Change-Id: I99507d7cfdcee064f808856dc2ce99d806fd864f
commit b53fc7c2974a50913f49e1d800fe904a28c338e3 upstream.
Fix the error message "directives may not be used inside a macro argument"
which appears when the kernel is compiled for the cris architecture.
Signed-off-by: Claudio Scordino <claudio@evidence.eu.com>
Rebase-Id: Rbc628711479b187a90437bea94776066c7a58b54
arch/arm/mach-tegra/Kconfig
arch/arm/mach-tegra/board-ventana.c
drivers/misc/Kconfig
drivers/video/tegra/dc/hdmi.c
Signed-off-by: Dan Willemsen <dwillemsen@nvidia.com>
For machines that use hotplug to control special power domains, report
present cpus in /proc/cpuinfo and /proc/stat instead of the standard of
reporting online. This break hotplug behavior on all other platforms.
The option is enabled using CONFIG_REPORT_PRESENT_CPUS
Bug 849167
Original-Change-Id: Ib04bb73634b3a8c99592b1ac13eb471a8ecfd0c5
Reviewed-on: http://git-master/r/37732
Reviewed-by: Jonathan Mayo <jmayo@nvidia.com>
Tested-by: Jonathan Mayo <jmayo@nvidia.com>
Reviewed-by: Aleksandr Frid <afrid@nvidia.com>
Reviewed-by: Krishna Reddy <vdumpa@nvidia.com>
Rebase-Id: R746f854d51a4b8f15774a547a3219acf7576bf6e
Signed-off-by: San Mehat <san@google.com>
Signed-off-by: Brian Swetland <swetland@google.com>
commit fc360bd9cdcf875639a77f07fafec26699c546f3 upstream.
The display of the "huge" tag was accidentally removed in 29ea2f698 ("mm:
use walk_page_range() instead of custom page table walking code").
Reported-by: Stephen Hemminger <shemminger@vyatta.com>
Tested-by: Stephen Hemminger <shemminger@vyatta.com>
Reviewed-by: Stephen Wilson <wilsons@start.ca>
Acked-by: David Rientjes <rientjes@google.com>
Cc: Lee Schermerhorn <lee.schermerhorn@hp.com>
Cc: Alexey Dobriyan <adobriyan@gmail.com>
This is modeled after the smaps code.
It detects transparent hugepages and then does a single gather_stats()
for the page as a whole. This has two benifits:
1. It is more efficient since it does many pages in a single shot.
2. It does not have to break down the huge page.
Signed-off-by: Dave Hansen <dave@linux.vnet.ibm.com>
gather_pte_stats() does a number of checks on a target page
to see whether it should even be considered for statistics.
This breaks that code out in to a separate function so that
we can use it in the transparent hugepage case in the next
patch.
Reviewed-by: Christoph Lameter <cl@gentwo.org>
We need to teach the numa_maps code about transparent huge pages. The
first step is to teach gather_stats() that the pte it is dealing with
might represent more than one page.
Note that will we use this in a moment for transparent huge pages since
they have use a single pmd_t which _acts_ as a "surrogate" for a bunch
of smaller pte_t's.
I'm a _bit_ unhappy that this interface counts in hugetlbfs page sizes
for hugetlbfs pages and PAGE_SIZE for normal pages. That means that to
figure out how many _bytes_ "dirty=1" means, you must first know the
hugetlbfs page size. That's easier said than done especially if you
don't have visibility in to the mount.
But, that's probably a discussion for another day especially since it
would change behavior to fix it. But, just in case anyone wonders why
this patch only passes a '1' in the hugetlb case...
The CLOEXE bit is magical, and for performance (and semantic) reasons we
don't actually maintain it in the file descriptor itself, but in a
separate bit array. Which means that when we show f_flags, the CLOEXE
status is shown incorrectly: we show the status not as it is now, but as
it was when the file was opened.
Fix that by looking up the bit properly in the 'fdt->close_on_exec' bit
array.
Uli needs this in order to re-implement the pfiles program:
"For normal file descriptors (not sockets) this was the last piece of
information which wasn't available. This is all part of my 'give
Solaris users no reason to not switch' effort. I intend to offer the
code to the util-linux-ng maintainers."
