path: root/fs/romfs
2009-05-09ROMFS: romfs_dev_read() error ignoredRoel Kluin
romfs_dev_read() may return -EIO, but ret is unsigned, so the errorpath isn't taken. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-04-24ROMFS: Advance destination buffer pointer when reading from a blockdevDavid Howells
RomFS should advance the destination buffer pointer when reading data from a blockdev source (the data may be split over multiple blocks, each requiring its own sb_read() call). Without this, all the data is copied to the beginning of the output buffer. Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-24ROMFS: romfs_lookup() shouldn't be doing a partial name comparisonDavid Howells
romfs_lookup() should be using a routine akin to strcmp() on the backing store, rather than one akin to strncmp(). If it uses the latter, it's liable to match /bin/shutdown when looking up /bin/sh. Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Michal Simek <monstr@monstr.eu> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-07fs/romfs: return f_fsid for statfs(2)Coly Li
Make romfs return f_fsid info for statfs(2). Signed-off-by: Coly Li <coly.li@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-24NOMMU: Fix the RomFS Kconfig to ensure at least one backing store is selectedDavid Howells
Fix the configuration of the RomFS to make sure that at least one backing store method is always selected. This is done by rendering it down to a choice item that selects between Block, MTD and both. This also works correctly in the case that CONFIG_MTD=m: MTD cannot be selected as a backing store unless CONFIG_ROMFS_FS is also 'm'. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-03-24NOMMU: Make it possible for RomFS to use MTD devices directlyDavid Howells
Change RomFS so that it can use MTD devices directly - without the intercession of the block layer - as well as using block devices. This permits RomFS: (1) to use the MTD direct mapping facility available under NOMMU conditions if the underlying device is directly accessible by the CPU (including XIP); (2) and thus to be used when the block layer is disabled. RomFS can be configured with support just for MTD devices, just for Block devices or for both. If RomFS is configured for both, then it will treat mtdblock device files as MTD backing stores, not block layer backing stores. I tested this using a CONFIG_MMU=n CONFIG_BLOCK=n kernel running on my FRV board with a RomFS image installed on the mtdram test device. I see my test program being run XIP: # cat /proc/maps ... c0c000b0-c0c01f8c r-xs 00000000 1f:00 144 /mnt/doshm ... GDB on the kernel can be used to show that these addresses are within the set-aside RAM space. Signed-off-by: David Howells <dhowells@redhat.com> Tested-by: Bernd Schmidt <bernd.schmidt@analog.com> Signed-off-by: David Woodhouse <David.Woodhouse@intel.com>
2009-01-22fs/Kconfig: move romfs outAlexey Dobriyan
2009-01-08romfs: romfs_iget() - unsigned ino >= 0 is always trueroel kluin
romfs_strnlen() returns int unsigned X >= 0 is always true [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: roel kluin <roel.kluin@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-05zero i_uid/i_gid on inode allocationAl Viro
... and don't bother in callers. Don't bother with zeroing i_blocks, while we are at it - it's already been zeroed. i_mode is not worth the effort; it has no common default value. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-30romfs_readpage: don't report errors for pages beyond i_sizeLinus Torvalds
We zero-fill them like we are supposed to, and that's all fine. It's only an error if the 'romfs_copyfrom()' routine isn't able to fill the data that is supposed to be there. Most of the patch is really just re-organizing the code a bit, and using separate variables for the error value and for how much of the page we actually filled from the filesystem. Reported-and-tested-by: Chris Fester <cfester@wms.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Cc: Matt Waddel <matt.waddel@freescale.com> Cc: Greg Ungerer <gerg@snapgear.com> Signed-of-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-26SL*B: drop kmem cache argument from constructorAlexey Dobriyan
Kmem cache passed to constructor is only needed for constructors that are themselves multiplexeres. Nobody uses this "feature", nor does anybody uses passed kmem cache in non-trivial way, so pass only pointer to object. Non-trivial places are: arch/powerpc/mm/init_64.c arch/powerpc/mm/hugetlbpage.c This is flag day, yes. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Christoph Lameter <cl@linux-foundation.org> Cc: Jon Tollefson <kniht@linux.vnet.ibm.com> Cc: Nick Piggin <nickpiggin@yahoo.com.au> Cc: Matt Mackall <mpm@selenic.com> [akpm@linux-foundation.org: fix arch/powerpc/mm/hugetlbpage.c] [akpm@linux-foundation.org: fix mm/slab.c] [akpm@linux-foundation.org: fix ubifs] Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-19ROMFS: Fix up an error in iget removalDavid Howells
