path: root/fs/reiserfs
2012-01-12reiserfs: Force inode evictions before umount to avoid crashJeff Mahoney
commit a9e36da655e54545c3289b2a0700b5c443de0edd upstream. This patch fixes a crash in reiserfs_delete_xattrs during umount. When shrink_dcache_for_umount clears the dcache from generic_shutdown_super, delayed evictions are forced to disk. If an evicted inode has extended attributes associated with it, it will need to walk the xattr tree to locate and remove them. But since shrink_dcache_for_umount will BUG if it encounters active dentries, the xattr tree must be released before it's called or it will crash during every umount. This patch forces the evictions to occur before generic_shutdown_super by calling shrink_dcache_sb first. The additional evictions caused by the removal of each associated xattr file and dir will be automatically handled as they're added to the LRU list. CC: reiserfs-devel@vger.kernel.org Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2012-01-12reiserfs: Fix quota mount option parsingJan Kara
commit a06d789b424190e9f59da391681f908486db2554 upstream. When jqfmt mount option is not specified on remount, we mistakenly clear s_jquota_fmt value stored in superblock. Fix the problem. CC: reiserfs-devel@vger.kernel.org Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-01switch posix_acl_equiv_mode() to umode_t *Al Viro
... so that &inode->i_mode could be passed to it Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-08-01switch posix_acl_create() to umode_t *Al Viro
so we can pass &inode->i_mode to it Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-25Merge 'akpm' patch seriesLinus Torvalds
* Merge akpm patch series: (122 commits) drivers/connector/cn_proc.c: remove unused local Documentation/SubmitChecklist: add RCU debug config options reiserfs: use hweight_long() reiserfs: use proper little-endian bitops pnpacpi: register disabled resources drivers/rtc/rtc-tegra.c: properly initialize spinlock drivers/rtc/rtc-twl.c: check return value of twl_rtc_write_u8() in twl_rtc_set_time() drivers/rtc: add support for Qualcomm PMIC8xxx RTC drivers/rtc/rtc-s3c.c: support clock gating drivers/rtc/rtc-mpc5121.c: add support for RTC on MPC5200 init: skip calibration delay if previously done misc/eeprom: add eeprom access driver for digsy_mtc board misc/eeprom: add driver for microwire 93xx46 EEPROMs checkpatch.pl: update $logFunctions checkpatch: make utf-8 test --strict checkpatch.pl: add ability to ignore various messages checkpatch: add a "prefer __aligned" check checkpatch: validate signature styles and To: and Cc: lines checkpatch: add __rcu as a sparse modifier checkpatch: suggest using min_t or max_t ... Did this as a merge because of (trivial) conflicts in - Documentation/feature-removal-schedule.txt - arch/xtensa/include/asm/uaccess.h that were just easier to fix up in the merge than in the patch series.
2011-07-25reiserfs: use hweight_long()Akinobu Mita
Use hweight_long() to count free bits in the bitmap. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25reiserfs: use proper little-endian bitopsAkinobu Mita
Using __test_and_{set,clear}_bit_le() with ignoring its return value can be replaced with __{set,clear}_bit_le(). This introduces reiserfs_{set,clear}_le_bit for __{set,clear}_bit_le and does the above change with them. Signed-off-by: Akinobu Mita <akinobu.mita@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: fs: take the ACL checks to common code bury posix_acl_..._masq() variants kill boilerplates around posix_acl_create_masq() generic_acl: no need to clone acl just to push it to set_cached_acl() kill boilerplate around posix_acl_chmod_masq() reiserfs: cache negative ACLs for v1 stat format xfs: cache negative ACLs if there is no attribute fork 9p: do no return 0 from ->check_acl without actually checking vfs: move ACL cache lookup into generic code CIFS: Fix oops while mounting with prefixpath xfs: Fix wrong return value of xfs_file_aio_write fix devtmpfs race caam: don't pass bogus S_IFCHR to debugfs_create_...() get rid of create_proc_entry() abuses - proc_mkdir() is there for purpose asus-wmi: ->is_visible() can't return negative fix jffs2 ACLs on big-endian with 16bit mode_t 9p: close ACL leaks ocfs2_init_acl(): fix a leak VFS : mount lock scalability for internal mounts
2011-07-25fs: take the ACL checks to common codeChristoph Hellwig
Replace the ->check_acl method with a ->get_acl method that simply reads an ACL from disk after having a cache miss. This means we can replace the ACL checking boilerplate code with a single implementation in namei.c. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-25kill boilerplates around posix_acl_create_masq()Al Viro
new helper: posix_acl_create(&acl, gfp, mode_p). Replaces acl with modified clone, on failure releases acl and replaces with NULL. Returns 0 or -ve on error. All callers of posix_acl_create_masq() switched. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-25kill boilerplate around posix_acl_chmod_masq()Al Viro