Requested-by: Ulrich Drepper <drepper@akkadia.org>
WARN_ONCE() is very annoying, in that it shows the stack trace that we
don't care about at all, and also triggers various user-level "kernel
oopsed" logic that we really don't care about. And it's not like the
user can do anything about the applications (sshd) in question, it's a
distro issue.
Requested-by: Andi Kleen <andi@firstfloor.org> (and many others)
Since __proc_create() appends the name it is given to the end of the PDE
structure that it allocates, there isn't a need to store a name pointer.
Instead we can just replace the name pointer with a terminal char array of
_unspecified_ length. The compiler will simply append the string to statically
defined variables of PDE type overlapping any hole at the end of the structure
and, unlike specifying an explicitly _zero_ length array, won't give a warning
if you try to statically initialise it with a string of more than zero length.
Also, whilst we're at it:
(1) Move namelen to end just prior to name and reduce it to a single byte
(name shouldn't be longer than NAME_MAX).
(2) Move pde_unload_lock two places further on so that if it's four bytes in
size on a 64-bit machine, it won't cause an unused hole in the PDE struct.
This allows us to move duplicated code in <asm/atomic.h>
(atomic_inc_not_zero() for now) to <linux/atomic.h>
Signed-off-by: Arun Sharma <asharma@fb.com>
Reviewed-by: Eric Dumazet <eric.dumazet@gmail.com>
If an inode's mode permits opening /proc/PID/io and the resulting file
descriptor is kept across execve() of a setuid or similar binary, the
ptrace_may_access() check tries to prevent using this fd against the
task with escalated privileges.
Unfortunately, there is a race in the check against execve(). If
execve() is processed after the ptrace check, but before the actual io
information gathering, io statistics will be gathered from the
privileged process. At least in theory this might lead to gathering
sensible information (like ssh/ftp password length) that wouldn't be
available otherwise.
Holding task->signal->cred_guard_mutex while gathering the io
information should protect against the race.
The order of locking is similar to the one inside of ptrace_attach():
first goes cred_guard_mutex, then lock_task_sighand().
Signed-off-by: Vasiliy Kulikov <segoon@openwall.com>
Cc: <stable@kernel.org>
Change the return value to ENOENT. This return value is then returned
when opening the proc entry that have been removed. For example,
open("/proc/bus/pci/XX/YY") when the corresponding device is being
hot-removed.
Signed-off-by: Daisuke Ogino <ogino.daisuke@jp.fujitsu.com>
Cc: Jesse Barnes <jbarnes@virtuousgeek.org>
Acked-by: Alexey Dobriyan <adobriyan@gmail.com>
/proc/pid/oom_adj is deprecated and scheduled for removal in August 2012
according to Documentation/feature-removal-schedule.txt.
This patch makes the warning more verbose by making it appear as a more
serious problem (the presence of a stack trace and being multiline should
attract more attention) so that applications still using the old interface
can get fixed.
Very popular users of the old interface have been converted since the oom
killer rewrite has been introduced. udevd switched to the
/proc/pid/oom_score_adj interface for v162, kde switched in 4.6.1, and
opensshd switched in 5.7p1.
At the start of 2012, this should be changed into a WARN() to emit all
such incidents and then finally remove the tunable in August 2012 as
scheduled.
Signed-off-by: David Rientjes <rientjes@google.com>
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (107 commits)
vfs: use ERR_CAST for err-ptr tossing in lookup_instantiate_filp
isofs: Remove global fs lock
jffs2: fix IN_DELETE_SELF on overwriting rename() killing a directory
fix IN_DELETE_SELF on overwriting rename() on ramfs et.al.
mm/truncate.c: fix build for CONFIG_BLOCK not enabled
fs:update the NOTE of the file_operations structure
Remove dead code in dget_parent()
AFS: Fix silly characters in a comment
switch d_add_ci() to d_splice_alias() in "found negative" case as well
simplify gfs2_lookup()
jfs_lookup(): don't bother with . or ..
get rid of useless dget_parent() in btrfs rename() and link()
get rid of useless dget_parent() in fs/btrfs/ioctl.c
fs: push i_mutex and filemap_write_and_wait down into ->fsync() handlers
drivers: fix up various ->llseek() implementations
fs: handle SEEK_HOLE/SEEK_DATA properly in all fs's that define their own llseek
Ext4: handle SEEK_HOLE/SEEK_DATA generically
Btrfs: implement our own ->llseek
fs: add SEEK_HOLE and SEEK_DATA flags
reiserfs: make reiserfs default to barrier=flush
Fix up trivial conflicts in fs/xfs/linux-2.6/xfs_super.c due to the new
shrinker callout for the inode cache, that clashed with the xfs code to
start the periodic workers later.
