run simultaneously without deadlock
[ Upstream commit 10dce8af34226d90fa56746a934f8da5dcdba3df ]
Commit 9c225f2655e3 ("vfs: atomic f_pos accesses as per POSIX") added
locking for file.f_pos access and in particular made concurrent read and
write not possible - now both those functions take f_pos lock for the
whole run, and so if e.g. a read is blocked waiting for data, write will
deadlock waiting for that read to complete.
This caused regression for stream-like files where previously read and
write could run simultaneously, but after that patch could not do so
anymore. See e.g. commit 581d21a2d02a ("xenbus: fix deadlock on writes
to /proc/xen/xenbus") which fixes such regression for particular case of
/proc/xen/xenbus.
The patch that added f_pos lock in 2014 did so to guarantee POSIX thread
safety for read/write/lseek and added the locking to file descriptors of
all regular files. In 2014 that thread-safety problem was not new as it
was already discussed earlier in 2006.
However even though 2006'th version of Linus's patch was adding f_pos
locking "only for files that are marked seekable with FMODE_LSEEK (thus
avoiding the stream-like objects like pipes and sockets)", the 2014
version - the one that actually made it into the tree as 9c225f2655e3 -
is doing so irregardless of whether a file is seekable or not.
See
https://lore.kernel.org/lkml/53022DB1.4070805@gmail.com/
https://lwn.net/Articles/180387
https://lwn.net/Articles/180396
for historic context.
The reason that it did so is, probably, that there are many files that
are marked non-seekable, but e.g. their read implementation actually
depends on knowing current position to correctly handle the read. Some
examples:
kernel/power/user.c snapshot_read
fs/debugfs/file.c u32_array_read
fs/fuse/control.c fuse_conn_waiting_read + ...
drivers/hwmon/asus_atk0110.c atk_debugfs_ggrp_read
arch/s390/hypfs/inode.c hypfs_read_iter
Despite that, many nonseekable_open users implement read and write with
pure stream semantics - they don't depend on passed ppos at all. And for
those cases where read could wait for something inside, it creates a
situation similar to xenbus - the write could be never made to go until
read is done, and read is waiting for some, potentially external, event,
for potentially unbounded time -> deadlock.
Besides xenbus, there are 14 such places in the kernel that I've found
with semantic patch (see below):
drivers/xen/evtchn.c:667:8-24: ERROR: evtchn_fops: .read() can deadlock .write()
drivers/isdn/capi/capi.c:963:8-24: ERROR: capi_fops: .read() can deadlock .write()
drivers/input/evdev.c:527:1-17: ERROR: evdev_fops: .read() can deadlock .write()
drivers/char/pcmcia/cm4000_cs.c:1685:7-23: ERROR: cm4000_fops: .read() can deadlock .write()
net/rfkill/core.c:1146:8-24: ERROR: rfkill_fops: .read() can deadlock .write()
drivers/s390/char/fs3270.c:488:1-17: ERROR: fs3270_fops: .read() can deadlock .write()
drivers/usb/misc/ldusb.c:310:1-17: ERROR: ld_usb_fops: .read() can deadlock .write()
drivers/hid/uhid.c:635:1-17: ERROR: uhid_fops: .read() can deadlock .write()
net/batman-adv/icmp_socket.c:80:1-17: ERROR: batadv_fops: .read() can deadlock .write()
drivers/media/rc/lirc_dev.c:198:1-17: ERROR: lirc_fops: .read() can deadlock .write()
drivers/leds/uleds.c:77:1-17: ERROR: uleds_fops: .read() can deadlock .write()
drivers/input/misc/uinput.c:400:1-17: ERROR: uinput_fops: .read() can deadlock .write()
drivers/infiniband/core/user_mad.c:985:7-23: ERROR: umad_fops: .read() can deadlock .write()
drivers/gnss/core.c:45:1-17: ERROR: gnss_fops: .read() can deadlock .write()
In addition to the cases above another regression caused by f_pos
locking is that now FUSE filesystems that implement open with
FOPEN_NONSEEKABLE flag, can no longer implement bidirectional
stream-like files - for the same reason as above e.g. read can deadlock
write locking on file.f_pos in the kernel.
FUSE's FOPEN_NONSEEKABLE was added in 2008 in a7c1b990f715 ("fuse:
implement nonseekable open") to support OSSPD. OSSPD implements /dev/dsp
in userspace with FOPEN_NONSEEKABLE flag, with corresponding read and
write routines not depending on current position at all, and with both
read and write being potentially blocking operations:
See
https://github.com/libfuse/osspd
https://lwn.net/Articles/308445
https://github.com/libfuse/osspd/blob/14a9cff0/osspd.c#L1406
https://github.com/libfuse/osspd/blob/14a9cff0/osspd.c#L1438-L1477
https://github.com/libfuse/osspd/blob/14a9cff0/osspd.c#L1479-L1510
Corresponding libfuse example/test also describes FOPEN_NONSEEKABLE as
"somewhat pipe-like files ..." with read handler not using offset.
