676495f29029aecdf486c upstream.
Commit ac7cf246dfdb ("ocfs2/dlm: fix race between convert and recovery")
checks if lockres master has changed to identify whether new master has
finished recovery or not. This will introduce a race that right after
old master does umount ( means master will change), a new convert
request comes.
In this case, it will reset lockres state to DLM_RECOVERING and then
retry convert, and then fail with lockres->l_action being set to
OCFS2_AST_INVALID, which will cause inconsistent lock level between
ocfs2 and dlm, and then finally BUG.
Since dlm recovery will clear lock->convert_pending in
dlm_move_lockres_to_recovery_list, we can use it to correctly identify
the race case between convert and recovery. So fix it.
Fixes: ac7cf246dfdb ("ocfs2/dlm: fix race between convert and recovery")
Link: http://lkml.kernel.org/r/57CE1569.8010704@huawei.com
Signed-off-by: Joseph Qi <joseph.qi@huawei.com>
Signed-off-by: Jun Piao <piaojun@huawei.com>
commit c25a1e0671fbca7b2c0d0757d533bd2650d6dc0c upstream.
Commit 702e5bc68ad2 ("ocfs2: use generic posix ACL infrastructure")
refactored code to use posix_acl_create. The problem with this function
is that it is not mindful of the cluster wide inode lock making it
unsuitable for use with ocfs2 inode creation with ACLs. For example,
when used in ocfs2_mknod, this function can cause deadlock as follows.
The parent dir inode lock is taken when calling posix_acl_create ->
get_acl -> ocfs2_iop_get_acl which takes the inode lock again. This can
cause deadlock if there is a blocked remote lock request waiting for the
lock to be downconverted. And same deadlock happened in ocfs2_reflink.
This fix is to revert back using ocfs2_init_acl.
Fixes: 702e5bc68ad2 ("ocfs2: use generic posix ACL infrastructure")
Signed-off-by: Tariq Saeed <tariq.x.saeed@oracle.com>
commit 5ee0fbd50fdf1c1329de8bee35ea9d7c6a81a2e0 upstream.
Commit 743b5f1434f5 ("ocfs2: take inode lock in ocfs2_iop_set/get_acl()")
introduced this issue. ocfs2_setattr called by chmod command holds
cluster wide inode lock when calling posix_acl_chmod. This latter
function in turn calls ocfs2_iop_get_acl and ocfs2_iop_set_acl. These
two are also called directly from vfs layer for getfacl/setfacl commands
and therefore acquire the cluster wide inode lock. If a remote
conversion request comes after the first inode lock in ocfs2_setattr,
OCFS2_LOCK_BLOCKED will be set. And this will cause the second call to
inode lock from the ocfs2_iop_get_acl() to block indefinetly.
The deleted version of ocfs2_acl_chmod() calls __posix_acl_chmod() which
does not call back into the filesystem. Therefore, we restore
ocfs2_acl_chmod(), modify it slightly for locking as needed, and use that
instead.
Fixes: 743b5f1434f5 ("ocfs2: take inode lock in ocfs2_iop_set/get_acl()")
commit be12b299a83fc807bbaccd2bcb8ec50cbb0cb55c upstream.
When master handles convert request, it queues ast first and then
returns status. This may happen that the ast is sent before the request
status because the above two messages are sent by two threads. And
right after the ast is sent, if master down, it may trigger BUG in
dlm_move_lockres_to_recovery_list in the requested node because ast
handler moves it to grant list without clear lock->convert_pending. So
remove BUG_ON statement and check if the ast is processed in
dlmconvert_remote.
Reported-by: Yiwen Jiang <jiangyiwen@huawei.com>
Cc: Tariq Saeed <tariq.x.saeed@oracle.com>
commit ac7cf246dfdbec3d8fed296c7bf30e16f5099dac upstream.
There is a race window between dlmconvert_remote and
dlm_move_lockres_to_recovery_list, which will cause a lock with
OCFS2_LOCK_BUSY in grant list, thus system hangs.
dlmconvert_remote
spin_lock(&res->spinlock);
list_move_tail(&lock->list, &res->converting);
lock->convert_pending = 1;
spin_unlock(&res->spinlock);
status = dlm_send_remote_convert_request();
>>>>>> race window, master has queued ast and return DLM_NORMAL,
and then down before sending ast.
this node detects master down and calls
dlm_move_lockres_to_recovery_list, which will revert the
lock to grant list.
Then OCFS2_LOCK_BUSY won't be cleared as new master won't
send ast any more because it thinks already be authorized.
lock->convert_pending = 0;
if (status != DLM_NORMAL)
dlm_revert_pending_convert(res, lock);
In this case, check if res->state has DLM_LOCK_RES_RECOVERING bit set
(res is still in recovering) or res master changed (new master has
finished recovery), reset the status to DLM_RECOVERING, then it will
retry convert.
