path: root/fs/reiserfs
2007-02-03reiserfs: avoid tail packing if an inode was ever mmappedVladimir Saveliev
This patch fixes a confusion reiserfs has for a long time. On release file operation reiserfs used to try to pack file data stored in last incomplete page of some files into metadata blocks. After packing the page got cleared with clear_page_dirty. It did not take into account that the page may be mmaped into other process's address space. Recent replacement for clear_page_dirty cancel_dirty_page found the confusion with sanity check that page has to be not mapped. The patch fixes the confusion by making reiserfs avoid tail packing if an inode was ever mmapped. reiserfs_mmap and reiserfs_file_release are serialized with mutex in reiserfs specific inode. reiserfs_mmap locks the mutex and sets a bit in reiserfs specific inode flags. reiserfs_file_release checks the bit having the mutex locked. If bit is set - tail packing is avoided. This eliminates a possibility that mmapped page gets cancel_page_dirty-ed. Signed-off-by: Vladimir Saveliev <vs@namesys.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-05-01[PATCH] Fix reiserfs deadlockJan Kara
reiserfs_cache_default_acl() should return whether we successfully found the acl or not. We have to return correct value even if reiserfs_get_acl() returns error code and not just 0. Otherwise callers such as reiserfs_mkdir() can unnecessarily lock the xattrs and later functions such as reiserfs_new_inode() fail to notice that we have already taken the lock and try to take it again with obvious consequences. Signed-off-by: Jan Kara <jack@suse.cz> Cc: <reiserfs-dev@namesys.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-02[PATCH] reiserfs: fix unaligned bitmap usageJeff Mahoney
The bitmaps associated with generation numbers for directory entries are declared as an array of ints. On some platforms, this causes alignment exceptions. The following patch uses the standard bitmap declaration macros to declare the bitmaps, fixing the problem. Originally from Takashi Iwai. Signed-off-by: Takashi Iwai <tiwai@suse.de> Acked-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-02[PATCH] reiserfs: do not check if unsigned < 0Vladimir V. Saveliev
This patch fixes bugs in reiserfs where unsigned integers were checked whether they are less then 0. Signed-off-by: Vladimir V. Saveliev <vs@namesys.com> Cc: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Hans Reiser <reiser@namesys.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-13[PATCH] reiserfs: fix potential (unlikely) oops in reiserfs_get_aclJeff Mahoney
This fixes a potential oops if there is an error reported by posix_acl_from_disk(). This is mostly theoretical due to the use of magics and checksums in xattrs, but is still possible. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-12[PATCH] reiserfs: disable automatic enabling of reiserfs inode attributesJeff Mahoney
Unfortunately, the reiserfs_attrs_cleared bit in the superblock flag can lie. File systems have been observed with the bit set, yet still contain garbage in the stat data field, causing unpredictable results. This patch backs out the enable-by-default behavior. It eliminates the changes from: d50a5cd860ce721dbeac6a4f3c6e42abcde68cd8, and ef5e5414e7a83eb9b4295bbaba5464410b11e030. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-07[PATCH] remove bogus asm/bug.h includes.Al Viro
A bunch of asm/bug.h includes are both not needed (since it will get pulled anyway) and bogus (since they are done too early). Removed. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2006-02-03[PATCH] someone broke reiserfs V3 mount options, this fixes itVitaly Fertman
Signed-off-by: Hans Reiser <reiser@namesys.com> Signed-off-by: Vitaly Fertman <vitaly@namesys.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] reiserfs: reiserfs: check for files > 2GB on 3.5.x disksJeff Mahoney
When a filesystem has been converted from 3.5.x to 3.6.x, we need an extra check during file write to make sure we are not trying to make a 3.5.x file > 2GB. Signed-off-by: Chris Mason <mason@suse.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] reiserfs: reiserfs fix journal accounting in ↵Chris Mason
journal_transaction_should_end reiserfs: journal_transaction_should_end should increase the count of blocks allocated so the transaction subsystem can keep new writers from creating a transaction that is too large. Signed-off-by: Chris Mason <mason@suse.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] reiserfs: reiserfs write_ordered_buffers should not oops on dirty ↵Chris Mason
non-uptodate bh write_ordered_buffers should handle dirty non-uptodate buffers without a BUG() Signed-off-by: Chris Mason <mason@suse.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] reiserfs: reiserfs hang and performance fix for data=journal modeChris Mason
