run simultaneously without deadlock
[ Upstream commit 10dce8af34226d90fa56746a934f8da5dcdba3df ]
Commit 9c225f2655e3 ("vfs: atomic f_pos accesses as per POSIX") added
locking for file.f_pos access and in particular made concurrent read and
write not possible - now both those functions take f_pos lock for the
whole run, and so if e.g. a read is blocked waiting for data, write will
deadlock waiting for that read to complete.
This caused regression for stream-like files where previously read and
write could run simultaneously, but after that patch could not do so
anymore. See e.g. commit 581d21a2d02a ("xenbus: fix deadlock on writes
to /proc/xen/xenbus") which fixes such regression for particular case of
/proc/xen/xenbus.
The patch that added f_pos lock in 2014 did so to guarantee POSIX thread
safety for read/write/lseek and added the locking to file descriptors of
all regular files. In 2014 that thread-safety problem was not new as it
was already discussed earlier in 2006.
However even though 2006'th version of Linus's patch was adding f_pos
locking "only for files that are marked seekable with FMODE_LSEEK (thus
avoiding the stream-like objects like pipes and sockets)", the 2014
version - the one that actually made it into the tree as 9c225f2655e3 -
is doing so irregardless of whether a file is seekable or not.
See
https://lore.kernel.org/lkml/53022DB1.4070805@gmail.com/
https://lwn.net/Articles/180387
https://lwn.net/Articles/180396
for historic context.
The reason that it did so is, probably, that there are many files that
are marked non-seekable, but e.g. their read implementation actually
depends on knowing current position to correctly handle the read. Some
examples:
kernel/power/user.c snapshot_read
fs/debugfs/file.c u32_array_read
fs/fuse/control.c fuse_conn_waiting_read + ...
drivers/hwmon/asus_atk0110.c atk_debugfs_ggrp_read
arch/s390/hypfs/inode.c hypfs_read_iter
Despite that, many nonseekable_open users implement read and write with
pure stream semantics - they don't depend on passed ppos at all. And for
those cases where read could wait for something inside, it creates a
situation similar to xenbus - the write could be never made to go until
read is done, and read is waiting for some, potentially external, event,
for potentially unbounded time -> deadlock.
Besides xenbus, there are 14 such places in the kernel that I've found
with semantic patch (see below):
drivers/xen/evtchn.c:667:8-24: ERROR: evtchn_fops: .read() can deadlock .write()
drivers/isdn/capi/capi.c:963:8-24: ERROR: capi_fops: .read() can deadlock .write()
drivers/input/evdev.c:527:1-17: ERROR: evdev_fops: .read() can deadlock .write()
drivers/char/pcmcia/cm4000_cs.c:1685:7-23: ERROR: cm4000_fops: .read() can deadlock .write()
net/rfkill/core.c:1146:8-24: ERROR: rfkill_fops: .read() can deadlock .write()
drivers/s390/char/fs3270.c:488:1-17: ERROR: fs3270_fops: .read() can deadlock .write()
drivers/usb/misc/ldusb.c:310:1-17: ERROR: ld_usb_fops: .read() can deadlock .write()
drivers/hid/uhid.c:635:1-17: ERROR: uhid_fops: .read() can deadlock .write()
net/batman-adv/icmp_socket.c:80:1-17: ERROR: batadv_fops: .read() can deadlock .write()
drivers/media/rc/lirc_dev.c:198:1-17: ERROR: lirc_fops: .read() can deadlock .write()
drivers/leds/uleds.c:77:1-17: ERROR: uleds_fops: .read() can deadlock .write()
drivers/input/misc/uinput.c:400:1-17: ERROR: uinput_fops: .read() can deadlock .write()
drivers/infiniband/core/user_mad.c:985:7-23: ERROR: umad_fops: .read() can deadlock .write()
drivers/gnss/core.c:45:1-17: ERROR: gnss_fops: .read() can deadlock .write()
In addition to the cases above another regression caused by f_pos
locking is that now FUSE filesystems that implement open with
FOPEN_NONSEEKABLE flag, can no longer implement bidirectional
stream-like files - for the same reason as above e.g. read can deadlock
write locking on file.f_pos in the kernel.
