path: root/fs/pipe.c
2008-05-08sys_pipe(): fix file descriptor leaksUlrich Drepper
Remember to close the files if copy_to_user() failed. Spotted by dm.n9107@gmail.com. Signed-off-by: Ulrich Drepper <drepper@redhat.com> Cc: DM <dm.n9107@gmail.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-03unified (weak) sys_pipe implementationUlrich Drepper
This replaces the duplicated arch-specific versions of "sys_pipe()" with one unified implementation. This removes almost 250 lines of duplicated code. It's marked __weak, so that *if* an architecture wants to override the default implementation it can do so by simply having its own replacement version, since many architectures use alternate calling conventions for the 'pipe()' system call for legacy reasons (ie traditional UNIX implementations often return the two file descriptors in registers) I still haven't changed the cris version even though Linus says the BKL isn't needed. The arch maintainer can easily do it if there are really no obstacles. Signed-off-by: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-22[PATCH] double-free of inode on alloc_file() failure exit in create_write_pipe()Al Viro
Duh... Fortunately, the bug is quite recent (post-2.6.25) and, embarrassingly, mine ;-/ Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-03-19[PATCH] fix up new filp allocatorsDave Hansen
Some new uses of get_empty_filp() have crept in; switched to alloc_file() to make sure that pieces of initialization won't be missing. We really need to kill get_empty_filp(). [AV] fixed dentry leak on failure exit in anon_inode_getfd() Cc: Erez Zadok <ezk@cs.sunysb.edu> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: "J Bruce Fields" <bfields@fieldses.org> Acked-by: Al Viro <viro@ZenIV.linux.org.uk> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-02-13kernel-doc: fix fs/pipe.c notationRandy Dunlap
Fix several kernel-doc notation errors in fs/pipe.c. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08BKL-Removal: convert pipe to use unlocked_ioctl tooAndi Kleen
No BKL needed in pipe_ioctl Signed-off-by: Andi Kleen <ak@suse.de> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-15sched: affine sync wakeupsIngo Molnar
make sync wakeups affine for cache-cold tasks: if a cache-cold task is woken up by a sync wakeup then use the opportunity to migrate it straight away. (the two tasks are 'related' because they communicate) Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-10-15sched: cleanup, remove the TASK_NONINTERACTIVE flagMike Galbraith
Here's another piece of low hanging obsolete fruit. Remove obsolete TASK_NONINTERACTIVE. Signed-off-by: Mike Galbraith <efault@gmx.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2007-07-27docbook: add pipes, other fixesRandy Dunlap
Fix some typos in pipe.c and splice.c. Add pipes API to kernel-api.tmpl. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-07-10pipe: add documentation and commentsJens Axboe
As per Andrew Mortons request, here's a set of documentation for the generic pipe_buf_operations hooks, the pipe, and pipe_buffer structures. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-07-10pipe: change the ->pin() operation to ->confirm()Jens Axboe
The name 'pin' was badly chosen, it doesn't pin a pipe buffer in the most commonly used sense in the kernel. So change the name to 'confirm', after debating this issue with Hugh Dickins a bit. A good return from ->confirm() means that the buffer is really there, and that the contents are good. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-05-08VFS: delay the dentry name generation on sockets and pipesEric Dumazet
1) Introduces a new method in 'struct dentry_operations'. This method called d_dname() might be called from d_path() to build a pathname for special filesystems. It is called without locks. Future patches (if we succeed in having one common dentry for all pipes/sockets) may need to change prototype of this method, but we now use : char *d_dname(struct dentry *dentry, char *buffer, int buflen); 2) Adds a dynamic_dname() helper function that eases d_dname() implementations 3) Defines d_dname method for sockets : No more sprintf() at socket creation. This is delayed up to the moment someone does an access to /proc/pid/fd/... 4) Defines d_dname method for pipes : No more sprintf() at pipe creation. This is delayed up to the moment someone does an access to /proc/pid/fd/... A benchmark consisting of 1.000.000 calls to pipe()/close()/close() gives a *nice* speedup on my Pentium(M) 1.6 Ghz : 3.090 s instead of 3.450 s Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Acked-by: Christoph Hellwig <hch@infradead.org> Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-17[PATCH] AUDIT_FD_PAIRAl Viro
Provide an audit record of the descriptor pair returned by pipe() and socketpair(). Rewritten from the original posted to linux-audit by John D. Ramsdell <ramsdell@mitre.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-12-21[PATCH] fix leaks on pipe(2) failure exitsAl Viro
2006-12-13[PATCH] constify pipe_buf_operationsEric Dumazet