Reviewed-by: Junxiao Bi <junxiao.bi@oracle.com>
commit a4a8481ff68a8a324a878e281bc37f18665224f7 upstream.
When doing append direct io cleanup, if deleting inode fails, it goes
out without unlocking inode, which will cause the inode deadlock.
This issue was introduced by commit cf1776a9e834 ("ocfs2: fix a tiny
race when truncate dio orohaned entry").
Signed-off-by: Guozhonghua <guozhonghua@h3c.com>
Reviewed-by: Gang He <ghe@suse.com>
commit c95a51807b730e4681e2ecbdfd669ca52601959e upstream.
When recovery master down, dlm_do_local_recovery_cleanup() only remove
the $RECOVERY lock owned by dead node, but do not clear the refmap bit.
Which will make umount thread falling in dead loop migrating $RECOVERY
to the dead node.
Signed-off-by: xuejiufei <xuejiufei@huawei.com>
Reviewed-by: Joseph Qi <joseph.qi@huawei.com>
commit bef5502de074b6f6fa647b94b73155d675694420 upstream.
We have found that migration source will trigger a BUG that the refcount
of mle is already zero before put when the target is down during
migration. The situation is as follows:
dlm_migrate_lockres
dlm_add_migration_mle
dlm_mark_lockres_migrating
dlm_get_mle_inuse
<<<<<< Now the refcount of the mle is 2.
dlm_send_one_lockres and wait for the target to become the
new master.
<<<<<< o2hb detect the target down and clean the migration
mle. Now the refcount is 1.
dlm_migrate_lockres woken, and put the mle twice when found the target
goes down which trigger the BUG with the following message:
"ERROR: bad mle: ".
Signed-off-by: Jiufei Xue <xuejiufei@huawei.com>
commit b1b1e15ef6b80facf76d6757649dfd7295eda29f upstream.
NFS on a 2 node ocfs2 cluster each node exporting dir. The lock causing
the hang is the global bit map inode lock. Node 1 is master, has the
lock granted in PR mode; Node 2 is in the converting list (PR -> EX).
There are no holders of the lock on the master node so it should
downconvert to NL and grant EX to node 2 but that does not happen.
BLOCKED + QUEUED in lock res are set and it is on osb blocked list.
Threads are waiting in __ocfs2_cluster_lock on BLOCKED. One thread
wants EX, rest want PR. So it is as though the downconvert thread needs
to be kicked to complete the conv.
The hang is caused by an EX req coming into __ocfs2_cluster_lock on the
heels of a PR req after it sets BUSY (drops l_lock, releasing EX
thread), forcing the incoming EX to wait on BUSY without doing anything.
PR has called ocfs2_dlm_lock, which sets the node 1 lock from NL -> PR,
queues ast.
At this time, upconvert (PR ->EX) arrives from node 2, finds conflict
with node 1 lock in PR, so the lock res is put on dlm thread's dirty
listt.
After ret from ocf2_dlm_lock, PR thread now waits behind EX on BUSY till
awoken by ast.
Now it is dlm_thread that serially runs dlm_shuffle_lists, ast, bast, in
that order. dlm_shuffle_lists ques a bast on behalf of node 2 (which
will be run by dlm_thread right after the ast). ast does its part, sets
UPCONVERT_FINISHING, clears BUSY and wakes its waiters. Next,
dlm_thread runs bast. It sets BLOCKED and kicks dc thread. dc thread
runs ocfs2_unblock_lock, but since UPCONVERT_FINISHING set, skips doing
anything and reques.
Inside of __ocfs2_cluster_lock, since EX has been waiting on BUSY ahead
of PR, it wakes up first, finds BLOCKED set and skips doing anything but
clearing UPCONVERT_FINISHING (which was actually "meant" for the PR
thread), and this time waits on BLOCKED. Next, the PR thread comes out
of wait but since UPCONVERT_FINISHING is not set, it skips updating the
l_ro_holders and goes straight to wait on BLOCKED. So there, we have a
hang! Threads in __ocfs2_cluster_lock wait on BLOCKED, lock res in osb
blocked list. Only when dc thread is awoken, it will run
ocfs2_unblock_lock and things will unhang.
