path: root/fs/quota/Makefile
2012-09-18userns: Implement struct kqidEric W. Biederman
Add the data type struct kqid which holds the kernel internal form of the owning identifier of a quota. struct kqid is a replacement for the implicit union of uid, gid and project id stored in an unsigned int and the quota type field that is was used in the quota data structures. Making the data type explicit allows the kuid_t and kgid_t type safety to propogate more thoroughly through the code, revealing more places where uid/gid conversions need be made. Along with the data type struct kqid comes the helper functions qid_eq, qid_lt, from_kqid, from_kqid_munged, qid_valid, make_kqid, make_kqid_invalid, make_kqid_uid, make_kqid_gid. Cc: Jan Kara <jack@suse.cz> Cc: Dave Chinner <david@fromorbit.com> Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2010-03-05quota: split out compat_sys_quotactl support from quota.cChristoph Hellwig
Instead of adding ifdefs just split it into a new file. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-03-05quota: split out netlink notification support from quota.cChristoph Hellwig
2009-04-27quota: remove obsolete comments in fs/quota/MakefileChristoph Hellwig
Get rid of useless comments and the equally useless obj-y initialization. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2009-03-26quota: Move quota files into separate directoryJan Kara
Quota subsystem has more and more files. It's time to create a dir for it. Signed-off-by: Jan Kara <jack@suse.cz>