- pipe/splice should use const pipe_buf_operations and file_operations - struct pipe_inode_info has an unused field "start" : get rid of it. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Cc: Jens Axboe <jens.axboe@oracle.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] VFS: change struct file to use struct pathJosef "Jeff" Sipek
This patch changes struct file to use struct path instead of having independent pointers to struct dentry and struct vfsmount, and converts all users of f_{dentry,vfsmnt} in fs/ to use f_path.{dentry,mnt}. Additionally, it adds two #define's to make the transition easier for users of the f_dentry and f_vfsmnt. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] don't insert pipe dentries into dentry_hashtable.Eric Dumazet
We currently insert pipe dentries into the global dentry hashtable. This is suboptimal because there is currently no way these entries can be used for a lookup(). (/proc/xxx/fd/xxx uses a different mechanism). Inserting them in dentry hashtable slows dcache lookups. To let __dpath() still work correctly (ie not adding a " (deleted)") after dentry name, we do : - Right after d_alloc(), pretend they are hashed by clearing the DCACHE_UNHASHED bit. - Call d_instantiate() instead of d_add() : dentry is not inserted in hash table. __dpath() & friends work as intended during dentry lifetime. - At dismantle time, once dput() must clear the dentry, setting again DCACHE_UNHASHED bit inside the custom d_delete() function provided by pipe code, so that dput() can just kill_it. This patch, combined with (avoid RCU for never hashed dentries) reduced time of { pipe(p); close(p[0]); close(p[1]);} on my UP machine (1.6GHz Pentium-M) from 3.23 us to 2.86 us (But this patch does not depend on other patches, only bench results) Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Acked-by: David Miller <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] Some cleanup in the pipe codeAndi Kleen
Split the big and hard to read do_pipe function into smaller pieces. This creates new create_write_pipe/free_write_pipe/create_read_pipe functions. These functions are made global so that they can be used by other parts of the kernel. The resulting code is more generic and easier to read and has cleaner error handling and less gotos. [akpm@osdl.org: cleanup] Signed-off-by: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] Remove readv/writev methods and use aio_read/aio_write insteadBadari Pulavarty
This patch removes readv() and writev() methods and replaces them with aio_read()/aio_write() methods. Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] VFS: Permit filesystem to override root dentry on mountDavid Howells
Extend the get_sb() filesystem operation to take an extra argument that permits the VFS to pass in the target vfsmount that defines the mountpoint. The filesystem is then required to manually set the superblock and root dentry pointers. For most filesystems, this should be done with simple_set_mnt() which will set the superblock pointer and then set the root dentry to the superblock's s_root (as per the old default behaviour). The get_sb() op now returns an integer as there's now no need to return the superblock pointer. This patch permits a superblock to be implicitly shared amongst several mount points, such as can be done with NFS to avoid potential inode aliasing. In such a case, simple_set_mnt() would not be called, and instead the mnt_root and mnt_sb would be set directly. The patch also makes the following changes: (*) the get_sb_*() convenience functions in the core kernel now take a vfsmount pointer argument and return an integer, so most filesystems have to change very little. (*) If one of the convenience function is not used, then get_sb() should normally call simple_set_mnt() to instantiate the vfsmount. This will always return 0, and so can be tail-called from get_sb(). (*) generic_shutdown_super() now calls shrink_dcache_sb() to clean up the dcache upon superblock destruction rather than shrink_dcache_anon(). This is required because the superblock may now have multiple trees that aren't actually bound to s_root, but that still need to be cleaned up. The currently called functions assume that the whole tree is rooted at s_root, and that anonymous dentries are not the roots of trees which results in dentries being left unculled. However, with the way NFS superblock sharing are currently set to be implemented, these assumptions are violated: the root of the filesystem is simply a dummy dentry and inode (the real inode for '/' may well be inaccessible), and all the vfsmounts are rooted on anonymous[*] dentries with child trees. [*] Anonymous until discovered from another tree. (*) The documentation has been adjusted, including the additional bit of changing ext2_* into foo_* in the documentation. [akpm@osdl.org: convert ipath_fs, do other stuff] Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Nathan Scott <nathans@sgi.com> Cc: Roland Dreier <rolandd@cisco.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-05-02[PATCH] vmsplice: restrict stealing a little moreJens Axboe
Apply the same rules as the anon pipe pages, only allow stealing if no one else is using the page. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-05-01[PATCH] pipe: enable atomic copying of pipe data to/from user spaceJens Axboe