One way to fix this is to wake the dc thread on the flag after clearing
UPCONVERT_FINISHING
Orabug: 20933419
Signed-off-by: Santosh Shilimkar <santosh.shilimkar@oracle.com>
Reviewed-by: Wengang Wang <wen.gang.wang@oracle.com>
Reviewed-by: Mark Fasheh <mfasheh@suse.de>
We have found a BUG on res->migration_pending when migrating lock
resources. The situation is as follows.
dlm_mark_lockres_migration
res->migration_pending = 1;
__dlm_lockres_reserve_ast
dlm_lockres_release_ast returns with res->migration_pending remains
because other threads reserve asts
wait dlm_migration_can_proceed returns 1
>>>>>>> o2hb found that target goes down and remove target
from domain_map
dlm_mark_lockres_migrating returns -ESHOTDOWN with
res->migration_pending still remains.
When reentering dlm_mark_lockres_migrating(), it will trigger the BUG_ON
with res->migration_pending. So clear migration_pending when target is
down.
Commit 4f6563677ae8 ("Move locks API users to locks_lock_inode_wait()")
move flock/posix lock indentify code to locks_lock_inode_wait(), but
missed to set fl_flags to FL_FLOCK which caused the following kernel
panic on 4.4.0_rc5.
kernel BUG at fs/locks.c:1895!
Modules linked in: ocfs2(O) ocfs2_dlmfs(O) ocfs2_stack_o2cb(O) ocfs2_dlm(O) ocfs2_nodemanager(O) ocfs2_stackglue(O) iscsi_tcp libiscsi_tcp libiscsi scsi_transport_iscsi xen_kbdfront xen_netfront xen_fbfront xen_blkfront
CPU: 0 PID: 20268 Comm: flock_unit_test Tainted: G O 4.4.0-rc5-next-20151217 #1
Hardware name: Xen HVM domU, BIOS 4.3.1OVM 05/14/2014
task: ffff88007b3672c0 ti: ffff880028b58000 task.ti: ffff880028b58000
RIP: locks_lock_inode_wait+0x2e/0x160
Call Trace:
ocfs2_do_flock+0x91/0x160 [ocfs2]
ocfs2_flock+0x76/0xd0 [ocfs2]
SyS_flock+0x10f/0x1a0
entry_SYSCALL_64_fastpath+0x12/0x71
Code: e5 41 57 41 56 49 89 fe 41 55 41 54 53 48 89 f3 48 81 ec 88 00 00 00 8b 46 40 83 e0 03 83 f8 01 0f 84 ad 00 00 00 83 f8 02 74 04 <0f> 0b eb fe 4c 8d ad 60 ff ff ff 4c 8d 7b 58 e8 0e 8e 73 00 4d
RIP locks_lock_inode_wait+0x2e/0x160
RSP <ffff880028b5bce8>
---[ end trace dfca74ec9b5b274c ]---
Fixes: 4f6563677ae8 ("Move locks API users to locks_lock_inode_wait()")
When resizing, it firstly extends the last gd. Once it should backup
super in the gd, it calculates new backup super and update the
corresponding value.
But it currently doesn't consider the situation that the backup super is
already done. And in this case, it still sets the bit in gd bitmap and
then decrease from bg_free_bits_count, which leads to a corrupted gd and
trigger the BUG in ocfs2_block_group_set_bits:
BUG_ON(le16_to_cpu(bg->bg_free_bits_count) < num_bits);
So check whether the backup super is done and then do the updates.
Reviewed-by: Jiufei Xue <xuejiufei@huawei.com>
Reviewed-by: Yiwen Jiang <jiangyiwen@huawei.com>
Cc: <stable@vger.kernel.org>
Commit 8f1eb48758aa ("ocfs2: fix umask ignored issue") introduced an
issue, SGID of sub dir was not inherited from its parents dir. It is
because SGID is set into "inode->i_mode" in ocfs2_get_init_inode(), but
is overwritten by "mode" which don't have SGID set later.
Fixes: 8f1eb48758aa ("ocfs2: fix umask ignored issue")
Acked-by: Srinivas Eeda <srinivas.eeda@oracle.com>
New created file's mode is not masked with umask, and this makes umask not
work for ocfs2 volume.
Fixes: 702e5bc ("ocfs2: use generic posix ACL infrastructure")
Cc: Gang He <ghe@suse.com>
git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending
Pull SCSI target updates from Nicholas Bellinger:
"This series contains HCH's changes to absorb configfs attribute
->show() + ->store() function pointer usage from it's original
tree-wide consumers, into common configfs code.
It includes usb-gadget, target w/ drivers, netconsole and ocfs2
changes to realize the improved simplicity, that now renders the
original include/target/configfs_macros.h CPP magic for fabric drivers
and others, unnecessary and obsolete.
And with common code in place, new configfs attributes can be added
easier than ever before.
Note, there are further improvements in-flight from other folks for
v4.5 code in configfs land, plus number of target fixes for post -rc1
code"
In the meantime, a new user of the now-removed old configfs API came in
through the char/misc tree in commit 7bd1d4093c2f ("stm class: Introduce
an abstraction for System Trace Module devices").