In data=journal mode, reiserfs writepage needs to make sure not to trigger transactions while being run under PF_MEMALLOC. This patch makes sure to redirty the page instead of forcing a transaction start in this case. Also, calling filemap_fdata* in order to trigger io on the block device can cause lock inversions on the page lock. Instead, do simple batching from flush_commit_list. Signed-off-by: Chris Mason <mason@suse.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] resierfs: fix reiserfs_invalidatepage race against data=orderedChris Mason
After a transaction has closed but before it has finished commit, there is a window where data=ordered mode requires invalidatepage to pin pages instead of freeing them. This patch fixes a race between the invalidatepage checks and data=ordered writeback, and it also adds a check to the reiserfs write_ordered_buffers routines to write any anonymous buffers that were dirtied after its first writeback loop. That bug works like this: proc1: transaction closes and a new one starts proc1: write_ordered_buffers starts processing data=ordered list proc1: buffer A is cleaned and written proc2: buffer A is dirtied by another process proc2: File is truncated to zero, page A goes through invalidatepage proc2: reiserfs_invalidatepage sees dirty buffer A with reiserfs journal head, pins it proc1: write_ordered_buffers frees the journal head on buffer A At this point, buffer A stays dirty forever Signed-off-by: Chris Mason <mason@suse.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] reiserfs: use generic_permissionChristoph Hellwig
Use the generic_permission code with a proper wrapper and callback instead of having a local copy. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Jeff Mahoney <jeffm@suse.com> Cc: Chris Mason <mason@suse.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] reiserfs: remove reiserfs_permission_lockedChristoph Hellwig
This function is completely unused since the xattr permission checking changes. Remove it and fold __reiserfs_permission into reiserfs_permission. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Jeff Mahoney <jeffm@suse.com> Cc: Chris Mason <mason@suse.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] reiserfs: missing kmalloc failure checkDiego Calleja
According to http://bugzilla.kernel.org/show_bug.cgi?id=5778 fs/reiserfs/file.c is missing this check. Signed-off-by: Diego Calleja <diegocg@gmail.com> Cc: Jeff Mahoney <jeffm@suse.com> Cc: Chris Mason <mason@suse.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] reiserfs: use __GFP_NOFAIL instead of yield and retry loop for ↵Pekka Enberg
allocation This patch replaces yield and retry loop with __GFP_NOFAIL in alloc_journal_list(). Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-02-01[PATCH] reiserfs: remove kmalloc wrapperPekka Enberg
Remove kmalloc() wrapper from fs/reiserfs/. Please note that a reiserfs /proc entry format is changed because kmalloc statistics is removed. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-14[PATCH] reiserfs: remove d_splice_alias NULL check from reiserfs_lookupPekka Enberg
Remove redundant NULL check in reiserfs_lookup() as d_splice_alias() can take NULL inode as input. Signed-off-by: Pekka Enberg <penberg@cs.helsinki.fi> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-11[PATCH] capable/capability.h (fs/)Randy Dunlap
fs: Use <linux/capability.h> where capable() is used. Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Tim Schmielau <tim@physik3.uni-rostock.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-11[PATCH] reiserfs: fix assertion failure in reiserfs+journaled quotasJan Kara
Sometimes we call do_journal_end() with t_refcount == 0. If quota is turned on and we happen to have some inode with preallocation bad things happen as we try to use the current handle for quota operations. Checks for t_refcount in journal_begin() fail and we Oops. We raise t_refcount to make those checks happy. We should not cause any bad as all the needed quota blocks should be already attached to the transaction (they were attached to the transaction when we allocated those preallocation blocks). Signed-off-by: Jan Kara <jack@suse.cz> Cc: Jeff Mahoney <jeffm@suse.com> Cc: Chris Mason <mason@suse.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] replace inode_update_time with file_update_timeChristoph Hellwig
To allow various options to work per-mount instead of per-sb we need a struct vfsmount when updating ctime and mtime. This preparation patch replaces the inode_update_time routine with a file_update_atime routine so we can easily get at the vfsmount. (and the file makes more sense in this context anyway). Also get rid of the unused second argument - we always want to update the ctime when calling this routine. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@ftp.linux.org.uk> Cc: Anton Altaparmakov <aia21@cantab.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] remove reiserfs xattr permission checksChristoph Hellwig
remove checks now in the VFS Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-09[PATCH] mutex subsystem, semaphore to mutex: VFS, ->i_semJes Sorensen
This patch converts the inode semaphore to a mutex. I have tested it on XFS and compiled as much as one can consider on an ia64. Anyway your luck with it might be different. Modified-by: Ingo Molnar <mingo@elte.hu> (finished the conversion) Signed-off-by: Jes Sorensen <jes@sgi.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2006-01-03s/retreiv/retriev/gMatt Mackall