The pipe ->map() method uses kmap() to virtually map the pages, which is both slow and has known scalability issues on SMP. This patch enables atomic copying of pipe pages, by pre-faulting data and using kmap_atomic() instead. lmbench bw_pipe and lat_pipe measurements agree this is a Good Thing. Here are results from that on a UP machine with highmem (1.5GiB of RAM), running first a UP kernel, SMP kernel, and SMP kernel patched. Vanilla-UP: Pipe bandwidth: 1622.28 MB/sec Pipe bandwidth: 1610.59 MB/sec Pipe bandwidth: 1608.30 MB/sec Pipe latency: 7.3275 microseconds Pipe latency: 7.2995 microseconds Pipe latency: 7.3097 microseconds Vanilla-SMP: Pipe bandwidth: 1382.19 MB/sec Pipe bandwidth: 1317.27 MB/sec Pipe bandwidth: 1355.61 MB/sec Pipe latency: 9.6402 microseconds Pipe latency: 9.6696 microseconds Pipe latency: 9.6153 microseconds Patched-SMP: Pipe bandwidth: 1578.70 MB/sec Pipe bandwidth: 1579.95 MB/sec Pipe bandwidth: 1578.63 MB/sec Pipe latency: 9.1654 microseconds Pipe latency: 9.2266 microseconds Pipe latency: 9.1527 microseconds Signed-off-by: Jens Axboe <axboe@suse.de>
2006-05-01[PATCH] pipe: introduce ->pin() buffer operationJens Axboe
The ->map() function is really expensive on highmem machines right now, since it has to use the slower kmap() instead of kmap_atomic(). Splice rarely needs to access the virtual address of a page, so it's a waste of time doing it. Introduce ->pin() to take over the responsibility of making sure the page data is valid. ->map() is then reduced to just kmap(). That way we can also share a most of the pipe buffer ops between pipe.c and splice.c Signed-off-by: Jens Axboe <axboe@suse.de>
2006-05-01[PATCH] splice: fix bugs in pipe_to_file()Jens Axboe
Found by Oleg Nesterov <oleg@tv-sign.ru>, fixed by me. - Only allow full pages to go to the page cache. - Check page != buf->page instead of using PIPE_BUF_FLAG_STOLEN. - Remember to clear 'stolen' if add_to_page_cache() fails. And as a cleanup on that: - Make the bottom fall-through logic a little less convoluted. Also make the steal path hold an extra reference to the page, so we don't have to differentiate between stolen and non-stolen at the end. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-04-30[PATCH] splice: fix bugs with stealing regular pipe pagesJens Axboe
- Check that page has suitable count for stealing in the regular pipes. - pipe_to_file() assumes that the page is locked on succesful steal, so do that in the pipe steal hook - Missing unlock_page() in add_to_page_cache() failure. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-04-11[PATCH] splice: add support for sys_tee()Jens Axboe
Basically an in-kernel implementation of tee, which uses splice and the pipe buffers as an intelligent way to pass data around by reference. Where the user space tee consumes the input and produces a stdout and file output, this syscall merely duplicates the data inside a pipe to another pipe. No data is copied, the output just grabs a reference to the input pipe data. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-04-11[PATCH] another round of fs/pipe.c cleanupsIngo Molnar
make pipe.c a bit more readable and hackable. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jens Axboe <axboe@suse.de>
2006-04-11[PATCH] pipe.c/fifo.c code cleanupsIngo Molnar
more code cleanups after the macro conversion: - standardize on 'struct pipe_inode_info *pipe' variable names - introduce 'pipe' temporaries to reduce mass inode->i_pipe dereferencing Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jens Axboe <axboe@suse.de>
2006-04-11[PATCH] get rid of the PIPE_*() macrosIngo Molnar
get rid of the PIPE_*() macros. Scripted transformation. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Jens Axboe <axboe@suse.de>
2006-04-11[PATCH] splice: add direct fd <-> fd splicing supportJens Axboe
It's more efficient for sendfile() emulation. Basically we cache an internal private pipe and just use that as the intermediate area for pages. Direct splicing is not available from sys_splice(), it is only meant to be used for sendfile() emulation. Additional patch from Ingo Molnar to avoid the PIPE_BUFFERS loop at exit for the normal fast path. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-04-10[PATCH] introduce a "kernel-internal pipe object" abstractionIngo Molnar
separate out the 'internal pipe object' abstraction, and make it usable to splice. This cleans up and fixes several aspects of the internal splice APIs and the pipe code: - pipes: the allocation and freeing of pipe_inode_info is now more symmetric and more streamlined with existing kernel practices. - splice: small micro-optimization: less pointer dereferencing in splice methods Signed-off-by: Ingo Molnar <mingo@elte.hu> Update XFS for the ->splice_read/->splice_write changes. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-04-02[PATCH] splice: fix page stealing LRU handling.Jens Axboe
Originally from Nick Piggin, just adapted to the newer branch. You can't check PageLRU without holding zone->lru_lock. The page release code can get away with it only because the page refcount is 0 at that point. Also, you can't reliably remove pages from the LRU unless the refcount is 0. Ever. Signed-off-by: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Jens Axboe <axboe@suse.de>