This merge resolution comes from Alexander Shishkin, who updated his stm
class tracing abstraction to account for the removal of the old
show_attribute and store_attribute methods in commit 517982229f78
("configfs: remove old API") from this pull. As Alexander says about
that patch:
"There's no need to keep an extra wrapper structure per item and the
awkward show_attribute/store_attribute item ops are no longer needed.
This patch converts policy code to the new api, all the while making
the code quite a bit smaller and easier on the eyes.
Signed-off-by: Alexander Shishkin <alexander.shishkin@linux.intel.com>"
That patch was folded into the merge so that the tree should be fully
bisectable.
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/nab/target-pending: (23 commits)
ocfs2/cluster: move locking into attribute store methods
netconsole: use per-attribute show and store methods
target: use per-attribute show and store methods
spear13xx_pcie_gadget: use per-attribute show and store methods
dlm: use per-attribute show and store methods
usb-gadget/f_serial: use per-attribute show and store methods
usb-gadget/f_phonet: use per-attribute show and store methods
usb-gadget/f_obex: use per-attribute show and store methods
usb-gadget/f_uac2: use per-attribute show and store methods
usb-gadget/f_uac1: use per-attribute show and store methods
usb-gadget/f_mass_storage: use per-attribute show and store methods
usb-gadget/f_sourcesink: use per-attribute show and store methods
usb-gadget/f_printer: use per-attribute show and store methods
usb-gadget/f_midi: use per-attribute show and store methods
usb-gadget/f_loopback: use per-attribute show and store methods
usb-gadget/ether: use per-attribute show and store methods
usb-gadget/f_acm: use per-attribute show and store methods
usb-gadget/f_hid: use per-attribute show and store methods
The xattr_handler operations are currently all passed a file system
specific flags value which the operations can use to disambiguate between
different handlers; some file systems use that to distinguish the xattr
namespace, for example. In some oprations, it would be useful to also have
access to the handler prefix. To allow that, pass a pointer to the handler
to operations instead of the flags value alone.
Merge patch-bomb from Andrew Morton:
- inotify tweaks
- some ocfs2 updates (many more are awaiting review)
- various misc bits
- kernel/watchdog.c updates
- Some of mm. I have a huge number of MM patches this time and quite a
lot of it is quite difficult and much will be held over to next time.
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (162 commits)
selftests: vm: add tests for lock on fault
mm: mlock: add mlock flags to enable VM_LOCKONFAULT usage
mm: introduce VM_LOCKONFAULT
mm: mlock: add new mlock system call
mm: mlock: refactor mlock, munlock, and munlockall code
kasan: always taint kernel on report
mm, slub, kasan: enable user tracking by default with KASAN=y
kasan: use IS_ALIGNED in memory_is_poisoned_8()
kasan: Fix a type conversion error
lib: test_kasan: add some testcases
kasan: update reference to kasan prototype repo
kasan: move KASAN_SANITIZE in arch/x86/boot/Makefile
kasan: various fixes in documentation
kasan: update log messages
kasan: accurately determine the type of the bad access
kasan: update reported bug types for kernel memory accesses
kasan: update reported bug types for not user nor kernel memory accesses
mm/kasan: prevent deadlock in kasan reporting
mm/kasan: don't use kasan shadow pointer in generic functions
mm/kasan: MODULE_VADDR is not available on all archs
readahead_pages in ocfs2_duplicate_clusters_by_page is defined but not
used, so clean it up.
Cc: Mark Fasheh <mfasheh@suse.com>
A node can mount multiple ocfs2 volumes. And if thread names are same for
each volume/domain, it will bring inconvenience when analyzing problems
because we have to identify which volume/domain the messages belong to.
Since thread name will be printed to messages, so add volume uuid or dlm
name to thread name can benefit problem analysis.
In ocfs2_mknod_locked if '__ocfs2_mknod_locke d' returns an error, we
should reclaim the inode successfully claimed above, otherwise, the
inode never be reused. The case is described below:
ocfs2_mknod
ocfs2_mknod_locked
ocfs2_claim_new_inode
Successfully claim the inode
__ocfs2_mknod_locked
ocfs2_journal_access_di
Failed because of -ENOMEM or other reasons, the inode
lockres has not been initialized yet.
iput(inode)
ocfs2_evict_inode
ocfs2_delete_inode
ocfs2_inode_lock
ocfs2_inode_lock_full_nested
Return -EINVAL because of the inode
lockres has not been initialized.
