commit 05fbf357d94152171bc50f8a369390f1f16efd89 upstream.
Lockless access to pte in pagemap_pte_range() might race with page
migration and trigger BUG_ON(!PageLocked()) in migration_entry_to_page():
CPU A (pagemap) CPU B (migration)
lock_page()
try_to_unmap(page, TTU_MIGRATION...)
make_migration_entry()
set_pte_at()
<read *pte>
pte_to_pagemap_entry()
remove_migration_ptes()
unlock_page()
if(is_migration_entry())
BUG_ON(!PageLocked(page))
Also lockless read might be non-atomic if pte is larger than wordsize.
Other pte walkers (smaps, numa_maps, clear_refs) already lock ptes.
Fixes: 052fb0d635df ("proc: report file/anon bit in /proc/pid/pagemap")
Signed-off-by: Konstantin Khlebnikov <khlebnikov@yandex-team.ru>
Reported-by: Andrey Ryabinin <a.ryabinin@samsung.com>
Reviewed-by: Cyrill Gorcunov <gorcunov@openvz.org>
Acked-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Acked-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com>
Cc: <stable@vger.kernel.org> [3.5+]
commit 81d0fa623c5b8dbd5279d9713094b0f9b0a00fb4 upstream.
If a /proc/pid/pagemap read spans a [VMA, an unmapped region, then a
VM_SOFTDIRTY VMA], the virtual pages in the unmapped region are reported
as softdirty. Here's a program to demonstrate the bug:
int main() {
const uint64_t PAGEMAP_SOFTDIRTY = 1ul << 55;
uint64_t pme[3];
int fd = open("/proc/self/pagemap", O_RDONLY);;
char *m = mmap(NULL, 3 * getpagesize(), PROT_READ,
MAP_ANONYMOUS | MAP_SHARED, -1, 0);
munmap(m + getpagesize(), getpagesize());
pread(fd, pme, 24, (unsigned long) m / getpagesize() * 8);
assert(pme[0] & PAGEMAP_SOFTDIRTY); /* passes */
assert(!(pme[1] & PAGEMAP_SOFTDIRTY)); /* fails */
assert(pme[2] & PAGEMAP_SOFTDIRTY); /* passes */
return 0;
(Note that all pages in new VMAs are softdirty until cleared).
Tested:
Used the program given above. I'm going to include this code in
a selftest in the future.
[n-horiguchi@ah.jp.nec.com: prevent pagemap_pte_range() from overrunning]
Signed-off-by: Peter Feiner <pfeiner@google.com>
Cc: "Kirill A. Shutemov" <kirill@shutemov.name>
Cc: Cyrill Gorcunov <gorcunov@openvz.org>
Cc: Pavel Emelyanov <xemul@parallels.com>
Cc: Jamie Liu <jamieliu@google.com>
Cc: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
Signed-off-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
commit ab676b7d6fbf4b294bf198fb27ade5b0e865c7ce upstream.
As pointed by recent post[1] on exploiting DRAM physical imperfection,
/proc/PID/pagemap exposes sensitive information which can be used to do
attacks.
This disallows anybody without CAP_SYS_ADMIN to read the pagemap.
[1] http://googleprojectzero.blogspot.com/2015/03/exploiting-dram-rowhammer-bug-to-gain.html
[ Eventually we might want to do anything more finegrained, but for now
this is the simple model. - Linus ]
Acked-by: Konstantin Khlebnikov <khlebnikov@openvz.org>
Acked-by: Andy Lutomirski <luto@amacapital.net>
Cc: Mark Seaborn <mseaborn@chromium.org>
commit 7e0e953bb0cf649f93277ac8fb67ecbb7f7b04a9 upstream.
use_pde()/unuse_pde() in ->follow_link()/->put_link() resp.
commit c291ee622165cb2c8d4e7af63fffd499354a23be upstream.
Since the rework of the sparse interrupt code to actually free the
unused interrupt descriptors there exists a race between the /proc
interfaces to the irq subsystem and the code which frees the interrupt
descriptor.
CPU0 CPU1
show_interrupts()
desc = irq_to_desc(X);
free_desc(desc)
remove_from_radix_tree();
kfree(desc);
raw_spinlock_irq(&desc->lock);
/proc/interrupts is the only interface which can actively corrupt
kernel memory via the lock access. /proc/stat can only read from freed
memory. Extremly hard to trigger, but possible.
The interfaces in /proc/irq/N/ are not affected by this because the
removal of the proc file is serialized in procfs against concurrent
readers/writers. The removal happens before the descriptor is freed.
For architectures which have CONFIG_SPARSE_IRQ=n this is a non issue
as the descriptor is never freed. It's merely cleared out with the irq
descriptor lock held. So any concurrent proc access will either see
the old correct value or the cleared out ones.
Protect the lookup and access to the irq descriptor in
show_interrupts() with the sparse_irq_lock.
Provide kstat_irqs_usr() which is protecting the lookup and access
with sparse_irq_lock and switch /proc/stat to use it.