* 'ptrace' of git://git.kernel.org/pub/scm/linux/kernel/git/oleg/misc: (39 commits)
ptrace: do_wait(traced_leader_killed_by_mt_exec) can block forever
ptrace: fix ptrace_signal() && STOP_DEQUEUED interaction
connector: add an event for monitoring process tracers
ptrace: dont send SIGSTOP on auto-attach if PT_SEIZED
ptrace: mv send-SIGSTOP from do_fork() to ptrace_init_task()
ptrace_init_task: initialize child->jobctl explicitly
has_stopped_jobs: s/task_is_stopped/SIGNAL_STOP_STOPPED/
ptrace: make former thread ID available via PTRACE_GETEVENTMSG after PTRACE_EVENT_EXEC stop
ptrace: wait_consider_task: s/same_thread_group/ptrace_reparented/
ptrace: kill real_parent_is_ptracer() in in favor of ptrace_reparented()
ptrace: ptrace_reparented() should check same_thread_group()
redefine thread_group_leader() as exit_signal >= 0
do not change dead_task->exit_signal
kill task_detached()
reparent_leader: check EXIT_DEAD instead of task_detached()
make do_notify_parent() __must_check, update the callers
__ptrace_detach: avoid task_detached(), check do_notify_parent()
kill tracehook_notify_death()
make do_notify_parent() return bool
ptrace: s/tracehook_tracer_task()/ptrace_parent()/
Moving the event counter into the dynamically allocated 'struc seq_file'
allows poll() support without the need to allocate its own tracking
structure.
All current users are switched over to use the new counter.
Requested-by: Andrew Morton akpm@linux-foundation.org
Acked-by: NeilBrown <neilb@suse.de>
Tested-by: Lucas De Marchi lucas.demarchi@profusion.mobi
Signed-off-by: Kay Sievers <kay.sievers@vrfy.org>
not used by the instances anymore.
redundant; all callers get it duplicated in mask & MAY_NOT_BLOCK and none of
them removes that bit.
Duplicate the flags argument into mask bitmap.
its value depends only on inode and does not change; we might as
well store it in ->i_op->check_acl and be done with that.
/proc/PID/io may be used for gathering private information. E.g. for
openssh and vsftpd daemons wchars/rchars may be used to learn the
precise password length. Restrict it to processes being able to ptrace
the target process.
ptrace_may_access() is needed to prevent keeping open file descriptor of
"io" file, executing setuid binary and gathering io information of the
setuid'ed process.
tracehook.h is on the way out. Rename tracehook_tracer_task() to
ptrace_parent() and move it from tracehook.h to ptrace.h.
Cc: John Johansen <john.johansen@canonical.com>
Cc: Stephen Smalley <sds@tycho.nsa.gov>
nothing blocking there, since all instances of sysctl
->permissions() method are non-blocking - both of them,
that is.
nothing blocking except generic_permission()
* git://git.kernel.org/pub/scm/linux/kernel/git/ebiederm/linux-2.6-nsfd:
proc: Fix Oops on stat of /proc/<zombie pid>/ns/net
Don't call iput with the inode half setup to be a namespace filedescriptor.
Instead rearrange the code so that we don't initialize ei->ns_ops until
after I ns_ops->get succeeds, preventing us from invoking ns_ops->put
when ns_ops->get failed.
Reported-by: Ingo Saitz <Ingo.Saitz@stud.uni-hannover.de>
set_anon_super() can fail...
* git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile:
arch/tile: more /proc and /sys file support
This change introduces a few of the less controversial /proc and
/proc/sys interfaces for tile, along with sysfs attributes for
various things that were originally proposed as /proc/tile files.
It also adjusts the "hardwall" proc API.
