commit 39aa3cb3e8250db9188a6f1e3fb62ffa1a717678 upstream.
So it can be used by all that need to check for that.
Signed-off-by: Stefan Bader <stefan.bader@canonical.com>
commit d7824370e26325c881b665350ce64fb0a4fde24a upstream.
This commit makes the stack guard page somewhat less visible to user
space. It does this by:
- not showing the guard page in /proc/<pid>/maps
It looks like lvm-tools will actually read /proc/self/maps to figure
out where all its mappings are, and effectively do a specialized
"mlockall()" in user space. By not showing the guard page as part of
the mapping (by just adding PAGE_SIZE to the start for grows-up
pages), lvm-tools ends up not being aware of it.
- by also teaching the _real_ mlock() functionality not to try to lock
the guard page.
That would just expand the mapping down to create a new guard page,
so there really is no point in trying to lock it in place.
It would perhaps be nice to show the guard page specially in
/proc/<pid>/maps (or at least mark grow-down segments some way), but
let's not open ourselves up to more breakage by user space from programs
that depends on the exact deails of the 'maps' file.
Special thanks to Henrique de Moraes Holschuh for diving into lvm-tools
source code to see what was going on with the whole new warning.
Reported-and-tested-by: François Valenduc <francois.valenduc@tvcablenet.be
Reported-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br>
commit 34441427aab4bdb3069a4ffcda69a99357abcb2e upstream.
Originally, commit d899bf7b ("procfs: provide stack information for
threads") attempted to introduce a new feature for showing where the
threadstack was located and how many pages are being utilized by the
stack.
Commit c44972f1 ("procfs: disable per-task stack usage on NOMMU") was
applied to fix the NO_MMU case.
Commit 89240ba0 ("x86, fs: Fix x86 procfs stack information for threads on
64-bit") was applied to fix a bug in ia32 executables being loaded.
Commit 9ebd4eba7 ("procfs: fix /proc/<pid>/stat stack pointer for kernel
threads") was applied to fix a bug which had kernel threads printing a
userland stack address.
Commit 1306d603f ('proc: partially revert "procfs: provide stack
information for threads"') was then applied to revert the stack pages
being used to solve a significant performance regression.
This patch nearly undoes the effect of all these patches.
The reason for reverting these is it provides an unusable value in
field 28. For x86_64, a fork will result in the task->stack_start
value being updated to the current user top of stack and not the stack
start address. This unpredictability of the stack_start value makes
it worthless. That includes the intended use of showing how much stack
space a thread has.
Other architectures will get different values. As an example, ia64
gets 0. The do_fork() and copy_process() functions appear to treat the
stack_start and stack_size parameters as architecture specific.
I only partially reverted c44972f1 ("procfs: disable per-task stack usage
on NOMMU") . If I had completely reverted it, I would have had to change
mm/Makefile only build pagewalk.o when CONFIG_PROC_PAGE_MONITOR is
configured. Since I could not test the builds without significant effort,
I decided to not change mm/Makefile.
I only partially reverted 89240ba0 ("x86, fs: Fix x86 procfs stack
information for threads on 64-bit") . I left the KSTK_ESP() change in
place as that seemed worthwhile.
Signed-off-by: Robin Holt <holt@sgi.com>
Cc: Stefani Seibold <stefani@seibold.net>
A patch to give a better overview of the userland application stack usage,
especially for embedded linux.
Currently you are only able to dump the main process/thread stack usage
which is showed in /proc/pid/status by the "VmStk" Value. But you get no
information about the consumed stack memory of the the threads.
There is an enhancement in the /proc/<pid>/{task/*,}/*maps and which marks
the vm mapping where the thread stack pointer reside with "[thread stack
xxxxxxxx]". xxxxxxxx is the maximum size of stack. This is a value
information, because libpthread doesn't set the start of the stack to the
top of the mapped area, depending of the pthread usage.
