path: root/fs/ramfs/internal.h
2008-04-29fs/ramfs/ extern cleanupAdrian Bunk
- internal.h shouldn't duplicate the extern declaration for ramfs_file_operations already in include/linux/ramfs.h - file-mmu.c needs two #include's for seeing the extern declarations of it's global struct's Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] mark struct inode_operations const 3Arjan van de Ven
2006-06-28[PATCH] mark address_space_operations constChristoph Hellwig
Same as with already do with the file operations: keep them in .rodata and prevents people from doing runtime patching. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Steven French <sfrench@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] Make most file operations structs in fs/ constArjan van de Ven
This is a conversion to make the various file_operations structs in fs/ const. Basically a regexp job, with a few manual fixups The goal is both to increase correctness (harder to accidentally write to shared datastructures) and reducing the false sharing of cachelines with things that get dirty in .data (while .rodata is nicely read only and thus cache clean) Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] NOMMU: Provide shared-writable mmap support on ramfsDavid Howells
The attached patch makes ramfs support shared-writable mmaps by: (1) Attempting to perform a contiguous block allocation to the requested size when truncate attempts to increase the file from zero size, such as happens when: fd = shm_open("/file/on/ramfs", ...): ftruncate(fd, size_requested); addr = mmap(NULL, subsize, PROT_READ|PROT_WRITE|PROT_EXEC, MAP_SHARED, fd, offset); (2) Permitting any shared-writable mapping over any contiguous set of extant pages. get_unmapped_area() will return the address into the actual ramfs pages. The mapping may start anywhere and be of any size, but may not go over the end of file. Multiple mappings may overlap in any way. (3) Not permitting a file to be shrunk if it would truncate any shared mappings (private mappings are copied). Thus this patch provides support for POSIX shared memory on NOMMU kernels, with certain limitations such as there being a large enough block of pages available to support the allocation and it only working on directly mappable filesystems. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
