path: root/fs/reiserfs/namei.c
2010-10-25new helper: ihold()Al Viro
Clones an existing reference to inode; caller must already hold one. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-21reiserfs: replace inode uid,gid,mode initialization with helper functionDmitry Monakhov
Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-05dquot: cleanup dquot initialize routineChristoph Hellwig
Get rid of the initialize dquot operation - it is now always called from the filesystem and if a filesystem really needs it's own (which none currently does) it can just call into it's own routine directly. Rename the now static low-level dquot_initialize helper to __dquot_initialize and vfs_dq_init to dquot_initialize to have a consistent namespace. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-03-05dquot: move dquot initialization responsibility into the filesystemChristoph Hellwig
Currently various places in the VFS call vfs_dq_init directly. This means we tie the quota code into the VFS. Get rid of that and make the filesystem responsible for the initialization. For most metadata operations this is a straight forward move into the methods, but for truncate and open it's a bit more complicated. For truncate we currently only call vfs_dq_init for the sys_truncate case because open already takes care of it for ftruncate and open(O_TRUNC) - the new code causes an additional vfs_dq_init for those which is harmless. For open the initialization is moved from do_filp_open into the open method, which means it happens slightly earlier now, and only for regular files. The latter is fine because we don't need to initialize it for operations on special files, and we already do it as part of the namespace operations for directories. Add a dquot_file_open helper that filesystems that support generic quotas can use to fill in ->open. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-03-05dquot: cleanup dquot drop routineChristoph Hellwig
Get rid of the drop dquot operation - it is now always called from the filesystem and if a filesystem really needs it's own (which none currently does) it can just call into it's own routine directly. Rename the now static low-level dquot_drop helper to __dquot_drop and vfs_dq_drop to dquot_drop to have a consistent namespace. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-01-02reiserfs: Fix unwanted recursive reiserfs lock in reiserfs_unlink()Frederic Weisbecker
reiserfs_unlink() may or may not be called under the reiserfs lock. But it also takes the reiserfs lock and can then acquire it recursively which leads to do_journal_begin_r() that fails to relax the reiserfs lock before grabbing the journal mutex, creating an unexpected lock inversion. We need to ensure reiserfs_unlink() won't get the reiserfs lock recursively using reiserfs_write_lock_once(). This fixes the following warning that precedes a lock inversion report (reiserfs lock <-> journal mutex). ------------[ cut here ]------------ WARNING: at fs/reiserfs/lock.c:95 reiserfs_lock_check_recursive+0x3a/0x50() Hardware name: MS-7418 Unwanted recursive reiserfs lock! Pid: 3208, comm: dbench Not tainted 2.6.32-atom #177 Call Trace: [<c114327a>] ? reiserfs_lock_check_recursive+0x3a/0x50 [<c114327a>] ? reiserfs_lock_check_recursive+0x3a/0x50 [<c10373a7>] warn_slowpath_common+0x67/0xc0 [<c114327a>] ? reiserfs_lock_check_recursive+0x3a/0x50 [<c1037446>] warn_slowpath_fmt+0x26/0x30 [<c114327a>] reiserfs_lock_check_recursive+0x3a/0x50 [<c113c213>] do_journal_begin_r+0x83/0x360 [<c105eb16>] ? __lock_acquire+0x1296/0x19e0 [<c1142a57>] ? xattr_unlink+0x57/0xb0 [<c113c670>] journal_begin+0x80/0x130 [<c1116d5d>] reiserfs_unlink+0x7d/0x2d0 [<c1142a57>] ? xattr_unlink+0x57/0xb0 [<c1142a57>] ? xattr_unlink+0x57/0xb0 [<c1142a57>] ? xattr_unlink+0x57/0xb0 [<c1142a64>] xattr_unlink+0x64/0xb0 [<c1143169>] delete_one_xattr+0x29/0x100 [<c11427ab>] reiserfs_for_each_xattr+0x10b/0x290 [<c1143140>] ? delete_one_xattr+0x0/0x100 [<c1401ca9>] ? mutex_lock_nested+0x299/0x340 [<c11429aa>] reiserfs_delete_xattrs+0x1a/0x60 [<c11432f9>] ? reiserfs_write_lock_once+0x29/0x50 [<c111ea1f>] reiserfs_delete_inode+0x9f/0x150 [<c11b0d0f>] ? _atomic_dec_and_lock+0x4f/0x70 [<c111e980>] ? reiserfs_delete_inode+0x0/0x150 [<c10c9c32>] generic_delete_inode+0xa2/0x170 [<c10c9d4f>] generic_drop_inode+0x4f/0x70 [<c10c8b07>] iput+0x47/0x50 [<c10c0965>] do_unlinkat+0xd5/0x160 [<c10505c6>] ? up_read+0x16/0x30 [<c1022ab7>] ? do_page_fault+0x187/0x330 [<c1002fd8>] ? restore_all_notrace+0x0/0x18 [<c1022930>] ? do_page_fault+0x0/0x330 [<c105cbe4>] ? trace_hardirqs_on_caller+0x124/0x170 [<c10c0a00>] sys_unlink+0x10/0x20 [<c1002ec4>] sysenter_do_call+0x12/0x32 ---[ end trace 2e35d71a6cc69d0c ]--- Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Tested-by: Christian Kujau <lists@nerdbynature.de> Cc: Alexander Beregalov <a.beregalov@gmail.com> Cc: Chris Mason <chris.mason@oracle.com> Cc: Ingo Molnar <mingo@elte.hu>
