path: root/fs/qnx4/bitmap.c
2009-12-16qnx4: use hweight8Akinobu Mita
Use hweight8 instead of counting for each bit Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Acked-by: Anders Larsen <al@alarsen.net> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16qnx4fs: remove remains of the (defunct) write supportAnders Larsen
commit 945ffe54bbd56ceed62de3b908800fd7c6ffb284 ("qnx4: remove write support") removed the (defunct) write support but missed a chunk of related, dead code. Signed-off-by: Anders Larsen <al@alarsen.net> Cc: Jiri Kosina <jkosina@suse.cz> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-11-09qnx4fs: add missing KERN_xxx to printk() callsAnders Larsen
fixed printk calls to consistently specify a KERN_xxx level. Signed-off-by: Anders Larsen <al@alarsen.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-23qnx4: remove write supportChristoph Hellwig
qnx4 wrte support has never been fully implement, is broken since the dawn of time and hasn't been actively developed since before git history started. Instead of letting it further bitrot and complicate API transition (like the new truncate code) remove it. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Anders Larsen <al@alarsen.net> Cc: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-11fs/qnx4: sanitize includesAl Viro
fs-internal parts of qnx4_fs.h taken to fs/qnx4/qnx4.h, includes adjusted, qnx4_fs.h doesn't need unifdef anymore. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-01-03fs/qnx4/bitmap.c: #if 0 qnx4_new_block()Adrian Bunk
qnx4_new_block() is neither implemented nor used. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: Anders Larsen <al@alarsen.net>