As everyone knows, the rule is: "i before e.. um.. always." Signed-off-by: Matt Mackall <mpm@selenic.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2005-12-14[PATCH] reiserfs: close open transactions on error pathJeff Mahoney
The following patch fixes a bug where if the journal is aborted, it can leave a transaction open. The result will be a BUG when another code path attempts to start a transaction and will get a "nesting into different fs" error, since current->journal_info will be left non-NULL. Original fix against SUSE kernel by Chris Mason <mason@suse.com> Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-12-14[PATCH] reiserfs: skip commit on io errorJeff Mahoney
This should have been part of the original io error patch, but got dropped somewhere along the way. It's extremely important when handling the i/o error in the journal to not commit the transaction with corrupt data. This patch adds that code back in. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-29[PATCH] reiserfs: handle cnode allocation failure gracefullyJeff Mahoney
If an external device is used for a journal, by default it will use the entire device. The reiserfs journal code allocates structures per journal block when it mounts the file system. If the journal device is too large, and memory cannot be allocated for the structures, it will continue and ultimately panic when it can't pull one off the free list. This patch handles the allocation failure gracefully and prints an error message at mount time. Changes: Updated error message to be more descriptive to the user. Discussed and approved on ReiserFS Mailing List, Nov 28. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-28[PATCH] reiserfs: fix 32-bit overflow in map_block_for_writepage()Oleg Drokin
I now see another overflow in reiserfs that should lead to data corruptions with files that are bigger than 4G under certain circumstances when using mmap. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-11Merge git://git.kernel.org/pub/scm/linux/kernel/git/bunk/trivialLinus Torvalds
2005-11-09[PATCH] Fix return value in reiserfs allocatorJan Kara
Make reiserfs correctly return EDQUOT when the allocation failed due to quotas (so far we just returned ENOSPC). Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-08fs/reiserfs/hashes.c should #include <linux/reiserfs_fs.h>Adrian Bunk
Every file should #include the headers containing the prototypes for it's global functions. Signed-off-by: Adrian Bunk <bunk@stusta.de>
2005-10-30[PATCH] reiserfs: [kv]free() checking cleanupJames Lamanna
Signed-off-by: James Lamanna <jlamanna@gmail.com> Signed-off-by: Domen Puncer <domen@coderock.org> Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-10-28[PATCH] gfp_t: reiserfs mapping_set_gfp_mask() useAl Viro
2005-10-28[PATCH] gfp_t: fs/*Al Viro
- ->releasepage() annotated (s/int/gfp_t), instances updated - missing gfp_t in fs/* added - fixed misannotation from the original sweep caught by bitwise checks: XFS used __nocast both for gfp_t and for flags used by XFS allocator. The latter left with unsigned int __nocast; we might want to add a different type for those but for now let's leave them alone. That, BTW, is a case when __nocast use had been actively confusing - it had been used in the same code for two different and similar types, with no way to catch misuses. Switch of gfp_t to bitwise had caught that immediately... One tricky bit is left alone to be dealt with later - mapping->flags is a mix of gfp_t and error indications. Left alone for now. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-13[PATCH] reiserfs: use mark_inode_dirty instead of reiserfs_update_sdChris Mason
reiserfs should use mark_inode_dirty during reiserfs_file_write and reiserfs_commit_write. This makes sure the inode is properly flagged as dirty, which is used during O_SYNC to decide when to trigger log commits. This patch also removes the O_SYNC check from reiserfs_commit_write, since that gets dealt with properly at higher layers once we start using mark_inode_dirty. Thanks to Hifumi Hisashi <hifumi.hisashi@lab.ntt.co.jp> for catching this. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-10[PATCH] fs: fix-up schedule_timeout() usageNishanth Aravamudan
Use schedule_timeout_{,un}interruptible() instead of set_current_state()/schedule_timeout() to reduce kernel size. Also use helper functions to convert between human time units and jiffies rather than constant HZ division to avoid rounding errors. Signed-off-by: Nishanth Aravamudan <nacc@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-10[PATCH] janitor: reiserfs: super.c - vfree() checking cleanupsJames Lamanna
super.c vfree() checking cleanups. Signed-off by: James Lamanna <jlamanna@gmail.com> Signed-off-by: Domen Puncer <domen@coderock.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] update filesystems for new delete_inode behaviorMark Fasheh