2009-09-14kill-the-bkl/reiserfs: fix recursive reiserfs lock in reiserfs_mkdir()Frederic Weisbecker
reiserfs_mkdir() acquires the reiserfs lock, assuming it has been called from the dir inodes callbacks, without the lock held. But it can also be called from other internal sites such as reiserfs_xattr_init() which already holds the lock. This recursive locking leads to further wrong assumptions. For example, later calls to reiserfs_mutex_lock_safe() won't actually unlock the reiserfs lock the time we acquire a given mutex, creating unexpected lock inversions. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Cc: Jeff Mahoney <jeffm@suse.com> Cc: Chris Mason <chris.mason@oracle.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Alexander Beregalov <a.beregalov@gmail.com> Cc: Laurent Riffard <laurent.riffard@free.fr>
2009-09-14kill-the-bkl/reiserfs: don't hold the write recursively in reiserfs_lookup()Frederic Weisbecker
The write lock can be acquired recursively in reiserfs_lookup(). But we may want to *really* release the lock before possible rescheduling from a reiserfs_lookup() callee. Hence we want to only acquire the lock once (ie: not recursively). [ Impact: prevent from possible false unreleased write lock on sleeping ] Cc: Jeff Mahoney <jeffm@suse.com> Cc: Chris Mason <chris.mason@oracle.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Alexander Beregalov <a.beregalov@gmail.com> Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com>
2009-05-09reiserfs: remove privroot hiding in lookupJeff Mahoney
With Al Viro's patch to move privroot lookup to fs mount, there's no need to have special code to hide the privroot in reiserfs_lookup. I've also cleaned up the privroot hiding in reiserfs_readdir_dentry and removed the last user of reiserfs_xattrs(). Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-03-30Merge branch 'reiserfs-updates' from Jeff MahoneyLinus Torvalds
* reiserfs-updates: (35 commits) reiserfs: rename [cn]_* variables reiserfs: rename p_._ variables reiserfs: rename p_s_tb to tb reiserfs: rename p_s_inode to inode reiserfs: rename p_s_bh to bh reiserfs: rename p_s_sb to sb reiserfs: strip trailing whitespace reiserfs: cleanup path functions reiserfs: factor out buffer_info initialization reiserfs: add atomic addition of selinux attributes during inode creation reiserfs: use generic readdir for operations across all xattrs reiserfs: journaled xattrs reiserfs: use generic xattr handlers reiserfs: remove i_has_xattr_dir reiserfs: make per-inode xattr locking more fine grained reiserfs: eliminate per-super xattr lock reiserfs: simplify xattr internal file lookups/opens reiserfs: Clean up xattrs when REISERFS_FS_XATTR is unset reiserfs: remove IS_PRIVATE helpers reiserfs: remove link detection code ... Fixed up conflicts manually due to: - quota name cleanups vs variable naming changes: fs/reiserfs/inode.c fs/reiserfs/namei.c fs/reiserfs/stree.c fs/reiserfs/xattr.c - exported include header cleanups include/linux/reiserfs_fs.h
2009-03-30reiserfs: strip trailing whitespaceJeff Mahoney
This patch strips trailing whitespace from the reiserfs code. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: add atomic addition of selinux attributes during inode creationJeff Mahoney
Some time ago, some changes were made to make security inode attributes be atomically written during inode creation. ReiserFS fell behind in this area, but with the reworking of the xattr code, it's now fairly easy to add. The following patch adds the ability for security attributes to be added automatically during inode creation. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: journaled xattrsJeff Mahoney
Deadlocks are possible in the xattr code between the journal lock and the xattr sems. This patch implements journalling for xattr operations. The benefit is twofold: * It gets rid of the deadlock possibility by always ensuring that xattr write operations are initiated inside a transaction. * It corrects the problem where xattr backing files aren't considered any differently than normal files, despite the fact they are metadata. I discussed the added journal load with Chris Mason, and we decided that since xattrs (versus other journal activity) is fairly rare, the introduction of larger transactions to support journaled xattrs wouldn't be too big a deal. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: eliminate per-super xattr lockJeff Mahoney