So the following operations are not performed
ocfs2_wipe_inode
ocfs2_remove_inode
ocfs2_free_dinode
ocfs2_free_suballoc_bits
Signed-off-by: Alex Chen <alex.chen@huawei.com>
There is a race case between mount and delete node/cluster, which will
lead o2hb_thread to malfunctioning dead loop.
o2hb_thread
o2nm_depend_this_node();
<<<<<< race window, node may have already been deleted, and then
enter the loop, o2hb thread will be malfunctioning
because of no configured nodes found.
while (!kthread_should_stop() &&
!reg->hr_unclean_stop && !reg->hr_aborted_start) {
So check the return value of o2nm_depend_this_node() is needed. If node
has been deleted, do not enter the loop and let mount fail.
We have no need to take inode mutex, rw and inode lock if it is not dio
entry when recover orphans. Optimize it by adding a flag
OCFS2_INODE_DIO_ORPHAN_ENTRY to ocfs2_inode_info to reduce contention.
dio entry will only do truncate in case of ORPHAN_NEED_TRUNCATE. So do
not include it when doing normal orphan scan to reduce contention.
Currently cluster allocation is always trying to find a victim chain (a
chian has most space), and this may lead to poor performance because of
discontiguous allocation in some scenarios.
Our test case is block size 4k, cluster size 1M and mount option with
localalloc=2048 (2G), since a gd is 32256M (about 31.5G) and a localalloc
window is only 2G, creating 50G file will result in 2G from gd0, 2G from
gd1, ...
One way to improve performance is enlarge localalloc window size (max
31104M), but this will make end user feel that about 30G is suddenly
"missing", and localalloc currently do not support steal, which means one
node cannot use another node's localalloc even it is not used in fact. So
using the last gd to record the allocation and continues with the gd if it
has enough space for a localalloc window can make the allocation as more
contiguous as possible.
Our test result is below (evaluated in IOPS), which is using iometer
running in VM, dynamic vhd virtual disk stored in ocfs2.
IO model Original After Improved(%)
16K60%Write100%Random 703 876 24.59%
8K90%Write100%Random 735 827 12.59%
4K100%Write100%Random 859 915 6.52%
4K100%Read100%Random 2092 2600 24.30%
Tested-by: Norton Zhu <norton.zhu@huawei.com>
A simplified test case is (this case from Ryan):
1) dd if=/dev/zero of=/mnt/hello bs=512 count=1 oflag=direct;
2) truncate /mnt/hello -s 2097152
file 'hello' is not exist before test. After this command,
file 'hello' should be all zero. But 512~4096 is some random data.
Setting bh state to new when get a new block, if so,
direct_io_worker()->dio_zero_block() will fill-in the unused portion
of the block with zero.
Signed-off-by: Yiwen Jiang <jiangyiwen@huawei.com>
If ocfs2_is_overwrite failed, ocfs2_direct_IO_write mays till return
success to the caller.
Signed-off-by: Norton.Zhu <norton.zhu@huawei.com>
Pull file locking updates from Jeff Layton:
"The largest series of changes is from Ben who offered up a set to add
a new helper function for setting locks based on the type set in
fl_flags. Dmitry also send in a fix for a potential race that he
found with KTSAN"
* tag 'locks-v4.4-1' of git://git.samba.org/jlayton/linux:
locks: cleanup posix_lock_inode_wait and flock_lock_inode_wait
locks: introduce locks_lock_inode_wait()
locks: Use more file_inode and fix a comment
fs: fix data races on inode->i_flctx
locks: change tracepoint for generic_add_lease
dlm_lockres_put will call dlm_lockres_release if it is the last
reference, and then it may call dlm_print_one_lock_resource and
take lockres spinlock.
So unlock lockres spinlock before dlm_lockres_put to avoid deadlock.
Instead of having users check for FL_POSIX or FL_FLOCK to call the correct
locks API function, use the check within locks_lock_inode_wait(). This
allows for some later cleanup.
Signed-off-by: Benjamin Coddington <bcodding@redhat.com>
Signed-off-by: Jeff Layton <jeff.layton@primarydata.com>
The test and separate set bit scheme was racy to start with, so move to do
a test_and_set_bit after doing the earlier error checks inside the actual
store methods. Also remove the locking for the local attribute which
already has a different scheme to synchronize.
The order of the following three spinlocks should be:
dlm_domain_lock < dlm_ctxt->spinlock < dlm_lock_resource->spinlock
But dlm_dispatch_assert_master() is called while holding
dlm_ctxt->spinlock and dlm_lock_resource->spinlock, and then it calls
dlm_grab() which will take dlm_domain_lock.
Once another thread (for example, dlm_query_join_handler) has already
taken dlm_domain_lock, and tries to take dlm_ctxt->spinlock deadlock
happens.