Arnd Bergmann reviewed the initial arch/tile submission, which
included a complete set of all the /proc/tile and /proc/sys/tile
knobs that we had added in a somewhat ad hoc way during initial
development, and provided feedback on where most of them should go.
One knob turned out to be similar enough to the existing
/proc/sys/debug/exception-trace that it was re-implemented to use
that model instead.
Another knob was /proc/tile/grid, which reported the "grid" dimensions
of a tile chip (e.g. 8x8 processors = 64-core chip). Arnd suggested
looking at sysfs for that, so this change moves that information
to a pair of sysfs attributes (chip_width and chip_height) in the
/sys/devices/system/cpu directory. We also put the "chip_serial"
and "chip_revision" information from our old /proc/tile/board file
as attributes in /sys/devices/system/cpu.
Other information collected via hypervisor APIs is now placed in
/sys/hypervisor. We create a /sys/hypervisor/type file (holding the
constant string "tilera") to be parallel with the Xen use of
/sys/hypervisor/type holding "xen". We create three top-level files,
"version" (the hypervisor's own version), "config_version" (the
version of the configuration file), and "hvconfig" (the contents of
the configuration file). The remaining information from our old
/proc/tile/board and /proc/tile/switch files becomes an attribute
group appearing under /sys/hypervisor/board/.
Finally, after some feedback from Arnd Bergmann for the previous
version of this patch, the /proc/tile/hardwall file is split up into
two conceptual parts. First, a directory /proc/tile/hardwall/ which
contains one file per active hardwall, each file named after the
hardwall's ID and holding a cpulist that says which cpus are enclosed by
the hardwall. Second, a /proc/PID file "hardwall" that is either
empty (for non-hardwall-using processes) or contains the hardwall ID.
Finally, this change pushes the /proc/sys/tile/unaligned_fixup/
directory, with knobs controlling the kernel code for handling the
fixup of unaligned exceptions.
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
The balloon driver in a Xen guest frees guest pages and marks them as
mmio. When the kernel crashes and the crash kernel attempts to read the
oldmem via /proc/vmcore a read from ballooned pages will generate 100%
load in dom0 because Xen asks qemu-dm for the page content. Since the
reads come in as 8byte requests each ballooned page is tried 512 times.
With this change a hook can be registered which checks wether the given
pfn is really ram. The hook has to return a value > 0 for ram pages, a
value < 0 on error (because the hypercall is not known) and 0 for non-ram
pages.
This will reduce the time to read /proc/vmcore. Without this change a
512M guest with 128M crashkernel region needs 200 seconds to read it, with
this change it takes just 2 seconds.
Signed-off-by: Olaf Hering <olaf@aepfle.de>
Currently, pagemap_read() has three error and/or corner case handling
mistake.
(1) If ppos parameter is wrong, mm refcount will be leak.
(2) If count parameter is 0, mm refcount will be leak too.
(3) If the current task is sleeping in kmalloc() and the system
is out of memory and oom-killer kill the proc associated task,
mm_refcount prevent the task free its memory. then system may
hang up.
<Quote Hugh's explain why we shold call kmalloc() before get_mm()>
check_mem_permission gets a reference to the mm. If we
__get_free_page after check_mem_permission, imagine what happens if the
system is out of memory, and the mm we're looking at is selected for
killing by the OOM killer: while we wait in __get_free_page for more
memory, no memory is freed from the selected mm because it cannot reach
exit_mmap while we hold that reference.
This patch fixes the above three.
Cc: Jovi Zhang <bookjovi@gmail.com>
Cc: Stephen Wilson <wilsons@start.ca>
It whould be better if put check_mem_permission after __get_free_page in
mem_write, to be same as function mem_read.
Hugh Dickins explained the reason.
check_mem_permission gets a reference to the mm. If we __get_free_page
after check_mem_permission, imagine what happens if the system is out
of memory, and the mm we're looking at is selected for killing by the
OOM killer: while we wait in __get_free_page for more memory, no memory
is freed from the selected mm because it cannot reach exit_mmap while
Reported-by: Jovi Zhang <bookjovi@gmail.com>
There is a macro for the max size kmalloc can allocate, so use it instead
of a hardcoded number.
Signed-off-by: Yuanhan Liu <yuanhan.liu@linux.intel.com>
No need for this local array to be writable, so mark it const.