new helper: posix_acl_chmod(&acl, gfp, mode). Replaces acl with modified clone or with NULL if that has failed; returns 0 or -ve on error. All callers of posix_acl_chmod_masq() switched to that - they'd been doing exactly the same thing. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-25reiserfs: cache negative ACLs for v1 stat formatChristoph Hellwig
Always set up a negative ACL cache entry if the inode can't have ACLs. That behaves much better than doing this check inside ->check_acl. Also remove the left over MAY_NOT_BLOCK check. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-25Merge branch 'for-3.1/core' of git://git.kernel.dk/linux-blockLinus Torvalds
* 'for-3.1/core' of git://git.kernel.dk/linux-block: (24 commits) block: strict rq_affinity backing-dev: use synchronize_rcu_expedited instead of synchronize_rcu block: fix patch import error in max_discard_sectors check block: reorder request_queue to remove 64 bit alignment padding CFQ: add think time check for group CFQ: add think time check for service tree CFQ: move think time check variables to a separate struct fixlet: Remove fs_excl from struct task. cfq: Remove special treatment for metadata rqs. block: document blk_plug list access block: avoid building too big plug list compat_ioctl: fix make headers_check regression block: eliminate potential for infinite loop in blkdev_issue_discard compat_ioctl: fix warning caused by qemu block: flush MEDIA_CHANGE from drivers on close(2) blk-throttle: Make total_nr_queued unsigned block: Add __attribute__((format(printf...) and fix fallout fs/partitions/check.c: make local symbols static block:remove some spare spaces in genhd.c block:fix the comment error in blkdev.h ...
2011-07-20fs: push i_mutex and filemap_write_and_wait down into ->fsync() handlersJosef Bacik
Btrfs needs to be able to control how filemap_write_and_wait_range() is called in fsync to make it less of a painful operation, so push down taking i_mutex and the calling of filemap_write_and_wait() down into the ->fsync() handlers. Some file systems can drop taking the i_mutex altogether it seems, like ext3 and ocfs2. For correctness sake I just pushed everything down in all cases to make sure that we keep the current behavior the same for everybody, and then each individual fs maintainer can make up their mind about what to do from there. Thanks, Acked-by: Jan Kara <jack@suse.cz> Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20reiserfs: make reiserfs default to barrier=flushChristoph Hellwig
Change the default reiserfs mount option to barrier=flush. Based on a patch from Jeff Mahoney in the SuSE tree. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20fs: simplify the blockdev_direct_IO prototypeChristoph Hellwig
Simple filesystems always pass inode->i_sb_bdev as the block device argument, and never need a end_io handler. Let's simply things for them and for my grepping activity by dropping these arguments. The only thing not falling into that scheme is ext4, which passes and end_io handler without needing special flags (yet), but given how messy the direct I/O code there is use of __blockdev_direct_IO in one instead of two out of three cases isn't going to make a large difference anyway. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20fs: move inode_dio_wait calls into ->setattrChristoph Hellwig
Let filesystems handle waiting for direct I/O requests themselves instead of doing it beforehand. This means filesystem-specific locks to prevent new dio referenes from appearing can be held. This is important to allow generalizing i_dio_count to non-DIO_LOCKING filesystems. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20fs: kill i_alloc_semChristoph Hellwig
i_alloc_sem is a rather special rw_semaphore. It's the last one that may be released by a non-owner, and it's write side is always mirrored by real exclusion. It's intended use it to wait for all pending direct I/O requests to finish before starting a truncate. Replace it with a hand-grown construct: - exclusion for truncates is already guaranteed by i_mutex, so it can simply fall way - the reader side is replaced by an i_dio_count member in struct inode that counts the number of pending direct I/O requests. Truncate can't proceed as long as it's non-zero - when i_dio_count reaches non-zero we wake up a pending truncate using wake_up_bit on a new bit in i_flags - new references to i_dio_count can't appear while we are waiting for it to read zero because the direct I/O count always needs i_mutex (or an equivalent like XFS's i_iolock) for starting a new operation. This scheme is much simpler, and saves the space of a spinlock_t and a struct list_head in struct inode (typically 160 bits on a non-debug 64-bit system). Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20->permission() sanitizing: don't pass flags to ->permission()Al Viro