Cc: "Junxiao Bi" <junxiao.bi@oracle.com>
Revert commit f83c7b5e9fd6 ("ocfs2/dlm: use list_for_each_entry instead
of list_for_each").
list_for_each_entry() will dereference its `pos' argument, which can be
NULL in dlm_process_recovery_data().
Reported-by: Julia Lawall <julia.lawall@lip6.fr>
Reported-by: Fengguang Wu <fengguang.wu@gmail.com>
Many file systems that implement the show_options hook fail to correctly
escape their output which could lead to unescaped characters (e.g. new
lines) leaking into /proc/mounts and /proc/[pid]/mountinfo files. This
could lead to confusion, spoofed entries (resulting in things like
systemd issuing false d-bus "mount" notifications), and who knows what
else. This looks like it would only be the root user stepping on
themselves, but it's possible weird things could happen in containers or
in other situations with delegated mount privileges.
Here's an example using overlay with setuid fusermount trusting the
contents of /proc/mounts (via the /etc/mtab symlink). Imagine the use
of "sudo" is something more sneaky:
$ BASE="ovl"
$ MNT="$BASE/mnt"
$ LOW="$BASE/lower"
$ UP="$BASE/upper"
$ WORK="$BASE/work/ 0 0
none /proc fuse.pwn user_id=1000"
$ mkdir -p "$LOW" "$UP" "$WORK"
$ sudo mount -t overlay -o "lowerdir=$LOW,upperdir=$UP,workdir=$WORK" none /mnt
$ cat /proc/mounts
none /root/ovl/mnt overlay rw,relatime,lowerdir=ovl/lower,upperdir=ovl/upper,workdir=ovl/work/ 0 0
none /proc fuse.pwn user_id=1000 0 0
$ fusermount -u /proc
$ cat /proc/mounts
cat: /proc/mounts: No such file or directory
This fixes the problem by adding new seq_show_option and
seq_show_option_n helpers, and updating the vulnerable show_option
handlers to use them as needed. Some, like SELinux, need to be open
coded due to unusual existing escape mechanisms.
[akpm@linux-foundation.org: add lost chunk, per Kees]
[keescook@chromium.org: seq_show_option should be using const parameters]
Acked-by: Serge Hallyn <serge.hallyn@canonical.com>
Acked-by: Jan Kara <jack@suse.com>
Acked-by: Paul Moore <paul@paul-moore.com>
Cc: J. R. Okajima <hooanon05g@gmail.com>
NULL check before kfree is redundant and so clean them up.
These uses sometimes do and sometimes don't have '\n' terminations. Make
the uses consistently use '\n' terminations and remove the newline from
the functions.
Miscellanea:
o Coalesce formats
o Realign arguments
While appending an extent to a file, it will call these functions:
ocfs2_insert_extent
-> call ocfs2_grow_tree() if there's no free rec
-> ocfs2_add_branch add a new branch to extent tree,
now rec[0] in the leaf of rightmost path is empty
-> ocfs2_do_insert_extent
-> ocfs2_rotate_tree_right
-> ocfs2_extend_rotate_transaction
-> jbd2_journal_restart if jbd2_journal_extend fail
-> ocfs2_insert_path
-> ocfs2_extend_trans
-> ocfs2_insert_at_leaf
-> ocfs2_et_update_clusters
Function jbd2_journal_restart() may be called and it may happened that
buffers dirtied in ocfs2_add_branch() are committed
while buffers dirtied in ocfs2_insert_at_leaf() and
ocfs2_et_update_clusters() are not.
So an empty rec[0] is left in rightmost path which will cause
read-only filesystem when call ocfs2_commit_truncate()
with the error message: "Inode %lu has an empty extent record".
This is not a serious problem, so remove the rightmost path when call
ocfs2_commit_truncate().
Signed-off-by: joyce.xue <xuejiufei@huawei.com>
ocfs2_write_end_nolock()
1: After we call ocfs2_journal_access_di() in ocfs2_write_begin(),
jbd2_journal_restart() may also be called, in this function transaction
A's t_updates-- and obtains a new transaction B. If
jbd2_journal_commit_transaction() is happened to commit transaction A,
when t_updates==0, it will continue to complete commit and unfile
buffer.