However that test implements only read without write and cannot exercise
the deadlock scenario:
https://github.com/libfuse/libfuse/blob/fuse-3.4.2-3-ga1bff7d/example/poll.c#L124-L131
https://github.com/libfuse/libfuse/blob/fuse-3.4.2-3-ga1bff7d/example/poll.c#L146-L163
https://github.com/libfuse/libfuse/blob/fuse-3.4.2-3-ga1bff7d/example/poll.c#L209-L216
I've actually hit the read vs write deadlock for real while implementing
my FUSE filesystem where there is /head/watch file, for which open
creates separate bidirectional socket-like stream in between filesystem
and its user with both read and write being later performed
simultaneously. And there it is semantically not easy to split the
stream into two separate read-only and write-only channels:
https://lab.nexedi.com/kirr/wendelin.core/blob/f13aa600/wcfs/wcfs.go#L88-169
Let's fix this regression. The plan is:
1. We can't change nonseekable_open to include &~FMODE_ATOMIC_POS -
doing so would break many in-kernel nonseekable_open users which
actually use ppos in read/write handlers.
2. Add stream_open() to kernel to open stream-like non-seekable file
descriptors. Read and write on such file descriptors would never use
nor change ppos. And with that property on stream-like files read and
write will be running without taking f_pos lock - i.e. read and write
could be running simultaneously.
3. With semantic patch search and convert to stream_open all in-kernel
nonseekable_open users for which read and write actually do not
depend on ppos and where there is no other methods in file_operations
which assume @offset access.
4. Add FOPEN_STREAM to fs/fuse/ and open in-kernel file-descriptors via
steam_open if that bit is present in filesystem open reply.
It was tempting to change fs/fuse/ open handler to use stream_open
instead of nonseekable_open on just FOPEN_NONSEEKABLE flags, but
grepping through Debian codesearch shows users of FOPEN_NONSEEKABLE,
and in particular GVFS which actually uses offset in its read and
write handlers
https://codesearch.debian.net/search?q=-%3Enonseekable+%3D
https://gitlab.gnome.org/GNOME/gvfs/blob/1.40.0-6-gcbc54396/client/gvfsfusedaemon.c#L1080
https://gitlab.gnome.org/GNOME/gvfs/blob/1.40.0-6-gcbc54396/client/gvfsfusedaemon.c#L1247-1346
https://gitlab.gnome.org/GNOME/gvfs/blob/1.40.0-6-gcbc54396/client/gvfsfusedaemon.c#L1399-1481
so if we would do such a change it will break a real user.
5. Add stream_open and FOPEN_STREAM handling to stable kernels starting
from v3.14+ (the kernel where 9c225f2655 first appeared).
This will allow to patch OSSPD and other FUSE filesystems that
provide stream-like files to return FOPEN_STREAM | FOPEN_NONSEEKABLE
in their open handler and this way avoid the deadlock on all kernel
versions. This should work because fs/fuse/ ignores unknown open
flags returned from a filesystem and so passing FOPEN_STREAM to a
kernel that is not aware of this flag cannot hurt. In turn the kernel
that is not aware of FOPEN_STREAM will be < v3.14 where just
FOPEN_NONSEEKABLE is sufficient to implement streams without read vs
write deadlock.
This patch adds stream_open, converts /proc/xen/xenbus to it and adds
semantic patch to automatically locate in-kernel places that are either
required to be converted due to read vs write deadlock, or that are just
safe to be converted because read and write do not use ppos and there
are no other funky methods in file_operations.
Regarding semantic patch I've verified each generated change manually -
that it is correct to convert - and each other nonseekable_open instance
left - that it is either not correct to convert there, or that it is not
converted due to current stream_open.cocci limitations.