Fix up an error in iget removal in which romfs_lookup() making a successful call to romfs_iget() continues through the negative/error handling (previously the successful case jumped around the negative/error handling case): (1) inode is initialised to NULL at the top of the function, eliminating the need for specific negative-inode handling. This means the positive success handling now flows straight through. (2) Rename the labels to be clearer about what they mean. Also make romfs_lookup()'s result variable of type long so as to avoid 32-bit/64-bit conversions with PTR_ERR() and friends. Based upon a report and patch from Adam Richter. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: "Adam J. Richter" <adam@yggdrasil.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07iget: stop ROMFS from using iget() and read_inode()David Howells
Stop the ROMFS filesystem from using iget() and read_inode(). Replace romfs_read_inode() with romfs_iget(), and call that instead of iget(). romfs_iget() then uses iget_locked() directly and returns a proper error code instead of an inode in the event of an error. romfs_fill_super() returns any error incurred when getting the root inode instead of EINVAL. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17fs/romfs/inode.c: trivial improvementsWANG Cong
- There are no lists in fs/romfs/inode.c, so using list_entry is a bit confusing. Replace it with container_of. - It is unnecessary to cast the return value of kmem_cache_alloc, since it returns a void* pointer. Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17Slab API: remove useless ctor parameter and reorder parametersChristoph Lameter
Slab constructors currently have a flags parameter that is never used. And the order of the arguments is opposite to other slab functions. The object pointer is placed before the kmem_cache pointer. Convert ctor(void *object, struct kmem_cache *s, unsigned long flags) to ctor(struct kmem_cache *s, void *object) throughout the kernel [akpm@linux-foundation.org: coupla fixes] Signed-off-by: Christoph Lameter <clameter@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] mark struct inode_operations const 3Arjan van de Ven
2006-12-08[PATCH] struct path: convert romfsJosef Sipek
2006-09-27[PATCH] Really ignore kmem_cache_destroy return valueAlexey Dobriyan
* Rougly half of callers already do it by not checking return value * Code in drivers/acpi/osl.c does the following to be sure: (void)kmem_cache_destroy(cache); * Those who check it printk something, however, slab_error already printed the name of failed cache. * XFS BUGs on failed kmem_cache_destroy which is not the decision low-level filesystem driver should make. Converted to ignore. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-28[PATCH] mark address_space_operations constChristoph Hellwig
Same as with already do with the file operations: keep them in .rodata and prevents people from doing runtime patching. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Steven French <sfrench@us.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] VFS: Permit filesystem to perform statfs with a known root dentryDavid Howells
Give the statfs superblock operation a dentry pointer rather than a superblock pointer. This complements the get_sb() patch. That reduced the significance of sb->s_root, allowing NFS to place a fake root there. However, NFS does require a dentry to use as a target for the statfs operation. This permits the root in the vfsmount to be used instead. linux/mount.h has been added where necessary to make allyesconfig build successfully. Interest has also been expressed for use with the FUSE and XFS filesystems. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Nathan Scott <nathans@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-23[PATCH] VFS: Permit filesystem to override root dentry on mountDavid Howells
Extend the get_sb() filesystem operation to take an extra argument that permits the VFS to pass in the target vfsmount that defines the mountpoint. The filesystem is then required to manually set the superblock and root dentry pointers. For most filesystems, this should be done with simple_set_mnt() which will set the superblock pointer and then set the root dentry to the superblock's s_root (as per the old default behaviour). The get_sb() op now returns an integer as there's now no need to return the superblock pointer. This patch permits a superblock to be implicitly shared amongst several mount points, such as can be done with NFS to avoid potential inode aliasing. In such a case, simple_set_mnt() would not be called, and instead the mnt_root and mnt_sb would be set directly. The patch also makes the following changes: (*) the get_sb_*() convenience functions in the core kernel now take a vfsmount pointer argument and return an integer, so most filesystems have to change very little. (*) If one of the convenience function is not used, then get_sb() should normally call simple_set_mnt() to instantiate the vfsmount. This will always return 0, and so can be tail-called from get_sb(). (*) generic_shutdown_super() now calls shrink_dcache_sb() to clean up the dcache upon superblock destruction rather than shrink_dcache_anon(). This is required because the superblock may now have multiple trees that aren't actually bound to s_root, but that still need to be cleaned up. The currently called functions assume that the whole tree is rooted at s_root, and that anonymous dentries are not the roots of trees which results in dentries being left unculled. However, with the way NFS superblock sharing are currently set to be implemented, these assumptions are violated: the root of the filesystem is simply a dummy dentry and inode (the real inode for '/' may well be inaccessible), and all the vfsmounts are rooted on anonymous[*] dentries with child trees. [*] Anonymous until discovered from another tree. (*) The documentation has been adjusted, including the additional bit of changing ext2_* into foo_* in the documentation. [akpm@osdl.org: convert ipath_fs, do other stuff] Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Al Viro <viro@zeniv.linux.org.uk> Cc: Nathan Scott <nathans@sgi.com> Cc: Roland Dreier <rolandd@cisco.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-28[PATCH] Make most file operations structs in fs/ constArjan van de Ven