So when jbd2_journal_dirty_metadata(), the handle is pointed a new
transaction B, and the buffer head's journal head is already freed,
jh->b_transaction == NULL, jh->b_next_transaction == NULL, it returns
EINVAL, So it triggers the BUG_ON(status).
thread 1 jbd2
ocfs2_write_begin jbd2_journal_commit_transaction
ocfs2_write_begin_nolock
ocfs2_start_trans
jbd2__journal_start(t_updates+1,
transaction A)
ocfs2_write_cluster_by_desc
ocfs2_mark_extent_written
ocfs2_change_extent_flag
ocfs2_split_extent
(t_updates-1,transaction B) t_updates==0
__jbd2_journal_refile_buffer
(jh->b_transaction = NULL)
ocfs2_write_end
ocfs2_journal_dirty
jbd2_journal_dirty_metadata(bug)
ocfs2_commit_trans
2. In ext4, I found that: jbd2_journal_get_write_access() called by
ext4_write_end.
ext4_write_begin
ext4_journal_start
__ext4_journal_start_sb
ext4_journal_check_start
jbd2__journal_start
ext4_write_end
ext4_mark_inode_dirty
ext4_reserve_inode_write
ext4_journal_get_write_access
ext4_mark_iloc_dirty
ext4_do_update_inode
ext4_handle_dirty_metadata
3. So I think we should put ocfs2_journal_access_di before
ocfs2_journal_dirty in the ocfs2_write_end. and it works well after my
modification.
Signed-off-by: vicky <vicky.yangwenfang@huawei.com>
Cc: Zhangguanghui <zhang.guanghui@h3c.com>
o2hb_elapsed_msecs computes the time taken for a disk heartbeat.
'struct timeval' variables are used to store start and end times. On
32-bit systems, the 'tv_sec' component of 'struct timeval' will overflow
in year 2038 and beyond.
This patch solves the overflow with the following:
1. Replace o2hb_elapsed_msecs using 'ktime_t' values to measure start
and end time, and built-in function 'ktime_ms_delta' to compute the
elapsed time. ktime_get_real() is used since the code prints out the
wallclock time.
2. Changes format string to print time as a single 64-bit nanoseconds
value ("%lld") instead of seconds and microseconds. This simplifies
the code since converting ktime_t to that format would need expensive
computation. However, the debug log string is less readable than the
previous format.
Signed-off-by: Tina Ruchandani <ruchandani.tina@gmail.com>
Suggested by: Arnd Bergmann <arnd@arndb.de>
There is a race case between crashed dio and rm, which will lead to
OCFS2_VALID_FL not set read-only.
N1 N2
dd with direct flag
rm file
crashed with an dio entry left
in orphan dir
clear OCFS2_VALID_FL in
ocfs2_remove_inode
recover N1 and read the corrupted inode,
and set filesystem read-only
So we skip the inode deletion this time and wait for dio entry recovered
first.
The following case will lead to a lockres is freed but is still in use.
cat /sys/kernel/debug/o2dlm/locking_state dlm_thread
lockres_seq_start
-> lock dlm->track_lock
-> get resA
resA->refs decrease to 0,
call dlm_lockres_release,
and wait for "cat" unlock.
Although resA->refs is already set to 0,
increase resA->refs, and then unlock
-> list_del_init()
-> unlock
-> free resA
In such a race case, invalid address access may occurs. So we should
delete list res->tracking before resA->refs decrease to 0.
Signed-off-by: Mark Fasheh <mfasheh@suse.de>
This bug in mainline code is pointed out by Mark Fasheh. When
ocfs2_iop_set_acl() and ocfs2_iop_get_acl() are entered from VFS layer,
inode lock is not held. This seems to be regression from older kernels.
The patch is to fix that.
Orabug: 20189959
PID: 614 TASK: ffff882a739da580 CPU: 3 COMMAND: "ocfs2dc"
#0 [ffff882ecc3759b0] machine_kexec at ffffffff8103b35d
#1 [ffff882ecc375a20] crash_kexec at ffffffff810b95b5
#2 [ffff882ecc375af0] oops_end at ffffffff815091d8
#3 [ffff882ecc375b20] die at ffffffff8101868b
#4 [ffff882ecc375b50] do_trap at ffffffff81508bb0
#5 [ffff882ecc375ba0] do_invalid_op at ffffffff810165e5
#6 [ffff882ecc375c40] invalid_op at ffffffff815116fb
[exception RIP: ocfs2_ci_checkpointed+208]
RIP: ffffffffa0a7e940 RSP: ffff882ecc375cf0 RFLAGS: 00010002
RAX: 0000000000000001 RBX: 000000000000654b RCX: ffff8812dc83f1f8
RDX: 00000000000017d9 RSI: ffff8812dc83f1f8 RDI: ffffffffa0b2c318
RBP: ffff882ecc375d20 R8: ffff882ef6ecfa60 R9: ffff88301f272200
R10: 0000000000000000 R11: 0000000000000000 R12: ffffffffffffffff
R13: ffff8812dc83f4f0 R14: 0000000000000000 R15: ffff8812dc83f1f8
ORIG_RAX: ffffffffffffffff CS: 0010 SS: 0018
#7 [ffff882ecc375d28] ocfs2_check_meta_downconvert at ffffffffa0a7edbd [ocfs2]
#8 [ffff882ecc375d38] ocfs2_unblock_lock at ffffffffa0a84af8 [ocfs2]
#9 [ffff882ecc375dc8] ocfs2_process_blocked_lock at ffffffffa0a85285 [ocfs2]
#10 [ffff882ecc375e18] ocfs2_downconvert_thread_do_work at ffffffffa0a85445 [ocfs2]
#11 [ffff882ecc375e68] ocfs2_downconvert_thread at ffffffffa0a854de [ocfs2]
#12 [ffff882ecc375ee8] kthread at ffffffff81090da7
#13 [ffff882ecc375f48] kernel_thread_helper at ffffffff81511884
assert is tripped because the tran is not checkpointed and the lock level is PR.