Document the existing kstat_irqs interfaces so it's clear that the
caller needs to take care about protection. The users of these
interfaces are either not affected due to SPARSE_IRQ=n or already
protected against removal.
Fixes: 1f5a5b87f78f "genirq: Implement a sane sparse_irq allocator"
commit 9cc46516ddf497ea16e8d7cb986ae03a0f6b92f8 upstream.
- Expose the knob to user space through a proc file /proc/<pid>/setgroups
A value of "deny" means the setgroups system call is disabled in the
current processes user namespace and can not be enabled in the
future in this user namespace.
A value of "allow" means the segtoups system call is enabled.
- Descendant user namespaces inherit the value of setgroups from
their parents.
- A proc file is used (instead of a sysctl) as sysctls currently do
not allow checking the permissions at open time.
- Writing to the proc file is restricted to before the gid_map
for the user namespace is set.
This ensures that disabling setgroups at a user namespace
level will never remove the ability to call setgroups
from a process that already has that ability.
A process may opt in to the setgroups disable for itself by
creating, entering and configuring a user namespace or by calling
setns on an existing user namespace with setgroups disabled.
Processes without privileges already can not call setgroups so this
is a noop. Prodcess with privilege become processes without
privilege when entering a user namespace and as with any other path
to dropping privilege they would not have the ability to call
setgroups. So this remains within the bounds of what is possible
without a knob to disable setgroups permanently in a user namespace.
commit 615d6e8756c87149f2d4c1b93d471bca002bd849 upstream.
This patch is a continuation of efforts trying to optimize find_vma(),
avoiding potentially expensive rbtree walks to locate a vma upon faults.
The original approach (https://lkml.org/lkml/2013/11/1/410), where the
largest vma was also cached, ended up being too specific and random,
thus further comparison with other approaches were needed. There are
two things to consider when dealing with this, the cache hit rate and
the latency of find_vma(). Improving the hit-rate does not necessarily
translate in finding the vma any faster, as the overhead of any fancy
caching schemes can be too high to consider.
We currently cache the last used vma for the whole address space, which
provides a nice optimization, reducing the total cycles in find_vma() by
up to 250%, for workloads with good locality. On the other hand, this
simple scheme is pretty much useless for workloads with poor locality.
Analyzing ebizzy runs shows that, no matter how many threads are
running, the mmap_cache hit rate is less than 2%, and in many situations
below 1%.
The proposed approach is to replace this scheme with a small per-thread
cache, maximizing hit rates at a very low maintenance cost.
Invalidations are performed by simply bumping up a 32-bit sequence
number. The only expensive operation is in the rare case of a seq
number overflow, where all caches that share the same address space are
flushed. Upon a miss, the proposed replacement policy is based on the
page number that contains the virtual address in question. Concretely,
the following results are seen on an 80 core, 8 socket x86-64 box:
1) System bootup: Most programs are single threaded, so the per-thread
scheme does improve ~50% hit rate by just adding a few more slots to
the cache.
| caching scheme | hit-rate | cycles (billion) |
| baseline | 50.61% | 19.90 |
| patched | 73.45% | 13.58 |
2) Kernel build: This one is already pretty good with the current
approach as we're dealing with good locality.
| baseline | 75.28% | 11.03 |
| patched | 88.09% | 9.31 |
3) Oracle 11g Data Mining (4k pages): Similar to the kernel build workload.
| baseline | 70.66% | 17.14 |
| patched | 91.15% | 12.57 |
4) Ebizzy: There's a fair amount of variation from run to run, but this
approach always shows nearly perfect hit rates, while baseline is just
about non-existent. The amounts of cycles can fluctuate between
anywhere from ~60 to ~116 for the baseline scheme, but this approach
reduces it considerably. For instance, with 80 threads:
| baseline | 1.06% | 91.54 |
| patched | 99.97% | 14.18 |
[akpm@linux-foundation.org: fix nommu build, per Davidlohr]
[akpm@linux-foundation.org: document vmacache_valid() logic]
[akpm@linux-foundation.org: attempt to untangle header files]
[akpm@linux-foundation.org: add vmacache_find() BUG_ON]
[hughd@google.com: add vmacache_valid_mm() (from Oleg)]
[akpm@linux-foundation.org: adjust and enhance comments]
Signed-off-by: Davidlohr Bueso <davidlohr@hp.com>
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Reviewed-by: Michel Lespinasse <walken@google.com>
Tested-by: Hugh Dickins <hughd@google.com>
commit 7d8b6c63751cfbbe5eef81a48c22978b3407a3ad upstream.
This is effectively a revert of 7b9a7ec565505699f503b4fcf61500dceb36e744
plus fixing it a different way...
We found, when trying to run an application from an application which
had dropped privs that the kernel does security checks on undefined
capability bits. This was ESPECIALLY difficult to debug as those
undefined bits are hidden from /proc/$PID/status.
Consider a root application which drops all capabilities from ALL 4
capability sets. We assume, since the application is going to set
eff/perm/inh from an array that it will clear not only the defined caps
less than CAP_LAST_CAP, but also the higher 28ish bits which are
undefined future capabilities.
