path: root/fs/ramfs
2009-07-29fs/ramfs/file-nommu.c needs include/linux/sched.hCatalin Marinas
This file makes use of various macros defined in files like asm/current.h or asm-generic/resource.h. All these files can be included via sched.h. The building of the !MMU ARM kernel (with additional patches) fails without this change. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Acked-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-14ramfs: ignore unknown mount optionsMike Frysinger
On systems where CONFIG_SHMEM is disabled, mounting tmpfs filesystems can fail when tmpfs options are used. This is because tmpfs creates a small wrapper around ramfs which rejects unknown options, and ramfs itself only supports a tiny subset of what tmpfs supports. This makes it pretty hard to use the same userspace systems across different configuration systems. As such, ramfs should ignore the tmpfs options when tmpfs is merely a wrapper around ramfs. This used to work before commit c3b1b1cbf0 as previously, ramfs would ignore all options. But now, we get: ramfs: bad mount option: size=10M mount: mounting mdev on /dev failed: Invalid argument Another option might be to restore the previous behavior, where ramfs simply ignored all unknown mount options ... which is what Hugh prefers. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Hugh Dickins <hugh.dickins@tiscali.co.uk> Acked-by: Matt Mackall <mpm@selenic.com> Acked-by: Wu Fengguang <fengguang.wu@intel.com> Cc: stable@kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07ramfs: fix double freeing s_fs_info on failed mountIngo Molnar
If ramfs mount fails, s_fs_info will be freed twice in ramfs_fill_super() and ramfs_kill_sb(), leading to kernel oops. Consolidate and beautify the code. Make sure s_fs_info and s_root are in known good states. Acked-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01ramfs: add support for "mode=" mount optionWu Fengguang
Addresses http://bugzilla.kernel.org/show_bug.cgi?id=12843 "I use ramfs instead of tmpfs for /tmp because I don't use swap on my laptop. Some apps need 1777 mode for /tmp directory, but ramfs does not support 'mode=' mount option." Reported-by: Avan Anishchuk <matimatik@gmail.com> Signed-off-by: Wu Fengguang <fengguang.wu@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-01ramfs-nommu: use generic lru cacheJohannes Weiner
Instead of open-coding the lru-list-add pagevec batching when expanding a file mapping from zero, defer to the appropriate page cache function that also takes care of adding the page to the lru list. This is cleaner, saves code and reduces the stack footprint by 16 words worth of pagevec. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: David Howells <dhowells@redhat.com> Cc: Nick Piggin <npiggin@suse.de> Acked-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Cc: Rik van Riel <riel@redhat.com> Cc: Peter Zijlstra <peterz@infradead.com> Cc: MinChan Kim <minchan.kim@gmail.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Cc: Greg Ungerer <gerg@snapgear.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-26ramfs: Remove quota callJan Kara
Ramfs has no bussiness in quotas. Signed-off-by: Jan Kara <jack@suse.cz>
2009-03-14nommu: ramfs: don't leak pages when adding to page cache failsJohannes Weiner
When a ramfs nommu mapping is expanded, contiguous pages are allocated and added to the pagecache. The caller's reference is then passed on by moving whole pagevecs to the file lru list. If the page cache adding fails, make sure that the error path also moves the pagevec contents which might still contain up to PAGEVEC_SIZE successfully added pages, of which we would leak references otherwise. Signed-off-by: Johannes Weiner <hannes@cmpxchg.org> Cc: David Howells <dhowells@redhat.com> Cc: Enrik Berkhan <Enrik.Berkhan@ge.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-14nommu: ramfs: pages allocated to an inode's pagecache may get wrongly discardedEnrik Berkhan
The pages attached to a ramfs inode's pagecache by truncation from nothing - as done by SYSV SHM for example - may get discarded under memory pressure. The problem is that the pages are not marked dirty. Anything that creates data in an MMU-based ramfs will cause the pages holding that data will cause the set_page_dirty() aop to be called. For the NOMMU-based mmap, set_page_dirty() may be called by write(), but it won't be called by page-writing faults on writable mmaps, and it isn't called by ramfs_nommu_expand_for_mapping() when a file is being truncated from nothing to allocate a contiguous run. The solution is to mark the pages dirty at the point of allocation by the truncation code. Signed-off-by: Enrik Berkhan <Enrik.Berkhan@ge.com> Signed-off-by: David Howells <dhowells@redhat.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Johannes Weiner <hannes@cmpxchg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-08NOMMU: Fix cleanup handling in ramfs_nommu_get_umapped_area()David Howells