The script also does not convert files that should be valid to convert,
but that currently have .llseek = noop_llseek or generic_file_llseek for
unknown reason despite file being opened with nonseekable_open (e.g.
drivers/input/mousedev.c)
Cc: Michael Kerrisk <mtk.manpages@gmail.com>
Cc: Yongzhi Pan <panyongzhi@gmail.com>
Cc: Jonathan Corbet <corbet@lwn.net>
Cc: David Vrabel <david.vrabel@citrix.com>
Cc: Juergen Gross <jgross@suse.com>
Cc: Miklos Szeredi <miklos@szeredi.hu>
Cc: Tejun Heo <tj@kernel.org>
Cc: Kirill Tkhai <ktkhai@virtuozzo.com>
Cc: Julia Lawall <Julia.Lawall@lip6.fr>
Cc: Nikolaus Rath <Nikolaus@rath.org>
Cc: Han-Wen Nienhuys <hanwen@google.com>
Signed-off-by: Kirill Smelkov <kirr@nexedi.com>
Signed-off-by: Sasha Levin (Microsoft) <sashal@kernel.org>
[ Upstream commit cc4b1242d7e3b42eed73881fc749944146493e4f ]
The preadv2 and pwritev2 syscalls are supposed to emulate the readv and
writev syscalls when offset == -1. Therefore the compat code should
check for offset before calling do_compat_preadv64 and
do_compat_pwritev64. This is the case for the preadv2 and pwritev2
syscalls, but handling of offset == -1 is missing in their 64-bit
equivalent.
This patch fixes that, calling do_compat_readv and do_compat_writev when
offset == -1. This fixes the following glibc tests on x32:
- misc/tst-preadvwritev2
- misc/tst-preadvwritev64v2
Cc: H.J. Lu <hjl.tools@gmail.com>
Signed-off-by: Aurelien Jarno <aurelien@aurel32.net>
Nobody has actually used the type (VERIFY_READ vs VERIFY_WRITE) argument
of the user address range verification function since we got rid of the
old racy i386-only code to walk page tables by hand.
It existed because the original 80386 would not honor the write protect
bit when in kernel mode, so you had to do COW by hand before doing any
user access. But we haven't supported that in a long time, and these
days the 'type' argument is a purely historical artifact.
A discussion about extending 'user_access_begin()' to do the range
checking resulted this patch, because there is no way we're going to
move the old VERIFY_xyz interface to that model. And it's best done at
the end of the merge window when I've done most of my merges, so let's
just get this done once and for all.
This patch was mostly done with a sed-script, with manual fix-ups for
the cases that weren't of the trivial 'access_ok(VERIFY_xyz' form.
There were a couple of notable cases:
- csky still had the old "verify_area()" name as an alias.
- the iter_iov code had magical hardcoded knowledge of the actual
values of VERIFY_{READ,WRITE} (not that they mattered, since nothing
really used it)
- microblaze used the type argument for a debug printout
but other than those oddities this should be a total no-op patch.
I tried to fix up all architectures, did fairly extensive grepping for
access_ok() uses, and the changes are trivial, but I may have missed
something. Any missed conversion should be trivially fixable, though.
In overlayfs, ovl_remap_file_range calls vfs_clone_file_range on the
lower filesystem's inode, passing through whatever remap flags it got
from its caller. Since vfs_copy_file_range first tries a filesystem's
remap function with REMAP_FILE_CAN_SHORTEN, this can get passed through
to the second vfs_copy_file_range call, and this isn't an issue.
Change the WARN_ON to look only for the DEDUP flag.
Signed-off-by: Darrick J. Wong <darrick.wong@oracle.com>
Reviewed-by: Amir Goldstein <amir73il@gmail.com>
It returns EINVAL when the operation is not supported by the
filesystem. Fix it to return EOPNOTSUPP to be consistent with
the man page and clone_file_range().
Clean up the inconsistent error return handling while I'm there.
(I know, lipstick on a pig, but every little bit helps...)
Signed-off-by: Dave Chinner <dchinner@redhat.com>
Reviewed-by: Darrick J. Wong <darrick.wong@oracle.com>
Pull vfs dedup fixes from Dave Chinner:
"This reworks the vfs data cloning infrastructure.
We discovered many issues with these interfaces late in the 4.19 cycle
- the worst of them (data corruption, setuid stripping) were fixed for
XFS in 4.19-rc8, but a larger rework of the infrastructure fixing all
the problems was needed. That rework is the contents of this pull
request.
Rework the vfs_clone_file_range and vfs_dedupe_file_range
infrastructure to use a common .remap_file_range method and supply
generic bounds and sanity checking functions that are shared with the
data write path. The current VFS infrastructure has problems with
rlimit, LFS file sizes, file time stamps, maximum filesystem file
sizes, stripping setuid bits, etc and so they are addressed in these
commits.
We also introduce the ability for the ->remap_file_range methods to
return short clones so that clones for vfs_copy_file_range() don't get
rejected if the entire range can't be cloned. It also allows
filesystems to sliently skip deduplication of partial EOF blocks if
they are not capable of doing so without requiring errors to be thrown
to userspace.
