path: root/fs/read_write.c
2019-12-01vfs: avoid problematic remapping requests into partial EOF blockDarrick J. Wong
[ Upstream commit 07d19dc9fbe9128378b9e226abe886fd8fd473df ] A deduplication data corruption is exposed in XFS and btrfs. It is caused by extending the block match range to include the partial EOF block, but then allowing unknown data beyond EOF to be considered a "match" to data in the destination file because the comparison is only made to the end of the source file. This corrupts the destination file when the source extent is shared with it. The VFS remapping prep functions only support whole block dedupe, but we still need to appear to support whole file dedupe correctly. Hence if the dedupe request includes the last block of the souce file, don't include it in the actual dedupe operation. If the rest of the range dedupes successfully, then reject the entire request. A subsequent patch will enable us to shorten dedupe requests correctly. When reflinking sub-file ranges, a data corruption can occur when the source file range includes a partial EOF block. This shares the unknown data beyond EOF into the second file at a position inside EOF, exposing stale data in the second file. If the reflink request includes the last block of the souce file, only proceed with the reflink operation if it lands at or past the destination file's current EOF. If it lands within the destination file EOF, reject the entire request with -EINVAL and make the caller go the hard way. A subsequent patch will enable us to shorten reflink requests correctly. Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Dave Chinner <david@fromorbit.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-09-10vfs: fix page locking deadlocks when deduping filesDarrick J. Wong
[ Upstream commit edc58dd0123b552453a74369bd0c8d890b497b4b ] When dedupe wants to use the page cache to compare parts of two files for dedupe, we must be very careful to handle locking correctly. The current code doesn't do this. It must lock and unlock the page only once if the two pages are the same, since the overlapping range check doesn't catch this when blocksize < pagesize. If the pages are distinct but from the same file, we must observe page locking order and lock them in order of increasing offset to avoid clashing with writeback locking. Fixes: 876bec6f9bbfcb3 ("vfs: refactor clone/dedupe_file_range common functions") Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com> Reviewed-by: Bill O'Donnell <billodo@redhat.com> Reviewed-by: Matthew Wilcox (Oracle) <willy@infradead.org> Signed-off-by: Sasha Levin <sashal@kernel.org>
2019-06-11fs: stream_open - opener for stream-like files so that read and write can ↵Kirill Smelkov
run simultaneously without deadlock commit 10dce8af34226d90fa56746a934f8da5dcdba3df upstream. Commit 9c225f2655e3 ("vfs: atomic f_pos accesses as per POSIX") added locking for file.f_pos access and in particular made concurrent read and write not possible - now both those functions take f_pos lock for the whole run, and so if e.g. a read is blocked waiting for data, write will deadlock waiting for that read to complete. This caused regression for stream-like files where previously read and write could run simultaneously, but after that patch could not do so anymore. See e.g. commit 581d21a2d02a ("xenbus: fix deadlock on writes to /proc/xen/xenbus") which fixes such regression for particular case of /proc/xen/xenbus. The patch that added f_pos lock in 2014 did so to guarantee POSIX thread safety for read/write/lseek and added the locking to file descriptors of all regular files. In 2014 that thread-safety problem was not new as it was already discussed earlier in 2006. However even though 2006'th version of Linus's patch was adding f_pos locking "only for files that are marked seekable with FMODE_LSEEK (thus avoiding the stream-like objects like pipes and sockets)", the 2014 version - the one that actually made it into the tree as 9c225f2655e3 - is doing so irregardless of whether a file is seekable or not. See https://lore.kernel.org/lkml/53022DB1.4070805@gmail.com/ https://lwn.net/Articles/180387 https://lwn.net/Articles/180396 for historic context. The reason that it did so is, probably, that there are many files that are marked non-seekable, but e.g. their read implementation actually depends on knowing current position to correctly handle the read. Some examples: kernel/power/user.c snapshot_read fs/debugfs/file.c u32_array_read fs/fuse/control.c fuse_conn_waiting_read + ... drivers/hwmon/asus_atk0110.c atk_debugfs_ggrp_read arch/s390/hypfs/inode.c hypfs_read_iter ... Despite that, many nonseekable_open users implement read and write with pure stream semantics - they don't depend on passed ppos at all. And for those cases where read could wait for something inside, it creates a situation similar to xenbus - the write could be never made to go until read is done, and read is waiting for some, potentially external, event, for potentially unbounded time -> deadlock. Besides xenbus, there are 14 such places in the kernel that I've found with semantic patch (see below): drivers/xen/evtchn.c:667:8-24: ERROR: evtchn_fops: .read() can deadlock .write() drivers/isdn/capi/capi.c:963:8-24: ERROR: capi_fops: .read() can deadlock .write() drivers/input/evdev.c:527:1-17: ERROR: evdev_fops: .read() can deadlock .write() drivers/char/pcmcia/cm4000_cs.c:1685:7-23: ERROR: cm4000_fops: .read() can deadlock .write() net/rfkill/core.c:1146:8-24: ERROR: rfkill_fops: .read() can deadlock .write() drivers/s390/char/fs3270.c:488:1-17: ERROR: fs3270_fops: .read() can deadlock .write() drivers/usb/misc/ldusb.c:310:1-17: ERROR: ld_usb_fops: .read() can deadlock .write() drivers/hid/uhid.c:635:1-17: ERROR: uhid_fops: .read() can deadlock .write() net/batman-adv/icmp_socket.c:80:1-17: ERROR: batadv_fops: .read() can deadlock .write() drivers/media/rc/lirc_dev.c:198:1-17: ERROR: lirc_fops: .read() can deadlock .write() drivers/leds/uleds.c:77:1-17: ERROR: uleds_fops: .read() can deadlock .write() drivers/input/misc/uinput.c:400:1-17: ERROR: uinput_fops: .read() can deadlock .write() drivers/infiniband/core/user_mad.c:985:7-23: ERROR: umad_fops: .read() can deadlock .write() drivers/gnss/core.c:45:1-17: ERROR: gnss_fops: .read() can deadlock .write() In addition to the cases above another regression caused by f_pos locking is that now FUSE filesystems that implement open with FOPEN_NONSEEKABLE flag, can no longer implement bidirectional stream-like files - for the same reason as above e.g. read can deadlock write locking on file.f_pos in the kernel. FUSE's FOPEN_NONSEEKABLE was added in 2008 in a7c1b990f715 ("fuse: implement nonseekable open") to support OSSPD. OSSPD implements /dev/dsp in userspace with FOPEN_NONSEEKABLE flag, with corresponding read and write routines not depending on current position at all, and with both read and write being potentially blocking operations: See https://github.com/libfuse/osspd https://lwn.net/Articles/308445 https://github.com/libfuse/osspd/blob/14a9cff0/osspd.c#L1406 https://github.com/libfuse/osspd/blob/14a9cff0/osspd.c#L1438-L1477 https://github.com/libfuse/osspd/blob/14a9cff0/osspd.c#L1479-L1510 Corresponding libfuse example/test also describes FOPEN_NONSEEKABLE as "somewhat pipe-like files ..." with read handler not using offset. However that test implements only read without write and cannot exercise the deadlock scenario: https://github.com/libfuse/libfuse/blob/fuse-3.4.2-3-ga1bff7d/example/poll.c#L124-L131 https://github.com/libfuse/libfuse/blob/fuse-3.4.2-3-ga1bff7d/example/poll.c#L146-L163 https://github.com/libfuse/libfuse/blob/fuse-3.4.2-3-ga1bff7d/example/poll.c#L209-L216 I've actually hit the read vs write deadlock for real while implementing my FUSE filesystem where there is /head/watch file, for which open creates separate bidirectional socket-like stream in between filesystem and its user with both read and write being later performed simultaneously. And there it is semantically not easy to split the stream into two separate read-only and write-only channels: https://lab.nexedi.com/kirr/wendelin.core/blob/f13aa600/wcfs/wcfs.go#L88-169 Let's fix this regression. The plan is: 1. We can't change nonseekable_open to include &~FMODE_ATOMIC_POS - doing so would break many in-kernel nonseekable_open users which actually use ppos in read/write handlers. 2. Add stream_open() to kernel to open stream-like non-seekable file descriptors. Read and write on such file descriptors would never use nor change ppos. And with that property on stream-like files read and write will be running without taking f_pos lock - i.e. read and write could be running simultaneously. 3. With semantic patch search and convert to stream_open all in-kernel nonseekable_open users for which read and write actually do not depend on ppos and where there is no other methods in file_operations which assume @offset access. 4. Add FOPEN_STREAM to fs/fuse/ and open in-kernel file-descriptors via steam_open if that bit is present in filesystem open reply. It was tempting to change fs/fuse/ open handler to use stream_open instead of nonseekable_open on just FOPEN_NONSEEKABLE flags, but grepping through Debian codesearch shows users of FOPEN_NONSEEKABLE, and in particular GVFS which actually uses offset in its read and write handlers https://codesearch.debian.net/search?q=-%3Enonseekable+%3D https://gitlab.gnome.org/GNOME/gvfs/blob/1.40.0-6-gcbc54396/client/gvfsfusedaemon.c#L1080 https://gitlab.gnome.org/GNOME/gvfs/blob/1.40.0-6-gcbc54396/client/gvfsfusedaemon.c#L1247-1346 https://gitlab.gnome.org/GNOME/gvfs/blob/1.40.0-6-gcbc54396/client/gvfsfusedaemon.c#L1399-1481 so if we would do such a change it will break a real user. 5. Add stream_open and FOPEN_STREAM handling to stable kernels starting from v3.14+ (the kernel where 9c225f2655 first appeared). This will allow to patch OSSPD and other FUSE filesystems that provide stream-like files to return FOPEN_STREAM | FOPEN_NONSEEKABLE in their open handler and this way avoid the deadlock on all kernel versions. This should work because fs/fuse/ ignores unknown open flags returned from a filesystem and so passing FOPEN_STREAM to a kernel that is not aware of this flag cannot hurt. In turn the kernel that is not aware of FOPEN_STREAM will be < v3.14 where just FOPEN_NONSEEKABLE is sufficient to implement streams without read vs write deadlock. This patch adds stream_open, converts /proc/xen/xenbus to it and adds semantic patch to automatically locate in-kernel places that are either required to be converted due to read vs write deadlock, or that are just safe to be converted because read and write do not use ppos and there are no other funky methods in file_operations. Regarding semantic patch I've verified each generated change manually - that it is