Fix cleanup handling in ramfs_nommu_get_umapped_area() by only freeing the number of pages that find_get_pages() said it had returned (nr) rather than attempting to free the number of pages we asked for (lpages) - thus avoiding the situation whereby put_page() may be handed NULL pointers if find_get_pages() returned fewer pages that were requested. Also avoid a warning about nr being uninitialised and the need for an if-statement in the cleanup path by using appropriate gotos. Signed-off-by: David Howells <dhowells@redhat.com>
2009-01-05zero i_uid/i_gid on inode allocationAl Viro
... and don't bother in callers. Don't bother with zeroing i_blocks, while we are at it - it's already been zeroed. i_mode is not worth the effort; it has no common default value. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-11-14CRED: Wrap task credential accesses in the RAMFS filesystemDavid Howells
Wrap access to task credentials so that they can be separated more easily from the task_struct during the introduction of COW creds. Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id(). Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more sense to use RCU directly rather than a convenient wrapper; these will be addressed by later patches. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2008-10-20Ramfs and Ram Disk pages are unevictableLee Schermerhorn
Christoph Lameter pointed out that ram disk pages also clutter the LRU lists. When vmscan finds them dirty and tries to clean them, the ram disk writeback function just redirties the page so that it goes back onto the active list. Round and round she goes... With the ram disk driver [rd.c] replaced by the newer 'brd.c', this is no longer the case, as ram disk pages are no longer maintained on the lru. [This makes them unmigratable for defrag or memory hot remove, but that can be addressed by a separate patch series.] However, the ramfs pages behave like ram disk pages used to, so: Define new address_space flag [shares address_space flags member with mapping's gfp mask] to indicate that the address space contains all unevictable pages. This will provide for efficient testing of ramfs pages in page_evictable(). Also provide wrapper functions to set/test the unevictable state to minimize #ifdefs in ramfs driver and any other users of this facility. Set the unevictable state on address_space structures for new ramfs inodes. Test the unevictable state in page_evictable() to cull unevictable pages. These changes depend on [CONFIG_]UNEVICTABLE_LRU. [riel@redhat.com: undo the brd.c part] Signed-off-by: Lee Schermerhorn <lee.schermerhorn@hp.com> Signed-off-by: Rik van Riel <riel@redhat.com> Debugged-by: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-20vmscan: split LRU lists into anon & file setsRik van Riel
Split the LRU lists in two, one set for pages that are backed by real file systems ("file") and one for pages that are backed by memory and swap ("anon"). The latter includes tmpfs. The advantage of doing this is that the VM will not have to scan over lots of anonymous pages (which we generally do not want to swap out), just to find the page cache pages that it should evict. This patch has the infrastructure and a basic policy to balance how much we scan the anon lists and how much we scan the file lists. The big policy changes are in separate patches. [lee.schermerhorn@hp.com: collect lru meminfo statistics from correct offset] [kosaki.motohiro@jp.fujitsu.com: prevent incorrect oom under split_lru] [kosaki.motohiro@jp.fujitsu.com: fix pagevec_move_tail() doesn't treat unevictable page] [hugh@veritas.com: memcg swapbacked pages active] [hugh@veritas.com: splitlru: BDI_CAP_SWAP_BACKED] [akpm@linux-foundation.org: fix /proc/vmstat units] [nishimura@mxp.nes.nec.co.jp: memcg: fix handling of shmem migration] [kosaki.motohiro@jp.fujitsu.com: adjust Quicklists field of /proc/meminfo] [kosaki.motohiro@jp.fujitsu.com: fix style issue of get_scan_ratio()] Signed-off-by: Rik van Riel <riel@redhat.com> Signed-off-by: Lee Schermerhorn <Lee.Schermerhorn@hp.com> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Daisuke Nishimura <nishimura@mxp.nes.nec.co.jp> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-02mm: tiny-shmem nommu fixNick Piggin
The previous patch db203d53d474aa068984e409d807628f5841da1b ("mm: tiny-shmem fix lock ordering: mmap_sem vs i_mutex") to fix the lock ordering in tiny-shmem breaks shared anonymous and IPC memory on NOMMU architectures because it was using the expanding truncate to signal ramfs to allocate a physically contiguous RAM backing the inode (otherwise it is unusable for "memory mapping" it to userspace). However do_truncate is what caused the lock ordering error, due to it taking i_mutex. In this case, we can actually just call ramfs directly to allocate memory for the mapping, rather than go via truncate. Acked-by: David Howells <dhowells@redhat.com> Acked-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Matt Mackall <mpm@selenic.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-04ramfs: enable splice writeOctavian Purdila