The BSET gets cleared differently. Instead it is cleared one bit at a
time. The problem here is that in security/commoncap.c::cap_task_prctl()
we actually check the validity of a capability being read. So any task
which attempts to 'read all things set in bset' followed by 'unset all
things set in bset' will not even attempt to unset the undefined bits
higher than CAP_LAST_CAP.
So the 'parent' will look something like:
CapInh: 0000000000000000
CapPrm: 0000000000000000
CapEff: 0000000000000000
CapBnd: ffffffc000000000
All of this 'should' be fine. Given that these are undefined bits that
aren't supposed to have anything to do with permissions. But they do...
So lets now consider a task which cleared the eff/perm/inh completely
and cleared all of the valid caps in the bset (but not the invalid caps
it couldn't read out of the kernel). We know that this is exactly what
the libcap-ng library does and what the go capabilities library does.
They both leave you in that above situation if you try to clear all of
you capapabilities from all 4 sets. If that root task calls execve()
the child task will pick up all caps not blocked by the bset. The bset
however does not block bits higher than CAP_LAST_CAP. So now the child
task has bits in eff which are not in the parent. These are
'meaningless' undefined bits, but still bits which the parent doesn't
have.
The problem is now in cred_cap_issubset() (or any operation which does a
subset test) as the child, while a subset for valid cap bits, is not a
subset for invalid cap bits! So now we set durring commit creds that
the child is not dumpable. Given it is 'more priv' than its parent. It
also means the parent cannot ptrace the child and other stupidity.
The solution here:
1) stop hiding capability bits in status
This makes debugging easier!
2) stop giving any task undefined capability bits. it's simple, it you
don't put those invalid bits in CAP_FULL_SET you won't get them in init
and you won't get them in any other task either.
This fixes the cap_issubset() tests and resulting fallout (which
made the init task in a docker container untraceable among other
things)
3) mask out undefined bits when sys_capset() is called as it might use
~0, ~0 to denote 'all capabilities' for backward/forward compatibility.
This lets 'capsh --caps="all=eip" -- -c /bin/bash' run.
4) mask out undefined bit when we read a file capability off of disk as
again likely all bits are set in the xattr for forward/backward
compatibility.
This lets 'setcap all+pe /bin/bash; /bin/bash' run
Signed-off-by: Eric Paris <eparis@redhat.com>
Cc: Andrew Vagin <avagin@openvz.org>
Cc: Andrew G. Morgan <morgan@kernel.org>
Cc: Serge E. Hallyn <serge.hallyn@canonical.com>
Cc: Steve Grubb <sgrubb@redhat.com>
Cc: Dan Walsh <dwalsh@redhat.com>
Signed-off-by: James Morris <james.l.morris@oracle.com>
commit d4c54919ed86302094c0ca7d48a8cbd4ee753e92 upstream.
The age table walker doesn't check non-present hugetlb entry in common
path, so hugetlb_entry() callbacks must check it. The reason for this
behavior is that some callers want to handle it in its own way.
[ I think that reason is bogus, btw - it should just do what the regular
code does, which is to call the "pte_hole()" function for such hugetlb
entries - Linus]
However, some callers don't check it now, which causes unpredictable
result, for example when we have a race between migrating hugepage and
reading /proc/pid/numa_maps. This patch fixes it by adding !pte_present
checks on buggy callbacks.
This bug exists for years and got visible by introducing hugepage
migration.
ChangeLog v2:
- fix if condition (check !pte_present() instead of pte_present())
Reported-by: Sasha Levin <sasha.levin@oracle.com>
[ Backported to 3.15. Signed-off-by: Josh Boyer <jwboyer@fedoraproject.org> ]
The expected logic of proc_map_files_get_link() is either to return 0
and initialize 'path' or return an error and leave 'path' uninitialized.
By the time dname_to_vma_addr() returns 0 the corresponding vma may have
already be gone. In this case the path is not initialized but the
return value is still 0. This results in 'general protection fault'
inside d_path().
Steps to reproduce:
CONFIG_CHECKPOINT_RESTORE=y
fd = open(...);
while (1) {
mmap(fd, ...);
munmap(fd, ...);
ls -la /proc/$PID/map_files
Addresses https://bugzilla.kernel.org/show_bug.cgi?id=68991
Signed-off-by: Artem Fetishev <artem_fetishev@epam.com>
Signed-off-by: Aleksandr Terekhov <aleksandr_terekhov@epam.com>
Reported-by: <wiebittewas@gmail.com>
Acked-by: Pavel Emelyanov <xemul@parallels.com>
Acked-by: Cyrill Gorcunov <gorcunov@openvz.org>
Reviewed-by: "Eric W. Biederman" <ebiederm@xmission.com>
Commit bf6bddf1924e ("mm: introduce compaction and migration for
ballooned pages") introduces page_count(page) into memory compaction
which dereferences page->first_page if PageTail(page).
This results in a very rare NULL pointer dereference on the
aforementioned page_count(page). Indeed, anything that does
compound_head(), including page_count() is susceptible to racing with
prep_compound_page() and seeing a NULL or dangling page->first_page
pointer.