A sample output of /proc/<pid>/task/<tid>/maps looks like:
08048000-08049000 r-xp 00000000 03:00 8312 /opt/z
08049000-0804a000 rw-p 00001000 03:00 8312 /opt/z
0804a000-0806b000 rw-p 00000000 00:00 0 [heap]
a7d12000-a7d13000 ---p 00000000 00:00 0
a7d13000-a7f13000 rw-p 00000000 00:00 0 [thread stack: 001ff4b4]
a7f13000-a7f14000 ---p 00000000 00:00 0
a7f14000-a7f36000 rw-p 00000000 00:00 0
a7f36000-a8069000 r-xp 00000000 03:00 4222 /lib/libc.so.6
a8069000-a806b000 r--p 00133000 03:00 4222 /lib/libc.so.6
a806b000-a806c000 rw-p 00135000 03:00 4222 /lib/libc.so.6
a806c000-a806f000 rw-p 00000000 00:00 0
a806f000-a8083000 r-xp 00000000 03:00 14462 /lib/libpthread.so.0
a8083000-a8084000 r--p 00013000 03:00 14462 /lib/libpthread.so.0
a8084000-a8085000 rw-p 00014000 03:00 14462 /lib/libpthread.so.0
a8085000-a8088000 rw-p 00000000 00:00 0
a8088000-a80a4000 r-xp 00000000 03:00 8317 /lib/ld-linux.so.2
a80a4000-a80a5000 r--p 0001b000 03:00 8317 /lib/ld-linux.so.2
a80a5000-a80a6000 rw-p 0001c000 03:00 8317 /lib/ld-linux.so.2
afaf5000-afb0a000 rw-p 00000000 00:00 0 [stack]
ffffe000-fffff000 r-xp 00000000 00:00 0 [vdso]
Also there is a new entry "stack usage" in /proc/<pid>/{task/*,}/status
which will you give the current stack usage in kb.
A sample output of /proc/self/status looks like:
State: R (running)
Tgid: 507
Pid: 507
CapBnd: fffffffffffffeff
voluntary_ctxt_switches: 0
nonvoluntary_ctxt_switches: 0
Stack usage: 12 kB
I also fixed stack base address in /proc/<pid>/{task/*,}/stat to the base
address of the associated thread stack and not the one of the main
process. This makes more sense.
[akpm@linux-foundation.org: fs/proc/array.c now needs walk_page_range()]
Signed-off-by: Stefani Seibold <stefani@seibold.net>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Cc: Randy Dunlap <randy.dunlap@oracle.com>
Andrew Morton pointed out similar string hacking and obfuscated check for
zero-length input at the end of the function, David Rientjes suggested to
use strict_strtol to replace simple_strtol, this patch cover above
suggestions, add removing of leading and trailing whitespace from user
input. It does not change function behavious.
Signed-off-by: Vincent Li <macli@brc.ubc.ca>
Acked-by: David Rientjes <rientjes@google.com>
Cc: Matt Mackall <mpm@selenic.com>
Cc: Amerigo Wang <xiyou.wangcong@gmail.com>
The patch makes the clear_refs more versatile in adding the option to
select anonymous pages or file backed pages for clearing. This addition
has a measurable impact on user space application performance as it
decreases the number of pagewalks in scenarios where one is only
interested in a specific type of page (anonymous or file mapped).
The patch adds anonymous and file backed filters to the clear_refs interface.
echo 1 > /proc/PID/clear_refs resets the bits on all pages
echo 2 > /proc/PID/clear_refs resets the bits on anonymous pages only
echo 3 > /proc/PID/clear_refs resets the bits on file backed pages only
Any other value is ignored
Signed-off-by: Moussa A. Ba <moussa.a.ba@gmail.com>
Signed-off-by: Jared E. Hulbert <jaredeh@gmail.com>
mm_for_maps() takes ->mmap_sem after security checks, this looks
strange and obfuscates the locking rules. Move this lock to its
single caller, m_start().