correct to convert - and each other nonseekable_open instance left - that it is either not correct to convert there, or that it is not converted due to current stream_open.cocci limitations. The script also does not convert files that should be valid to convert, but that currently have .llseek = noop_llseek or generic_file_llseek for unknown reason despite file being opened with nonseekable_open (e.g. drivers/input/mousedev.c) Cc: Michael Kerrisk <mtk.manpages@gmail.com> Cc: Yongzhi Pan <panyongzhi@gmail.com> Cc: Jonathan Corbet <corbet@lwn.net> Cc: David Vrabel <david.vrabel@citrix.com> Cc: Juergen Gross <jgross@suse.com> Cc: Miklos Szeredi <miklos@szeredi.hu> Cc: Tejun Heo <tj@kernel.org> Cc: Kirill Tkhai <ktkhai@virtuozzo.com> Cc: Arnd Bergmann <arnd@arndb.de> Cc: Christoph Hellwig <hch@lst.de> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Julia Lawall <Julia.Lawall@lip6.fr> Cc: Nikolaus Rath <Nikolaus@rath.org> Cc: Han-Wen Nienhuys <hanwen@google.com> Signed-off-by: Kirill Smelkov <kirr@nexedi.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2019-04-05vfs: fix preadv64v2 and pwritev64v2 compat syscalls with offset == -1Aurelien Jarno
[ Upstream commit cc4b1242d7e3b42eed73881fc749944146493e4f ] The preadv2 and pwritev2 syscalls are supposed to emulate the readv and writev syscalls when offset == -1. Therefore the compat code should check for offset before calling do_compat_preadv64 and do_compat_pwritev64. This is the case for the preadv2 and pwritev2 syscalls, but handling of offset == -1 is missing in their 64-bit equivalent. This patch fixes that, calling do_compat_readv and do_compat_writev when offset == -1. This fixes the following glibc tests on x32: - misc/tst-preadvwritev2 - misc/tst-preadvwritev64v2 Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: H.J. Lu <hjl.tools@gmail.com> Signed-off-by: Aurelien Jarno <aurelien@aurel32.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Sasha Levin <sashal@kernel.org>
2018-11-10vfs: swap names of {do,vfs}_clone_file_range()Amir Goldstein
commit a725356b6659469d182d662f22d770d83d3bc7b5 upstream. Commit 031a072a0b8a ("vfs: call vfs_clone_file_range() under freeze protection") created a wrapper do_clone_file_range() around vfs_clone_file_range() moving the freeze protection to former, so overlayfs could call the latter. The more common vfs practice is to call do_xxx helpers from vfs_xxx helpers, where freeze protecction is taken in the vfs_xxx helper, so this anomality could be a source of confusion. It seems that commit 8ede205541ff ("ovl: add reflink/copyfile/dedup support") may have fallen a victim to this confusion - ovl_clone_file_range() calls the vfs_clone_file_range() helper in the hope of getting freeze protection on upper fs, but in fact results in overlayfs allowing to bypass upper fs freeze protection. Swap the names of the two helpers to conform to common vfs practice and call the correct helpers from overlayfs and nfsd. Signed-off-by: Amir Goldstein <amir73il@gmail.com> Signed-off-by: Miklos Szeredi <mszeredi@redhat.com> Fixes: 031a072a0b8a ("vfs: call vfs_clone_file_range() under freeze...") Signed-off-by: Amir Goldstein <amir73il@gmail.com> Signed-off-by: Sasha Levin <sashal@kernel.org>
Many source files in the tree are missing licensing information, which makes it harder for compliance tools to determine the correct license. By default all files without license information are under the default license of the kernel, which is GPL version 2. Update the files which contain no license information with the 'GPL-2.0' SPDX license identifier. The SPDX identifier is a legally binding shorthand, which can be used instead of the full boiler plate text. This patch is based on work done by Thomas Gleixner and Kate Stewart and Philippe Ombredanne. How this work was done: Patches were generated and checked against linux-4.14-rc6 for a subset of the use cases: - file had no licensing information it it. - file was a */uapi/* one with no licensing information in it, - file was a */uapi/* one with existing licensing information, Further patches will be generated in subsequent months to fix up cases where non-standard license headers were used, and references to license had to be inferred by heuristics based on keywords. The analysis to determine which SPDX License Identifier to be applied to a file was done in a spreadsheet of side by side results from of the output of two independent scanners (ScanCode & Windriver) producing SPDX tag:value files created by Philippe Ombredanne. Philippe prepared the base worksheet, and did an initial spot review of a few 1000 files. The 4.13 kernel was the starting point of the analysis with 60,537 files assessed. Kate Stewart did a file by file comparison of the scanner results in the spreadsheet to determine which SPDX license identifier(s) to be applied to the file. She confirmed any determination that was not immediately clear with lawyers working with the Linux Foundation. Criteria used to select files for SPDX license identifier tagging was: - Files considered eligible had to be source code files. - Make and config files were included as candidates if they contained >5 lines of source - File already had some variant of a license header in it (even if <5 lines). All documentation files were explicitly excluded. The following heuristics were used to determine which SPDX license identifiers to apply. - when both scanners couldn't