Existing filesystems are converted to user the new remap_file_range
method, and both XFS and ocfs2 are modified to make use of the new
generic checking infrastructure"
* tag 'xfs-4.20-merge-2' of git://git.kernel.org/pub/scm/fs/xfs/xfs-linux: (28 commits)
xfs: remove [cm]time update from reflink calls
xfs: remove xfs_reflink_remap_range
xfs: remove redundant remap partial EOF block checks
xfs: support returning partial reflink results
xfs: clean up xfs_reflink_remap_blocks call site
xfs: fix pagecache truncation prior to reflink
ocfs2: remove ocfs2_reflink_remap_range
ocfs2: support partial clone range and dedupe range
ocfs2: fix pagecache truncation prior to reflink
ocfs2: truncate page cache for clone destination file before remapping
vfs: clean up generic_remap_file_range_prep return value
vfs: hide file range comparison function
vfs: enable remap callers that can handle short operations
vfs: plumb remap flags through the vfs dedupe functions
vfs: plumb remap flags through the vfs clone functions
vfs: make remap_file_range functions take and return bytes completed
vfs: remap helper should update destination inode metadata
vfs: pass remap flags to generic_remap_checks
vfs: pass remap flags to generic_remap_file_range_prep
vfs: combine the clone and dedupe into a single remap_file_range
Pull misc vfs updates from Al Viro:
"No common topic, really - a handful of assorted stuff; the least
trivial bits are Mark's dedupe patches"
* 'work.misc' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
fs/exofs: only use true/false for asignment of bool type variable
fs/exofs: fix potential memory leak in mount option parsing
Delete invalid assignment statements in do_sendfile
iomap: remove duplicated include from iomap.c
vfs: dedupe should return EPERM if permission is not granted
vfs: allow dedupe of user owned read-only files
ntfs: don't open-code ERR_CAST
ext4: don't open-code ERR_CAST
Since the remap prep function can update the length of the remap
request, we can change this function to return the usual return status
instead of the odd behavior it has now.
Signed-off-by: Dave Chinner <david@fromorbit.com>
There are no callers of vfs_dedupe_file_range_compare, so we might as
well make it a static helper and remove the export.
Plumb in a remap flag that enables the filesystem remap handler to
shorten remapping requests for callers that can handle it. Now
copy_file_range can report partial success (in case we run up against
alignment problems, resource limits, etc.).
We also enable CAN_SHORTEN for fideduperange to maintain existing
userspace-visible behavior where xfs/btrfs shorten the dedupe range to
avoid stale post-eof data exposure.
Plumb a remap_flags argument through the vfs_dedupe_file_range_one
functions so that dedupe can take advantage of it.
Plumb a remap_flags argument through the {do,vfs}_clone_file_range
functions so that clone can take advantage of it.
Change the remap_file_range functions to take a number of bytes to
operate upon and return the number of bytes they operated on. This is a
requirement for allowing fs implementations to return short clone/dedupe
results to the user, which will enable us to obey resource limits in a
graceful manner.
A subsequent patch will enable copy_file_range to signal to the
->clone_file_range implementation that it can handle a short length,
which will be returned in the function's return value. For now the
short return is not implemented anywhere so the behavior won't change --
either copy_file_range manages to clone the entire range or it tries an
alternative.
Neither clone ioctl can take advantage of this, alas.
Extend generic_remap_file_range_prep to handle inode metadata updates
when remapping into a file. If the operation can possibly alter the
file contents, we must update the ctime and mtime and remove security
privileges, just like we do for regular file writes.
Pass the same remap flags to generic_remap_checks for consistency.
Plumb the remap flags through the filesystem from the vfs function
dispatcher all the way to the prep function to prepare for behavior
changes in subsequent patches.
Combine the clone_file_range and dedupe_file_range operations into a
single remap_file_range file operation dispatch since they're
fundamentally the same operation. The differences between the two can
be made in the prep functions.
Since we use clone_verify_area for both clone and dedupe range checks,
rename the function to make it clear that it's for both.
The vfs_clone_file_prep is a generic function to be called by filesystem
implementations only. Rename the prefix to generic_ and make it more
clear that it applies to remap operations, not just clones.
Don't bother calling the filesystem for a zero-length dedupe request;
we can return zero and exit.
A deduplication data corruption is exposed in XFS and btrfs. It is
caused by extending the block match range to include the partial EOF
block, but then allowing unknown data beyond EOF to be considered a
"match" to data in the destination file because the comparison is only
made to the end of the source file. This corrupts the destination file
when the source extent is shared with it.
The VFS remapping prep functions only support whole block dedupe, but
we still need to appear to support whole file dedupe correctly. Hence
if the dedupe request includes the last block of the souce file, don't
include it in the actual dedupe operation. If the rest of the range
dedupes successfully, then reject the entire request. A subsequent
patch will enable us to shorten dedupe requests correctly.