This patch uses Andrea's implementation of compound_trans_head() that
deals with such a race and makes it the default compound_head()
implementation. This includes a read memory barrier that ensures that
if PageTail(head) is true that we return a head page that is neither
NULL nor dangling. The patch then adds a store memory barrier to
prep_compound_page() to ensure page->first_page is set.
This is the safest way to ensure we see the head page that we are
expecting, PageTail(page) is already in the unlikely() path and the
memory barriers are unfortunately required.
Hugetlbfs is the exception, we don't enforce a store memory barrier
during init since no race is possible.
Signed-off-by: David Rientjes <rientjes@google.com>
Cc: Holger Kiehl <Holger.Kiehl@dwd.de>
Cc: Christoph Lameter <cl@linux.com>
Cc: Rafael Aquini <aquini@redhat.com>
Cc: "Kirill A. Shutemov" <kirill.shutemov@linux.intel.com>
Currently, update_note_header_size_elf64() and
update_note_header_size_elf32() will add the size of a PT_NOTE entry to
real_sz even if that causes real_sz to exceeds max_sz. This patch
corrects the while loop logic in those routines to ensure that does not
happen and prints a warning if a PT_NOTE entry is dropped. If zero
PT_NOTE entries are found or this condition is encountered because the
only entry was dropped, a warning is printed and an error is returned.
One possible negative side effect of exceeding the max_sz limit is an
allocation failure in merge_note_headers_elf64() or
merge_note_headers_elf32() which would produce console output such as
the following while booting the crash kernel.
vmalloc: allocation failure: 14076997632 bytes
swapper/0: page allocation failure: order:0, mode:0x80d2
CPU: 0 PID: 1 Comm: swapper/0 Not tainted 3.10.0-gbp1 #7
Call Trace:
dump_stack+0x19/0x1b
warn_alloc_failed+0xf0/0x160
__vmalloc_node_range+0x19e/0x250
vmalloc_user+0x4c/0x70
merge_note_headers_elf64.constprop.9+0x116/0x24a
vmcore_init+0x2d4/0x76c
do_one_initcall+0xe2/0x190
kernel_init_freeable+0x17c/0x207
kernel_init+0xe/0x180
ret_from_fork+0x7c/0xb0
Kdump: vmcore not initialized
kdump: dump target is /dev/sda4
kdump: saving to /sysroot//var/crash/127.0.0.1-2014.01.28-13:58:52/
kdump: saving vmcore-dmesg.txt
Cannot open /proc/vmcore: No such file or directory
kdump: saving vmcore-dmesg.txt failed
kdump: saving vmcore failed
This type of failure has been seen on a four socket prototype system
with certain memory configurations. Most PT_NOTE sections have a single
entry similar to:
n_namesz = 0x5
n_descsz = 0x150
n_type = 0x1
Occasionally, a second entry is encountered with very large n_namesz and
n_descsz sizes:
n_namesz = 0x80000008
n_descsz = 0x510ae163
n_type = 0x80000008
Not yet sure of the source of these extra entries, they seem bogus, but
they shouldn't cause crash dump to fail.
Signed-off-by: Greg Pearson <greg.pearson@hp.com>
Acked-by: Vivek Goyal <vgoyal@redhat.com>
Cc: HATAYAMA Daisuke <d.hatayama@jp.fujitsu.com>
Cc: Michael Holzheu <holzheu@linux.vnet.ibm.com>
Cc: "Eric W. Biederman" <ebiederm@xmission.com>
Change the remaining next_thread (ab)users to use while_each_thread().
The last user which should be changed is next_tid(), but we can't do this
now.
__exit_signal() and complete_signal() are fine, they actually need
next_thread() logic.
This patch (of 3):
do_task_stat() can use while_each_thread(), no changes in
the compiled code.
Reviewed-by: Sameer Nanda <snanda@chromium.org>
PROC_FS is a bool, so this code is either present or absent. It will
never be modular, so using module_init as an alias for __initcall is
rather misleading.
Fix this up now, so that we can relocate module_init from init.h into
module.h in the future. If we don't do this, we'd have to add module.h to
obviously non-modular code, and that would be ugly at best.
Note that direct use of __initcall is discouraged, vs. one of the
priority categorized subgroups. As __initcall gets mapped onto
device_initcall, our use of fs_initcall (which makes sense for fs code)
will thus change these registrations from level 6-device to level 5-fs
(i.e. slightly earlier). However no observable impact of that small
difference has been observed during testing, or is expected.
Also note that this change uncovers a missing semicolon bug in the
registration of vmcore_init as an initcall.
exists.
Distribution kernels might want to build in support for /proc/device-tree
for kernels that might end up running on hardware that doesn't support
openfirmware. This results in an empty /proc/device-tree existing.
Remove it if the OFW root node doesn't exist.
This situation actually confuses grub2, resulting in install failures.
grub2 sees the /proc/device-tree and picks the wrong install target cf.
http://bzr.savannah.gnu.org/lh/grub/trunk/grub/annotate/4300/util/grub-install.in#L311
grub should be more robust, but still, leaving an empty proc dir seems
pointless.