With the switch to using inode->i_mutex locking during lookups/creation in the xattr root, the per-super xattr lock is no longer needed. This patch removes it. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: remove IS_PRIVATE helpersJeff Mahoney
There are a number of helper functions for marking a reiserfs inode private that were leftover from reiserfs did its own thing wrt to private inodes. S_PRIVATE has been in the kernel for some time, so this patch removes the helpers and uses IS_PRIVATE instead. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: use reiserfs_error()Jeff Mahoney
This patch makes many paths that are currently using warnings to handle the error. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: rework reiserfs_panicJeff Mahoney
ReiserFS panics can be somewhat inconsistent. In some cases: * a unique identifier may be associated with it * the function name may be included * the device may be printed separately This patch aims to make warnings more consistent. reiserfs_warning() prints the device name, so printing it a second time is not required. The function name for a warning is always helpful in debugging, so it is now automatically inserted into the output. Hans has stated that every warning should have a unique identifier. Some cases lack them, others really shouldn't have them. reiserfs_warning() now expects an id associated with each message. In the rare case where one isn't needed, "" will suffice. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: rework reiserfs_warningJeff Mahoney
ReiserFS warnings can be somewhat inconsistent. In some cases: * a unique identifier may be associated with it * the function name may be included * the device may be printed separately This patch aims to make warnings more consistent. reiserfs_warning() prints the device name, so printing it a second time is not required. The function name for a warning is always helpful in debugging, so it is now automatically inserted into the output. Hans has stated that every warning should have a unique identifier. Some cases lack them, others really shouldn't have them. reiserfs_warning() now expects an id associated with each message. In the rare case where one isn't needed, "" will suffice. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-26reiserfs: Use lowercase names of quota functionsJan Kara
Use lowercase names of quota functions instead of old uppercase ones. Signed-off-by: Jan Kara <jack@suse.cz> CC: reiserfs-devel@vger.kernel.org
2008-12-31nfsd race fixes: reiserfsAl Viro
... and the same for reiserfs. The difference here is that we need insert_inode_locked4() to match iget5_locked(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-11-14CRED: Wrap task credential accesses in the ReiserFS filesystemDavid Howells
Wrap access to task credentials so that they can be separated more easily from the task_struct during the introduction of COW creds. Change most current->(|e|s|fs)[ug]id to current_(|e|s|fs)[ug]id(). Change some task->e?[ug]id to task_e?[ug]id(). In some places it makes more sense to use RCU directly rather than a convenient wrapper; these will be addressed by later patches. Signed-off-by: David Howells <dhowells@redhat.com> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Cc: reiserfs-devel@vger.kernel.org Signed-off-by: James Morris <jmorris@namei.org>
2008-10-23[PATCH] switch all filesystems over to d_obtain_aliasChristoph Hellwig
Switch all users of d_alloc_anon to d_obtain_alias. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-28reiserfs: replace remaining __FUNCTION__ occurrencesHarvey Harrison
__FUNCTION__ is gcc-specific, use __func__ Signed-off-by: Harvey Harrison <harvey.harrison@gmail.com> Cc: Chris Mason <chris.mason@oracle.com> Cc: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-30NULL noise: fs/*, mm/*, kernel/*Al Viro
2007-02-12[PATCH] mark struct inode_operations const 3Arjan van de Ven
2006-12-08[PATCH] struct path: rename Reiserfs's struct pathJosef "Jeff" Sipek