find any license traces, file was considered to have no license information in it, and the top level COPYING file license applied. For non */uapi/* files that summary was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 11139 and resulted in the first patch in this series. If that file was a */uapi/* path one, it was "GPL-2.0 WITH Linux-syscall-note" otherwise it was "GPL-2.0". Results of that was: SPDX license identifier # files ---------------------------------------------------|------- GPL-2.0 WITH Linux-syscall-note 930 and resulted in the second patch in this series. - if a file had some form of licensing information in it, and was one of the */uapi/* ones, it was denoted with the Linux-syscall-note if any GPL family license was found in the file or had no licensing in it (per prior point). Results summary: SPDX license identifier # files ---------------------------------------------------|------ GPL-2.0 WITH Linux-syscall-note 270 GPL-2.0+ WITH Linux-syscall-note 169 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-2-Clause) 21 ((GPL-2.0 WITH Linux-syscall-note) OR BSD-3-Clause) 17 LGPL-2.1+ WITH Linux-syscall-note 15 GPL-1.0+ WITH Linux-syscall-note 14 ((GPL-2.0+ WITH Linux-syscall-note) OR BSD-3-Clause) 5 LGPL-2.0+ WITH Linux-syscall-note 4 LGPL-2.1 WITH Linux-syscall-note 3 ((GPL-2.0 WITH Linux-syscall-note) OR MIT) 3 ((GPL-2.0 WITH Linux-syscall-note) AND MIT) 1 and that resulted in the third patch in this series. - when the two scanners agreed on the detected license(s), that became the concluded license(s). - when there was disagreement between the two scanners (one detected a license but the other didn't, or they both detected different licenses) a manual inspection of the file occurred. - In most cases a manual inspection of the information in the file resulted in a clear resolution of the license that should apply (and which scanner probably needed to revisit its heuristics). - When it was not immediately clear, the license identifier was confirmed with lawyers working with the Linux Foundation. - If there was any question as to the appropriate license identifier, the file was flagged for further research and to be revisited later in time. In total, over 70 hours of logged manual review was done on the spreadsheet to determine the SPDX license identifiers to apply to the source files by Kate, Philippe, Thomas and, in some cases, confirmation by lawyers working with the Linux Foundation. Kate also obtained a third independent scan of the 4.13 code base from FOSSology, and compared selected files where the other two scanners disagreed against that SPDX file, to see if there was new insights. The Windriver scanner is based on an older version of FOSSology in part, so they are related. Thomas did random spot checks in about 500 files from the spreadsheets for the uapi headers and agreed with SPDX license identifier in the files he inspected. For the non-uapi files Thomas did random spot checks in about 15000 files. In initial set of patches against 4.14-rc6, 3 files were found to have copy/paste license identifier errors, and have been fixed to reflect the correct identifier. Additionally Philippe spent 10 hours this week doing a detailed manual inspection and review of the 12,461 patched files from the initial patch version early this week with: - a full scancode scan run, collecting the matched texts, detected license ids and scores - reviewing anything where there was a license detected (about 500+ files) to ensure that the applied SPDX license was correct - reviewing anything where there was no detection but the patch license was not GPL-2.0 WITH Linux-syscall-note to ensure that the applied SPDX license was correct This produced a worksheet with 20 files needing minor correction. This worksheet was then exported into 3 different .csv files for the different types of files to be modified. These .csv files were then reviewed by Greg. Thomas wrote a script to parse the csv files and add the proper SPDX tag to the file, in the format that the file expected. This script was further refined by Greg based on the output to detect more types of files automatically and to distinguish between header and source .c files (which need different comment types.) Finally Greg ran the script using the .csv files to generate the patches. Reviewed-by: Kate Stewart <kstewart@linuxfoundation.org> Reviewed-by: Philippe Ombredanne <pombredanne@nexb.com> Reviewed-by: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2017-09-26vfs: Return -ENXIO for negative SEEK_HOLE / SEEK_DATA offsetsAndreas Gruenbacher
In generic_file_llseek_size, return -ENXIO for negative offsets as well as offsets beyond EOF. This affects filesystems which don't implement SEEK_HOLE / SEEK_DATA internally, possibly because they don't support holes. Fixes xfstest generic/448. Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com> Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-09-14Merge branch 'work.set_fs' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull more set_fs removal from Al Viro: "Christoph's 'use kernel_read and friends rather than open-coding set_fs()' series" * 'work.set_fs' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: fs: unexport vfs_readv and vfs_writev fs: unexport vfs_read and vfs_write fs: unexport __vfs_read/__vfs_write lustre: switch to kernel_write gadget/f_mass_storage: stop messing with the address limit mconsole: switch to kernel_read btrfs: switch write_buf to kernel_write net/9p: switch p9_fd_read to kernel_write mm/nommu: switch do_mmap_private to kernel_read serial2002: switch serial2002_tty_write to kernel_{read/write} fs: make the buf argument to __kernel_write a void pointer fs: fix kernel_write prototype fs: fix kernel_read prototype fs: move kernel_read to fs/read_write.c fs: move kernel_write to fs/read_write.c autofs4: switch autofs4_write to __kernel_write ashmem: switch to ->read_iter
