path: root/fs/reiserfs
2007-12-05proc: fix proc_dir_entry refcountingAlexey Dobriyan
Creating PDEs with refcount 0 and "deleted" flag has problems (see below). Switch to usual scheme: * PDE is created with refcount 1 * every de_get does +1 * every de_put() and remove_proc_entry() do -1 * once refcount reaches 0, PDE is freed. This elegantly fixes at least two following races (both observed) without introducing new locks, without abusing old locks, without spreading lock_kernel(): 1) PDE leak remove_proc_entry de_put ----------------- ------ [refcnt = 1] if (atomic_read(&de->count) == 0) if (atomic_dec_and_test(&de->count)) if (de->deleted) /* also not taken! */ free_proc_entry(de); else de->deleted = 1; [refcount=0, deleted=1] 2) use after free remove_proc_entry de_put ----------------- ------ [refcnt = 1] if (atomic_dec_and_test(&de->count)) if (atomic_read(&de->count) == 0) free_proc_entry(de); /* boom! */ if (de->deleted) free_proc_entry(de); BUG: unable to handle kernel paging request at virtual address 6b6b6b6b printing eip: c10acdda *pdpt = 00000000338f8001 *pde = 0000000000000000 Oops: 0000 [#1] PREEMPT SMP Modules linked in: af_packet ipv6 cpufreq_ondemand loop serio_raw psmouse k8temp hwmon sr_mod cdrom Pid: 23161, comm: cat Not tainted (2.6.24-rc2-8c0863403f109a43d7000b4646da4818220d501f #4) EIP: 0060:[<c10acdda>] EFLAGS: 00210097 CPU: 1 EIP is at strnlen+0x6/0x18 EAX: 6b6b6b6b EBX: 6b6b6b6b ECX: 6b6b6b6b EDX: fffffffe ESI: c128fa3b EDI: f380bf34 EBP: ffffffff ESP: f380be44 DS: 007b ES: 007b FS: 00d8 GS: 0033 SS: 0068 Process cat (pid: 23161, ti=f380b000 task=f38f2570 task.ti=f380b000) Stack: c10ac4f0 00000278 c12ce000 f43cd2a8 00000163 00000000 7da86067 00000400 c128fa20 00896b18 f38325a8 c128fe20 ffffffff 00000000 c11f291e 00000400 f75be300 c128fa20 f769c9a0 c10ac779 f380bf34 f7bfee70 c1018e6b f380bf34 Call Trace: [<c10ac4f0>] vsnprintf+0x2ad/0x49b [<c10ac779>] vscnprintf+0x14/0x1f [<c1018e6b>] vprintk+0xc5/0x2f9 [<c10379f1>] handle_fasteoi_irq+0x0/0xab [<c1004f44>] do_IRQ+0x9f/0xb7 [<c117db3b>] preempt_schedule_irq+0x3f/0x5b [<c100264e>] need_resched+0x1f/0x21 [<c10190ba>] printk+0x1b/0x1f [<c107c8ad>] de_put+0x3d/0x50 [<c107c8f8>] proc_delete_inode+0x38/0x41 [<c107c8c0>] proc_delete_inode+0x0/0x41 [<c1066298>] generic_delete_inode+0x5e/0xc6 [<c1065aa9>] iput+0x60/0x62 [<c1063c8e>] d_kill+0x2d/0x46 [<c1063fa9>] dput+0xdc/0xe4 [<c10571a1>] __fput+0xb0/0xcd [<c1054e49>] filp_close+0x48/0x4f [<c1055ee9>] sys_close+0x67/0xa5 [<c10026b6>] sysenter_past_esp+0x5f/0x85 ======================= Code: c9 74 0c f2 ae 74 05 bf 01 00 00 00 4f 89 fa 5f 89 d0 c3 85 c9 57 89 c7 89 d0 74 05 f2 ae 75 01 4f 89 f8 5f c3 89 c1 89 c8 eb 06 <80> 38 00 74 07 40 4a 83 fa ff 75 f4 29 c8 c3 90 90 90 57 83 c9 EIP: [<c10acdda>] strnlen+0x6/0x18 SS:ESP 0068:f380be44 Also, remove broken usage of ->deleted from reiserfs: if sget() succeeds, module is already pinned and remove_proc_entry() can't happen => nobody can mark PDE deleted. Dummy proc root in netns code is not marked with refcount 1. AFAICS, we never get it, it's just for proper /proc/net removal. I double checked CLONE_NETNS continues to work. Patch survives many hours of modprobe/rmmod/cat loops without new bugs which can be attributed to refcounting. Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-14reiserfs: don't drop PG_dirty when releasing sub-page-sized dirty fileFengguang Wu
This is not a new problem in 2.6.23-git17. 2.6.22/2.6.23 is buggy in the same way. Reiserfs could accumulate dirty sub-page-size files until umount time. They cannot be synced to disk by pdflush routines or explicit `sync' commands. Only `umount' can do the trick. The direct cause is: the dirty page's PG_dirty is wrongly _cleared_. Call trace: [<ffffffff8027e920>] cancel_dirty_page+0xd0/0xf0 [<ffffffff8816d470>] :reiserfs:reiserfs_cut_from_item+0x660/0x710 [<ffffffff8816d791>] :reiserfs:reiserfs_do_truncate+0x271/0x530 [<ffffffff8815872d>] :reiserfs:reiserfs_truncate_file+0xfd/0x3b0 [<ffffffff8815d3d0>] :reiserfs:reiserfs_file_release+0x1e0/0x340 [<ffffffff802a187c>] __fput+0xcc/0x1b0 [<ffffffff802a1ba6>] fput+0x16/0x20 [<ffffffff8029e676>] filp_close+0x56/0x90 [<ffffffff8029fe0d>] sys_close+0xad/0x110 [<ffffffff8020c41e>] system_call+0x7e/0x83 Fix the bug by removing the cancel_dirty_page() call. Tests show that it causes no bad behaviors on various write sizes. === for the patient === Here are more detailed demonstrations of the problem. 