path: root/fs/partitions/amiga.c
2010-08-11partitions: fix sometimes unreadable partition stringsAlexey Dobriyan
Fix this garbage happening quite often: ==> sda: scsi 3:0:0:0: CD-ROM TOSHIBA ==> sda1 sda2 sda3 sda4 <sr0: scsi3-mmc drive: 24x/24x writer dvd-ram cd/rw xa/form2 cdda tray ^^^ Uniform CD-ROM driver Revision: 3.20 sr 3:0:0:0: Attached scsi CD-ROM sr0 ==> sda5 sda6 sda7 > Make "sda: sda1 ..." lines actually lines. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-21block: use struct parsed_partitions *state universally in partition check codeTejun Heo
Make the following changes to partition check code. * Add ->bdev to struct parsed_partitions. * Introduce read_part_sector() which is a simple wrapper around read_dev_sector() which takes struct parsed_partitions *state instead of @bdev. * For functions which used to take @state and @bdev, drop @bdev. For functions which used to take @bdev, replace it with @state. * While updating, drop superflous checks on NULL state/bdev in ldm.c. This cleans up the API a bit and enables better handling of IO errors during partition check as the generic partition check code now has much better visibility into what went wrong in the low level code paths. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Ben Hutchings <ben@decadent.org.uk> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2006-12-07[PATCH] Fix check_partition routinesSuzuki K P
check_partition() stops its probe once it hits an I/O error from the partition checkers. This would prevent the actual partition checker getting a chance to verify the partition. So this patch lets check_partition() continue probing untill it hits a success while recording the I/O error which might have been reported by the checking routines. Also, it does some cleanup of the partition methods for ibm, atari and amiga to return -1 upon hitting an I/O error. Signed-off-by: Suzuki K P <suzuki@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