FUSE's FOPEN_NONSEEKABLE was added in 2008 in a7c1b990f715 ("fuse:
implement nonseekable open") to support OSSPD. OSSPD implements /dev/dsp
in userspace with FOPEN_NONSEEKABLE flag, with corresponding read and
write routines not depending on current position at all, and with both
read and write being potentially blocking operations:
See
https://github.com/libfuse/osspd
https://lwn.net/Articles/308445
https://github.com/libfuse/osspd/blob/14a9cff0/osspd.c#L1406
https://github.com/libfuse/osspd/blob/14a9cff0/osspd.c#L1438-L1477
https://github.com/libfuse/osspd/blob/14a9cff0/osspd.c#L1479-L1510
Corresponding libfuse example/test also describes FOPEN_NONSEEKABLE as
"somewhat pipe-like files ..." with read handler not using offset.
However that test implements only read without write and cannot exercise
the deadlock scenario:
https://github.com/libfuse/libfuse/blob/fuse-3.4.2-3-ga1bff7d/example/poll.c#L124-L131
https://github.com/libfuse/libfuse/blob/fuse-3.4.2-3-ga1bff7d/example/poll.c#L146-L163
https://github.com/libfuse/libfuse/blob/fuse-3.4.2-3-ga1bff7d/example/poll.c#L209-L216
I've actually hit the read vs write deadlock for real while implementing
my FUSE filesystem where there is /head/watch file, for which open
creates separate bidirectional socket-like stream in between filesystem
and its user with both read and write being later performed
simultaneously. And there it is semantically not easy to split the
stream into two separate read-only and write-only channels:
https://lab.nexedi.com/kirr/wendelin.core/blob/f13aa600/wcfs/wcfs.go#L88-169
Let's fix this regression. The plan is:
1. We can't change nonseekable_open to include &~FMODE_ATOMIC_POS -
doing so would break many in-kernel nonseekable_open users which
actually use ppos in read/write handlers.
2. Add stream_open() to kernel to open stream-like non-seekable file
descriptors. Read and write on such file descriptors would never use
nor change ppos. And with that property on stream-like files read and
write will be running without taking f_pos lock - i.e. read and write
could be running simultaneously.
3. With semantic patch search and convert to stream_open all in-kernel
nonseekable_open users for which read and write actually do not
depend on ppos and where there is no other methods in file_operations
which assume @offset access.
4. Add FOPEN_STREAM to fs/fuse/ and open in-kernel file-descriptors via
steam_open if that bit is present in filesystem open reply.
It was tempting to change fs/fuse/ open handler to use stream_open
instead of nonseekable_open on just FOPEN_NONSEEKABLE flags, but
grepping through Debian codesearch shows users of FOPEN_NONSEEKABLE,
and in particular GVFS which actually uses offset in its read and
write handlers
https://codesearch.debian.net/search?q=-%3Enonseekable+%3D
https://gitlab.gnome.org/GNOME/gvfs/blob/1.40.0-6-gcbc54396/client/gvfsfusedaemon.c#L1080
https://gitlab.gnome.org/GNOME/gvfs/blob/1.40.0-6-gcbc54396/client/gvfsfusedaemon.c#L1247-1346
https://gitlab.gnome.org/GNOME/gvfs/blob/1.40.0-6-gcbc54396/client/gvfsfusedaemon.c#L1399-1481
so if we would do such a change it will break a real user.
5. Add stream_open and FOPEN_STREAM handling to stable kernels starting
from v3.14+ (the kernel where 9c225f2655 first appeared).
This will allow to patch OSSPD and other FUSE filesystems that
provide stream-like files to return FOPEN_STREAM | FOPEN_NONSEEKABLE
in their open handler and this way avoid the deadlock on all kernel
versions. This should work because fs/fuse/ ignores unknown open
flags returned from a filesystem and so passing FOPEN_STREAM to a
kernel that is not aware of this flag cannot hurt. In turn the kernel
that is not aware of FOPEN_STREAM will be < v3.14 where just
FOPEN_NONSEEKABLE is sufficient to implement streams without read vs
write deadlock.