not used by the instances anymore. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20->permission() sanitizing: don't pass flags to generic_permission()Al Viro
redundant; all callers get it duplicated in mask & MAY_NOT_BLOCK and none of them removes that bit. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20->permission() sanitizing: don't pass flags to ->check_acl()Al Viro
not used in the instances anymore. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20->permission() sanitizing: pass MAY_NOT_BLOCK to ->check_acl()Al Viro
2011-07-20kill check_acl callback of generic_permission()Al Viro
its value depends only on inode and does not change; we might as well store it in ->i_op->check_acl and be done with that. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-12fixlet: Remove fs_excl from struct task.Justin TerAvest
fs_excl is a poor man's priority inheritance for filesystems to hint to the block layer that an operation is important. It was never clearly specified, not widely adopted, and will not prevent starvation in many cases (like across cgroups). fs_excl was introduced with the time sliced CFQ IO scheduler, to indicate when a process held FS exclusive resources and thus needed a boost. It doesn't cover all file systems, and it was never fully complete. Lets kill it. Signed-off-by: Justin TerAvest <teravest@google.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-06-20reiserfs_permission() doesn't need to bail out in RCU modeAl Viro
nothing blocking other than generic_permission() (and check_acl callback does bail out in RCU mode). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-28reiserfs: remove unnecessary dentry_unhash from rmdir, dir renameSage Weil
Reiserfs does not have problems with references to unlinked directories. CC: reiserfs-devel@vger.kernel.org Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-27fs: pass exact type of data dirties to ->dirty_inodeChristoph Hellwig
Tell the filesystem if we just updated timestamp (I_DIRTY_SYNC) or anything else, so that the filesystem can track internally if it needs to push out a transaction for fdatasync or not. This is just the prototype change with no user for it yet. I plan to push large XFS changes for the next merge window, and getting this trivial infrastructure in this window would help a lot to avoid tree interdependencies. Also remove incorrect comments that ->dirty_inode can't block. That has been changed a long time ago, and many implementations rely on it. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-26vfs: push dentry_unhash on rename_dir into file systemsSage Weil
Only a few file systems need this. Start by pushing it down into each rename method (except gfs2 and xfs) so that it can be dealt with on a per-fs basis. Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-26vfs: push dentry_unhash on rmdir into file systemsSage Weil
Only a few file systems need this. Start by pushing it down into each fs rmdir method (except gfs2 and xfs) so it can be dealt with on a per-fs basis. This does not change behavior for any in-tree file systems. Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-26vfs: remove dget() from dentry_unhash()Sage Weil
This serves no useful purpose that I can discern. All callers (rename, rmdir) hold their own reference to the dentry. A quick audit of all file systems showed no relevant checks on the value of d_count in vfs_rmdir/vfs_rename_dir paths. Signed-off-by: Sage Weil <sage@newdream.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-24Merge branch 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-block: (65 commits) Documentation/iostats.txt: bit-size reference etc. cfq-iosched: removing unnecessary think time checking cfq-iosched: Don't clear queue stats when preempt. blk-throttle: Reset group slice when limits are changed blk-cgroup: Only give unaccounted_time under debug cfq-iosched: Don't set active queue in preempt block: fix non-atomic access to genhd inflight structures block: attempt to merge with existing requests on plug flush block: NULL dereference on error path in __blkdev_get() cfq-iosched: Don't update group weights when on service tree fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going away block: Require subsystems to explicitly allocate bio_set integrity mempool jbd2: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging fs: make fsync_buffers_list() plug mm: make generic_writepages() use plugging blk-cgroup: Add unaccounted time to timeslice_used. block: fixup plugging stubs for !CONFIG_BLOCK block: remove obsolete comments for blkdev_issue_zeroout. blktrace: Use rq->cmd_flags directly in blk_add_trace_rq. ... Fix up conflicts in fs/{aio.c,super.c}