Acked-by: Serge Hallyn <serue@us.ibm.com>
Signed-off-by: James Morris <jmorris@namei.org>
The intention of commit aae8679b0ebcaa92f99c1c3cb0cd651594a43915
("pagemap: fix bug in add_to_pagemap, require aligned-length reads of
/proc/pid/pagemap") was to force reads of /proc/pid/pagemap to be a
multiple of 8 bytes, but now it allows to read 0 bytes, which actually
puts some data to user's buffer. According to POSIX, if count is zero,
read() should return zero and has no other results.
Signed-off-by: Vitaly Mayatskikh <v.mayatskih@gmail.com>
Cc: Thomas Tuttle <ttuttle@google.com>
Acked-by: Matt Mackall <mpm@selenic.com>
Cc: <stable@kernel.org>
Recently, it's argued that what proc/pid/maps shows is ugly when a 32bit
binary runs on 64bit host.
/proc/pid/maps outputs vma's pgoff member but vma->pgoff is of no use
information is the vma is for ANON. With this patch, /proc/pid/maps shows
just 0 if no file backing store.
[kamezawa.hiroyu@jp.fujitsu.com: coding-style fixes]
Signed-off-by: KAMEZAWA Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com>
Cc: Mike Waychison <mikew@google.com>
Reported-by: Ying Han <yinghan@google.com>
Cc: Hugh Dickins <hugh@veritas.com>
fs/proc/task_mmu.c:696:12: warning: cast removes address space of expression
fs/proc/task_mmu.c:696:9: warning: incorrect type in assignment (different address spaces)
fs/proc/task_mmu.c:696:9: expected unsigned long long [noderef] [usertype] <asn:1>*out
fs/proc/task_mmu.c:696:9: got unsigned long long [usertype] *<noident>
fs/proc/task_mmu.c:697:12: warning: cast removes address space of expression
fs/proc/task_mmu.c:697:9: warning: incorrect type in assignment (different address spaces)
fs/proc/task_mmu.c:697:9: expected unsigned long long [noderef] [usertype] <asn:1>*end
fs/proc/task_mmu.c:697:9: got unsigned long long [usertype] *<noident>
fs/proc/task_mmu.c:723:12: warning: cast removes address space of expression
fs/proc/task_mmu.c:723:26: error: subtraction of different types can't work (different address spaces)
fs/proc/task_mmu.c:725:24: error: subtraction of different types can't work (different address spaces)
Signed-off-by: Milind Arun Choudhary <milindchoudhary@gmail.com>
The KernelPageSize entry in /proc/pid/smaps is the pagesize used by the
kernel to back a VMA. This matches the size used by the MMU in the
majority of cases. However, one counter-example occurs on PPC64 kernels
whereby a kernel using 64K as a base pagesize may still use 4K pages for
the MMU on older processor. To distinguish, this patch reports
MMUPageSize as the pagesize used by the MMU in /proc/pid/smaps.
Signed-off-by: Mel Gorman <mel@csn.ul.ie>
Cc: "KOSAKI Motohiro" <kosaki.motohiro@jp.fujitsu.com>
It is useful to verify a hugepage-aware application is using the expected
pagesizes for its memory regions. This patch creates an entry called
KernelPageSize in /proc/pid/smaps that is the size of page used by the
kernel to back a VMA. The entry is not called PageSize as it is possible
the MMU uses a different size. This extension should not break any sensible
parser that skips lines containing unrecognised information.
Acked-by: "KOSAKI Motohiro" <kosaki.motohiro@jp.fujitsu.com>
The large pages fix from bcf8039ed45 broke 32-bit pagemap by pulling the
pagemap entry code out into a function with the wrong return type.
Pagemap entries are 64 bits on all systems and unsigned long is only 32
bits on 32-bit systems.