2017-09-04fs: unexport vfs_readv and vfs_writevChristoph Hellwig
We've got no modular users left, and any potential modular user is better of with iov_iter based variants. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2017-09-04fs: unexport vfs_read and vfs_writeChristoph Hellwig
No modular users left. Given that they take user pointers there is no good reason to export it to drivers to start with. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2017-09-04fs: unexport __vfs_read/__vfs_writeChristoph Hellwig
No modular users left, and any new ones should use kernel_read/write or iov_iter variants instead. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2017-09-04fs: make the buf argument to __kernel_write a void pointerChristoph Hellwig
This matches kernel_read and kernel_write and avoids any need for casts in the callers. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2017-09-04fs: fix kernel_write prototypeChristoph Hellwig
Make the position an in/out argument like all the other read/write helpers and and make the buf argument a void pointer. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2017-09-04fs: fix kernel_read prototypeChristoph Hellwig
Use proper ssize_t and size_t types for the return value and count argument, move the offset last and make it an in/out argument like all other read/write helpers, and make the buf argument a void pointer to get rid of lots of casts in the callers. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2017-09-04fs: move kernel_read to fs/read_write.cChristoph Hellwig
2017-09-04fs: move kernel_write to fs/read_write.cChristoph Hellwig
2017-08-31annotate RWF_... flagsChristoph Hellwig
[AV: added missing annotations in syscalls.h/compat.h] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2017-07-07Merge branch 'work.read_write' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull read/write fix from Al Viro: "file_start_write()/file_end_write() got mixed into vfs_iter_write() by accident; that's a deadlock for all existing callers - they already do that, some - quite a bit outside. Easily fixed, fortunately" * 'work.read_write' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: move file_{start,end}_write() out of do_iter_write()
2017-07-06move file_{start,end}_write() out of do_iter_write()Al Viro
... and do *not* grab it in vfs_write_iter(). Fixes: "fs: implement vfs_iter_read using do_iter_read" Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2017-07-05Merge branch 'work.read_write' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull read/write updates from Al Viro: "Christoph's fs/read_write.c series - consolidation and cleanups" * 'work.read_write' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: nfsd: remove nfsd_vfs_read nfsd: use vfs_iter_read/write fs: implement vfs_iter_write using do_iter_write fs: implement vfs_iter_read using do_iter_read fs: move more code into do_iter_read/do_iter_write fs: remove __do_readv_writev fs: remove do_compat_readv_writev fs: remove do_readv_writev
2017-07-03Merge branch 'for-4.13/block' of git://git.kernel.dk/linux-blockLinus Torvalds
Pull core block/IO updates from Jens Axboe: "This is the main pull request for the block layer for 4.13. Not a huge round in terms of features, but there's a lot of churn related to some core cleanups. Note this depends on the UUID tree pull request, that Christoph already sent out. This pull request contains: - A series from Christoph, unifying the error/stats codes in the block layer. We now use blk_status_t everywhere, instead of using different schemes for different places. - Also from Christoph, some cleanups around request allocation and IO scheduler interactions in blk-mq. - And yet another series from Christoph, cleaning up how we handle and do bounce buffering in the block layer. - A blk-mq debugfs series from Bart, further improving on the support we have for exporting internal information to aid debugging IO hangs or stalls. - Also from Bart, a series that cleans up the request initialization differences across types of devices. - A series from Goldwyn Rodrigues, allowing the block layer to return failure if we will block and the user asked for non-blocking. - Patch from Hannes for supporting setting loop devices block size to that of the underlying device. - Two series of patches from Javier, fixing various issues with lightnvm, particular around pblk. - A series from me, adding support for write hints. This comes with NVMe support as well, so applications can help guide data placement on flash to improve performance, latencies, and write amplification. - A series from Ming, improving and hardening blk-mq support for stopping/starting and quiescing hardware queues. - Two pull requests for NVMe updates. Nothing major on the feature side, but lots of cleanups and bug fixes. From the usual crew. - A series from Neil Brown, greatly improving the bio rescue set support. Most