1) the page has both PG_dirty(D)/PAGECACHE_TAG_DIRTY(d) after being written to; and then only PAGECACHE_TAG_DIRTY(d) remains after the file is closed. ------------------------------ screen 0 ------------------------------ [T0] root /home/wfg# cat > /test/tiny [T1] hi [T2] root /home/wfg# ------------------------------ screen 1 ------------------------------ [T1] root /home/wfg# echo /test/tiny > /proc/filecache [T1] root /home/wfg# cat /proc/filecache # file /test/tiny # flags R:referenced A:active M:mmap U:uptodate D:dirty W:writeback O:owner B:buffer d:dirty w:writeback # idx len state refcnt 0 1 ___UD__Bd_ 2 [T2] root /home/wfg# cat /proc/filecache # file /test/tiny # flags R:referenced A:active M:mmap U:uptodate D:dirty W:writeback O:owner B:buffer d:dirty w:writeback # idx len state refcnt 0 1 ___U___Bd_ 2 2) note the non-zero 'cancelled_write_bytes' after /tmp/hi is copied. ------------------------------ screen 0 ------------------------------ [T0] root /home/wfg# echo hi > /tmp/hi [T1] root /home/wfg# cp /tmp/hi /dev/stdin /test [T2] hi [T3] root /home/wfg# ------------------------------ screen 1 ------------------------------ [T1] root /proc/4397# cd /proc/`pidof cp` [T1] root /proc/4713# cat io rchar: 8396 wchar: 3 syscr: 20 syscw: 1 read_bytes: 0 write_bytes: 20480 cancelled_write_bytes: 4096 [T2] root /proc/4713# cat io rchar: 8399 wchar: 6 syscr: 21 syscw: 2 read_bytes: 0 write_bytes: 24576 cancelled_write_bytes: 4096 //Question: the 'write_bytes' is a bit more than expected ;-) Tested-by: Maxim Levitsky <maximlevitsky@gmail.com> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Fengguang Wu <wfg@mail.ustc.edu.cn> Reviewed-by: Chris Mason <chris.mason@oracle.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-14Forbid user to change file flags on quota filesJan Kara
Forbid user from changing file flags on quota files. User has no bussiness in playing with these flags when quota is on. Furthermore there is a remote possibility of deadlock due to a lock inversion between quota file's i_mutex and transaction's start (i_mutex for quota file is locked only when trasaction is started in quota operations) in ext3 and ext4. Signed-off-by: Jan Kara <jack@suse.cz> Cc: LIOU Payphone <lioupayphone@gmail.com> Cc: <linux-ext4@vger.kernel.org> Acked-by: Dave Kleikamp <shaggy@austin.ibm.com> Cc: <reiserfs-dev@namesys.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-22exportfs: make struct export_operations constChristoph Hellwig
Now that nfsd has stopped writing to the find_exported_dentry member we an mark the export_operations const Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Neil Brown <neilb@suse.de> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: <linux-ext4@vger.kernel.org> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Cc: Anton Altaparmakov <aia21@cantab.net> Cc: David Chinner <dgc@sgi.com> Cc: Timothy Shimmin <tes@sgi.com> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: Chris Mason <mason@suse.com> Cc: Jeff Mahoney <jeffm@suse.com> Cc: "Vladimir V. Saveliev" <vs@namesys.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-22reiserfs: new export opsChristoph Hellwig
Another nice little cleanup by using the new methods. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Neil Brown <neilb@suse.de> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Chris Mason <mason@suse.com> Cc: Jeff Mahoney <jeffm@suse.com> Cc: "Vladimir V. Saveliev" <vs@namesys.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19Fix misspellings of "system", "controller", "interrupt" and "necessary".Robert P. J. Day
Fix the various misspellings of "system", controller", "interrupt" and "[un]necessary". Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-19reiserfs: ignore on disk s_bmap_nr valueJeff Mahoney
Implement support for file systems larger than 8 TiB. The reiserfs superblock contains a 16 bit value for counting the number of bitmap blocks. The rest of the disk format supports file systems up to 2^32 blocks, but the bitmap block limitation artificially limits this to 8 TiB with a 4KiB block size. Rather than trust the superblock's 16-bit bitmap block count, we calculate it dynamically based on the number of blocks in the file system. When an incorrect value is observed in the superblock, it is zeroed out, ensuring that older kernels will not be able to mount the file system. Userspace support has already been implemented and shipped in reiserfsprogs 3.6.20. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19reiserfs: remove first_zero_hintJeff Mahoney