Signed-off-by: Matt Mackall <mpm@selenic.com>
Reported-by: Doug Graham <dgraham@nortel.com>
Cc: Dave Hansen <dave@linux.vnet.ibm.com>
Cc: <stable@kernel.org> [2.6.26.x, 2.6.27.x]
Commit 4752c369789250eafcd7813e11c8fb689235b0d2 aka
"maps4: simplify interdependence of maps and smaps" broke /proc/pid/smaps,
causing it to display some vmas twice and other vmas not at all. For example:
grep .- /proc/1/smaps >/tmp/smaps; diff /proc/1/maps /tmp/smaps
1 25d24
2 < 7fd7e23aa000-7fd7e23ac000 rw-p 7fd7e23aa000 00:00 0
3 28a28
4 > ffffffffff600000-ffffffffff601000 r-xp 00000000 00:00 0 [vsyscall]
The bug has something to do with setting m->version before all the
seq_printf's have been performed. show_map was doing this correctly,
but show_smap was doing this in the middle of its seq_printf sequence.
This patch arranges things so that the setting of m->version in show_smap
is also done at the end of its seq_printf sequence.
Testing: in addition to the above grep test, for each process I summed
up the 'Rss' fields of /proc/pid/smaps and compared that to the 'VmRSS'
field of /proc/pid/status. All matched except for Xorg (which has a
/dev/mem mapping which Rss accounts for but VmRSS does not). This result
gives us some confidence that neither /proc/pid/maps nor /proc/pid/smaps
are any longer skipping or double-counting vmas.
Signed-off-by: Joe Korty <joe.korty@ccur.com>
After commit 831830b5a2b5d413407adf380ef62fe17d6fcbf2 aka
"restrict reading from /proc/<pid>/maps to those who share ->mm or can ptrace"
sysctl stopped being relevant because commit moved security checks from ->show
time to ->start time (mm_for_maps()).
Acked-by: Kees Cook <kees.cook@canonical.com>
This addresses
http://bugzilla.kernel.org/show_bug.cgi?id=11318
In function show_map (file: fs/proc/task_mmu.c), if vma->vm_pgoff > 2^20
than (vma->vm_pgoff << PAGE_SIZE) is greater than 2^32 (with PAGE_SIZE
equal to 4096 (i.e. 2^12). The next seq_printf use an unsigned long for
the conversion of (vma->vm_pgoff << PAGE_SIZE), as a result the offset
value displayed in /proc/self/maps is truncated if the page offset is
greater than 2^20.
A test that shows this issue:
#define _GNU_SOURCE
#include <sys/types.h>
#include <sys/stat.h>
#include <sys/mman.h>
#include <stdlib.h>
#include <stdio.h>
#include <fcntl.h>
#include <unistd.h>
#include <string.h>
#define PAGE_SIZE (getpagesize())
#if __i386__
# define U64_STR "%llx"
#elif __x86_64
# define U64_STR "%lx"
#else
# error "Architecture Unsupported"
#endif
int main(int argc, char *argv[])
int fd;
char *addr;
off64_t offset = 0x10000000;
char *filename = "/dev/zero";
fd = open(filename, O_RDONLY);
if (fd < 0) {
perror("open");
return 1;
offset *= 0x10;
printf("offset = " U64_STR "\n", offset);
addr = (char*)mmap64(NULL, PAGE_SIZE, PROT_READ, MAP_PRIVATE, fd,
offset);
if ((void*)addr == MAP_FAILED) {
perror("mmap64");
return 1;
FILE *fmaps;
char *line = NULL;
size_t len = 0;
ssize_t read;
size_t filename_len = strlen(filename);
fmaps = fopen("/proc/self/maps", "r");
if (!fmaps) {
perror("fopen");
return 1;
while ((read = getline(&line, &len, fmaps)) != -1) {
if ((read > filename_len + 1)
&& (strncmp(&line[read - filename_len - 1], filename, filename_len) == 0))
printf("%s", line);
if (line)
free(line);
fclose(fmaps);
close(fd);
return 0;
Signed-off-by: Clement Calmels <cboulte@gmail.com>
struct pagemap_walk was placed on stack, some hooks are initialized, the
rest (->pgd_entry, ->pud_entry, ->pte_entry) are valid but junk.