Addresses https://bugzilla.redhat.com/show_bug.cgi?id=818378.
Signed-off-by: Dave Jones <davej@redhat.com>
Cc: Al Viro <viro@ZenIV.linux.org.uk>
Cc: Josh Boyer <jwboyer@fedoraproject.org>
Use existing accessors proc_set_user() and proc_set_size() to set
attributes. Just a cleanup.
Signed-off-by: Rui Xiang <rui.xiang@huawei.com>
1. proc_task_readdir()->first_tid() path truncates f_pos to int, this
is wrong even on 64bit.
We could check that f_pos < PID_MAX or even INT_MAX in
proc_task_readdir(), but this patch simply checks the potential
overflow in first_tid(), this check is nop on 64bit. We do not care if
it was negative and the new unsigned value is huge, all we need to
ensure is that we never wrongly return !NULL.
2. Remove the 2nd "nr != 0" check before get_nr_threads(),
nr_threads == 0 is not distinguishable from !pid_task() above.
Cc: Sameer Nanda <snanda@chromium.org>
Cc: Sergey Dyasly <dserrg@gmail.com>
proc_task_readdir() does not really need "leader", first_tid() has to
revalidate it anyway. Just pass proc_pid(inode) to first_tid() instead,
it can do pid_task(PIDTYPE_PID) itself and read ->group_leader only if
necessary.
The patch also extracts the "inode is dead" code from
pid_delete_dentry(dentry) into the new trivial helper,
proc_inode_is_dead(inode), proc_task_readdir() uses it to return -ENOENT
if this dir was removed.
This is a bit racy, but the race is very inlikely and the getdents() after
openndir() can see the empty "." + ".." dir only once.
Rerwrite the main loop to use while_each_thread() instead of
next_thread(). We are going to fix or replace while_each_thread(),
next_thread() should be avoided whenever possible.
proc_task_readdir() verifies that the result of get_proc_task() is
pid_alive() and thus its ->group_leader is fine too. However this is not
necessarily true after rcu_read_unlock(), we need to recheck this again
after first_tid() does rcu_read_lock(). Otherwise
leader->thread_group.next (used by next_thread()) can be invalid if the
rcu grace period expires in between.
The race is subtle and unlikely, but still it is possible afaics. To
simplify lets ignore the "likely" case when tid != 0, f_version can be
cleared by proc_task_operations->llseek().
Suppose we have a main thread M and its subthread T. Suppose that f_pos
== 3, iow first_tid() should return T. Now suppose that the following
happens between rcu_read_unlock() and rcu_read_lock():
1. T execs and becomes the new leader. This removes M from
->thread_group but next_thread(M) is still T.
2. T creates another thread X which does exec as well, T
goes away.
3. X creates another subthread, this increments nr_threads.
4. first_tid() does next_thread(M) and returns the already
dead T.
Note also that we need 2. and 3. only because of get_nr_threads() check,
and this check was supposed to be optimization only.
get_task_state() and task_state_array[] look confusing and suboptimal, it
is not clear what it can actually report to user-space and
task_state_array[] blows .data for no reason.
1. state = (tsk->state & TASK_REPORT) | tsk->exit_state is not
clear. TASK_REPORT is self-documenting but it is not clear
what ->exit_state can add.
Move the potential exit_state's (EXIT_ZOMBIE and EXIT_DEAD)
into TASK_REPORT and use it to calculate the final result.
2. With the change above it is obvious that task_state_array[]
has the unused entries just to make BUILD_BUG_ON() happy.
Change this BUILD_BUG_ON() to use TASK_REPORT rather than
TASK_STATE_MAX and shrink task_state_array[].
3. Turn the "while (state)" loop into fls(state).
Cc: David Laight <David.Laight@ACULAB.COM>
Cc: Tejun Heo <tj@kernel.org>
stable_page_flags() checks !PageHuge && PageTransCompound && PageLRU to
know that a specified page is thp or not. But sometimes it's not enough
and we fail to detect thp when the thp is on pagevec. This happens only
for a few seconds after LRU list operations, but it makes it difficult
to control our applications depending on this flag.
So this patch adds another check PageAnon to detect thps on pagevec. It
might not give the future extensibility for thp pagecache, but it's OK
at least for now.
Cc: Wu Fengguang <fengguang.wu@intel.com>
Many load balancing and workload placing programs check /proc/meminfo to
estimate how much free memory is available. They generally do this by
adding up "free" and "cached", which was fine ten years ago, but is
pretty much guaranteed to be wrong today.
It is wrong because Cached includes memory that is not freeable as page
cache, for example shared memory segments, tmpfs, and ramfs, and it does
not include reclaimable slab memory, which can take up a large fraction
of system memory on mostly idle systems with lots of files.
Currently, the amount of memory that is available for a new workload,
without pushing the system into swap, can be estimated from MemFree,
Active(file), Inactive(file), and SReclaimable, as well as the "low"
watermarks from /proc/zoneinfo.
However, this may change in the future, and user space really should not
be expected to know kernel internals to come up with an estimate for the
amount of free memory.