When reflinking sub-file ranges, a data corruption can occur when the
source file range includes a partial EOF block. This shares the unknown
data beyond EOF into the second file at a position inside EOF, exposing
stale data in the second file.
If the reflink request includes the last block of the souce file, only
proceed with the reflink operation if it lands at or past the
destination file's current EOF. If it lands within the destination file
EOF, reject the entire request with -EINVAL and make the caller go the
hard way. A subsequent patch will enable us to shorten reflink requests
correctly.
If a remap caller asks us to remap to the source file's EOF and the
source file length leaves us with a zero byte request, exit early.
Move the file range checks from vfs_clone_file_prep into a separate
generic_remap_checks function so that all the checks are collected in a
central location. This forms the basis for adding more checks from
generic_write_checks that will make cloning's input checking more
consistent with write input checking.
vfs_clone_file_prep_inodes cannot return 0 if it is asked to remap from
a zero byte file because that's what btrfs does.
Pull timekeeping updates from Thomas Gleixner:
"The timers and timekeeping departement provides:
- Another large y2038 update with further preparations for providing
the y2038 safe timespecs closer to the syscalls.
- An overhaul of the SHCMT clocksource driver
- SPDX license identifier updates
- Small cleanups and fixes all over the place"
* 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (31 commits)
tick/sched : Remove redundant cpu_online() check
clocksource/drivers/dw_apb: Add reset control
clocksource: Remove obsolete CLOCKSOURCE_OF_DECLARE
clocksource/drivers: Unify the names to timer-* format
clocksource/drivers/sh_cmt: Add R-Car gen3 support
dt-bindings: timer: renesas: cmt: document R-Car gen3 support
clocksource/drivers/sh_cmt: Properly line-wrap sh_cmt_of_table[] initializer
clocksource/drivers/sh_cmt: Fix clocksource width for 32-bit machines
clocksource/drivers/sh_cmt: Fixup for 64-bit machines
clocksource/drivers/sh_tmu: Convert to SPDX identifiers
clocksource/drivers/sh_mtu2: Convert to SPDX identifiers
clocksource/drivers/sh_cmt: Convert to SPDX identifiers
clocksource/drivers/renesas-ostm: Convert to SPDX identifiers
clocksource: Convert to using %pOFn instead of device_node.name
tick/broadcast: Remove redundant check
RISC-V: Request newstat syscalls
y2038: signal: Change rt_sigtimedwait to use __kernel_timespec
y2038: socket: Change recvmmsg to use __kernel_timespec
y2038: sched: Change sched_rr_get_interval to use __kernel_timespec
y2038: utimes: Rework #ifdef guards for compat syscalls
Assigning value -EINVAL to "retval" here, but that stored value is
overwritten before it can be used.
retval = -EINVAL;
retval = rw_verify_area(WRITE, out.file, &out_pos, count);
value_overwrite: Overwriting previous write to "retval" with value
from rw_verify_area
delete invalid assignment statements
Signed-off-by: n00202754 <nixiaoming@huawei.com>
Right now we return EINVAL if a process does not have permission to dedupe a
file. This was an oversight on my part. EPERM gives a true description of
the nature of our error, and EINVAL is already used for the case that the
filesystem does not support dedupe.
Signed-off-by: Mark Fasheh <mfasheh@suse.de>
Acked-by: David Sterba <dsterba@suse.com>
The permission check in vfs_dedupe_file_range_one() is too coarse - We only
allow dedupe of the destination file if the user is root, or they have the
file open for write.
This effectively limits a non-root user from deduping their own read-only
files. In addition, the write file descriptor that the user is forced to
hold open can prevent execution of files. As file data during a dedupe
does not change, the behavior is unexpected and this has caused a number of
issue reports. For an example, see:
https://github.com/markfasheh/duperemove/issues/129
So change the check so we allow dedupe on the target if:
- the root or admin is asking for it
- the process has write access
- the owner of the file is asking for the dedupe
- the process could get write access
That way users can open read-only and still get dedupe.
Commit 031a072a0b8a ("vfs: call vfs_clone_file_range() under freeze
protection") created a wrapper do_clone_file_range() around
vfs_clone_file_range() moving the freeze protection to former, so
overlayfs could call the latter.
The more common vfs practice is to call do_xxx helpers from vfs_xxx
helpers, where freeze protecction is taken in the vfs_xxx helper, so
this anomality could be a source of confusion.
It seems that commit 8ede205541ff ("ovl: add reflink/copyfile/dedup
support") may have fallen a victim to this confusion -
ovl_clone_file_range() calls the vfs_clone_file_range() helper in the
hope of getting freeze protection on upper fs, but in fact results in
overlayfs allowing to bypass upper fs freeze protection.
