path: root/fs/pstore/Makefile
2015-10-22pstore: add pstore unregisterGeliang Tang
pstore doesn't support unregistering yet. It was marked as TODO. This patch adds some code to fix it: 1) Add functions to unregister kmsg/console/ftrace/pmsg. 2) Add a function to free compression buffer. 3) Unmap the memory and free it. 4) Add a function to unregister pstore filesystem. Signed-off-by: Geliang Tang <geliangtang@163.com> Acked-by: Kees Cook <keescook@chromium.org> [Removed __exit annotation from ramoops_remove(). Reported by Arnd Bergmann] Signed-off-by: Tony Luck <tony.luck@intel.com>
2015-01-16pstore: Add pmsg - user-space accessible pstore objectMark Salyzyn
A secured user-space accessible pstore object. Writes to /dev/pmsg0 are appended to the buffer, on reboot the persistent contents are available in /sys/fs/pstore/pmsg-ramoops-[ID]. One possible use is syslogd, or other daemon, can write messages, then on reboot provides a means to triage user-space activities leading up to a panic as a companion to the pstore dmesg or console logs. Signed-off-by: Mark Salyzyn <salyzyn@android.com> Acked-by: Kees Cook <keescook@chromium.org> Signed-off-by: Tony Luck <tony.luck@intel.com>
2012-07-17pstore: Add persistent function tracingAnton Vorontsov
With this support kernel can save function call chain log into a persistent ram buffer that can be decoded and dumped after reboot through pstore filesystem. It can be used to determine what function was last called before a reset or panic. We store the log in a binary format and then decode it at read time. p.s. Mostly the code comes from trace_persistent.c driver found in the Android git tree, written by Colin Cross <ccross@android.com> (according to sign-off history). I reworked the driver a little bit, and ported it to pstore. Signed-off-by: Anton Vorontsov <anton.vorontsov@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-17staging: android: persistent_ram: Move to fs/pstore/ram_core.cAnton Vorontsov
This is a first step for adding ECC support for pstore RAM backend: we will use the persistent_ram routines, kindly provided by Google. Basically, persistent_ram is a set of helper routines to deal with the [optionally] ECC-protected persistent ram regions. A bit of Makefile, Kconfig and header files adjustments were needed because of the move. Signed-off-by: Anton Vorontsov <anton.vorontsov@linaro.org> Acked-by: Kees Cook <keescook@chromium.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-16ramoops: Move to fs/pstore/ram.cAnton Vorontsov
Since ramoops was converted to pstore, it has nothing to do with character devices nowadays. Instead, today it is just a RAM backend for pstore. The patch just moves things around. There are a few changes were needed because of the move: 1. Kconfig and Makefiles fixups, of course. 2. In pstore/ram.c we have to play a bit with MODULE_PARAM_PREFIX, this is needed to keep user experience the same as with ramoops driver (i.e. so that ramoops.foo kernel command line arguments would still work). Signed-off-by: Anton Vorontsov <anton.vorontsov@linaro.org> Acked-by: Marco Stornelli <marco.stornelli@gmail.com> Acked-by: Kees Cook <keescook@chromium.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2010-12-28pstore: new filesystem interface to platform persistent storageTony Luck
Some platforms have a small amount of non-volatile storage that can be used to store information useful to diagnose the cause of a system crash. This is the generic part of a file system interface that presents information from the crash as a series of files in /dev/pstore. Once the information has been seen, the underlying storage is freed by deleting the files. Signed-off-by: Tony Luck <tony.luck@intel.com>