This patch adds stream_open, converts /proc/xen/xenbus to it and adds
semantic patch to automatically locate in-kernel places that are either
required to be converted due to read vs write deadlock, or that are just
safe to be converted because read and write do not use ppos and there
are no other funky methods in file_operations.
Regarding semantic patch I've verified each generated change manually -
that it is correct to convert - and each other nonseekable_open instance
left - that it is either not correct to convert there, or that it is not
converted due to current stream_open.cocci limitations.
The script also does not convert files that should be valid to convert,
but that currently have .llseek = noop_llseek or generic_file_llseek for
unknown reason despite file being opened with nonseekable_open (e.g.
drivers/input/mousedev.c)
Cc: Michael Kerrisk <mtk.manpages@gmail.com>
Cc: Yongzhi Pan <panyongzhi@gmail.com>
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: David Vrabel <david.vrabel@citrix.com>
Cc: Juergen Gross <jgross@suse.com>
Cc: Miklos Szeredi <miklos@szeredi.hu>
Cc: Tejun Heo <tj@kernel.org>
Cc: Kirill Tkhai <ktkhai@virtuozzo.com>
Cc: Julia Lawall <Julia.Lawall@lip6.fr>
Cc: Nikolaus Rath <Nikolaus@rath.org>
Cc: Han-Wen Nienhuys <hanwen@google.com>
Signed-off-by: Kirill Smelkov <kirr@nexedi.com>
[ Upstream commit cc4b1242d7e3b42eed73881fc749944146493e4f ]
The preadv2 and pwritev2 syscalls are supposed to emulate the readv and
writev syscalls when offset == -1. Therefore the compat code should
check for offset before calling do_compat_preadv64 and
do_compat_pwritev64. This is the case for the preadv2 and pwritev2
syscalls, but handling of offset == -1 is missing in their 64-bit
equivalent.
This patch fixes that, calling do_compat_readv and do_compat_writev when
offset == -1. This fixes the following glibc tests on x32:
- misc/tst-preadvwritev2
- misc/tst-preadvwritev64v2
Cc: H.J. Lu <hjl.tools@gmail.com>
Signed-off-by: Aurelien Jarno <aurelien@aurel32.net>
Commit 031a072a0b8a ("vfs: call vfs_clone_file_range() under freeze
protection") created a wrapper do_clone_file_range() around
vfs_clone_file_range() moving the freeze protection to former, so
overlayfs could call the latter.
The more common vfs practice is to call do_xxx helpers from vfs_xxx
helpers, where freeze protecction is taken in the vfs_xxx helper, so
this anomality could be a source of confusion.
It seems that commit 8ede205541ff ("ovl: add reflink/copyfile/dedup
support") may have fallen a victim to this confusion -
ovl_clone_file_range() calls the vfs_clone_file_range() helper in the
hope of getting freeze protection on upper fs, but in fact results in
overlayfs allowing to bypass upper fs freeze protection.
Swap the names of the two helpers to conform to common vfs practice
and call the correct helpers from overlayfs and nfsd.
Signed-off-by: Amir Goldstein <amir73il@gmail.com>
Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
This is needed by the stacked dedupe implementation in overlayfs.
Extract vfs_dedupe_file_range_one() helper to deal with a single dedup
request.
Clean up f_op->dedupe_file_range() interface.
1) Use loff_t for offsets and length instead of u64
2) Order the arguments the same way as {copy|clone}_file_range().
Reviewed-by: Darrick J. Wong <darrick.wong@oracle.com>
Suggested-by: Darrick J. Wong <darrick.wong@oracle.com>
The kmalloc() function has a 2-factor argument form, kmalloc_array(). This
patch replaces cases of:
kmalloc(a * b, gfp)
with:
kmalloc_array(a * b, gfp)
as well as handling cases of:
kmalloc(a * b * c, gfp)
with:
kmalloc(array3_size(a, b, c), gfp)
as it's slightly less ugly than:
kmalloc_array(array_size(a, b), c, gfp)
This does, however, attempt to ignore constant size factors like:
kmalloc(4 * 1024, gfp)
though any constants defined via macros get caught up in the conversion.