Convert fs/proc/ from strict_strto*() to kstrto*() functions.
Setup and cleanup of mm_struct->exe_file is currently done in fs/proc/.
This was because exe_file was needed only for /proc/<pid>/exe. Since we
will need the exe_file functionality also for core dumps (so core name can
contain full binary path), built this functionality always into the
kernel.
To achieve that move that out of proc FS to the kernel/ where in fact it
should belong. By doing that we can make dup_mm_exe_file static. Also we
can drop linux/proc_fs.h inclusion in fs/exec.c and kernel/fork.c.
The type of vma->vm_flags is 'unsigned long'. Neither 'int' nor
'unsigned int'. This patch fixes such misuse.
[ Changed to use a typedef - we'll extend it to cover more cases
later, since there has been discussion about making it a 64-bit
type.. - Linus ]
net: fix get_net_ns_by_fd for !CONFIG_NET_NS
ns proc: Return -ENOENT for a nonexistent /proc/self/ns/ entry.
ns: Declare sys_setns in syscalls.h
net: Allow setting the network namespace by fd
ns proc: Add support for the ipc namespace
ns proc: Add support for the uts namespace
ns proc: Add support for the network namespace.
ns: Introduce the setns syscall
ns: proc files for namespace naming policy.
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (89 commits)
bonding: documentation and code cleanup for resend_igmp
bonding: prevent deadlock on slave store with alb mode (v3)
net: hold rtnl again in dump callbacks
Add Fujitsu 1000base-SX PCI ID to tg3
bnx2x: protect sequence increment with mutex
sch_sfq: fix peek() implementation
isdn: netjet - blacklist Digium TDM400P
via-velocity: don't annotate MAC registers as packed
xen: netfront: hold RTNL when updating features.
sctp: fix memory leak of the ASCONF queue when free asoc
net: make dev_disable_lro use physical device if passed a vlan dev (v2)
net: move is_vlan_dev into public header file (v2)
bug.h: Fix build with CONFIG_PRINTK disabled.
wireless: fix fatal kernel-doc error + warning in mac80211.h
wireless: fix cfg80211.h new kernel-doc warnings
iwlagn: dbg_fixed_rate only used when CONFIG_MAC80211_DEBUGFS enabled
dst: catch uninitialized metrics
be2net: hash key for rss-config cmd not set
bridge: initialize fake_rtable metrics
net: fix __dst_destroy_metrics_generic()
Fix up trivial conflicts in drivers/staging/brcm80211/brcmfmac/wl_cfg80211.c
In show_numa_map() we collect statistics into a numa_maps structure.
Since the number of NUMA nodes can be very large, this structure is not a
candidate for stack allocation.
Instead of going thru a kmalloc()+kfree() cycle each time show_numa_map()
is invoked, perform the allocation just once when /proc/pid/numa_maps is
opened.
Performing the allocation when numa_maps is opened, and thus before a
reference to the target tasks mm is taken, eliminates a potential
stalemate condition in the oom-killer as originally described by Hugh
Dickins:
... imagine what happens if the system is out of memory, and the mm
we're looking at is selected for killing by the OOM killer: while
we wait in __get_free_page for more memory, no memory is freed
from the selected mm because it cannot reach exit_mmap while we hold
that reference.
Signed-off-by: Stephen Wilson <wilsons@start.ca>
Reviewed-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com>
Now that mm/mempolicy.c is no longer implementing /proc/pid/numa_maps
there is no need to export struct proc_maps_private to the world. Move it
to fs/proc/internal.h instead.
Moving show_numa_map() from mempolicy.c to task_mmu.c solves several
issues.
- Having the show() operation "miles away" from the corresponding
seq_file iteration operations is a maintenance burden.
- The need to export ad hoc info like struct proc_maps_private is
eliminated.
- The implementation of show_numa_map() can be improved in a simple
manner by cooperating with the other seq_file operations (start,
stop, etc) -- something that would be messy to do without this
change.
Spotted-by: Nathan Lynch <ntl@pobox.com>
ssh://master.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6 into for-davem
* use proc_mkdir_mode() instead of create_proc_entry(S_IFDIR|...),
export proc_mkdir_mode() for that, oh well.
* don't supply S_IFREG to proc_create_data(), it's unnecessary