Reported-by: Eric Sesterhenn <snakebyte@gmx.de>
Cc: "Vegard Nossum" <vegard.nossum@gmail.com>
Cc: <stable@kernel.org> [2.6.25.x, 2.6.26.x]
Enable security modules to distinguish reading of process state via
proc from full ptrace access by renaming ptrace_may_attach to
ptrace_may_access and adding a mode argument indicating whether only
read access or full attach access is requested. This allows security
modules to permit access to reading process state without granting
full ptrace access. The base DAC/capability checking remains unchanged.
Read access to /proc/pid/mem continues to apply a full ptrace attach
check since check_mem_permission() already requires the current task
to already be ptracing the target. The other ptrace checks within
proc for elements like environ, maps, and fds are changed to pass the
read mode instead of attach.
In the SELinux case, we model such reading of process state as a
reading of a proc file labeled with the target process' label. This
enables SELinux policy to permit such reading of process state without
permitting control or manipulation of the target process, as there are
a number of cases where programs probe for such information via proc
but do not need to be able to control the target (e.g. procps,
lsof, PolicyKit, ConsoleKit). At present we have to choose between
allowing full ptrace in policy (more permissive than required/desired)
or breaking functionality (or in some cases just silencing the denials
via dontaudit rules but this can hide genuine attacks).
This version of the patch incorporates comments from Casey Schaufler
(change/replace existing ptrace_may_attach interface, pass access
mode), and Chris Wright (provide greater consistency in the checking).
Note that like their predecessors __ptrace_may_attach and
ptrace_may_attach, the __ptrace_may_access and ptrace_may_access
interfaces use different return value conventions from each other (0
or -errno vs. 1 or 0). I retained this difference to avoid any
changes to the caller logic but made the difference clearer by
changing the latter interface to return a bool rather than an int and
by adding a comment about it to ptrace.h for any future callers.
Signed-off-by: Stephen Smalley <sds@tycho.nsa.gov>
Acked-by: Chris Wright <chrisw@sous-sol.org>
Fix some issues in pagemap_read noted by Alexey:
- initialize pagemap_walk.mm to "mm" , so the code starts working as
advertised
- initialize ->private to "&pm" so it wouldn't immediately oops in
pagemap_pte_hole()
- unstatic struct pagemap_walk, so two threads won't fsckup each other
(including those started by root, including flipping ->mm when you don't
have permissions)
- pagemap_read() contains two calls to ptrace_may_attach(), second one
looks unneeded.
- avoid possible kmalloc(0) and integer wraparound.
[ Personally, I'd just remove the functionality entirely - Linus ]
Don't use a static entry, so as to prevent races during concurrent use
of this function.
Reported-by: Alexey Dobriyan <adobriyan@gmail.com>
We were walking right into huge page areas in the pagemap walker, and
calling the pmds pmd_bad() and clearing them.
That leaked huge pages. Bad.
This patch at least works around that for now. It ignores huge pages in
the pagemap walker for the time being, and won't leak those pages.
Signed-off-by: Dave Hansen <dave@linux.vnet.ibm.com>
We need this at least for huge page detection for now, because powerpc
needs the vm_area_struct to be able to determine whether a virtual address
is referring to a huge page (its pmd_huge() doesn't work).
It might also come in handy for some of the other users.
/proc/pid/pagemap
Fix a bug in add_to_pagemap. Previously, since pm->out was a char *,
put_user was only copying 1 byte of every PFN, resulting in the top 7
bytes of each PFN not being copied. By requiring that reads be a multiple
of 8 bytes, I can make pm->out and pm->end u64*s instead of char*s, which
makes put_user work properly, and also simplifies the logic in
add_to_pagemap a bit.
Signed-off-by: Thomas Tuttle <ttuttle@google.com>
Removed duplicated include files <linux/ptrace.h> and <linux/seq_file.h> in
fs/proc/task_mmu.c.
Signed-off-by: Huang Weiyi <weiyi.huang@gmail.com>
The kernel implements readlink of /proc/pid/exe by getting the file from
the first executable VMA. Then the path to the file is reconstructed and
reported as the result.