notably, this kills the bio rescue work queues, if we don't really need them. - Lots of other little bug fixes that are all over the place" * 'for-4.13/block' of git://git.kernel.dk/linux-block: (217 commits) lightnvm: pblk: set line bitmap check under debug lightnvm: pblk: verify that cache read is still valid lightnvm: pblk: add initialization check lightnvm: pblk: remove target using async. I/Os lightnvm: pblk: use vmalloc for GC data buffer lightnvm: pblk: use right metadata buffer for recovery lightnvm: pblk: schedule if data is not ready lightnvm: pblk: remove unused return variable lightnvm: pblk: fix double-free on pblk init lightnvm: pblk: fix bad le64 assignations nvme: Makefile: remove dead build rule blk-mq: map all HWQ also in hyperthreaded system nvmet-rdma: register ib_client to not deadlock in device removal nvme_fc: fix error recovery on link down. nvmet_fc: fix crashes on bad opcodes nvme_fc: Fix crash when nvme controller connection fails. nvme_fc: replace ioabort msleep loop with completion nvme_fc: fix double calls to nvme_cleanup_cmd() nvme-fabrics: verify that a controller returns the correct NQN nvme: simplify nvme_dev_attrs_are_visible ...
2017-06-29fs: implement vfs_iter_write using do_iter_writeChristoph Hellwig
De-dupliate some code and allow for passing the flags argument to vfs_iter_write. Additionally it now properly updates timestamps. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2017-06-29fs: implement vfs_iter_read using do_iter_readChristoph Hellwig
De-dupliate some code and allow for passing the flags argument to vfs_iter_read. Additional it properly updates atime now. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2017-06-29fs: move more code into do_iter_read/do_iter_writeChristoph Hellwig
The checks for the permissions and can read / write flags are common for the callers. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2017-06-29fs: remove __do_readv_writevChristoph Hellwig
Split it into one helper each for reads vs writes. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2017-06-29fs: remove do_compat_readv_writevChristoph Hellwig
opencode it in both callers to simplify the call stack a bit. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2017-06-29fs: remove do_readv_writevChristoph Hellwig
2017-06-20fs: Separate out kiocb flags setup based on RWF_* flagsGoldwyn Rodrigues
Also added RWF_SUPPORTED to encompass all flags. Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Jan Kara <jack@suse.cz> Signed-off-by: Goldwyn Rodrigues <rgoldwyn@suse.com> Signed-off-by: Jens Axboe <axboe@kernel.dk>
2017-06-16fs: pass on flags in compat_writevChristoph Hellwig
Fixes: 793b80ef14af ("vfs: pass a flags argument to vfs_readv/vfs_writev") Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: stable@vger.kernel.org Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2017-04-17move compat_rw_copy_check_uvector() over to fs/read_write.cAl Viro
2017-03-03Merge branch 'WIP.sched-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull sched.h split-up from Ingo Molnar: "The point of these changes is to significantly reduce the <linux/sched.h> header footprint, to speed up the kernel build and to have a cleaner header structure. After these changes the new <linux/sched.h>'s typical preprocessed size goes down from a previous ~0.68 MB (~22K lines) to ~0.45 MB (~15K lines), which is around 40% faster to build on typical configs. Not much changed from the last version (-v2) posted three weeks ago: I eliminated quirks, backmerged fixes plus I rebased it to an upstream SHA1 from yesterday that includes most changes queued up in -next plus all sched.h changes that were pending from Andrew. I've re-tested the series both on x86 and on cross-arch defconfigs, and did a bisectability test at a number of random points. I tried to test as many build configurations as possible, but some build breakage is probably still left - but it should be mostly limited to architectures that have no cross-compiler binaries available on kernel.org, and non-default configurations" * 'WIP.sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (146 commits) sched/headers: Clean up <linux/sched.h> sched/headers: Remove #ifdefs from <linux/sched.h> sched/headers: Remove the <linux/topology.h> include from <linux/sched.h> sched/headers, hrtimer: Remove the <linux/wait.h> include from <linux/hrtimer.h> sched/headers, x86/apic: Remove the <linux/pm.h> header inclusion from <asm/apic.h> sched/headers, timers: Remove the <linux/sysctl.h> include from <linux/timer.h> sched/headers: Remove <linux/magic.h> from <linux/sched/task_stack.h> sched/headers: Remove <linux/sched.h> from <linux/sched/init.h> sched/core: Remove unused prefetch_stack() sched/headers: Remove <linux/rculist.h> from <linux/sched.h> sched/headers: Remove the 'init_pid_ns' prototype from <linux/sched.h> sched/headers: Remove <linux/signal.h> from <linux/sched.h> sched/headers: Remove <linux/rwsem.h> from <linux/sched.h> sched/headers: Remove the runqueue_is_locked() prototype sched/headers: Remove <linux/sched.h> from <linux/sched/hotplug.h> sched/headers: Remove <linux/sched.h> from <linux/sched/debug.h> sched/headers: Remove <linux/sched.h> from <linux/sched/nohz.h> sched/headers: Remove <linux/sched.h> from <linux/sched/stat.h> sched/headers: Remove the <linux/gfp.h> include from <linux/sched.h> sched/headers: Remove <linux/rtmutex.h> from <linux/sched.h> ...