2006-04-02[PATCH] splice: improve writeback and clean up page stealingJens Axboe
By cleaning up the writeback logic (killing write_one_page() and the manual set_page_dirty()), we can get rid of ->stolen inside the pipe_buffer and just keep it local in pipe_to_file(). This also adds dirty page balancing logic and O_SYNC handling. Signed-off-by: Jens Axboe <axboe@suse.de>
2006-03-30[PATCH] splice: add support for SPLICE_F_MOVE flagJens Axboe
This enables the caller to migrate pages from one address space page cache to another. In buzz word marketing, you can do zero-copy file copies! Signed-off-by: Jens Axboe <axboe@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-30[PATCH] Introduce sys_splice() system callJens Axboe
This adds support for the sys_splice system call. Using a pipe as a transport, it can connect to files or sockets (latter as output only). From the splice.c comments: "splice": joining two ropes together by interweaving their strands. This is the "extended pipe" functionality, where a pipe is used as an arbitrary in-memory buffer. Think of a pipe as a small kernel buffer that you can use to transfer data from one end to the other. The traditional unix read/write is extended with a "splice()" operation that transfers data buffers to or from a pipe buffer. Named by Larry McVoy, original implementation from Linus, extended by Jens to support splicing to files and fixing the initial implementation bugs. Signed-off-by: Jens Axboe <axboe@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] Make most file operations structs in fs/ constArjan van de Ven
This is a conversion to make the various file_operations structs in fs/ const. Basically a regexp job, with a few manual fixups The goal is both to increase correctness (harder to accidentally write to shared datastructures) and reducing the false sharing of cachelines with things that get dirty in .data (while .rodata is nicely read only and thus cache clean) Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-26[PATCH] Use __read_mostly on some hot fs variablesEric Dumazet
I discovered on oprofile hunting on a SMP platform that dentry lookups were slowed down because d_hash_mask, d_hash_shift and dentry_hashtable were in a cache line that contained inodes_stat. So each time inodes_stats is changed by a cpu, other cpus have to refill their cache line. This patch moves some variables to the __read_mostly section, in order to avoid false sharing. RCU dentry lookups can go full speed. Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] use kzalloc and kcalloc in core fs codeOliver Neukum
Signed-off-by: Oliver Neukum <oliver@neukum.name> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-08Mark the pipe file operations staticLinus Torvalds
They aren't used (nor even really usable) outside of pipe.c anyway Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[PATCH] Unlinline a bunch of other functionsArjan van de Ven
Remove the "inline" keyword from a bunch of big functions in the kernel with the goal of shrinking it by 30kb to 40kb Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Acked-by: Jeff Garzik <jgarzik@pobox.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] replace inode_update_time with file_update_timeChristoph Hellwig
To allow various options to work per-mount instead of per-sb we need a struct vfsmount when updating ctime and mtime. This preparation patch replaces the inode_update_time routine with a file_update_atime routine so we can easily get at the vfsmount. (and the file makes more sense in this context anyway). Also get rid of the unused second argument - we always want to update the ctime when calling this routine. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@ftp.linux.org.uk> Cc: Anton Altaparmakov <aia21@cantab.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09[PATCH] mutex subsystem, semaphore to mutex: VFS, ->i_semJes Sorensen
This patch converts the inode semaphore to a mutex. I have tested it on XFS and compiled as much as one can consider on an ia64. Anyway your luck with it might be different. Modified-by: Ingo Molnar <mingo@elte.hu> (finished the conversion) Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2005-09-10[PATCH] sched: TASK_NONINTERACTIVEIngo Molnar
This patch implements a task state bit (TASK_NONINTERACTIVE), which can be used by blocking points to mark the task's wait as "non-interactive". This does not mean the task will be considered a CPU-hog - the wait will simply not have an effect on the waiting task's priority - positive or negative alike. Right now only pipe_wait() will make use of it, because it's a common source of not-so-interactive waits (kernel compilation jobs, etc.). Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] pipe: remove redundant fifo_poll abstractionPekka Enberg
Remove a redundant fifo_poll() abstraction from fs/pipe.c and adds a big fat comment stating we set POLLERR for FIFOs too on Linux unlike most Unices. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Cc: Manfred Spraul <manfred@colorfullife.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