Any factors with a sizeof() of "unsigned char", "char", and "u8" were
dropped, since they're redundant.
The tools/ directory was manually excluded, since it has its own
implementation of kmalloc().
The Coccinelle script used for this was:
// Fix redundant parens around sizeof().
type TYPE;
expression THING, E;
kmalloc(
- (sizeof(TYPE)) * E
+ sizeof(TYPE) * E
kmalloc(
- (sizeof(THING)) * E
+ sizeof(THING) * E
// Drop single-byte sizes and redundant parens.
expression COUNT;
typedef u8;
typedef __u8;
kmalloc(
- sizeof(u8) * (COUNT)
+ COUNT
kmalloc(
- sizeof(__u8) * (COUNT)
+ COUNT
kmalloc(
- sizeof(char) * (COUNT)
+ COUNT
kmalloc(
- sizeof(unsigned char) * (COUNT)
+ COUNT
kmalloc(
- sizeof(u8) * COUNT
+ COUNT
kmalloc(
- sizeof(__u8) * COUNT
+ COUNT
kmalloc(
- sizeof(char) * COUNT
+ COUNT
kmalloc(
- sizeof(unsigned char) * COUNT
+ COUNT
// 2-factor product with sizeof(type/expression) and identifier or constant.
type TYPE;
expression THING;
identifier COUNT_ID;
constant COUNT_CONST;
- kmalloc
+ kmalloc_array
- sizeof(TYPE) * (COUNT_ID)
+ COUNT_ID, sizeof(TYPE)
- kmalloc
+ kmalloc_array
- sizeof(TYPE) * COUNT_ID
- kmalloc
+ kmalloc_array
- sizeof(TYPE) * (COUNT_CONST)
+ COUNT_CONST, sizeof(TYPE)
- kmalloc
+ kmalloc_array
- sizeof(TYPE) * COUNT_CONST
- kmalloc
+ kmalloc_array
- sizeof(THING) * (COUNT_ID)
+ COUNT_ID, sizeof(THING)
- kmalloc
+ kmalloc_array
- sizeof(THING) * COUNT_ID
- kmalloc
+ kmalloc_array
- sizeof(THING) * (COUNT_CONST)
+ COUNT_CONST, sizeof(THING)
- kmalloc
+ kmalloc_array
- sizeof(THING) * COUNT_CONST
// 2-factor product, only identifiers.
identifier SIZE, COUNT;
- kmalloc
+ kmalloc_array
- SIZE * COUNT
+ COUNT, SIZE
// 3-factor product with 1 sizeof(type) or sizeof(expression), with
// redundant parens removed.
expression THING;
identifier STRIDE, COUNT;
type TYPE;
kmalloc(
- sizeof(TYPE) * (COUNT) * (STRIDE)
+ array3_size(COUNT, STRIDE, sizeof(TYPE))
kmalloc(
- sizeof(TYPE) * (COUNT) * STRIDE
kmalloc(
- sizeof(TYPE) * COUNT * (STRIDE)
kmalloc(
- sizeof(TYPE) * COUNT * STRIDE
kmalloc(
- sizeof(THING) * (COUNT) * (STRIDE)
+ array3_size(COUNT, STRIDE, sizeof(THING))
kmalloc(
- sizeof(THING) * (COUNT) * STRIDE
kmalloc(
- sizeof(THING) * COUNT * (STRIDE)
kmalloc(
- sizeof(THING) * COUNT * STRIDE
// 3-factor product with 2 sizeof(variable), with redundant parens removed.
expression THING1, THING2;
identifier COUNT;
type TYPE1, TYPE2;
kmalloc(
- sizeof(TYPE1) * sizeof(TYPE2) * COUNT
+ array3_size(COUNT, sizeof(TYPE1), sizeof(TYPE2))
kmalloc(
- sizeof(TYPE1) * sizeof(THING2) * (COUNT)
kmalloc(
- sizeof(THING1) * sizeof(THING2) * COUNT
+ array3_size(COUNT, sizeof(THING1), sizeof(THING2))
kmalloc(
- sizeof(THING1) * sizeof(THING2) * (COUNT)
kmalloc(
- sizeof(TYPE1) * sizeof(THING2) * COUNT
+ array3_size(COUNT, sizeof(TYPE1), sizeof(THING2))
kmalloc(
// 3-factor product, only identifiers, with redundant parens removed.