2017-03-02sched/headers: Prepare for new header dependencies before moving code to ↵Ingo Molnar
<linux/sched/xacct.h> We are going to split <linux/sched/xacct.h> out of <linux/sched.h>, which will have to be picked up from other headers and a couple of .c files. Create a trivial placeholder <linux/sched/xacct.h> file that just maps to <linux/sched.h> to make this patch obviously correct and bisectable. Include the new header in the .c file that is going to need it. Acked-by: Linus Torvalds <torvalds@linux-foundation.org> Cc: Mike Galbraith <efault@gmx.de> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: linux-kernel@vger.kernel.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2017-02-20vfs: use helpers for calling f_op->{read,write}_iter()Miklos Szeredi
2017-02-20vfs: pass type instead of fn to do_{loop,iter}_readv_writev()Miklos Szeredi
2017-02-20vfs: extract common parts of {compat_,}do_readv_writev()Miklos Szeredi
2017-02-07vfs: wrap write f_ops with file_{start,end}_write()Amir Goldstein
Before calling write f_ops, call file_start_write() instead of sb_start_write(). Replace {sb,file}_start_write() for {copy,clone}_file_range() and for fallocate(). Beyond correct semantics, this avoids freeze protection to sb when operating on special inodes, such as fallocate() on a blockdev. Reviewed-by: Jan Kara <jack@suse.cz> Signed-off-by: Amir Goldstein <amir73il@gmail.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2017-02-07vfs: deny copy_file_range() for non regular filesAmir Goldstein
There is no in-tree file system that implements copy_file_range() for non regular files. Deny an attempt to copy_file_range() a directory with EISDIR and any other non regualr file with EINVAL to conform with behavior of vfs_{clone,dedup}_file_range(). This change is needed prior to converting sb_start_write() to file_start_write() in the vfs helper. Cc: linux-api@vger.kernel.org Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Amir Goldstein <amir73il@gmail.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2016-12-24Replace <asm/uaccess.h> with <linux/uaccess.h> globallyLinus Torvalds
This was entirely automated, using the script by Al: PATT='^[[:blank:]]*#[[:blank:]]*include[[:blank:]]*<asm/uaccess.h>' sed -i -e "s!$PATT!#include <linux/uaccess.h>!" \ $(git grep -l "$PATT"|grep -v ^include/linux/uaccess.h) to do the replacement at the end of the merge window. Requested-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-12-22vfs: fix isize/pos/len checks for reflink & dedupeDarrick J. Wong
Strengthen the checking of pos/len vs. i_size, clarify the return values for the clone prep function, and remove pointless code. Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-12-17Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull more vfs updates from Al Viro: "In this pile: - autofs-namespace series - dedupe stuff - more struct path constification" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (40 commits) ocfs2: implement the VFS clone_range, copy_range, and dedupe_range features ocfs2: charge quota for reflinked blocks ocfs2: fix bad pointer cast ocfs2: always unlock when completing dio writes ocfs2: don't eat io errors during _dio_end_io_write ocfs2: budget for extent tree splits when adding refcount flag ocfs2: prohibit refcounted swapfiles ocfs2: add newlines to some error messages ocfs2: convert inode refcount test to a helper simple_write_end(): don't zero in short copy into uptodate exofs: don't mess with simple_write_{begin,end} 9p: saner ->write_end() on failing copy into non-uptodate page fix gfs2_stuffed_write_end() on short copies fix ceph_write_end() nfs_write_end(): fix handling of short copies vfs: refactor clone/dedupe_file_range common functions fs: try to clone files first in vfs_copy_file_range vfs: misc struct path constification namespace.c: constify struct path passed to a bunch of primitives quota: constify struct path in quota_on ...