The first_zero_hint metadata caching was never actually used, and it's of dubious optimization quality. This patch removes it. It doesn't actually shrink the size of the reiserfs_bitmap_info struct, since that doesn't work with block sizes larger than 8K. There was a big fixme in there, and with all the work lately in allowing block size > page size, I might as well kill the fixme as well. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19reiserfs: fix usage of signed ints for block numbersJeff Mahoney
Do a quick signedness check for block numbers. There are a number of places where signed integers are used for block numbers, which limits the usable file system size to 8 TiB. The disk format, excepting a problem which will be fixed in the following patch, supports file systems up to 16 TiB in size. This patch cleans up those sites so that we can enable the full usable size. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19reiserfs: fix memset byte count during resizeJeff Mahoney
Correct the memset in reiserfs_resize to clear the memory allocated for the new bitmap info structs. Previously, it would clear the memory used by the old size. Depending on the contents of memory, this could cause incorrect caching behavior for bitmap blocks in the newly allocated area. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19reiserfs: use is_reusable to catch corruptionJeff Mahoney
Build in is_reusable() unconditionally and use it to catch corruption before it reaches the block freeing paths. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19reiserfs: dont use BUG when panickingJeff Mahoney
Change reiserfs_panic() to use panic() initially instead of BUG(). Using BUG() ignores the configurable panic behavior, so systems that should be failing and rebooting are left hanging. This causes problems in active/standby HA scenarios. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19reiserfs: fix up lockdep warningsJeff Mahoney
Add I_MUTEX_XATTR annotations to the inode locking in the reiserfs xattr code. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18reiserfs: turn of ATTR_KILL_S*ID at beginning of reiserfs_setattrJeff Layton
reiserfs_setattr can call notify_change recursively using the same iattr struct. This could cause it to trip the BUG() in notify_change. Fix reiserfs to clear those bits near the beginning of the function. Signed-off-by: Jeff Layton <jlayton@redhat.com> Cc: Chris Mason <chris.mason@oracle.com> Cc: Jeff Mahoney <jeffm@suse.com> Cc: "Vladimir V. Saveliev" <vs@namesys.com> Cc: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17reiserfs: do not repair wrong journal paramsEdward Shishkin
When mounting a file system with wrong journal params do not try to repair them, suggest fsck instead. Signed-off-by: Edward Shishkin <edward@namesys.com> Cc: Jeff Mahoney <jeffm@suse.com> Cc: Chris Mason <chris.mason@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17reiserfs: workaround for dead loop in finish_unfinishedLepton Wu
There is possible dead loop in finish_unfinished function. In most situation, the call chain iput -> ... -> reiserfs_delete_inode -> remove_save_link will success. But for some reason such as data corruption, reiserfs_delete_inode fails on reiserfs_do_truncate -> search_for_position_by_key. Then remove_save_link won't be called. We always get the same "save_link_key" in the while loop in finish_unfinished function. The following patch adds a check for the possible dead loop and just remove save link when deap loop. [akpm@linux-foundation.org: cleanups] Signed-off-by: Lepton Wu <ytht.net@gmail.com> Cc: Chris Mason <chris.mason@oracle.com> Cc: Jeff Mahoney <jeffm@suse.com> Cc: "Vladimir V. Saveliev" <vs@namesys.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17reiserfs: fix kernel panic on corrupted directoryLepton Wu