It is more convenient to provide such an estimate in /proc/meminfo. If
things change in the future, we only have to change it in one place.
Signed-off-by: Rik van Riel <riel@redhat.com>
Reported-by: Erik Mouw <erik.mouw_2@nxp.com>
Commit fad1a86e25e0 ("procfs: call default get_unmapped_area on
MMU-present architectures"), as its title says, took care of only the
MMU case, leaving the !MMU side still in the regressed state (returning
-EIO in all cases where pde->proc_fops->get_unmapped_area is NULL).
From the fad1a86e25e0 changelog:
"Commit c4fe24485729 ("sparc: fix PCI device proc file mmap(2)") added
proc_reg_get_unmapped_area in proc_reg_file_ops and
proc_reg_file_ops_no_compat, by which now mmap always returns EIO if
get_unmapped_area method is not defined for the target procfs file, which
causes regression of mmap on /proc/vmcore.
To address this issue, like get_unmapped_area(), call default
current->mm->get_unmapped_area on MMU-present architectures if
pde->proc_fops->get_unmapped_area, i.e. the one in actual file operation
in the procfs file, is not defined"
Signed-off-by: Jan Beulich <jbeulich@suse.com>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
Cc: <stable@vger.kernel.org> [3.12.x]
Pull audit updates from Eric Paris:
"Nothing amazing. Formatting, small bug fixes, couple of fixes where
we didn't get records due to some old VFS changes, and a change to how
we collect execve info..."
Fixed conflict in fs/exec.c as per Eric and linux-next.
* git://git.infradead.org/users/eparis/audit: (28 commits)
audit: fix type of sessionid in audit_set_loginuid()
audit: call audit_bprm() only once to add AUDIT_EXECVE information
audit: move audit_aux_data_execve contents into audit_context union
audit: remove unused envc member of audit_aux_data_execve
audit: Kill the unused struct audit_aux_data_capset
audit: do not reject all AUDIT_INODE filter types
audit: suppress stock memalloc failure warnings since already managed
audit: log the audit_names record type
audit: add child record before the create to handle case where create fails
audit: use given values in tty_audit enable api
audit: use nlmsg_len() to get message payload length
audit: use memset instead of trying to initialize field by field
audit: fix info leak in AUDIT_GET requests
audit: update AUDIT_INODE filter rule to comparator function
audit: audit feature to set loginuid immutable
audit: audit feature to only allow unsetting the loginuid
audit: allow unsetting the loginuid (with priv)
audit: remove CONFIG_AUDIT_LOGINUID_IMMUTABLE
audit: loginuid functions coding style
selinux: apply selinux checks on new audit message types
Rename simple_delete_dentry() to always_delete_dentry() and export it.
Export simple_dentry_operations, while we are at it, and get rid of
their duplicates
All seq_printf() users are using "%n" for calculating padding size,
convert them to use seq_setwidth() / seq_pad() pair.
Cc: Joe Perches <joe@perches.com>
Hugetlb supports multiple page sizes. We use split lock only for PMD
level, but not for PUD.
Tested-by: Alex Thorlton <athorlton@sgi.com>
Cc: "Eric W . Biederman" <ebiederm@xmission.com>
Cc: "Paul E . McKenney" <paulmck@linux.vnet.ibm.com>
Cc: Dave Jones <davej@redhat.com>
Cc: Michael Kerrisk <mtk.manpages@gmail.com>
Cc: Robin Holt <robinmholt@gmail.com>
Cc: Sedat Dilek <sedat.dilek@gmail.com>
Cc: Srikar Dronamraju <srikar@linux.vnet.ibm.com>
With split ptlock it's important to know which lock
pmd_trans_huge_lock() took. This patch adds one more parameter to the
function to return the lock.
In most places migration to new api is trivial. Exception is
move_huge_pmd(): we need to take two locks if pmd tables are different.
With split page table lock for PMD level we can't hold mm->page_table_lock
while updating nr_ptes.
Let's convert it to atomic_long_t to avoid races.