2016-12-16vfs: fix vfs_clone_file_range() for overlayfs filesAmir Goldstein
With overlayfs, it is wrong to compare file_inode(inode)->i_sb of regular files with those of non-regular files, because the former reference the real (upper/lower) sb and the latter reference the overlayfs sb. Move the test for same super block after the sanity tests for clone range of directory and non-regular file. This change fixes xfstest generic/157, which returned EXDEV instead of EISDIR/EINVAL in the following test cases over overlayfs: echo "Try to reflink a dir" _reflink_range $testdir1/dir1 0 $testdir1/file2 0 $blksz echo "Try to reflink a device" _reflink_range $testdir1/dev1 0 $testdir1/file2 0 $blksz Signed-off-by: Amir Goldstein <amir73il@gmail.com> Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2016-12-16vfs: call vfs_clone_file_range() under freeze protectionAmir Goldstein
Move sb_start_write()/sb_end_write() out of the vfs helper and up into the ioctl handler. Signed-off-by: Amir Goldstein <amir73il@gmail.com> Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2016-12-16vfs: allow vfs_clone_file_range() across mount pointsAmir Goldstein
FICLONE/FICLONERANGE ioctls return -EXDEV if src and dest files are not on the same mount point. Practically, clone only requires that src and dest files are on the same file system. Move the check for same mount point to ioctl handler and keep only the check for same super block in the vfs helper. A following patch is going to use the vfs_clone_file_range() helper in overlayfs to copy up between lower and upper mount points on the same file system. Signed-off-by: Amir Goldstein <amir73il@gmail.com> Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2016-12-16vfs: no mnt_want_write_file() in vfs_{copy,clone}_file_range()Miklos Szeredi
We've checked for file_out being opened for write. This ensures that we already have mnt_want_write() on target. Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
2016-12-09vfs: refactor clone/dedupe_file_range common functionsDarrick J. Wong
Hoist both the XFS reflink inode state and preparation code and the XFS file blocks compare functions into the VFS so that ocfs2 can take advantage of it for reflink and dedupe. Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com>
2016-12-09fs: try to clone files first in vfs_copy_file_rangeChristoph Hellwig
A clone is a perfectly fine implementation of a file copy, so most file systems just implement the copy that way. Instead of duplicating this logic move it to the VFS. Currently btrfs and XFS implement copies the same way as clones and there is no behavior change for them, cifs only implements clones and grow support for copy_file_range with this patch. NFS implements both, so this will allow copy_file_range to work on servers that only implement CLONE and be lot more efficient on servers that implements CLONE and COPY. Signed-off-by: Christoph Hellwig <hch@lst.de>
2016-10-14iov_iter: kernel-doc import_iovec() and rw_copy_check_uvector()Vegard Nossum
Both import_iovec() and rw_copy_check_uvector() take an array (typically small and on-stack) which is used to hold an iovec array copy from userspace. This is to avoid an expensive memory allocation in the fast path (i.e. few iovec elements). The caller may have to check whether these functions actually used the provided buffer or allocated a new one -- but this differs between the too. Let's just add a kernel doc to clarify what the semantics are for each function. Signed-off-by: Vegard Nossum <vegard.nossum@oracle.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-07-15x86/syscalls: Add compat_sys_preadv64v2/compat_sys_pwritev64v2H.J. Lu
Don't use the same syscall numbers for 2 different syscalls: 534 x32 preadv compat_sys_preadv64 535 x32 pwritev compat_sys_pwritev64 534 x32 preadv2 compat_sys_preadv2 535 x32 pwritev2 compat_sys_pwritev2 Add compat_sys_preadv64v2() and compat_sys_pwritev64v2() so that 64-bit offset is passed in one 64-bit register on x32, similar to compat_sys_preadv64() and compat_sys_pwritev64(). Signed-off-by: H.J. Lu <hjl.tools@gmail.com> Cc: Andy Lutomirski <luto@kernel.org> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Josh Poimboeuf <jpoimboe@redhat.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Thomas Gleixner <tglx@linutronix.de> Link: http://lkml.kernel.org/r/CAMe9rOovCMf-RQfx_n1U_Tu_DX1BYkjtFr%3DQ4-_PFVSj9BCzUA@mail.gmail.com Signed-off-by: Ingo Molnar <mingo@kernel.org>
2016-05-18Merge branch 'work.iov_iter' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull iov_iter cleanups from Al Viro. * 'work.iov_iter' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: fold checks into iterate_and_advance() rw_verify_area(): saner calling conventions aio: remove a pointless assignment
2016-05-17Merge branch 'work.preadv2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs cleanups from Al Viro: "More cleanups from Christoph" * 'work.preadv2' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: nfsd: use RWF_SYNC fs: add RWF_DSYNC aand RWF_SYNC ceph: use generic_write_sync fs: simplify the generic_write_sync prototype fs: add IOCB_SYNC and IOCB_DSYNC direct-io: remove the offset argument to dio_complete direct-io: eliminate the offset argument to ->direct_IO xfs: eliminate the pos variable in xfs_file_dio_aio_write filemap: remove the pos argument to generic_file_direct_write filemap: remove pos variables in generic_file_read_iter