Some time ago, chmod command had been executed. As result, the following call
chain left the inode cluster lock in PR state, latter on causing the assert.
system_call_fastpath
-> my_chmod
-> sys_chmod
-> sys_fchmodat
-> notify_change
-> ocfs2_setattr
-> posix_acl_chmod
-> ocfs2_iop_set_acl
-> ocfs2_set_acl
-> ocfs2_acl_set_mode
Here is how.
1119 int ocfs2_setattr(struct dentry *dentry, struct iattr *attr)
1120 {
1247 ocfs2_inode_unlock(inode, 1); <<< WRONG thing to do.
1258 if (!status && attr->ia_valid & ATTR_MODE) {
1259 status = posix_acl_chmod(inode, inode->i_mode);
519 posix_acl_chmod(struct inode *inode, umode_t mode)
520 {
539 ret = inode->i_op->set_acl(inode, acl, ACL_TYPE_ACCESS);
287 int ocfs2_iop_set_acl(struct inode *inode, struct posix_acl *acl, ...
288 {
289 return ocfs2_set_acl(NULL, inode, NULL, type, acl, NULL, NULL);
224 int ocfs2_set_acl(handle_t *handle,
225 struct inode *inode, ...
231 {
252 ret = ocfs2_acl_set_mode(inode, di_bh,
253 handle, mode);
168 static int ocfs2_acl_set_mode(struct inode *inode, struct buffer_head ...
170 {
183 if (handle == NULL) {
>>> BUG: inode lock not held in ex at this point <<<
184 handle = ocfs2_start_trans(OCFS2_SB(inode->i_sb),
185 OCFS2_INODE_UPDATE_CREDITS);
ocfs2_setattr.#1247 we unlock and at #1259 call posix_acl_chmod. When we reach
ocfs2_acl_set_mode.#181 and do trans, the inode cluster lock is not held in EX
mode (it should be). How this could have happended?
We are the lock master, were holding lock EX and have released it in
ocfs2_setattr.#1247. Note that there are no holders of this lock at
this point. Another node needs the lock in PR, and we downconvert from
EX to PR. So the inode lock is PR when do the trans in
ocfs2_acl_set_mode.#184. The trans stays in core (not flushed to disc).
Now another node want the lock in EX, downconvert thread gets kicked
(the one that tripped assert abovt), finds an unflushed trans but the
lock is not EX (it is PR). If the lock was at EX, it would have flushed
the trans ocfs2_ci_checkpointed -> ocfs2_start_checkpoint before
downconverting (to NULL) for the request.
ocfs2_setattr must not drop inode lock ex in this code path. If it
does, takes it again before the trans, say in ocfs2_set_acl, another
cluster node can get in between, execute another setattr, overwriting
the one in progress on this node, resulting in a mode acl size combo
that is a mix of the two.
Orabug: 20189959
Currently error handling in dlm_request_join is a little obscure, so
optimize it to promote readability.
If packet.code is invalid, reset it to JOIN_DISALLOW to keep it
meaningful. It only influences the log printing.
Cc: Srinivas Eeda <srinivas.eeda@oracle.com>
When running dirop_fileop_racer we found a case that inode
can not removed.
Two nodes, say Node A and Node B, mount the same ocfs2 volume. Create
two dirs /race/1/ and /race/2/ in the filesystem.
Node A Node B
rm -r /race/2/
mv /race/1/ /race/2/
call ocfs2_unlink(), get
the EX mode of /race/2/
wait for B unlock /race/2/
decrease i_nlink of /race/2/ to 0,
and add inode of /race/2/ into
orphan dir, unlock /race/2/
got EX mode of /race/2/. because
/race/1/ is dir, so inc i_nlink
of /race/2/ and update into disk,
unlock /race/2/
because i_nlink of /race/2/
is not zero, this inode will
always remain in orphan dir
This patch fixes this case by test whether i_nlink of new dir is zero.
Cc: Xue jiufei <xuejiufei@huawei.com>