When reading corrupted reiserfs directory data, d_reclen could be a negative number or a big positive number, this can lead to kernel panic or oop. The following patch adds a sanity check. Signed-off-by: Lepton Wu <ytht.net@gmail.com> Cc: Chris Mason <chris.mason@oracle.com> Cc: Jeff Mahoney <jeffm@suse.com> Cc: "Vladimir V. Saveliev" <vs@namesys.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17try to reap reiserfs pages left around by invalidatepageChris Mason
reiserfs_invalidatepage will refuse to free pages if they have been logged in data=journal mode, or were pinned down by a data=ordered operation. For data=journal, this is fairly easy to trigger just with fsx-linux, and it results in a large number of pages hanging around on the LRUs with page->mapping == NULL. Calling try_to_free_buffers when reiserfs decides it is done with the page allows it to be freed earlier, and with much less VM thrashing. Lock ordering rules mean that reiserfs can't call lock_page when it is releasing the buffers, so TestSetPageLocked is used instead. Contention on these pages should be rare, so it should be sufficient most of the time. Signed-off-by: Chris Mason <chris.mason@oracle.com> Cc: "Vladimir V. Saveliev" <vs@namesys.com> Cc: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17fs/reiserfs/: cleanupsAdrian Bunk
- remove the following no longer used functions: - bitmap.c: reiserfs_claim_blocks_to_be_allocated() - bitmap.c: reiserfs_release_claimed_blocks() - bitmap.c: reiserfs_can_fit_pages() - make the following functions static: - inode.c: restart_transaction() - journal.c: reiserfs_async_progress_wait() Signed-off-by: Adrian Bunk <bunk@stusta.de> Acked-by: Vladimir V. Saveliev <vs@namesys.com> Cc: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Slab API: remove useless ctor parameter and reorder parametersChristoph Lameter
Slab constructors currently have a flags parameter that is never used. And the order of the arguments is opposite to other slab functions. The object pointer is placed before the kmem_cache pointer. Convert ctor(void *object, struct kmem_cache *s, unsigned long flags) to ctor(struct kmem_cache *s, void *object) throughout the kernel [akpm@linux-foundation.org: coupla fixes] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16reiserfs: use generic_cont_expand_simpleVladimir Saveliev
This patch makes reiserfs to use AOP_FLAG_CONT_EXPAND in order to get rid of the special generic_cont_expand routine Signed-off-by: Vladimir Saveliev <vs@namesys.com> Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16reiserfs: convert to new aopsVladimir Saveliev
Convert reiserfs to new aops Signed-off-by: Vladimir Saveliev <vs@namesys.com> Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16reiserfs: use generic writeVladimir Saveliev
Make reiserfs to write via generic routines. Original reiserfs write optimized for big writes is deadlock rone Signed-off-by: Vladimir Saveliev <vs@namesys.com> Signed-off-by: Nick Piggin <npiggin@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-09-11quota: fix infinite loopJan Kara
If we fail to start a transaction when releasing dquot, we have to call dquot_release() anyway to mark dquot structure as inactive. Otherwise we end in an infinite loop inside dqput(). Signed-off-by: Jan Kara <jack@suse.cz> Cc: xb <xavier.bru@bull.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-26more reiserfs endianness annotationsAl Viro
2007-07-17Introduce is_owner_or_cap() to wrap CAP_FOWNER use with fsuid checkSatyam Sharma
Introduce is_owner_or_cap() macro in fs.h, and convert over relevant users to it. This is done because we want to avoid bugs in the future where we check for only effective fsuid of the current task against a file's owning uid, without simultaneously checking for CAP_FOWNER as well, thus violating its semantics. [ XFS uses special macros and structures, and in general looked ... untouchable, so we leave it alone -- but it has been looked over. ] The (current->fsuid != inode->i_uid) check in generic_permission() and exec_permission_lite() is left alone, because those operations are covered by CAP_DAC_OVERRIDE and CAP_DAC_READ_SEARCH. Similarly operations falling under the purview of CAP_CHOWN and CAP_LEASE are also left alone. Signed-off-by: Satyam Sharma <ssatyam@cse.iitk.ac.in> Cc: Al Viro <viro@ftp.linux.org.uk> Acked-by: Serge E. Hallyn <serge@hallyn.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17knfsd: exportfs: add exportfs.h headerChristoph Hellwig