identifier STRIDE, SIZE, COUNT;
kmalloc(
- (COUNT) * STRIDE * SIZE
+ array3_size(COUNT, STRIDE, SIZE)
kmalloc(
- COUNT * (STRIDE) * SIZE
kmalloc(
- COUNT * STRIDE * (SIZE)
kmalloc(
- (COUNT) * (STRIDE) * SIZE
kmalloc(
- COUNT * (STRIDE) * (SIZE)
kmalloc(
- (COUNT) * STRIDE * (SIZE)
kmalloc(
- (COUNT) * (STRIDE) * (SIZE)
kmalloc(
- COUNT * STRIDE * SIZE
// Any remaining multi-factor products, first at least 3-factor products,
// when they're not all constants...
expression E1, E2, E3;
constant C1, C2, C3;
kmalloc(C1 * C2 * C3, ...)
kmalloc(
- (E1) * E2 * E3
+ array3_size(E1, E2, E3)
kmalloc(
- (E1) * (E2) * E3
kmalloc(
- (E1) * (E2) * (E3)
kmalloc(
- E1 * E2 * E3
// And then all remaining 2 factors products when they're not all constants,
// keeping sizeof() as the second factor argument.
expression THING, E1, E2;
type TYPE;
kmalloc(sizeof(THING) * C2, ...)
kmalloc(sizeof(TYPE) * C2, ...)
kmalloc(C1 * C2, ...)
- kmalloc
+ kmalloc_array
- sizeof(TYPE) * (E2)
+ E2, sizeof(TYPE)
- kmalloc
+ kmalloc_array
- sizeof(TYPE) * E2
+ E2, sizeof(TYPE)
- kmalloc
+ kmalloc_array
- sizeof(THING) * (E2)
+ E2, sizeof(THING)
- kmalloc
+ kmalloc_array
- sizeof(THING) * E2
+ E2, sizeof(THING)
- kmalloc
+ kmalloc_array
- (E1) * E2
+ E1, E2
- kmalloc
+ kmalloc_array
- (E1) * (E2)
+ E1, E2
- kmalloc
+ kmalloc_array
- E1 * E2
+ E1, E2
It's a fairly inconsequential bug, since fdput() won't actually try to
fput() the file due to fd.flags (and thus FDPUT_FPUT) being zero in
the failure case, but most other vfs code takes steps to avoid this.
Signed-off-by: Zev Weiss <zev@bewilderbeest.net>
Using the ksys_p{read,write}64() wrappers allows us to get rid of
in-kernel calls to the sys_pread64() and sys_pwrite64() syscalls.
The ksys_ prefix denotes that this function is meant as a drop-in
replacement for the syscall. In particular, it uses the same calling
convention as sys_p{read,write}64().
This patch is part of a series which removes in-kernel calls to syscalls.
On this basis, the syscall entry path can be streamlined. For details, see
http://lkml.kernel.org/r/20180325162527.GA17492@light.dominikbrodowski.net
Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
Using this helper allows us to avoid the in-kernel calls to the
sys_read() syscall. The ksys_ prefix denotes that this function
is meant as a drop-in replacement for the syscall. In particular, it
uses the same calling convention as sys_read().
sys_lseek() syscall. The ksys_ prefix denotes that this function
uses the same calling convention as sys_lseek().
Using this helper allows us to avoid the in-kernel calls to the sys_write()
syscall. The ksys_ prefix denotes that this function is meant as a drop-in
convention as sys_write().
In the near future, the do_mounts / initramfs callers of ksys_write()
should be converted to use filp_open() and vfs_write() instead.
Cc: linux-s390@vger.kernel.org
Pull iov_iter updates from Al Viro:
- bio_{map,copy}_user_iov() series; those are cleanups - fixes from the
same pile went into mainline (and stable) in late September.