Swap the names of the two helpers to conform to common vfs practice
and call the correct helpers from overlayfs and nfsd.
Signed-off-by: Amir Goldstein <amir73il@gmail.com>
Signed-off-by: Miklos Szeredi <mszeredi@redhat.com>
The sys_llseek sytem call is needed on all 32-bit architectures and
none of the 64-bit ones, so we can remove the __ARCH_WANT_SYS_LLSEEK guard
and simplify the include/asm-generic/unistd.h header further.
Since 32-bit tasks can run either natively or in compat mode on 64-bit
architectures, we have to check for both !CONFIG_64BIT and CONFIG_COMPAT.
There are a few 64-bit architectures that also reference sys_llseek
in their 64-bit ABI (e.g. sparc), but I verified that those all
select CONFIG_COMPAT, so the #if check is still correct here. It's
a bit odd to include it in the syscall table though, as it's the
same as sys_lseek() on 64-bit, but with strange calling conventions.
Acked-by: Geert Uytterhoeven <geert@linux-m68k.org>
This is needed by the stacked dedupe implementation in overlayfs.
Extract vfs_dedupe_file_range_one() helper to deal with a single dedup
request.
Clean up f_op->dedupe_file_range() interface.
1) Use loff_t for offsets and length instead of u64
2) Order the arguments the same way as {copy|clone}_file_range().
Suggested-by: Darrick J. Wong <darrick.wong@oracle.com>
The kmalloc() function has a 2-factor argument form, kmalloc_array(). This
patch replaces cases of:
kmalloc(a * b, gfp)
with:
kmalloc_array(a * b, gfp)
as well as handling cases of:
kmalloc(a * b * c, gfp)
with:
kmalloc(array3_size(a, b, c), gfp)
as it's slightly less ugly than:
kmalloc_array(array_size(a, b), c, gfp)
This does, however, attempt to ignore constant size factors like:
kmalloc(4 * 1024, gfp)
though any constants defined via macros get caught up in the conversion.
Any factors with a sizeof() of "unsigned char", "char", and "u8" were
dropped, since they're redundant.
The tools/ directory was manually excluded, since it has its own
implementation of kmalloc().
The Coccinelle script used for this was:
// Fix redundant parens around sizeof().
type TYPE;
expression THING, E;
kmalloc(
- (sizeof(TYPE)) * E
+ sizeof(TYPE) * E
kmalloc(
- (sizeof(THING)) * E
+ sizeof(THING) * E
// Drop single-byte sizes and redundant parens.
expression COUNT;
typedef u8;
typedef __u8;
kmalloc(
- sizeof(u8) * (COUNT)
+ COUNT
kmalloc(
- sizeof(__u8) * (COUNT)
+ COUNT
kmalloc(
- sizeof(char) * (COUNT)
+ COUNT
kmalloc(
- sizeof(unsigned char) * (COUNT)
+ COUNT
kmalloc(
- sizeof(u8) * COUNT
+ COUNT
kmalloc(
- sizeof(__u8) * COUNT
+ COUNT
kmalloc(
- sizeof(char) * COUNT
+ COUNT
kmalloc(
- sizeof(unsigned char) * COUNT
+ COUNT
// 2-factor product with sizeof(type/expression) and identifier or constant.
type TYPE;
expression THING;
identifier COUNT_ID;
constant COUNT_CONST;
- kmalloc
+ kmalloc_array
- sizeof(TYPE) * (COUNT_ID)
+ COUNT_ID, sizeof(TYPE)
- kmalloc
+ kmalloc_array
- sizeof(TYPE) * COUNT_ID
- kmalloc
+ kmalloc_array
- sizeof(TYPE) * (COUNT_CONST)
+ COUNT_CONST, sizeof(TYPE)
- kmalloc
+ kmalloc_array
- sizeof(TYPE) * COUNT_CONST
- kmalloc
+ kmalloc_array
- sizeof(THING) * (COUNT_ID)
+ COUNT_ID, sizeof(THING)
- kmalloc
+ kmalloc_array
- sizeof(THING) * COUNT_ID
- kmalloc
+ kmalloc_array
- sizeof(THING) * (COUNT_CONST)
+ COUNT_CONST, sizeof(THING)
- kmalloc
+ kmalloc_array
- sizeof(THING) * COUNT_CONST
// 2-factor product, only identifiers.
identifier SIZE, COUNT;
- kmalloc
+ kmalloc_array
- SIZE * COUNT
+ COUNT, SIZE
// 3-factor product with 1 sizeof(type) or sizeof(expression), with
// redundant parens removed.
