path: root/fs/readdir.c
2010-08-09vfs: fix warning: 'dirent' is used uninitialized in this functionKevin Winchester
Using: gcc (GCC) 4.5.0 20100610 (prerelease) The following warnings appear: fs/readdir.c: In function `filldir64': fs/readdir.c:240:15: warning: `dirent' is used uninitialized in this function fs/readdir.c: In function `filldir': fs/readdir.c:155:15: warning: `dirent' is used uninitialized in this function fs/compat.c: In function `compat_filldir64': fs/compat.c:1071:11: warning: `dirent' is used uninitialized in this function fs/compat.c: In function `compat_filldir': fs/compat.c:984:15: warning: `dirent' is used uninitialized in this function The warnings are related to the use of the NAME_OFFSET() macro. Luckily, it appears as though the standard offsetof() macro is what is being implemented by NAME_OFFSET(), thus we can fix the warning and use a more standard code construct at the same time. Signed-off-by: Kevin Winchester <kjwinchester@gmail.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-14[CVE-2009-0029] System call wrappers part 32Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 21Heiko Carstens
2009-01-14[CVE-2009-0029] Rename old_readdir to sys_old_readdirHeiko Carstens
This way it matches the generic system call name convention. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2008-10-23[PATCH] prepare vfs_readdir() callers to returning filldir resultAl Viro
It's not the final state, but it allows moving ->readdir() instances to passing filldir return value to caller of vfs_readdir(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-08-25[PATCH] fix regular readdir() and friendsAl Viro
Handling of -EOVERFLOW. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2007-12-06Use mutex_lock_killable in vfs_readdirLiam R. Howlett
Signed-off-by: Liam R. Howlett <howlett@gmail.com> Acked-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Matthew Wilcox <willy@linux.intel.com>
2007-05-08ROUND_UP macro cleanup in fs/(select|compat|readdir).cMilind Arun Choudhary
ROUND_UP macro cleanup use,ALIGN or DIV_ROUND_UP where ever appropriate. Signed-off-by: Milind Arun Choudhary <milindchoudhary@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] VFS: change struct file to use struct pathJosef "Jeff" Sipek
This patch changes struct file to use struct path instead of having independent pointers to struct dentry and struct vfsmount, and converts all users of f_{dentry,vfsmnt} in fs/ to use f_path.{dentry,mnt}. Additionally, it adds two #define's to make the transition easier for users of the f_dentry and f_vfsmnt. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03[PATCH] VFS: Make filldir_t and struct kstat deal in 64-bit inode numbersDavid Howells
These patches make the kernel pass 64-bit inode numbers internally when communicating to userspace, even on a 32-bit system. They are required because some filesystems have intrinsic 64-bit inode numbers: NFS3+ and XFS for example. The 64-bit inode numbers are then propagated to userspace automatically where the arch supports it. Problems have been seen with userspace (eg: ld.so) using the 64-bit inode number returned by stat64() or getdents64() to differentiate files, and failing because the 64-bit inode number space was compressed to 32-bits, and so overlaps occur. This patch: Make filldir_t take a 64-bit inode number and struct kstat carry a 64-bit inode number so that 64-bit inode numbers can be passed back to userspace. The stat functions then returns the full 64-bit inode number where available and where possible. If it is not possible to represent the inode number supplied by the filesystem in the field provided by userspace, then error EOVERFLOW will be issued. Similarly, the getdents/readdir functions now pass the full 64-bit inode number to userspace where possible, returning EOVERFLOW instead when a directory entry is encountered that can't be properly represented. Note that this means that some inodes will not be stat'able on a 32-bit system with old libraries where they were before - but it does mean that there will be no ambiguity over what a 32-bit inode number refers to. Note similarly that directory scans may be cut short with an error on a 32-bit system with old libraries where the scan would work before for the same reasons. It is judged unlikely that this situation will occur because modern glibc uses 64-bit capable versions of stat and getdents class functions exclusively, and that older systems are unlikely to encounter unrepresentable inode numbers anyway. [akpm: alpha build fix] Signed-off-by: David Howells <dhowells@redhat.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09[PATCH] mutex subsystem, semaphore to mutex: VFS, ->i_semJes Sorensen
This patch converts the inode semaphore to a mutex. I have tested it on XFS and compiled as much as one can consider on an ia64. Anyway your luck with it might be different. Modified-by: Ingo Molnar <mingo@elte.hu> (finished the conversion) Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