- fs/iomap.c iov_iter-related fixes
- new primitive - iov_iter_for_each_range(), which applies a function
to kernel-mapped segments of an iov_iter.
Usable for kvec and bvec ones, the latter does kmap()/kunmap() around
the callback. _Not_ usable for iovec- or pipe-backed iov_iter; the
latter is not hard to fix if the need ever appears, the former is by
design.
Another related primitive will have to wait for the next cycle - it
passes page + offset + size instead of pointer + size, and that one
will be usable for everything _except_ kvec. Unfortunately, that one
didn't get exposure in -next yet, so...
- a bit more lustre iov_iter work, including a use case for
iov_iter_for_each_range() (checksum calculation)
- vhost/scsi leak fix in failure exit
- misc cleanups and detritectomy...
* 'work.iov_iter' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (21 commits)
iomap_dio_actor(): fix iov_iter bugs
switch ksocknal_lib_recv_...() to use of iov_iter_for_each_range()
lustre: switch struct ksock_conn to iov_iter
vhost/scsi: switch to iov_iter_get_pages()
fix a page leak in vhost_scsi_iov_to_sgl() error recovery
new primitive: iov_iter_for_each_range()
lnet_return_rx_credits_locked: don't abuse list_entry
xen: don't open-code iov_iter_kvec()
orangefs: remove detritus from struct orangefs_kiocb_s
kill iov_shorten()
bio_alloc_map_data(): do bmd->iter setup right there
bio_copy_user_iov(): saner bio size calculation
bio_map_user_iov(): get rid of copying iov_iter
bio_copy_from_iter(): get rid of copying iov_iter
move more stuff down into bio_copy_user_iov()
blk_rq_map_user_iov(): move iov_iter_advance() down
bio_map_user_iov(): get rid of the iov_for_each()
bio_map_user_iov(): move alignment check into the main loop
don't rely upon subsequent bio_add_pc_page() calls failing
... and with iov_iter_get_pages_alloc() it becomes even simpler
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
In generic_file_llseek_size, return -ENXIO for negative offsets as well
as offsets beyond EOF. This affects filesystems which don't implement
SEEK_HOLE / SEEK_DATA internally, possibly because they don't support
holes.
Fixes xfstest generic/448.
Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com>
Cc: stable@vger.kernel.org
Pull more set_fs removal from Al Viro:
"Christoph's 'use kernel_read and friends rather than open-coding
set_fs()' series"
* 'work.set_fs' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
fs: unexport vfs_readv and vfs_writev
fs: unexport vfs_read and vfs_write
fs: unexport __vfs_read/__vfs_write
lustre: switch to kernel_write
gadget/f_mass_storage: stop messing with the address limit
mconsole: switch to kernel_read
btrfs: switch write_buf to kernel_write
net/9p: switch p9_fd_read to kernel_write
mm/nommu: switch do_mmap_private to kernel_read
serial2002: switch serial2002_tty_write to kernel_{read/write}
fs: make the buf argument to __kernel_write a void pointer
fs: fix kernel_write prototype
fs: fix kernel_read prototype
fs: move kernel_read to fs/read_write.c
fs: move kernel_write to fs/read_write.c
autofs4: switch autofs4_write to __kernel_write
ashmem: switch to ->read_iter
We've got no modular users left, and any potential modular user is better
of with iov_iter based variants.
No modular users left. Given that they take user pointers there is no
good reason to export it to drivers to start with.
No modular users left, and any new ones should use kernel_read/write
or iov_iter variants instead.
This matches kernel_read and kernel_write and avoids any need for casts in
the callers.
Make the position an in/out argument like all the other read/write
helpers and and make the buf argument a void pointer.
Use proper ssize_t and size_t types for the return value and count
argument, move the offset last and make it an in/out argument like
all other read/write helpers, and make the buf argument a void pointer
to get rid of lots of casts in the callers.
[AV: added missing annotations in syscalls.h/compat.h]
Pull read/write fix from Al Viro:
"file_start_write()/file_end_write() got mixed into vfs_iter_write() by
accident; that's a deadlock for all existing callers - they already do
that, some - quite a bit outside.