2011-03-23userns: rename is_owner_or_cap to inode_owner_or_capableSerge E. Hallyn
And give it a kernel-doc comment. [akpm@linux-foundation.org: btrfs changed in linux-next] Signed-off-by: Serge E. Hallyn <serge.hallyn@canonical.com> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Cc: Daniel Lezcano <daniel.lezcano@free.fr> Acked-by: David Howells <dhowells@redhat.com> Cc: James Morris <jmorris@namei.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-20Merge branch 'trivial' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6 * 'trivial' of git://git.kernel.org/pub/scm/linux/kernel/git/mmarek/kbuild-2.6: (25 commits) video: change to new flag variable scsi: change to new flag variable rtc: change to new flag variable rapidio: change to new flag variable pps: change to new flag variable net: change to new flag variable misc: change to new flag variable message: change to new flag variable memstick: change to new flag variable isdn: change to new flag variable ieee802154: change to new flag variable ide: change to new flag variable hwmon: change to new flag variable dma: change to new flag variable char: change to new flag variable fs: change to new flag variable xtensa: change to new flag variable um: change to new flag variables s390: change to new flag variable mips: change to new flag variable ... Fix up trivial conflict in drivers/hwmon/Makefile
2011-03-17fs: change to new flag variablematt mooney
Replace EXTRA_CFLAGS with ccflags-y. And change ntfs-objs to ntfs-y for cleaner conditional inclusion. Signed-off-by: matt mooney <mfm@muteddisk.com> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Michal Marek <mmarek@suse.cz>
2011-03-16Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/security-testing-2.6: (33 commits) AppArmor: kill unused macros in lsm.c AppArmor: cleanup generated files correctly KEYS: Add an iovec version of KEYCTL_INSTANTIATE KEYS: Add a new keyctl op to reject a key with a specified error code KEYS: Add a key type op to permit the key description to be vetted KEYS: Add an RCU payload dereference macro AppArmor: Cleanup make file to remove cruft and make it easier to read SELinux: implement the new sb_remount LSM hook LSM: Pass -o remount options to the LSM SELinux: Compute SID for the newly created socket SELinux: Socket retains creator role and MLS attribute SELinux: Auto-generate security_is_socket_class TOMOYO: Fix memory leak upon file open. Revert "selinux: simplify ioctl checking" selinux: drop unused packet flow permissions selinux: Fix packet forwarding checks on postrouting selinux: Fix wrong checks for selinux_policycap_netpeer selinux: Fix check for xfrm selinux context algorithm ima: remove unnecessary call to ima_must_measure IMA: remove IMA imbalance checking ...
2011-03-16Merge branch 'for-2.6.39' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wqLinus Torvalds
* 'for-2.6.39' of git://git.kernel.org/pub/scm/linux/kernel/git/tj/wq: workqueue: fix build failure introduced by s/freezeable/freezable/ workqueue: add system_freezeable_wq rds/ib: use system_wq instead of rds_ib_fmr_wq net/9p: replace p9_poll_task with a work net/9p: use system_wq instead of p9_mux_wq xfs: convert to alloc_workqueue() reiserfs: make commit_wq use the default concurrency level ocfs2: use system_wq instead of ocfs2_quota_wq ext4: convert to alloc_workqueue() scsi/scsi_tgt_lib: scsi_tgtd isn't used in memory reclaim path scsi/be2iscsi,qla2xxx: convert to alloc_workqueue() misc/iwmc3200top: use system_wq instead of dedicated workqueues i2o: use alloc_workqueue() instead of create_workqueue() acpi: kacpi*_wq don't need WQ_MEM_RECLAIM fs/aio: aio_wq isn't used in memory reclaim path input/tps6507x-ts: use system_wq instead of dedicated workqueue cpufreq: use system_wq instead of dedicated workqueues wireless/ipw2x00: use system_wq instead of dedicated workqueues arm/omap: use system_wq in mailbox workqueue: use WQ_MEM_RECLAIM instead of WQ_RESCUER
2011-03-16Merge branch 'next' into for-linusJames Morris
2011-03-15fs: Remove i_nlink check from file system link callbackAneesh Kumar K.V
Now that VFS check for inode->i_nlink == 0 and returns proper error, remove similar check from file system Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-14exportfs: Return the minimum required handle sizeAneesh Kumar K.V
The exportfs encode handle function should return the minimum required handle size. This helps user to find out the handle size by passing 0 handle size in the first step and then redoing to the call again with the returned handle size value. Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-10reiserfs xattr ->d_revalidate() shouldn't care about RCUAl Viro
... it returns an error unconditionally Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-10block: remove per-queue pluggingJens Axboe
