path: root/fs/quota/Kconfig
2010-10-05quota: Make QUOTACTL config be selected by its usersJan Kara
Remove "depends on" line from QUOTACTL config option and rather select the option explicitely from config options which need it. It makes more sense this way and also fixes Kconfig warning due to GFS2 selecting QUOTACTL but QUOTACTL not depending on it. Signed-off-by: Jan Kara <jack@suse.cz>
2010-04-20quota: Convert __DQUOT_PARANOIA symbol to standard config optionJan Kara
Make __DQUOT_PARANOIA define from the old days a standard config option and turn it off by default. This gets rid of a quota warning about writes before quota is turned on for systems with ext4 root filesystem. Currently there's no way to legally solve this because /etc/mtab has to be written before quota is turned on on most systems. Signed-off-by: Jan Kara <jack@suse.cz>
2010-03-05quota: split out compat_sys_quotactl support from quota.cChristoph Hellwig
Instead of adding ifdefs just split it into a new file. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2009-12-10quota: Implement quota format with 64-bit space and inode limitsJan Kara
So far the maximum quota space limit was 4TB. Apparently this isn't enough for Lustre guys anymore. So implement new quota format which raises block limits to 2^64 bytes. Also store number of inodes and inode limits in 64-bit variables as 2^32 files isn't that insanely high anymore. The first version of the patch has been developed by Andrew Perepechko <Andrew.Perepechko@Sun.COM>. CC: Andrew.Perepechko@Sun.COM Signed-off-by: Jan Kara <jack@suse.cz>
2009-12-03VFS: Export dquot_send_warningSteven Whitehouse
Sending a message to userspace in a generic format to warn of events (e.g. quota exceeded) in the quota subsystem is a generically useful feature. This patch makes some minor changes to the send_message function from dquot.c renaming it quota_send_message, moving it to quota.c and exporting it for use by filesystems which do not use the dquot code. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com>
2009-03-26trivial: fix typos/grammar errors in fs/KconfigMatt LaPlante
Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Jan Kara <jack@suse.cz>
2009-03-26quota: Move quota files into separate directoryJan Kara
Quota subsystem has more and more files. It's time to create a dir for it. Signed-off-by: Jan Kara <jack@suse.cz>
