path: root/fs/reiserfs/do_balan.c
2009-09-14kill-the-bkl/reiserfs: move the concurrent tree accesses checks per superblockFrederic Weisbecker
When do_balance() balances the tree, a trick is performed to provide the ability for other tree writers/readers to check whether do_balance() is executing concurrently (requires CONFIG_REISERFS_CHECK). This is done to protect concurrent accesses to the tree. The trick is the following: When do_balance is called, a unique global variable called cur_tb takes a pointer to the current tree to be rebalanced. Once do_balance finishes its work, cur_tb takes the NULL value. Then, concurrent tree readers/writers just have to check the value of cur_tb to ensure do_balance isn't executing concurrently. If it is, then it proves that schedule() occured on do_balance(), which then relaxed the bkl that protected the tree. Now that the bkl has be turned into a mutex, this check is still fine even though do_balance() becomes preemptible: the write lock will not be automatically released on schedule(), so the tree is still protected. But this is only fine if we have a single reiserfs mountpoint. Indeed, because the bkl is a global lock, it didn't allowed concurrent executions between a tree reader/writer in a mount point and a do_balance() on another tree from another mountpoint. So assuming all these readers/writers weren't supposed to be reentrant, the current check now sometimes detect false positives with the current per-superblock mutex which allows this reentrancy. This patch keeps the concurrent tree accesses check but moves it per superblock, so that only trees from a same mount point are checked to be not accessed concurrently. [ Impact: fix spurious panic while running several reiserfs mount-points ] Cc: Jeff Mahoney <jeffm@suse.com> Cc: Chris Mason <chris.mason@oracle.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2009-06-18reiserfs: fix warnings with gcc 4.4Jeff Mahoney
Several code paths in reiserfs have a construct like: if (is_direntry_le_ih(ih = B_N_PITEM_HEAD(src, item_num))) ... which, in addition to being ugly, end up causing compiler warnings with gcc 4.4.0. Previous compilers didn't issue a warning. fs/reiserfs/do_balan.c:1273: warning: operation on `aux_ih' may be undefined fs/reiserfs/lbalance.c:393: warning: operation on `ih' may be undefined fs/reiserfs/lbalance.c:421: warning: operation on `ih' may be undefined fs/reiserfs/lbalance.c:777: warning: operation on `ih' may be undefined I believe this is due to the ih being passed to macros which evaluate the argument more than once. This is old code and we haven't seen any problems with it, but this patch eliminates the warnings. It converts the multiple evaluation macros to static inlines and does a preassignment for the cases that were causing the warnings because that code is just ugly. Reported-by: Chris Mason <mason@oracle.com> Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: strip trailing whitespaceJeff Mahoney
This patch strips trailing whitespace from the reiserfs code. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: factor out buffer_info initializationJeff Mahoney
This is the first in a series of patches to make balance_leaf() not quite so insane. This patch factors out the open coded initializations of buffer_info structures and defines a few initializers for the 4 cases they're used. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: rework reiserfs_panicJeff Mahoney
ReiserFS panics can be somewhat inconsistent. In some cases: * a unique identifier may be associated with it * the function name may be included * the device may be printed separately This patch aims to make warnings more consistent. reiserfs_warning() prints the device name, so printing it a second time is not required. The function name for a warning is always helpful in debugging, so it is now automatically inserted into the output. Hans has stated that every warning should have a unique identifier. Some cases lack them, others really shouldn't have them. reiserfs_warning() now expects an id associated with each message. In the rare case where one isn't needed, "" will suffice. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: rework reiserfs_warningJeff Mahoney
ReiserFS warnings can be somewhat inconsistent. In some cases: * a unique identifier may be associated with it * the function name may be included * the device may be printed separately This patch aims to make warnings more consistent. reiserfs_warning() prints the device name, so printing it a second time is not required. The function name for a warning is always helpful in debugging, so it is now automatically inserted into the output. Hans has stated that every warning should have a unique identifier. Some cases lack them, others really shouldn't have them. reiserfs_warning() now expects an id associated with each message. In the rare case where one isn't needed, "" will suffice. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: use buffer_info for leaf_paste_entriesJeff Mahoney
This patch makes leaf_paste_entries more consistent with respect to the other leaf operations. Using buffer_info instead of buffer_head directly allows us to get a superblock pointer for use in error handling. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28reiserfs: fix more sparse warnings in do_balan.cHarvey Harrison
fs/reiserfs/do_balan.c:1467:10: warning: symbol 'ret_val' shadows an earlier one fs/reiserfs/do_balan.c:275:6: originally declared here fs/reiserfs/do_balan.c:1471:23: warning: symbol 'ih' shadows an earlier one fs/reiserfs/do_balan.c:249:67: originally declared here Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Chris Mason <chris.mason@oracle.com> Cc: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-30NULL noise: fs/*, mm/*, kernel/*Al Viro
2007-02-12[PATCH] reiserfs: Use ARRAY_SIZE macro when appropriateAhmed S. Darwish
Use ARRAY_SIZE macro already defined in kernel.h Signed-off-by: Ahmed S. Darwish <darwish.07@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2005-07-12reiserfs: run scripts/Lindent on reiserfs codeLinus Torvalds
This was a pure indentation change, using: scripts/Lindent fs/reiserfs/*.c include/linux/reiserfs_*.h to make reiserfs match the regular Linux indentation style. As Jeff Mahoney <jeffm@suse.com> writes: The ReiserFS code is a mix of a number of different coding styles, sometimes different even from line-to-line. Since the code has been relatively stable for quite some time and there are few outstanding patches to be applied, it is time to reformat the code to conform to the Linux style standard outlined in Documentation/CodingStyle. This patch contains the result of running scripts/Lindent against fs/reiserfs/*.c and include/linux/reiserfs_*.h. There are places where the code can be made to look better, but I'd rather keep those patches separate so that there isn't a subtle by-hand hand accident in the middle of a huge patch. To be clear: This patch is reformatting *only*. A number of patches may follow that continue to make the code more consistent with the Linux coding style. Hans wasn't particularly enthusiastic about these patches, but said he wouldn't really oppose them either. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