Signed-off-by: Octavian Purdila <opurdila@ixiacom.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-04-30mm: bdi: add separate writeback accounting capabilityMiklos Szeredi
Add a new BDI capability flag: BDI_CAP_NO_ACCT_WB. If this flag is set, then don't update the per-bdi writeback stats from test_set_page_writeback() and test_clear_page_writeback(). Misc cleanups: - convert bdi_cap_writeback_dirty() and friends to static inline functions - create a flag that includes all three dirty/writeback related flags, since almst all users will want to have them toghether Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-29fs/ramfs/ extern cleanupAdrian Bunk
- internal.h shouldn't duplicate the extern declaration for ramfs_file_operations already in include/linux/ramfs.h - file-mmu.c needs two #include's for seeing the extern declarations of it's global struct's Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Remove valueless definition of hard-selected RAMFS optionRobert P. J. Day
Since CONFIG_RAMFS is currently hard-selected to "y", and since Documentation/filesystems/ramfs-rootfs-initramfs.txt reads as follows: "The amount of code required to implement ramfs is tiny, because all the work is done by the existing Linux caching infrastructure. Basically, you're mounting the disk cache as a filesystem. Because of this, ramfs is not an optional component removable via menuconfig, since there would be negligible space savings." It seems pointless to leave this as a Kconfig entry. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17mm: bdi init hooksPeter Zijlstra
provide BDI constructor/destructor hooks [akpm@linux-foundation.org: compile fix] Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16implement simple fs aopsNick Piggin
Implement new aops for some of the simpler filesystems. Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-31NOMMU: Fix SYSV IPC SHMDavid Howells
Fix the SYSV IPC SHM to work with the changes applied by the new fault handler patches when CONFIG_MMU=n. Signed-off-by: David Howells <dhowells@redhat.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17Add __GFP_MOVABLE for callers to flag allocations from high memory that may ↵Mel Gorman
be migrated It is often known at allocation time whether a page may be migrated or not. This patch adds a flag called __GFP_MOVABLE and a new mask called GFP_HIGH_MOVABLE. Allocations using the __GFP_MOVABLE can be either migrated using the page migration mechanism or reclaimed by syncing with backing storage and discarding. An API function very similar to alloc_zeroed_user_highpage() is added for __GFP_MOVABLE allocations called alloc_zeroed_user_highpage_movable(). The flags used by alloc_zeroed_user_highpage() are not changed because it would change the semantics of an existing API. After this patch is applied there are no in-kernel users of alloc_zeroed_user_highpage() so it probably should be marked deprecated if this patch is merged. Note that this patch includes a minor cleanup to the use of __GFP_ZERO in shmem.c to keep all flag modifications to inode->mapping in the shmem_dir_alloc() helper function. This clean-up suggestion is courtesy of Hugh Dickens. Additional credit goes to Christoph Lameter and Linus Torvalds for shaping the concept. Credit to Hugh Dickens for catching issues with shmem swap vector and ramfs allocations. [akpm@linux-foundation.org: build fix] [hugh@veritas.com: __GFP_ZERO cleanup] Signed-off-by: Mel Gorman <mel@csn.ul.ie> Cc: Andy Whitcroft <apw@shadowen.org> Cc: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-10sendfile: remove .sendfile from filesystems that use generic_file_sendfile()Jens Axboe
They can use generic_file_splice_read() instead. Since sys_sendfile() now prefers that, there should be no change in behaviour. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-06-07RAMFS NOMMU: missed POSIX UID/GID inode attribute checkingBryan Wu
This bug was caught by LTP testcase fchmod06 on Blackfin platform. In the manpage of fchmod, "EPERM: The effective UID does not match the owner of the file, and the process is not privileged (Linux: it does not have the CAP_FOWNER capability)." But the ramfs nommu code missed the inode_change_ok POSIX UID/GID verification. This patch fixed this. Signed-off-by: Bryan Wu <bryan.wu@analog.com> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-30a bug in ramfs_nommu_resize function, passing old size to vmtruncateBryan Wu