This is a conversion to make the various file_operations structs in fs/ const. Basically a regexp job, with a few manual fixups The goal is both to increase correctness (harder to accidentally write to shared datastructures) and reducing the false sharing of cachelines with things that get dirty in .data (while .rodata is nicely read only and thus cache clean) Signed-off-by: Arjan van de Ven <arjan@infradead.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] cpuset memory spread: slab cache formatPaul Jackson
Rewrap the overly long source code lines resulting from the previous patch's addition of the slab cache flag SLAB_MEM_SPREAD. This patch contains only formatting changes, and no function change. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-24[PATCH] cpuset memory spread: slab cache filesystemsPaul Jackson
Mark file system inode and similar slab caches subject to SLAB_MEM_SPREAD memory spreading. If a slab cache is marked SLAB_MEM_SPREAD, then anytime that a task that's in a cpuset with the 'memory_spread_slab' option enabled goes to allocate from such a slab cache, the allocations are spread evenly over all the memory nodes (task->mems_allowed) allowed to that task, instead of favoring allocation on the node local to the current cpu. The following inode and similar caches are marked SLAB_MEM_SPREAD: file cache ==== ===== fs/adfs/super.c adfs_inode_cache fs/affs/super.c affs_inode_cache fs/befs/linuxvfs.c befs_inode_cache fs/bfs/inode.c bfs_inode_cache fs/block_dev.c bdev_cache fs/cifs/cifsfs.c cifs_inode_cache fs/coda/inode.c coda_inode_cache fs/dquot.c dquot fs/efs/super.c efs_inode_cache fs/ext2/super.c ext2_inode_cache fs/ext2/xattr.c (fs/mbcache.c) ext2_xattr fs/ext3/super.c ext3_inode_cache fs/ext3/xattr.c (fs/mbcache.c) ext3_xattr fs/fat/cache.c fat_cache fs/fat/inode.c fat_inode_cache fs/freevxfs/vxfs_super.c vxfs_inode fs/hpfs/super.c hpfs_inode_cache fs/isofs/inode.c isofs_inode_cache fs/jffs/inode-v23.c jffs_fm fs/jffs2/super.c jffs2_i fs/jfs/super.c jfs_ip fs/minix/inode.c minix_inode_cache fs/ncpfs/inode.c ncp_inode_cache fs/nfs/direct.c nfs_direct_cache fs/nfs/inode.c nfs_inode_cache fs/ntfs/super.c ntfs_big_inode_cache_name fs/ntfs/super.c ntfs_inode_cache fs/ocfs2/dlm/dlmfs.c dlmfs_inode_cache fs/ocfs2/super.c ocfs2_inode_cache fs/proc/inode.c proc_inode_cache fs/qnx4/inode.c qnx4_inode_cache fs/reiserfs/super.c reiser_inode_cache fs/romfs/inode.c romfs_inode_cache fs/smbfs/inode.c smb_inode_cache fs/sysv/inode.c sysv_inode_cache fs/udf/super.c udf_inode_cache fs/ufs/super.c ufs_inode_cache net/socket.c sock_inode_cache net/sunrpc/rpc_pipe.c rpc_inode_cache The choice of which slab caches to so mark was quite simple. I marked those already marked SLAB_RECLAIM_ACCOUNT, except for fs/xfs, dentry_cache, inode_cache, and buffer_head, which were marked in a previous patch. Even though SLAB_RECLAIM_ACCOUNT is for a different purpose, it marks the same potentially large file system i/o related slab caches as we need for memory spreading. Given that the rule now becomes "wherever you would have used a SLAB_RECLAIM_ACCOUNT slab cache flag before (usually the inode cache), use the SLAB_MEM_SPREAD flag too", this should be easy enough to maintain. Future file system writers will just copy one of the existing file system slab cache setups and tend to get it right without thinking. Signed-off-by: Paul Jackson <pj@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-08[PATCH] fix possible PAGE_CACHE_SHIFT overflowsAndrew Morton
We've had two instances recently of overflows when doing 64_bit_value = (32_bit_value << PAGE_CACHE_SHIFT) I did a tree-wide grep of `<<.*PAGE_CACHE_SHIFT' and this is the result. - afs_rxfs_fetch_descriptor.offset is of type off_t, which seems broken. - jfs and jffs are limited to 4GB anyway. - reiserfs map_block_for_writepage() takes an unsigned long for the block - it should take sector_t. (It'll fail for huge filesystems with blocksize<PAGE_CACHE_SIZE) - cramfs_read() needs to use sector_t (I think cramsfs is busted on large filesystems anyway) - affs is limited in file size anyway. - I generally didn't fix 32-bit overflows in directory operations. - arm's __flush_dcache_page() is peculiar. What if the page lies beyond 4G? - gss_wrap_req_priv() needs checking (snd_buf->page_base) Cc: Oleg Drokin <green@linuxhacker.ru> Cc: David Howells <dhowells@redhat.com> Cc: David Woodhouse <dwmw2@infradead.org> Cc: <reiserfs-dev@namesys.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Anton Altaparmakov <aia21@cantab.net> Cc: Jeff Dike <jdike@addtoit.com> Cc: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Roman Zippel <zippel@linux-m68k.org> Cc: <linux-fsdevel@vger.kernel.org> Cc: Miklos Szeredi <miklos@szeredi.hu> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Neil Brown <neilb@cse.unsw.edu.au> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