currently the export_operation structure and helpers related to it are in fs.h. fs.h is already far too large and there are very few places needing the export bits, so split them off into a separate header. [akpm@linux-foundation.org: fix cifs build] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Neil Brown <neilb@suse.de> Cc: Steven French <sfrench@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16Only send SIGXFSZ when exceeding rlimits.Micah Cowan
Some users have been having problems with utilities like cp or dd dumping core when they try to copy a file that's too large for the destination filesystem (typically, > 4gb). Apparently, some defunct standards required SIGXFSZ to be sent in such circumstances, but SUS only requires/allows it for when a written file exceeds the process's resource limits. I'd like to limit SIGXFSZs to the bare minimum required by SUS. Patch sent per http://lkml.org/lkml/2007/4/10/302 Signed-off-by: Micah Cowan <micahcowan@ubuntu.com> Acked-by: Alan Cox <alan@redhat.com> Cc: <reiserfs-dev@namesys.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-10sendfile: remove .sendfile from filesystems that use generic_file_sendfile()Jens Axboe
They can use generic_file_splice_read() instead. Since sys_sendfile() now prefers that, there should be no change in behaviour. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-05-23Missing 'const' from reiserfs MIN_KEY declaration.David Woodhouse
In stree.c, MIN_KEY is declared const. The extern declaration in dir.c doesn't match... Signed-off-by: David Woodhouse <dwmw2@infradead.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivial: (25 commits) sound: convert "sound" subdirectory to UTF-8 MAINTAINERS: Add cxacru website/mailing list include files: convert "include" subdirectory to UTF-8 general: convert "kernel" subdirectory to UTF-8 documentation: convert the Documentation directory to UTF-8 Convert the toplevel files CREDITS and MAINTAINERS to UTF-8. remove broken URLs from net drivers' output Magic number prefix consistency change to Documentation/magic-number.txt trivial: s/i_sem /i_mutex/ fix file specification in comments drivers/base/platform.c: fix small typo in doc misc doc and kconfig typos Remove obsolete fat_cvf help text Fix occurrences of "the the " Fix minor typoes in kernel/module.c Kconfig: Remove reference to external mqueue library Kconfig: A couple of grammatical fixes in arch/i386/Kconfig Correct comments in genrtc.c to refer to correct /proc file. Fix more "deprecated" spellos. Fix "deprecated" typoes. ... Fix trivial comment conflict in kernel/relay.c.
2007-05-09reiserfs: use zero_user_pageNate Diller
Use zero_user_page() instead of open-coding it. Signed-off-by: Nate Diller <nate.diller@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09Fix misspellings collected by members of KJ list.Robert P. J. Day
Fix the misspellings of "propogate", "writting" and (oh, the shame :-) "kenrel" in the source tree. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-08reiserfs: use __set_current_state()Milind Arun Choudhary
use __set_current_state(TASK_*) instead of current->state = TASK_*, in fs/reiserfs Signed-off-by: Milind Arun Choudhary <milindchoudhary@gmail.com> Cc: <reiserfs-dev@namesys.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08reiserfs: correct misspelled "REISERFS_PROC_INFO" to "CONFIG_REISERFS_PROC_INFO"Robert P. J. Day
Correct the misspelling of the preprocessor check of a Kconfig option to refer to CONFIG_REISERFS_PROC_INFO and not just the incorrect REISERFS_PROC_INFO. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08reiserfs: shrink superblock if no xattrsAlexey Dobriyan
This makes in-core superblock fit into one cacheline here. Before: struct dentry * xattr_root; /* 124 4 */ /* --- cacheline 1 boundary (128 bytes) --- */ struct rw_semaphore xattr_dir_sem; /* 128 12 */ int j_errno; /* 140 4 */ }; /* size: 144, cachelines: 2 */ /* sum members: 142, holes: 1, sum holes: 2 */ /* last cacheline: 16 bytes */ After: int j_errno; /* 124 4 */ /* --- cacheline 1 boundary (128 bytes) --- */ }; /* size: 128, cachelines: 1 */ /* sum members: 126, holes: 1, sum holes: 2 */ Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: <reiserfs-dev@namesys.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08reiserfs: possible null pointer dereference during resizeDmitriy Monakhov