Easily fixed, fortunately"
* 'work.read_write' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
move file_{start,end}_write() out of do_iter_write()
... and do *not* grab it in vfs_write_iter().
Fixes: "fs: implement vfs_iter_read using do_iter_read"
Pull read/write updates from Al Viro:
"Christoph's fs/read_write.c series - consolidation and cleanups"
nfsd: remove nfsd_vfs_read
nfsd: use vfs_iter_read/write
fs: implement vfs_iter_write using do_iter_write
fs: move more code into do_iter_read/do_iter_write
fs: remove __do_readv_writev
fs: remove do_compat_readv_writev
fs: remove do_readv_writev
Pull core block/IO updates from Jens Axboe:
"This is the main pull request for the block layer for 4.13. Not a huge
round in terms of features, but there's a lot of churn related to some
core cleanups.
Note this depends on the UUID tree pull request, that Christoph
already sent out.
This pull request contains:
- A series from Christoph, unifying the error/stats codes in the
block layer. We now use blk_status_t everywhere, instead of using
different schemes for different places.
- Also from Christoph, some cleanups around request allocation and IO
scheduler interactions in blk-mq.
- And yet another series from Christoph, cleaning up how we handle
and do bounce buffering in the block layer.
- A blk-mq debugfs series from Bart, further improving on the support
we have for exporting internal information to aid debugging IO
hangs or stalls.
- Also from Bart, a series that cleans up the request initialization
differences across types of devices.
- A series from Goldwyn Rodrigues, allowing the block layer to return
failure if we will block and the user asked for non-blocking.
- Patch from Hannes for supporting setting loop devices block size to
that of the underlying device.
- Two series of patches from Javier, fixing various issues with
lightnvm, particular around pblk.
- A series from me, adding support for write hints. This comes with
NVMe support as well, so applications can help guide data placement
on flash to improve performance, latencies, and write
amplification.
- A series from Ming, improving and hardening blk-mq support for
stopping/starting and quiescing hardware queues.
- Two pull requests for NVMe updates. Nothing major on the feature
side, but lots of cleanups and bug fixes. From the usual crew.
- A series from Neil Brown, greatly improving the bio rescue set
support. Most notably, this kills the bio rescue work queues, if we
don't really need them.
- Lots of other little bug fixes that are all over the place"
* 'for-4.13/block' of git://git.kernel.dk/linux-block: (217 commits)
lightnvm: pblk: set line bitmap check under debug
lightnvm: pblk: verify that cache read is still valid
lightnvm: pblk: add initialization check
lightnvm: pblk: remove target using async. I/Os
lightnvm: pblk: use vmalloc for GC data buffer
lightnvm: pblk: use right metadata buffer for recovery
lightnvm: pblk: schedule if data is not ready
lightnvm: pblk: remove unused return variable
lightnvm: pblk: fix double-free on pblk init
lightnvm: pblk: fix bad le64 assignations
nvme: Makefile: remove dead build rule
blk-mq: map all HWQ also in hyperthreaded system
nvmet-rdma: register ib_client to not deadlock in device removal
nvme_fc: fix error recovery on link down.
nvmet_fc: fix crashes on bad opcodes
nvme_fc: Fix crash when nvme controller connection fails.
nvme_fc: replace ioabort msleep loop with completion
nvme_fc: fix double calls to nvme_cleanup_cmd()
nvme-fabrics: verify that a controller returns the correct NQN
nvme: simplify nvme_dev_attrs_are_visible
De-dupliate some code and allow for passing the flags argument to
vfs_iter_write. Additionally it now properly updates timestamps.
vfs_iter_read. Additional it properly updates atime now.
The checks for the permissions and can read / write flags are common
for the callers.
Split it into one helper each for reads vs writes.
opencode it in both callers to simplify the call stack a bit.
Also added RWF_SUPPORTED to encompass all flags.
Signed-off-by: Goldwyn Rodrigues <rgoldwyn@suse.com>
Fixes: 793b80ef14af ("vfs: pass a flags argument to vfs_readv/vfs_writev")
Pull sched.h split-up from Ingo Molnar:
"The point of these changes is to significantly reduce the
<linux/sched.h> header footprint, to speed up the kernel build and to
have a cleaner header structure.
