path: root/fs/qnx4/dir.c
2010-10-21BKL: remove BKL from qnx4Arnd Bergmann
All uses of the BKL in qnx4 were the result of a pushdown into code that doesn't really need it. As Christoph points out, this is a read-only file system, which eliminates most of the races in readdir/lookup. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Anders Larsen <al@alarsen.net> Cc: Christoph Hellwig <hch@infradead.org>
2010-05-27rename the generic fsync implementationsChristoph Hellwig
We don't name our generic fsync implementations very well currently. The no-op implementation for in-memory filesystems currently is called simple_sync_file which doesn't make too much sense to start with, the the generic one for simple filesystems is called simple_fsync which can lead to some confusion. This patch renames the generic file fsync method to generic_file_fsync to match the other generic_file_* routines it is supposed to be used with, and the no-op implementation to noop_fsync to make it obvious what to expect. In addition add some documentation for both methods. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-27fs/: do not fallback to default_llseek() when readdir() uses BKLjan Blunck
Do not use the fallback default_llseek() if the readdir operation of the filesystem still uses the big kernel lock. Since llseek() modifies file->f_pos of the directory directly it may need locking to not confuse readdir which usually uses file->f_pos directly as well Since the special characteristics of the BKL (unlocked on schedule) are not necessary in this case, the inode mutex can be used for locking as provided by generic_file_llseek(). This is only possible since all filesystems, except reiserfs, either use a directory as a flat file or with disk address offsets. Reiserfs on the other hand uses a 32bit hash off the filename as the offset so generic_file_llseek() can get used as well since the hash is always smaller than sb->s_maxbytes (= (512 << 32) - blocksize). Signed-off-by: Jan Blunck <jblunck@suse.de> Acked-by: Jan Kara <jack@suse.cz> Acked-by: Anders Larsen <al@alarsen.net> Cc: Frederic Weisbecker <fweisbec@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-11-09qnx4fs: add missing KERN_xxx to printk() callsAnders Larsen
fixed printk calls to consistently specify a KERN_xxx level. Signed-off-by: Anders Larsen <al@alarsen.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-23qnx4: remove write supportChristoph Hellwig
qnx4 wrte support has never been fully implement, is broken since the dawn of time and hasn't been actively developed since before git history started. Instead of letting it further bitrot and complicate API transition (like the new truncate code) remove it. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Anders Larsen <al@alarsen.net> Cc: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-11fs/qnx4: sanitize includesAl Viro
fs-internal parts of qnx4_fs.h taken to fs/qnx4/qnx4.h, includes adjusted, qnx4_fs.h doesn't need unifdef anymore. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-06-11Sanitize qnx4 fsync handlingAl Viro
* have directory operations use mark_buffer_dirty_inode(), so that sync_mapping_buffers() would get those. * make qnx4_write_inode() honour its last argument. * get rid of insane copies of very ancient "walk the indirect blocks" in qnx4/fsync - they never matched the actual fs layout and, fortunately, never'd been called. Again, all this junk is not needed; ->fsync() should just do sync_mapping_buffers + sync_inode (and if we implement block allocation for qnx4, we'll need to use mark_buffer_dirty_inode() for extent blocks) Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2007-02-12[PATCH] mark struct inode_operations const 3Arjan van de Ven
2006-12-08[PATCH] struct path: convert qnx4Josef Sipek
2006-03-28[PATCH] Make most file operations structs in fs/ constArjan van de Ven
This is a conversion to make the various file_operations structs in fs/ const. Basically a regexp job, with a few manual fixups The goal is both to increase correctness (harder to accidentally write to shared datastructures) and reducing the false sharing of cachelines with things that get dirty in .data (while .rodata is nicely read only and thus cache clean) Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] fs/qnx4/*: fix sparse warningsAlexey Dobriyan
This patch fixes sparse warnings in the qnx4fs (and might even make qnx4fs work on big-endian boxes) Signed-off-by: Alexey Dobriyan <adobriyan@mail.ru> Signed-off-by: Domen Puncer <domen@coderock.org> Signed-off-by: Anders Larsen <al@alarsen.net> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