sb_read may return NULL, let's explicitly check it. If so free new bitmap blocks array, after this we may safely exit as it done above during bitmap allocation. Signed-off-by: Dmitriy Monakhov <dmonakhov@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-07mm: make read_cache_page synchronousNick Piggin
Ensure pages are uptodate after returning from read_cache_page, which allows us to cut out most of the filesystem-internal PageUptodate calls. I didn't have a great look down the call chains, but this appears to fixes 7 possible use-before uptodate in hfs, 2 in hfsplus, 1 in jfs, a few in ecryptfs, 1 in jffs2, and a possible cleared data overwritten with readpage in block2mtd. All depending on whether the filler is async and/or can return with a !uptodate page. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-30reiserfs: suppress lockdep warningJeff Mahoney
We're getting lockdep warnings due to a post-2.6.21-rc7 bugfix. The xattr_sem can never be taken in the manner described. Internal inodes are protected by I_PRIVATE. Add the appropriate annotation. Cc: <stable@kernel.org> Cc: "Antonino A. Daplas" <adaplas@pol.net> Cc: Takashi Iwai <tiwai@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-24reiserfs: fix xattr root locking/refcount bugJeff Mahoney
The listxattr() and getxattr() operations are only protected by a read lock. As a result, if either of these operations run in parallel, a race condition exists where the xattr_root will end up being cached twice, which results in the leaking of a reference and a BUG() on umount. This patch refactors get_xa_root(), __get_xa_root(), and create_xa_root(), into one get_xa_root() function that takes the appropriate locking around the entire critical section. Reported, diagnosed and tested by Andrea Righi <a.righi@cineca.it> Signed-off-by: Jeff Mahoney <jeffm@suse.com> Cc: Andrea Righi <a.righi@cineca.it> Cc: "Vladimir V. Saveliev" <vs@namesys.com> Cc: Edward Shishkin <edward@namesys.com> Cc: Alex Zarochentsev <zam@namesys.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-12[PATCH] reiserfs: fix key decrementingVladimir Saveliev
This patch fixes a bug in function decrementing a key of stat data item. Offset of reiserfs keys are compared as signed values. To set key offset to maximal possible value maximal signed value has to be used. This bug is responsible for severe reiserfs filesystem corruption which shows itself as warning vs-13060. reiserfsck fixes this corruption by filesystem tree rebuilding. Signed-off-by: Vladimir Saveliev <vs@namesys.com> Cc: <reiserfs-dev@namesys.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] mark struct inode_operations const 3Arjan van de Ven
2007-02-12[PATCH] reiserfs: Use ARRAY_SIZE macro when appropriateAhmed S. Darwish
Use ARRAY_SIZE macro already defined in kernel.h Signed-off-by: Ahmed S. Darwish <darwish.07@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-23[PATCH] resierfs: avoid tail packing if an inode was ever mmappedVladimir Saveliev
This patch fixes a confusion reiserfs has for a long time. On release file operation reiserfs used to try to pack file data stored in last incomplete page of some files into metadata blocks. After packing the page got cleared with clear_page_dirty. It did not take into account that the page may be mmaped into other process's address space. Recent replacement for clear_page_dirty cancel_dirty_page found the confusion with sanity check that page has to be not mapped. The patch fixes the confusion by making reiserfs avoid tail packing if an inode was ever mmapped. reiserfs_mmap and reiserfs_file_release are serialized with mutex in reiserfs specific inode. reiserfs_mmap locks the mutex and sets a bit in reiserfs specific inode flags. reiserfs_file_release checks the bit having the mutex locked. If bit is set - tail packing is avoided. This eliminates a possibility that mmapped page gets cancel_page_dirty-ed. Signed-off-by: Vladimir Saveliev <vs@namesys.com> Cc: Jeff Mahoney <jeffm@suse.com> Cc: Chris Mason <mason@suse.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-23Fix reiserfs after "test_clear_page_dirty()" removalLinus Torvalds
Thanks to Len Brown for testing this fix, since while they have in the past, none of my machines run reiserfs at the moment. Cc: Vladimir V. Saveliev <vs@namesys.com> Acked-by: Len Brown <lenb@kernel.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