Merge first patch-bomb from Andrew Morton:
"Quite a lot of other stuff is banked up awaiting further
next->mainline merging, but this batch contains:
- Lots of random misc patches
- OCFS2
- Most of MM
- backlight updates
- lib/ updates
- printk updates
- checkpatch updates
- epoll tweaking
- rtc updates
- hfs
- hfsplus
- documentation
- procfs
- update gcov to gcc-4.7 format
- IPC"
* emailed patches from Andrew Morton <akpm@linux-foundation.org>: (269 commits)
ipc, msg: fix message length check for negative values
ipc/util.c: remove unnecessary work pending test
devpts: plug the memory leak in kill_sb
./Makefile: export initial ramdisk compression config option
init/Kconfig: add option to disable kernel compression
drivers: w1: make w1_slave::flags long to avoid memory corruption
drivers/w1/masters/ds1wm.cuse dev_get_platdata()
drivers/memstick/core/ms_block.c: fix unreachable state in h_msb_read_page()
drivers/memstick/core/mspro_block.c: fix attributes array allocation
drivers/pps/clients/pps-gpio.c: remove redundant of_match_ptr
kernel/panic.c: reduce 1 byte usage for print tainted buffer
gcov: reuse kbasename helper
kernel/gcov/fs.c: use pr_warn()
kernel/module.c: use pr_foo()
gcov: compile specific gcov implementation based on gcc version
gcov: add support for gcc 4.7 gcov format
gcov: move gcov structs definitions to a gcc version specific file
kernel/taskstats.c: return -ENOMEM when alloc memory fails in add_del_listener()
kernel/taskstats.c: add nla_nest_cancel() for failure processing between nla_nest_start() and nla_nest_end()
kernel/sysctl_binary.c: use scnprintf() instead of snprintf()
Pull vfs updates from Al Viro:
"All kinds of stuff this time around; some more notable parts:
- RCU'd vfsmounts handling
- new primitives for coredump handling
- files_lock is gone
- Bruce's delegations handling series
- exportfs fixes
plus misc stuff all over the place"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (101 commits)
ecryptfs: ->f_op is never NULL
locks: break delegations on any attribute modification
locks: break delegations on link
locks: break delegations on rename
locks: helper functions for delegation breaking
locks: break delegations on unlink
namei: minor vfs_unlink cleanup
locks: implement delegations
locks: introduce new FL_DELEG lock flag
vfs: take i_mutex on renamed file
vfs: rename I_MUTEX_QUOTA now that it's not used for quotas
vfs: don't use PARENT/CHILD lock classes for non-directories
vfs: pull ext4's double-i_mutex-locking into common code
exportfs: fix quadratic behavior in filehandle lookup
exportfs: better variable name
exportfs: move most of reconnect_path to helper function
exportfs: eliminate unused "noprogress" counter
exportfs: stop retrying once we race with rename/remove
exportfs: clear DISCONNECTED on all parents sooner
exportfs: more detailed comment for path_reconnect
Under Pseudo filesystems, /proc/kcore support has no help.
Fixes a portion of kernel bugzilla #52671:
https://bugzilla.kernel.org/show_bug.cgi?id=52671
Thanks for David Howells for the help text.
Reported-by: <lailavrazda1979@gmail.com>
Clean up proc_reg_get_unmapped_area due to its 80-column limit
violation.
Signed-off-by: HATAYAMA Daisuke <d.hatayama@jp.fujitsu.com>
Tested-by: Michael Holzheu <holzheu@linux.vnet.ibm.com>
The same calculation is currently done in three differents places.
Factor that code so future changes has to be made at only one place.
[akpm@linux-foundation.org: uninline vm_commit_limit()]
Signed-off-by: Jerome Marchand <jmarchan@redhat.com>
Cc: Dave Hansen <dave.hansen@linux.intel.com>
This flag shows that the VMA is "newly created" and thus represents
"dirty" in the task's VM.
You can clear it by "echo 4 > /proc/pid/clear_refs."
mpol_to_str() should not fail. Currently, it either fails because the
string buffer is too small or because a string hasn't been defined for a
mempolicy mode.
If a new mempolicy mode is introduced and no string is defined for it,
just warn and return "unknown".
If the buffer is too small, just truncate the string and return, the
same behavior as snprintf().
This also fixes a bug where there was no NULL-byte termination when doing
*p++ = '=' and *p++ ':' and maxlen has been reached.
Cc: Chen Gang <gang.chen@asianux.com>
Use "pgdat_end_pfn()" instead of "pgdat->node_start_pfn +
pgdat->node_spanned_pages". Simplify the code, no functional change.
Signed-off-by: Xishi Qiu <qiuxishi@huawei.com>
git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux
Pull devicetree updates from Rob Herring:
"DeviceTree updates for 3.13. This is a bit larger pull request than
usual for this cycle with lots of clean-up.
- Cross arch clean-up and consolidation of early DT scanning code.
- Clean-up and removal of arch prom.h headers. Makes arch specific
prom.h optional on all but Sparc.
- Addition of interrupts-extended property for devices connected to
multiple interrupt controllers.
- Refactoring of DT interrupt parsing code in preparation for
deferred probe of interrupts.
- ARM cpu and cpu topology bindings documentation.
- Various DT vendor binding documentation updates"
* tag 'devicetree-for-3.13' of git://git.kernel.org/pub/scm/linux/kernel/git/robh/linux: (82 commits)
powerpc: add missing explicit OF includes for ppc
dt/irq: add empty of_irq_count for !OF_IRQ
dt: disable self-tests for !OF_IRQ
of: irq: Fix interrupt-map entry matching
MIPS: Netlogic: replace early_init_devtree() call
of: Add Panasonic Corporation vendor prefix
of: Add Chunghwa Picture Tubes Ltd. vendor prefix
of: Add AU Optronics Corporation vendor prefix
of/irq: Fix potential buffer overflow
of/irq: Fix bug in interrupt parsing refactor.
of: set dma_mask to point to coherent_dma_mask
of: add vendor prefix for PHYTEC Messtechnik GmbH
DT: sort vendor-prefixes.txt
of: Add vendor prefix for Cadence
of: Add empty for_each_available_child_of_node() macro definition
arm/versatile: Fix versatile irq specifications.
of/irq: create interrupts-extended property
microblaze/pci: Drop PowerPC-ism from irq parsing
of/irq: Create of_irq_parse_and_map_pci() to consolidate arch code.
of/irq: Use irq_of_parse_and_map()
If a task has CAP_AUDIT_CONTROL allow that task to unset their loginuid.