Because of the VMA walk the code is slightly different on nommu systems.
This patch avoids separate /proc/pid/exe code on nommu systems. Instead of
walking the VMAs to find the first executable file-backed VMA we store a
reference to the exec'd file in the mm_struct.
That reference would prevent the filesystem holding the executable file
from being unmounted even after unmapping the VMAs. So we track the number
of VM_EXECUTABLE VMAs and drop the new reference when the last one is
unmapped. This avoids pinning the mounted filesystem.
[akpm@linux-foundation.org: improve comments]
[yamamoto@valinux.co.jp: fix dup_mmap]
Signed-off-by: Matt Helsley <matthltc@us.ibm.com>
Cc: Oleg Nesterov <oleg@tv-sign.ru>
Cc:"Eric W. Biederman" <ebiederm@xmission.com>
Signed-off-by: YAMAMOTO Takashi <yamamoto@valinux.co.jp>
Show the amount of swap for each vma. This can be used to see where all the
swap goes.
Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Make the needlessly global swap_pte_to_pagemap_entry() static.
Signed-off-by: Adrian Bunk <bunk@kernel.org>
Change pagemap output format to allow for future reporting of huge pages.
(Format comment and minor cleanups: mpm@selenic.com)
Signed-off-by: Hans Rosenfeld <hans.rosenfeld@amd.com>
Fix pagemap_read() error handling by releasing acquired resources and checking
for get_user_pages() partial failure.
Signed-off-by: Marcelo Tosatti <mtosatti@redhat.com>
There seems to be a bug in the PM_SPECIAL macro for /proc/pid/pagemap. I
think masking out those other bits makes more sense then setting all those
mask bits.
Signed-off-by: Hans Rosenfeld <Hans.Rosenfeld@amd.com>
Cc: Dave Hansen <haveblue@us.ibm.com>
seq_path() is always called with a dentry and a vfsmount from a struct path.
Make seq_path() take it directly as an argument.
Signed-off-by: Jan Blunck <jblunck@suse.de>
Cc: "J. Bruce Fields" <bfields@fieldses.org>
Cc: Neil Brown <neilb@suse.de>
proc_get_link() is always called with a dentry and a vfsmount from a struct
path. Make proc_get_link() take it directly as an argument.
Acked-by: Christoph Hellwig <hch@infradead.org>
Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de>
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
Acked-By: David Howells <dhowells@redhat.com>
Acked-by: Bryan Wu <bryan.wu@analog.com>
Acked-by: Jesper Nilsson <jesper.nilsson@axis.com>
Cc: <linux-arch@vger.kernel.org>
Currently we possibly lookup the pid in the wrong pid namespace. So
seq_file convert proc_pid_status which ensures the proper pid namespaces is
passed in.
[akpm@linux-foundation.org: build fix]
[akpm@linux-foundation.org: another build fix]
[akpm@linux-foundation.org: s390 build fix]
[akpm@linux-foundation.org: fix task_name() output]
[akpm@linux-foundation.org: fix nommu build]
Cc: Andrew Morgan <morgan@kernel.org>
Cc: Serge Hallyn <serue@us.ibm.com>
Cc: Cedric Le Goater <clg@fr.ibm.com>
Cc: Pavel Emelyanov <xemul@openvz.org>
Cc: Paul Menage <menage@google.com>
Cc: Paul Jackson <pj@sgi.com>
Make /proc/ page monitoring configurable
This puts the following files under an embedded config option:
/proc/pid/clear_refs
/proc/pid/smaps
/proc/pid/pagemap
/proc/kpagecount
/proc/kpageflags
[akpm@linux-foundation.org: Kconfig fix]
This interface provides a mapping for each page in an address space to its
physical page frame number, allowing precise determination of what pages are
mapped and what pages are shared between processes.
New in this version:
- headers gone again (as recommended by Dave Hansen and Alan Cox)
- 64-bit entries (as per discussion with Andi Kleen)
- swap pte information exported (from Dave Hansen)
- page walker callback for holes (from Dave Hansen)
- direct put_user I/O (as suggested by Rusty Russell)
This patch folds in cleanups and swap PTE support from Dave Hansen
<haveblue@us.ibm.com>.