Rename Reiserfs's struct path to struct treepath to prevent name collision between it and struct path from fs/namei.c. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Cc: <reiserfs-dev@namesys.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03BUG_ON conversion for fs/reiserfsEric Sesterhenn
This patch converts several if () BUG(); construct to BUG_ON(); which occupies less space, uses unlikely and is safer when BUG() is disabled. S_ISREG() has no side effects, so the conversion is safe. Signed-off-by: Eric Sesterhenn <snakebyte@gmx.de> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-01[PATCH] r/o bind mounts: monitor zeroing of i_nlinkDave Hansen
Some filesystems, instead of simply decrementing i_nlink, simply zero it during an unlink operation. We need to catch these in addition to the decrement operations. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] r/o bind mount prepwork: inc_nlink() helperDave Hansen
This is mostly included for parity with dec_nlink(), where we will have some more hooks. This one should stay pretty darn straightforward for now. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-01[PATCH] r/o bind mounts: unlink: monitor i_nlinkDave Hansen
When a filesystem decrements i_nlink to zero, it means that a write must be performed in order to drop the inode from the filesystem. We're shortly going to have keep filesystems from being remounted r/o between the time that this i_nlink decrement and that write occurs. So, add a little helper function to do the decrements. We'll tie into it in a bit to note when i_nlink hits zero. Signed-off-by: Dave Hansen <haveblue@us.ibm.com> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-02[PATCH] reiserfs: fix unaligned bitmap usageJeff Mahoney
The bitmaps associated with generation numbers for directory entries are declared as an array of ints. On some platforms, this causes alignment exceptions. The following patch uses the standard bitmap declaration macros to declare the bitmaps, fixing the problem. Originally from Takashi Iwai. Signed-off-by: Takashi Iwai <tiwai@suse.de> Acked-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] reiserfs: remove kmalloc wrapperPekka Enberg
Remove kmalloc() wrapper from fs/reiserfs/. Please note that a reiserfs /proc entry format is changed because kmalloc statistics is removed. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[PATCH] reiserfs: remove d_splice_alias NULL check from reiserfs_lookupPekka Enberg
Remove redundant NULL check in reiserfs_lookup() as d_splice_alias() can take NULL inode as input. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-13[PATCH] Fix error handling in reiserfsJan Kara
Initialize key object ID in inode so that we don't try to remove the inode when we fail on some checks even before we manage to allocate something. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-12reiserfs: run scripts/Lindent on reiserfs codeLinus Torvalds
This was a pure indentation change, using: scripts/Lindent fs/reiserfs/*.c include/linux/reiserfs_*.h to make reiserfs match the regular Linux indentation style. As Jeff Mahoney <jeffm@suse.com> writes: The ReiserFS code is a mix of a number of different coding styles, sometimes different even from line-to-line. Since the code has been relatively stable for quite some time and there are few outstanding patches to be applied, it is time to reformat the code to conform to the Linux style standard outlined in Documentation/CodingStyle. This patch contains the result of running scripts/Lindent against fs/reiserfs/*.c and include/linux/reiserfs_*.h. There are places where the code can be made to look better, but I'd rather keep those patches separate so that there isn't a subtle by-hand hand accident in the middle of a huge patch. To be clear: This patch is reformatting *only*. A number of patches may follow that continue to make the code more consistent with the Linux coding style. Hans wasn't particularly enthusiastic about these patches, but said he wouldn't really oppose them either. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-24[PATCH] quota: reiserfs: improve quota credit estimatesJan Kara
Use improved credits estimates for quota operations. Also reserve space for a quota operation in a transaction only if filesystem was mounted with some quota option. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-05[PATCH] reiserfs: use NULL instead of 0Randy.Dunlap
Use NULL instead of 0 for pointer (sparse warning): fs/reiserfs/namei.c:611:50: warning: Using plain integer as NULL pointer Signed-off-by: Randy Dunlap <rddunlap@osdl.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