Code has been converted over to the new explicit on-stack plugging, and delay users have been converted to use the new API for that. So lets kill off the old plugging along with aops->sync_page(). Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-08Merge branch 'master' of git://git.infradead.org/users/eparis/selinux into nextJames Morris
2011-03-03fix reiserfs mkdir() breakageAl Viro
if directory has so many subdirectories that its link count is set to 1 (i.e. "can't tell accurately") and reiserfs_new_inode() fails, we shouldn't decrement the parent's link count in cleanup path; that's what DEC_DIR_INODE_NLINK() is for. As it is, we end up with parent suddenly getting zero i_nlink, with very unpleasant effects. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-02-01fs/vfs/security: pass last path component to LSM on inode creationEric Paris
SELinux would like to implement a new labeling behavior of newly created inodes. We currently label new inodes based on the parent and the creating process. This new behavior would also take into account the name of the new object when deciding the new label. This is not the (supposed) full path, just the last component of the path. This is very useful because creating /etc/shadow is different than creating /etc/passwd but the kernel hooks are unable to differentiate these operations. We currently require that userspace realize it is doing some difficult operation like that and than userspace jumps through SELinux hoops to get things set up correctly. This patch does not implement new behavior, that is obviously contained in a seperate SELinux patch, but it does pass the needed name down to the correct LSM hook. If no such name exists it is fine to pass NULL. Signed-off-by: Eric Paris <eparis@redhat.com>
2011-02-01reiserfs: make commit_wq use the default concurrency levelTejun Heo
The maximum number of concurrent work items queued on commit_wq is bound by the number of active journals. Convert to alloc_workqueue() and use the default concurrency level so that they can be processed in parallel. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: reiserfs-devel@vger.kernel.org
2011-01-21Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: quota: Fix deadlock during path resolution
2011-01-13Merge branch 'for-2.6.38/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.38/core' of git://git.kernel.dk/linux-2.6-block: (43 commits) block: ensure that completion error gets properly traced blktrace: add missing probe argument to block_bio_complete block cfq: don't use atomic_t for cfq_group block cfq: don't use atomic_t for cfq_queue block: trace event block fix unassigned field block: add internal hd part table references block: fix accounting bug on cross partition merges kref: add kref_test_and_get bio-integrity: mark kintegrityd_wq highpri and CPU intensive block: make kblockd_workqueue smarter Revert "sd: implement sd_check_events()" block: Clean up exit_io_context() source code. Fix compile warnings due to missing removal of a 'ret' variable fs/block: type signature of major_to_index(int) to major_to_index(unsigned) block: convert !IS_ERR(p) && p to !IS_ERR_NOR_NULL(p) cfq-iosched: don't check cfqg in choose_service_tree() fs/splice: Pull buf->ops->confirm() from splice_from_pipe actors cdrom: export cdrom_check_events() sd: implement sd_check_events() sr: implement sr_check_events() ...
2011-01-13reiserfs: make sure va_end() is always called after va_start().Jesper Juhl
A call to va_start() must always be followed by a call to va_end() in the same function. In fs/reiserfs/prints.c::print_block() this is not always the case. If 'bh' is NULL we'll return without calling va_end(). One could add a call to va_end() before the 'return' statement, but it's nicer to just move the call to va_start() after the test for 'bh' being NULL. Signed-off-by: Jesper Juhl <jj@chaosbits.net> Acked-by: Edward Shishkin <edward.shishkin@gmail.com> Cc: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-12quota: Fix deadlock during path resolutionJan Kara
As Al Viro pointed out path resolution during Q_QUOTAON calls to quotactl is prone to deadlocks. We hold s_umount semaphore for reading during the path resolution and resolution itself may need to acquire the semaphore for writing when e. g. autofs mountpoint is passed. Solve the problem by performing the resolution before we get hold of the superblock (and thus s_umount semaphore). The whole thing is complicated by the fact that some filesystems (OCFS2) ignore the path argument. So to distinguish between filesystem which want the path and which do not we introduce new .quota_on_meta callback which does not get the path. OCFS2 then uses this callback instead of old .quota_on. CC: Al Viro <viro@ZenIV.linux.org.uk> CC: Christoph Hellwig <hch@lst.de> CC: Ted Ts'o <tytso@mit.edu> CC: Joel Becker <joel.becker@oracle.com> Signed-off-by: Jan Kara <jack@suse.cz>