Reorder source so that all the code and data for each interface is together.
This puts all the clear_refs code where it belongs and probably lets things
compile on MMU-less systems as well.
This pulls the shared map display code out of show_map and puts it in
show_smap where it belongs.
Use the generic pagewalker for smaps and clear_refs
The "proportional set size" (PSS) of a process is the count of pages it has
in memory, where each page is divided by the number of processes sharing
it. So if a process has 1000 pages all to itself, and 1000 shared with one
other process, its PSS will be 1500.
- lwn.net: "ELC: How much memory are applications really using?"
The PSS proposed by Matt Mackall is a very nice metic for measuring an
process's memory footprint. So collect and export it via
/proc/<pid>/smaps.
Matt Mackall's pagemap/kpagemap and John Berthels's exmap can also do the
job. They are comprehensive tools. But for PSS, let's do it in the simple
way.
Cc: John Berthels <jjberthels@gmail.com>
Cc: Bernardo Innocenti <bernie@codewiz.org>
Cc: Padraig Brady <P@draigBrady.com>
Cc: Denys Vlasenko <vda.linux@googlemail.com>
Cc: Balbir Singh <balbir@linux.vnet.ibm.com>
Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn>
Contents of /proc/*/maps is sensitive and may become sensitive after
open() (e.g. if target originally shares our ->mm and later does exec
on suid-root binary).
Check at read() (actually, ->start() of iterator) time that mm_struct
we'd grabbed and locked is
- still the ->mm of target
- equal to reader's ->mm or the target is ptracable by reader.
The /proc/pid/ "maps", "smaps", and "numa_maps" files contain sensitive
information about the memory location and usage of processes. Issues:
- maps should not be world-readable, especially if programs expect any
kind of ASLR protection from local attackers.
- maps cannot just be 0400 because "-D_FORTIFY_SOURCE=2 -O2" makes glibc
check the maps when %n is in a *printf call, and a setuid(getuid())
process wouldn't be able to read its own maps file. (For reference
see http://lkml.org/lkml/2006/1/22/150)
- a system-wide toggle is needed to allow prior behavior in the case of
non-root applications that depend on access to the maps contents.
This change implements a check using "ptrace_may_attach" before allowing
access to read the maps contents. To control this protection, the new knob
/proc/sys/kernel/maps_protect has been added, with corresponding updates to
the procfs documentation.
[akpm@linux-foundation.org: build fixes]
[akpm@linux-foundation.org: New sysctl numbers are old hat]
Signed-off-by: Kees Cook <kees@outflux.net>
Cc: Arjan van de Ven <arjan@infradead.org>
Adds /proc/pid/clear_refs. When any non-zero number is written to this file,
pte_mkold() and ClearPageReferenced() is called for each pte and its
corresponding page, respectively, in that task's VMAs. This file is only
writable by the user who owns the task.
It is now possible to measure _approximately_ how much memory a task is using
by clearing the reference bits with
echo 1 > /proc/pid/clear_refs
and checking the reference count for each VMA from the /proc/pid/smaps output
at a measured time interval. For example, to observe the approximate change
in memory footprint for a task, write a script that clears the references
(echo 1 > /proc/pid/clear_refs), sleeps, and then greps for Pgs_Referenced and
extracts the size in kB. Add the sizes for each VMA together for the total
referenced footprint. Moments later, repeat the process and observe the
difference.
For example, using an efficient Mozilla:
accumulated time referenced memory
0 s 408 kB
1 s 408 kB
2 s 556 kB
3 s 1028 kB
4 s 872 kB
5 s 1956 kB
6 s 416 kB
7 s 1560 kB
8 s 2336 kB
9 s 1044 kB
10 s 416 kB
This is a valuable tool to get an approximate measurement of the memory
footprint for a task.