This would allow a child of that task to set their loginuid without
CAP_AUDIT_CONTROL. Thus when launching a new login daemon, a
priviledged helper would be able to unset the loginuid and then the
daemon, which may be malicious user facing, do not need priv to function
correctly.
Signed-off-by: Richard Guy Briggs <rgb@redhat.com>
Resolve cherry-picking conflicts:
mm/huge_memory.c
mm/memory.c
mm/mprotect.c
See this upstream merge commit for more details:
52469b4fcd4f Merge branch 'core-urgent-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip
duplicated to hell and back...
which causes regression of mmap on /proc/vmcore.
operation in the procfs file, is not defined.
Reported-by: Michael Holzheu <holzheu@linux.vnet.ibm.com>
Currently, proc_reg_get_unmapped_area truncates upper 32-bit of the
mapped virtual address returned from get_unmapped_area method in
pde->proc_fops due to the variable rv of signed integer on x86_64. This
is too small to have vitual address of unsigned long on x86_64 since on
x86_64, signed integer is of 4 bytes while unsigned long is of 8 bytes.
To fix this issue, use unsigned long instead.
Fixes a regression added in commit c4fe24485729 ("sparc: fix PCI device
proc file mmap(2)").
If a page we are inspecting is in swap we may occasionally report it as
having soft dirty bit (even if it is clean). The pte_soft_dirty helper
should be called on present pte only.
Signed-off-by: Cyrill Gorcunov <gorcunov@openvz.org>
Cc: Matt Mackall <mpm@selenic.com>
Cc: Xiao Guangrong <xiaoguangrong@linux.vnet.ibm.com>
Cc: Marcelo Tosatti <mtosatti@redhat.com>
Cc: KOSAKI Motohiro <kosaki.motohiro@gmail.com>
Cc: "Aneesh Kumar K.V" <aneesh.kumar@linux.vnet.ibm.com>
Reviewed-by: Naoya Horiguchi <n-horiguchi@ah.jp.nec.com>
HAVE_ARCH_DEVTREE_FIXUPS appears to always be needed except for sparc,
but it is only used for /proc/device-teee and sparc does not enable
/proc/device-tree. So this option is redundant. Remove the option and
always enable it. This has the side effect of fixing /proc/device-tree
on arches such as arm64 which failed to define this option.
Acked-by: Vineet Gupta <vgupta@synopsys.com>
Acked-by: Grant Likely <grant.likely@linaro.org>
Cc: James Hogan <james.hogan@imgtec.com>
Cc: Jonas Bonn <jonas@southpole.se>
Cc: x86@kernel.org
Cc: Chris Zankel <chris@zankel.net>
Cc: Max Filippov <jcmvbkbc@gmail.com>
It is desirable to model from userspace how the scheduler groups tasks
over time. This patch adds an ID to the numa_group and reports it via
/proc/PID/status.
Signed-off-by: Peter Zijlstra <peterz@infradead.org>
Link: http://lkml.kernel.org/r/1381141781-10992-45-git-send-email-mgorman@suse.de
We use NR_ANON_PAGES as base for reporting AnonPages to user. There's
not much sense in not accounting transparent huge pages there, but add
them on printing to user.
Let's account transparent huge pages in NR_ANON_PAGES in the first place.
Acked-by: Dave Hansen <dave.hansen@linux.intel.com>
Cc: Jan Kara <jack@suse.cz>
Cc: Matthew Wilcox <willy@linux.intel.com>
Cc: Hillf Danton <dhillf@gmail.com>
Cc: Ning Qu <quning@google.com>
The patch "s390/vmcore: Implement remap_oldmem_pfn_range for s390" allows
now to use mmap also on s390.
So enable mmap for s390 again.
Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com>
Cc: Jan Willeke <willeke@de.ibm.com>
Cc: Vivek Goyal <vgoyal@redhat.com>
For zfcpdump we can't map the HSA storage because it is only available via
a read interface. Therefore, for the new vmcore mmap feature we have
introduce a new mechanism to create mappings on demand.
This patch introduces a new architecture function remap_oldmem_pfn_range()
that should be used to create mappings with remap_pfn_range() for oldmem
areas that can be directly mapped. For zfcpdump this is everything
besides of the HSA memory. For the areas that are not mapped by
remap_oldmem_pfn_range() a generic vmcore a new generic vmcore fault
handler mmap_vmcore_fault() is called.
This handler works as follows:
* Get already available or new page from page cache (find_or_create_page)
* Check if /proc/vmcore page is filled with data (PageUptodate)
* If yes:
Return that page
* If no:
Fill page using __vmcore_read(), set PageUptodate, and return page