It should be pass "newsize" to vmtruncate function to modify the inode->i_size, while the old size is passed to vmtruncate. This bug was caught by LTP truncate test case on Blackfin platform. After it was fixed, the LTP truncate test case passed. Signed-off-by: Bryan Wu <bryan.wu@analog.com> Cc: David Howells <dhowells@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-21Detach sched.h from mm.hAlexey Dobriyan
First thing mm.h does is including sched.h solely for can_do_mlock() inline function which has "current" dereference inside. By dealing with can_do_mlock() mm.h can be detached from sched.h which is good. See below, why. This patch a) removes unconditional inclusion of sched.h from mm.h b) makes can_do_mlock() normal function in mm/mlock.c c) exports can_do_mlock() to not break compilation d) adds sched.h inclusions back to files that were getting it indirectly. e) adds less bloated headers to some files (asm/signal.h, jiffies.h) that were getting them indirectly Net result is: a) mm.h users would get less code to open, read, preprocess, parse, ... if they don't need sched.h b) sched.h stops being dependency for significant number of files: on x86_64 allmodconfig touching sched.h results in recompile of 4083 files, after patch it's only 3744 (-8.3%). Cross-compile tested on all arm defconfigs, all mips defconfigs, all powerpc defconfigs, alpha alpha-up arm i386 i386-up i386-defconfig i386-allnoconfig ia64 ia64-up m68k mips parisc parisc-up powerpc powerpc-up s390 s390-up sparc sparc-up sparc64 sparc64-up um-x86_64 x86_64 x86_64-up x86_64-defconfig x86_64-allnoconfig as well as my two usual configs. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] mark struct inode_operations const 3Arjan van de Ven
2007-02-11[PATCH] convert ramfs to use __set_page_dirty_no_writebackKen Chen
As pointed out by Hugh, ramfs would also benefit from using the new set_page_dirty aop method for memory backed file systems. Signed-off-by: Ken Chen <kenchen@google.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-30[PATCH] ramfs breaks without CONFIG_BLOCKDimitri Gorokhovik
ramfs doesn't provide the .set_dirty_page a_op, and when the BLOCK layer is not configured in, 'set_page_dirty' makes a call via a NULL pointer. Signed-off-by: Dimitri Gorokhovik <dimitri.gorokhovik@free.fr> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-08[PATCH] struct path: convert ramfsJosef Sipek
2006-10-01[PATCH] r/o bind mount prepwork: inc_nlink() helperDave Hansen
This is mostly included for parity with dec_nlink(), where we will have some more hooks. This one should stay pretty darn straightforward for now. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] Streamline generic_file_* interfaces and filemap cleanupsBadari Pulavarty
This patch cleans up generic_file_*_read/write() interfaces. Christoph Hellwig gave me the idea for this clean ups. In a nutshell, all filesystems should set .aio_read/.aio_write methods and use do_sync_read/ do_sync_write() as their .read/.write methods. This allows us to cleanup all variants of generic_file_* routines. Final available interfaces: generic_file_aio_read() - read handler generic_file_aio_write() - write handler generic_file_aio_write_nolock() - no lock write handler __generic_file_aio_write_nolock() - internal worker routine Signed-off-by: Badari Pulavarty <pbadari@us.ibm.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-07-10[PATCH] NOMMU: Fix execution off of ramfs with mmap()David Howells
Fix execution through the FDPIC binfmt of programs stored on ramfs by preventing the ramfs mmap() returning successfully on a private mapping of a ramfs file. This causes NOMMU mmap to make a copy of the mapped portion of the file and map that instead. This could be improved by granting direct mapping access to read-only private mappings for which the data is stored on a contiguous run of pages. However, this is only likely to be the case if the file was extended with truncate before being written. ramfs is left to map the file directly for shared mappings so that SYSV IPC and POSIX shared memory both still work. Signed-off-by: David Howells <dhowells@redhat.com> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-28[PATCH] mark address_space_operations constChristoph Hellwig
Same as with already do with the file operations: keep them in .rodata and prevents people from doing runtime patching. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Steven French <sfrench@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] VFS: Permit filesystem to override root dentry on mountDavid Howells