Update the file systems in fs/ implementing a delete_inode() callback to call truncate_inode_pages(). One implementation note: In developing this patch I put the calls to truncate_inode_pages() at the very top of those filesystems delete_inode() callbacks in order to retain the previous behavior. I'm guessing that some of those could probably be optimized. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com> Acked-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: Hugh Dickins <hugh@veritas.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-07[PATCH] Change ll_rw_block() calls in ReiserJan Kara
We need to be sure that current data in buffer are sent to disk. Hence we need to call ll_rw_block() with SWRITE. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-18[PATCH] reiserfs+acl+quota deadlock fixJan Kara
When i_acl_default is set to some error we do not hold the lock (hence we are not allowed to drop it and reacquire later). Signed-off-by: Jan Kara <jack@suse.cz> Cc: Jeff Mahoney <jeffm@suse.com> Cc: Chris Mason <mason@suse.com> Cc: <reiserfs-dev@namesys.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-08-13[PATCH] Fix error handling in reiserfsJan Kara
Initialize key object ID in inode so that we don't try to remove the inode when we fail on some checks even before we manage to allocate something. Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-27[PATCH] clean up inline static vs static inlineJesper Juhl
`gcc -W' likes to complain if the static keyword is not at the beginning of the declaration. This patch fixes all remaining occurrences of "inline static" up with "static inline" in the entire kernel tree (140 occurrences in 47 files). While making this change I came across a few lines with trailing whitespace that I also fixed up, I have also added or removed a blank line or two here and there, but there are no functional changes in the patch. Signed-off-by: Jesper Juhl <juhl-lkml@dif.dk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-27[PATCH] reiserfs doesn't use mbcacheAndreas Gruenbacher
reiserfs doesn't use the mbcache, so this can go. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-27[PATCH] reiserfs: fix deadlock in inode creation failure path w/ default ACLJeff Mahoney
reiserfs_new_inode() can call iput() with the xattr lock held. This will cause a deadlock to occur when reiserfs_delete_xattrs() is called to clean up. The following patch releases the lock and reacquires it after the iput. This is safe because interaction with xattrs is complete, and the relock is just to balance out the release in the caller. The locking needs some reworking to be more sane, but that's more intrusive and I was just looking to fix this bug. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-12reiserfs: run scripts/Lindent on reiserfs codeLinus Torvalds
This was a pure indentation change, using: scripts/Lindent fs/reiserfs/*.c include/linux/reiserfs_*.h to make reiserfs match the regular Linux indentation style. As Jeff Mahoney <jeffm@suse.com> writes: The ReiserFS code is a mix of a number of different coding styles, sometimes different even from line-to-line. Since the code has been relatively stable for quite some time and there are few outstanding patches to be applied, it is time to reformat the code to conform to the Linux style standard outlined in Documentation/CodingStyle. This patch contains the result of running scripts/Lindent against fs/reiserfs/*.c and include/linux/reiserfs_*.h. There are places where the code can be made to look better, but I'd rather keep those patches separate so that there isn't a subtle by-hand hand accident in the middle of a huge patch. To be clear: This patch is reformatting *only*. A number of patches may follow that continue to make the code more consistent with the Linux coding style. Hans wasn't particularly enthusiastic about these patches, but said he wouldn't really oppose them either. Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-12[PATCH] reiserfs: fix up case where indent misreads the codeJeff Mahoney
indent(1) doesn't know how to handle the "do not compile" error. It results in the item_ops array declaration being indented a tab stop in when it should not be. This patch replaces it with a #error that describes why it's failing. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-30[PATCH] reiserfs: handle_attrs() fixAndrew Morton
Fix a use-uninitialised bug. Cc: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-29[PATCH] reiserfs: enable attrs by default if safJeff Mahoney
The following patch enables attrs by default if the reiserfs_attrs_cleared bit is set in the superblock. This allows chattr-type attrs to be used without any further action by the user. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-29[PATCH] reiserfs: Check if attrs are enabled for attr ioctlsJeff Mahoney
ReiserFS currently will allow the user to set/get attrs for files regardless if they are enabled. The patch checks to see if they are enabled, and returns -NOTTY if they are not. ext[23] doesn't need this check because attrs are always enabled. Signed-off-by: Jeff Mahoney <jeffm@suse.com> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