After these changes the new <linux/sched.h>'s typical preprocessed
size goes down from a previous ~0.68 MB (~22K lines) to ~0.45 MB (~15K
lines), which is around 40% faster to build on typical configs.
Not much changed from the last version (-v2) posted three weeks ago: I
eliminated quirks, backmerged fixes plus I rebased it to an upstream
SHA1 from yesterday that includes most changes queued up in -next plus
all sched.h changes that were pending from Andrew.
I've re-tested the series both on x86 and on cross-arch defconfigs,
and did a bisectability test at a number of random points.
I tried to test as many build configurations as possible, but some
build breakage is probably still left - but it should be mostly
limited to architectures that have no cross-compiler binaries
available on kernel.org, and non-default configurations"
* 'WIP.sched-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (146 commits)
sched/headers: Clean up <linux/sched.h>
sched/headers: Remove #ifdefs from <linux/sched.h>
sched/headers: Remove the <linux/topology.h> include from <linux/sched.h>
sched/headers, hrtimer: Remove the <linux/wait.h> include from <linux/hrtimer.h>
sched/headers, x86/apic: Remove the <linux/pm.h> header inclusion from <asm/apic.h>
sched/headers, timers: Remove the <linux/sysctl.h> include from <linux/timer.h>
sched/headers: Remove <linux/magic.h> from <linux/sched/task_stack.h>
sched/headers: Remove <linux/sched.h> from <linux/sched/init.h>
sched/core: Remove unused prefetch_stack()
sched/headers: Remove <linux/rculist.h> from <linux/sched.h>
sched/headers: Remove the 'init_pid_ns' prototype from <linux/sched.h>
sched/headers: Remove <linux/signal.h> from <linux/sched.h>
sched/headers: Remove <linux/rwsem.h> from <linux/sched.h>
sched/headers: Remove the runqueue_is_locked() prototype
sched/headers: Remove <linux/sched.h> from <linux/sched/hotplug.h>
sched/headers: Remove <linux/sched.h> from <linux/sched/debug.h>
sched/headers: Remove <linux/sched.h> from <linux/sched/nohz.h>
sched/headers: Remove <linux/sched.h> from <linux/sched/stat.h>
sched/headers: Remove the <linux/gfp.h> include from <linux/sched.h>
sched/headers: Remove <linux/rtmutex.h> from <linux/sched.h>
<linux/sched/xacct.h>
We are going to split <linux/sched/xacct.h> out of <linux/sched.h>, which
will have to be picked up from other headers and a couple of .c files.
Create a trivial placeholder <linux/sched/xacct.h> file that just
maps to <linux/sched.h> to make this patch obviously correct and
bisectable.
Include the new header in the .c file that is going to need it.
Acked-by: Linus Torvalds <torvalds@linux-foundation.org>
Before calling write f_ops, call file_start_write() instead
of sb_start_write().
Replace {sb,file}_start_write() for {copy,clone}_file_range() and
for fallocate().
Beyond correct semantics, this avoids freeze protection to sb when
operating on special inodes, such as fallocate() on a blockdev.
There is no in-tree file system that implements copy_file_range()
for non regular files.
Deny an attempt to copy_file_range() a directory with EISDIR
and any other non regualr file with EINVAL to conform with
behavior of vfs_{clone,dedup}_file_range().
This change is needed prior to converting sb_start_write()
to file_start_write() in the vfs helper.
Cc: linux-api@vger.kernel.org
This was entirely automated, using the script by Al:
PATT='^[[:blank:]]*#[[:blank:]]*include[[:blank:]]*<asm/uaccess.h>'
sed -i -e "s!$PATT!#include <linux/uaccess.h>!" \
$(git grep -l "$PATT"|grep -v ^include/linux/uaccess.h)
to do the replacement at the end of the merge window.
Requested-by: Al Viro <viro@zeniv.linux.org.uk>
Strengthen the checking of pos/len vs. i_size, clarify the return values
for the clone prep function, and remove pointless code.
Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com>