Extend the get_sb() filesystem operation to take an extra argument that permits the VFS to pass in the target vfsmount that defines the mountpoint. The filesystem is then required to manually set the superblock and root dentry pointers. For most filesystems, this should be done with simple_set_mnt() which will set the superblock pointer and then set the root dentry to the superblock's s_root (as per the old default behaviour). The get_sb() op now returns an integer as there's now no need to return the superblock pointer. This patch permits a superblock to be implicitly shared amongst several mount points, such as can be done with NFS to avoid potential inode aliasing. In such a case, simple_set_mnt() would not be called, and instead the mnt_root and mnt_sb would be set directly. The patch also makes the following changes: (*) the get_sb_*() convenience functions in the core kernel now take a vfsmount pointer argument and return an integer, so most filesystems have to change very little. (*) If one of the convenience function is not used, then get_sb() should normally call simple_set_mnt() to instantiate the vfsmount. This will always return 0, and so can be tail-called from get_sb(). (*) generic_shutdown_super() now calls shrink_dcache_sb() to clean up the dcache upon superblock destruction rather than shrink_dcache_anon(). This is required because the superblock may now have multiple trees that aren't actually bound to s_root, but that still need to be cleaned up. The currently called functions assume that the whole tree is rooted at s_root, and that anonymous dentries are not the roots of trees which results in dentries being left unculled. However, with the way NFS superblock sharing are currently set to be implemented, these assumptions are violated: the root of the filesystem is simply a dummy dentry and inode (the real inode for '/' may well be inaccessible), and all the vfsmounts are rooted on anonymous[*] dentries with child trees. [*] Anonymous until discovered from another tree. (*) The documentation has been adjusted, including the additional bit of changing ext2_* into foo_* in the documentation. [akpm@osdl.org: convert ipath_fs, do other stuff] Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Nathan Scott <nathans@sgi.com> Cc: Roland Dreier <rolandd@cisco.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] Make most file operations structs in fs/ constArjan van de Ven
This is a conversion to make the various file_operations structs in fs/ const. Basically a regexp job, with a few manual fixups The goal is both to increase correctness (harder to accidentally write to shared datastructures) and reducing the false sharing of cachelines with things that get dirty in .data (while .rodata is nicely read only and thus cache clean) Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] fs/*/file.c: drop insane header dependenciesAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-22[PATCH] mm: nommu use compound pagesNick Piggin
Now that compound page handling is properly fixed in the VM, move nommu over to using compound pages rather than rolling their own refcounting. nommu vm page refcounting is broken anyway, but there is no need to have divergent code in the core VM now, nor when it gets fixed. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: David Howells <dhowells@redhat.com> (Needs testing, please). Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-06[PATCH] ramfs needs to update directory m/ctime on symlinkPeter Staubach
ramfs neglects to update the directory mtime and ctime fields when creating a new symbolic link. Ramfs was modified in 2.6.15 to update these fields when other types of entries are created. The symlink support is separate from that other support, so that change did not cover quite all of the possibilities. All of the directory content manipulation entry points now seem to be covered with respect to these time field updates. Signed-off-by: Peter Staubach <staubach@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-24[PATCH] ramfs: update dir mtime and ctimeAndrew Morton
Phil Marek <philipp.marek@bmlv.gv.at> points out that ramfs forgets to update a directory's mtime and ctime when it is modified. Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-06[PATCH] NOMMU: Provide shared-writable mmap support on ramfsDavid Howells
The attached patch makes ramfs support shared-writable mmaps by: (1) Attempting to perform a contiguous block allocation to the requested size when truncate attempts to increase the file from zero size, such as happens when: fd = shm_open("/file/on/ramfs", ...): ftruncate(fd, size_requested); addr = mmap(NULL, subsize, PROT_READ|PROT_WRITE|PROT_EXEC, MAP_SHARED, fd, offset); (2) Permitting any shared-writable mapping over any contiguous set of extant pages. get_unmapped_area() will return the address into the actual ramfs pages. The mapping may start anywhere and be of any size, but may not go over the end of file. Multiple mappings may overlap in any way. (3) Not permitting a file to be shrunk if it would truncate any shared mappings (private mappings are copied). Thus this patch provides support for POSIX shared memory on NOMMU kernels, with certain limitations such as there being a large enough block of pages available to support the allocation and it only working on directly mappable filesystems. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