expression THING;
identifier STRIDE, COUNT;
type TYPE;
kmalloc(
- sizeof(TYPE) * (COUNT) * (STRIDE)
+ array3_size(COUNT, STRIDE, sizeof(TYPE))
kmalloc(
- sizeof(TYPE) * (COUNT) * STRIDE
kmalloc(
- sizeof(TYPE) * COUNT * (STRIDE)
kmalloc(
- sizeof(TYPE) * COUNT * STRIDE
kmalloc(
- sizeof(THING) * (COUNT) * (STRIDE)
+ array3_size(COUNT, STRIDE, sizeof(THING))
kmalloc(
- sizeof(THING) * (COUNT) * STRIDE
kmalloc(
- sizeof(THING) * COUNT * (STRIDE)
kmalloc(
- sizeof(THING) * COUNT * STRIDE
// 3-factor product with 2 sizeof(variable), with redundant parens removed.
expression THING1, THING2;
identifier COUNT;
type TYPE1, TYPE2;
kmalloc(
- sizeof(TYPE1) * sizeof(TYPE2) * COUNT
+ array3_size(COUNT, sizeof(TYPE1), sizeof(TYPE2))
kmalloc(
- sizeof(TYPE1) * sizeof(THING2) * (COUNT)
kmalloc(
- sizeof(THING1) * sizeof(THING2) * COUNT
+ array3_size(COUNT, sizeof(THING1), sizeof(THING2))
kmalloc(
- sizeof(THING1) * sizeof(THING2) * (COUNT)
kmalloc(
- sizeof(TYPE1) * sizeof(THING2) * COUNT
+ array3_size(COUNT, sizeof(TYPE1), sizeof(THING2))
kmalloc(
// 3-factor product, only identifiers, with redundant parens removed.
identifier STRIDE, SIZE, COUNT;
kmalloc(
- (COUNT) * STRIDE * SIZE
+ array3_size(COUNT, STRIDE, SIZE)
kmalloc(
- COUNT * (STRIDE) * SIZE
kmalloc(
- COUNT * STRIDE * (SIZE)
kmalloc(
- (COUNT) * (STRIDE) * SIZE
kmalloc(
- COUNT * (STRIDE) * (SIZE)
kmalloc(
- (COUNT) * STRIDE * (SIZE)
kmalloc(
- (COUNT) * (STRIDE) * (SIZE)
kmalloc(
- COUNT * STRIDE * SIZE
// Any remaining multi-factor products, first at least 3-factor products,
// when they're not all constants...
expression E1, E2, E3;
constant C1, C2, C3;
kmalloc(C1 * C2 * C3, ...)
kmalloc(
- (E1) * E2 * E3
+ array3_size(E1, E2, E3)
kmalloc(
- (E1) * (E2) * E3
kmalloc(
- (E1) * (E2) * (E3)
kmalloc(
- E1 * E2 * E3
// And then all remaining 2 factors products when they're not all constants,
// keeping sizeof() as the second factor argument.
expression THING, E1, E2;
type TYPE;
kmalloc(sizeof(THING) * C2, ...)
kmalloc(sizeof(TYPE) * C2, ...)
kmalloc(C1 * C2, ...)
- kmalloc
+ kmalloc_array
- sizeof(TYPE) * (E2)
+ E2, sizeof(TYPE)
- kmalloc
+ kmalloc_array
- sizeof(TYPE) * E2
+ E2, sizeof(TYPE)
- kmalloc
+ kmalloc_array
- sizeof(THING) * (E2)
+ E2, sizeof(THING)
- kmalloc
+ kmalloc_array
- sizeof(THING) * E2
+ E2, sizeof(THING)
- kmalloc
+ kmalloc_array
- (E1) * E2
+ E1, E2
- kmalloc
+ kmalloc_array
- (E1) * (E2)
+ E1, E2
- kmalloc
+ kmalloc_array
- E1 * E2
+ E1, E2
It's a fairly inconsequential bug, since fdput() won't actually try to
fput() the file due to fd.flags (and thus FDPUT_FPUT) being zero in
the failure case, but most other vfs code takes steps to avoid this.
Signed-off-by: Zev Weiss <zev@bewilderbeest.net>
Using the ksys_p{read,write}64() wrappers allows us to get rid of
in-kernel calls to the sys_pread64() and sys_pwrite64() syscalls.
The ksys_ prefix denotes that this function is meant as a drop-in
replacement for the syscall. In particular, it uses the same calling
convention as sys_p{read,write}64().
This patch is part of a series which removes in-kernel calls to syscalls.