Cc: Christoph Lameter <clameter@sgi.com>
Signed-off-by: David Rientjes <rientjes@google.com>
[mpm@selenic.com: rename for_each_pmd]
Adds an additional unsigned long field to struct mem_size_stats called
'referenced'. For each pte walked in the smaps code, this field is
incremented by PAGE_SIZE if it has pte-reference bits.
An additional line was added to the /proc/pid/smaps output for each VMA to
indicate how many pages within it are currently marked as referenced or
accessed.
Extracts the pmd walker from smaps-specific code in fs/proc/task_mmu.c.
The new struct pmd_walker includes the struct vm_area_struct of the memory to
walk over. Iteration begins at the vma->vm_start and completes at
vma->vm_end. A pointer to another data structure may be stored in the private
field such as struct mem_size_stats, which acts as the smaps accumulator. For
each pmd in the VMA, the action function is called with a pointer to its
struct vm_area_struct, a pointer to the pmd_t, its start and end addresses,
and the private field.
The interface for walking pmd's in a VMA for fs/proc/task_mmu.c is now:
void for_each_pmd(struct vm_area_struct *vma,
void (*action)(struct vm_area_struct *vma,
pmd_t *pmd, unsigned long addr,
unsigned long end,
void *private),
void *private);
Since the pmd walker is now extracted from the smaps code, smaps_one_pmd() is
invoked for each pmd in the VMA. Its behavior and efficiency is identical to
the existing implementation.
Many struct file_operations in the kernel can be "const". Marking them const
moves these to the .rodata section, which avoids false sharing with potential
dirty data. In addition it'll catch accidental writes at compile time to
these shared resources.
Signed-off-by: Arjan van de Ven <arjan@linux.intel.com>
Change all the uses of f_{dentry,vfsmnt} to f_path.{dentry,mnt} in the proc
filesystem code.
Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu>
Move the fallback arch_vma_name() to a sensible place (kernel/signal.c).
Currently it's in fs/proc/task_mmu.c, a file that is dependent on both
CONFIG_PROC_FS and CONFIG_MMU being enabled, but it's used from
kernel/signal.c from where it is called unconditionally.
[akpm@osdl.org: build fix]
Move the i386 VDSO down into a vma and thus randomize it.
Besides the security implications, this feature also helps debuggers, which
can COW a vma-backed VDSO just like a normal DSO and can thus do
single-stepping and other debugging features.
It's good for hypervisors (Xen, VMWare) too, which typically live in the same
high-mapped address space as the VDSO, hence whenever the VDSO is used, they
get lots of guest pagefaults and have to fix such guest accesses up - which
slows things down instead of speeding things up (the primary purpose of the
VDSO).
There's a new CONFIG_COMPAT_VDSO (default=y) option, which provides support
for older glibcs that still rely on a prelinked high-mapped VDSO. Newer
distributions (using glibc 2.3.3 or later) can turn this option off. Turning
it off is also recommended for security reasons: attackers cannot use the
predictable high-mapped VDSO page as syscall trampoline anymore.
There is a new vdso=[0|1] boot option as well, and a runtime
/proc/sys/vm/vdso_enabled sysctl switch, that allows the VDSO to be turned
on/off.
(This version of the VDSO-randomization patch also has working ELF
coredumping, the previous patch crashed in the coredumping code.)
This code is a combined work of the exec-shield VDSO randomization
code and Gerd Hoffmann's hypervisor-centric VDSO patch. Rusty Russell
started this patch and i completed it.
[akpm@osdl.org: cleanups]
[akpm@osdl.org: compile fix]
[akpm@osdl.org: compile fix 2]
[akpm@osdl.org: compile fix 3]
[akpm@osdl.org: revernt MAXMEM change]
Signed-off-by: Arjan van de Ven <arjan@infradead.org>
Cc: Gerd Hoffmann <kraxel@suse.de>
Cc: Zachary Amsden <zach@vmware.com>
Cc: Andi Kleen <ak@muc.de>
Cc: Jan Beulich <jbeulich@novell.com>
