path: root/fs/reiserfs/xattr_security.c
2010-05-21reiserfs: constify xattr_handlerStephen Hemminger
Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-24reiserfs: fix oops while creating privroot with selinux enabledJeff Mahoney
Commit 57fe60df ("reiserfs: add atomic addition of selinux attributes during inode creation") contains a bug that will cause it to oops when mounting a file system that didn't previously contain extended attributes on a system using security.* xattrs. The issue is that while creating the privroot during mount reiserfs_security_init calls reiserfs_xattr_jcreate_nblocks which dereferences the xattr root. The xattr root doesn't exist, so we get an oops. Addresses http://bugzilla.kernel.org/show_bug.cgi?id=15309 Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-16sanitize xattr handler prototypesChristoph Hellwig
Add a flags argument to struct xattr_handler and pass it to all xattr handler methods. This allows using the same methods for multiple handlers, e.g. for the ACL methods which perform exactly the same action for the access and default ACLs, just using a different underlying attribute. With a little more groundwork it'll also allow sharing the methods for the regular user/trusted/secure handlers in extN, ocfs2 and jffs2 like it's already done for xfs in this patch. Also change the inode argument to the handlers to a dentry to allow using the handlers mechnism for filesystems that require it later, e.g. cifs. [with GFS2 bits updated by Steven Whitehouse <swhiteho@redhat.com>] Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: James Morris <jmorris@namei.org> Acked-by: Joel Becker <joel.becker@oracle.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-05-09reiserfs: dont associate security.* with xattr filesJeff Mahoney
The security.* xattrs are ignored for xattr files, so don't create them. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-03-30reiserfs: add atomic addition of selinux attributes during inode creationJeff Mahoney
Some time ago, some changes were made to make security inode attributes be atomically written during inode creation. ReiserFS fell behind in this area, but with the reworking of the xattr code, it's now fairly easy to add. The following patch adds the ability for security attributes to be added automatically during inode creation. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: use generic xattr handlersJeff Mahoney
Christoph Hellwig had asked me quite some time ago to port the reiserfs xattrs to the generic xattr interface. This patch replaces the reiserfs-specific xattr handling code with the generic struct xattr_handler. However, since reiserfs doesn't split the prefix and name when accessing xattrs, it can't leverage generic_{set,get,list,remove}xattr without needlessly reconstructing the name on the back end. Update 7/26/07: Added missing dput() to deletion path. Update 8/30/07: Added missing mark_inode_dirty when i_mode is used to represent an ACL and no previous ACL existed. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-30reiserfs: remove IS_PRIVATE helpersJeff Mahoney
There are a number of helper functions for marking a reiserfs inode private that were leftover from reiserfs did its own thing wrt to private inodes. S_PRIVATE has been in the kernel for some time, so this patch removes the helpers and uses IS_PRIVATE instead. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25reiserfs: remove double definitions of xattr macrosShen Feng
remove the definitions of macros: XATTR_SECURITY_PREFIX XATTR_TRUSTED_PREFIX XATTR_USER_PREFIX since they are defined in linux/xattr.h Signed-off-by: Shen Feng <shen@cn.fujitsu.com> Signed-off-by: Mingming Cao <cmm@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2005-07-12reiserfs: run scripts/Lindent on reiserfs codeLinus Torvalds
This was a pure indentation change, using: scripts/Lindent fs/reiserfs/*.c include/linux/reiserfs_*.h to make reiserfs match the regular Linux indentation style. As Jeff Mahoney <jeffm@suse.com> writes: The ReiserFS code is a mix of a number of different coding styles, sometimes different even from line-to-line. Since the code has been relatively stable for quite some time and there are few outstanding patches to be applied, it is time to reformat the code to conform to the Linux style standard outlined in Documentation/CodingStyle. This patch contains the result of running scripts/Lindent against fs/reiserfs/*.c and include/linux/reiserfs_*.h. There are places where the code can be made to look better, but I'd rather keep those patches separate so that there isn't a subtle by-hand hand accident in the middle of a huge patch. To be clear: This patch is reformatting *only*. A number of patches may follow that continue to make the code more consistent with the Linux coding style. Hans wasn't particularly enthusiastic about these patches, but said he wouldn't really oppose them either. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