On this basis, the syscall entry path can be streamlined. For details, see
http://lkml.kernel.org/r/20180325162527.GA17492@light.dominikbrodowski.net
Signed-off-by: Dominik Brodowski <linux@dominikbrodowski.net>
Using this helper allows us to avoid the in-kernel calls to the
sys_read() syscall. The ksys_ prefix denotes that this function
is meant as a drop-in replacement for the syscall. In particular, it
uses the same calling convention as sys_read().
sys_lseek() syscall. The ksys_ prefix denotes that this function
uses the same calling convention as sys_lseek().
Using this helper allows us to avoid the in-kernel calls to the sys_write()
syscall. The ksys_ prefix denotes that this function is meant as a drop-in
convention as sys_write().
In the near future, the do_mounts / initramfs callers of ksys_write()
should be converted to use filp_open() and vfs_write() instead.
Cc: linux-s390@vger.kernel.org
Pull iov_iter updates from Al Viro:
- bio_{map,copy}_user_iov() series; those are cleanups - fixes from the
same pile went into mainline (and stable) in late September.
- fs/iomap.c iov_iter-related fixes
- new primitive - iov_iter_for_each_range(), which applies a function
to kernel-mapped segments of an iov_iter.
Usable for kvec and bvec ones, the latter does kmap()/kunmap() around
the callback. _Not_ usable for iovec- or pipe-backed iov_iter; the
latter is not hard to fix if the need ever appears, the former is by
design.
Another related primitive will have to wait for the next cycle - it
passes page + offset + size instead of pointer + size, and that one
will be usable for everything _except_ kvec. Unfortunately, that one
didn't get exposure in -next yet, so...
- a bit more lustre iov_iter work, including a use case for
iov_iter_for_each_range() (checksum calculation)
- vhost/scsi leak fix in failure exit
- misc cleanups and detritectomy...
* 'work.iov_iter' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (21 commits)
iomap_dio_actor(): fix iov_iter bugs
switch ksocknal_lib_recv_...() to use of iov_iter_for_each_range()
lustre: switch struct ksock_conn to iov_iter
vhost/scsi: switch to iov_iter_get_pages()
fix a page leak in vhost_scsi_iov_to_sgl() error recovery
new primitive: iov_iter_for_each_range()
lnet_return_rx_credits_locked: don't abuse list_entry
xen: don't open-code iov_iter_kvec()
orangefs: remove detritus from struct orangefs_kiocb_s
kill iov_shorten()
bio_alloc_map_data(): do bmd->iter setup right there
bio_copy_user_iov(): saner bio size calculation
bio_map_user_iov(): get rid of copying iov_iter
bio_copy_from_iter(): get rid of copying iov_iter
move more stuff down into bio_copy_user_iov()
blk_rq_map_user_iov(): move iov_iter_advance() down
bio_map_user_iov(): get rid of the iov_for_each()
bio_map_user_iov(): move alignment check into the main loop
don't rely upon subsequent bio_add_pc_page() calls failing
... and with iov_iter_get_pages_alloc() it becomes even simpler
Philippe Ombredanne.
How this work was done:
the use cases:
lines of source
lines).
identifiers to apply.
COPYING file license applied.
GPL-2.0 11139
the concluded license(s).
in time.
they are related.
in about 15000 files.
correct identifier.
version early this week with:
license ids and scores
generate the patches.
In generic_file_llseek_size, return -ENXIO for negative offsets as well
as offsets beyond EOF. This affects filesystems which don't implement
SEEK_HOLE / SEEK_DATA internally, possibly because they don't support
holes.
Fixes xfstest generic/448.
Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com>
Cc: stable@vger.kernel.org
Pull more set_fs removal from Al Viro:
"Christoph's 'use kernel_read and friends rather than open-coding
set_fs()' series"
* 'work.set_fs' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs:
fs: unexport vfs_readv and vfs_writev
fs: unexport vfs_read and vfs_write
fs: unexport __vfs_read/__vfs_write
lustre: switch to kernel_write
gadget/f_mass_storage: stop messing with the address limit
mconsole: switch to kernel_read
btrfs: switch write_buf to kernel_write
net/9p: switch p9_fd_read to kernel_write
mm/nommu: switch do_mmap_private to kernel_read
serial2002: switch serial2002_tty_write to kernel_{read/write}
fs: make the buf argument to __kernel_write a void pointer
fs: fix kernel_write prototype
fs: fix kernel_read prototype
fs: move kernel_read to fs/read_write.c
fs: move kernel_write to fs/read_write.c
autofs4: switch autofs4_write to __kernel_write
ashmem: switch to ->read_iter
We've got no modular users left, and any potential modular user is better
of with iov_iter based variants.
No modular users left. Given that they take user pointers there is no
good reason to export it to drivers to start with.
No modular users left, and any new ones should use kernel_read/write
or iov_iter variants instead.
This matches kernel_read and kernel_write and avoids any need for casts in
the callers.
