path: root/fs/seq_file.c
2008-04-23[patch 2/7] vfs: mountinfo: add seq_file_root()Miklos Szeredi
Add a new function: seq_file_root() This is similar to seq_path(), but calculates the path relative to the given root, instead of current->fs->root. If the path was unreachable from root, then modify the root parameter to reflect this. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-23[patch 1/7] vfs: mountinfo: add dentry_path()Ram Pai
[mszeredi@suse.cz] split big patch into managable chunks Add the following functions: dentry_path() seq_dentry() These are similar to d_path() and seq_path(). But instead of calculating the path within a mount namespace, they calculate the path from the root of the filesystem to a given dentry, ignoring mounts completely. Signed-off-by: Ram Pai <linuxram@us.ibm.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-22Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: [PATCH] get rid of __exit_files(), __exit_fs() and __put_fs_struct() [PATCH] proc_readfd_common() race fix [PATCH] double-free of inode on alloc_file() failure exit in create_write_pipe() [PATCH] teach seq_file to discard entries [PATCH] umount_tree() will unhash everything itself [PATCH] get rid of more nameidata passing in namespace.c [PATCH] switch a bunch of LSM hooks from nameidata to path [PATCH] lock exclusively in collect_mounts() and drop_collected_mounts() [PATCH] move a bunch of declarations to fs/internal.h
2008-04-22fs: use loff_t type instead of long longDavid Sterba
Use offset type consistently. Signed-off-by: David Sterba <dsterba@suse.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-21[PATCH] teach seq_file to discard entriesAl Viro
Allow ->show() return SEQ_SKIP; that will discard all output from that element and move on. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-02-14d_path: Make d_path() use a struct pathJan Blunck
d_path() is used on a <dentry,vfsmount> pair. Lets use a struct path to reflect this. [akpm@linux-foundation.org: fix build in mm/memory.c] Signed-off-by: Jan Blunck <jblunck@suse.de> Acked-by: Bryan Wu <bryan.wu@analog.com> Acked-by: Christoph Hellwig <hch@infradead.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Neil Brown <neilb@suse.de> Cc: Michael Halcrow <mhalcrow@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14d_path: Make seq_path() use a struct path argumentJan Blunck
seq_path() is always called with a dentry and a vfsmount from a struct path. Make seq_path() take it directly as an argument. Signed-off-by: Jan Blunck <jblunck@suse.de> Cc: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: Neil Brown <neilb@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-10[FS] seq_file: Introduce the seq_open_private()Pavel Emelyanov
This function allocates the zeroed chunk of memory and call seq_open(). The __seq_open_private() helper returns the allocated memory to make it possible for the caller to initialize it. Signed-off-by: Pavel Emelyanov <xemul@openvz.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-07-16seq_file: more atomicity in traverse()Alexey Dobriyan
Original problem: in some circumstances seq_file interface can present infinite proc file to the following script when normally said proc file is finite: while read line; do [do something with $line] done </proc/$FILE bash, to implement such loop does essentially read(0, buf, 128); [find \n] lseek(0, -difference, SEEK_CUR); Consider, proc file prints list of objects each of them consists of many lines, each line is shorter than 128 bytes. Two objects in list, with ->index'es being 0 and 1. Current one is 1, as bash prints second object line by line. Imagine first object being removed right before lseek(). traverse() will be called, because there is negative offset. traverse() will reset ->index to 0 (!). traverse() will call ->next() and get NULL in any usual iterate-over-list code using list_for_each_entry_continue() and such. There is one object in list now after all... traverse() will return 0, lseek() will update file position and pretend everything is OK. So, what we have now: ->f_pos points to place where second object will be printed, but ->index is 0. seq_read() instead of returning EOF, will start printing first line of first object every time it's called, until enough objects are added to ->f_pos return in bounds. Fix is to update ->index only after we're sure we saw enough objects down the road. Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16mutex_unlock() later in seq_lseek()Alexey Dobriyan
All manipulations with struct seq_file::version are done under struct seq_file::lock except one introduced in commit d6b7a781c51c91dd054e5c437885205592faac21 aka "[PATCH] Speed up /proc/pid/maps" Signed-off-by: Alexey Dobriyan <adobriyan@sw.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-10Make common helpers for seq_files that work with list_headsPavel Emelianov
Many places in kernel use seq_file API to iterate over a regular list_head. The code for such iteration is identical in all the places, so it's worth introducing a common helpers. This makes code about 300 lines smaller: The first version of this patch made the helper functions static inline in the seq_file.h header. This patch moves them to the fs/seq_file.c as Andrew proposed. The vmlinux .text section sizes are as follows: 2.6.22-rc1-mm1: 0x001794d5 with the previous version: 0x00179505 with this patch: 0x00179135 The config file used was make allnoconfig with the "y" inclusion of all the possible options to make the files modified by the patch compile plus drivers I have on the test node. This patch: Many places in kernel use seq_file API to iterate over a regular list_head. The code for such iteration is identical in all the places, so it's worth introducing a common helpers. Signed-off-by: Pavel Emelianov <xemul@openvz.org> Cc: "David S. Miller" <davem@davemloft.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] VFS: change struct file to use struct pathJosef "Jeff" Sipek
This patch changes struct file to use struct path instead of having independent pointers to struct dentry and struct vfsmount, and converts all users of f_{dentry,vfsmnt} in fs/ to use f_path.{dentry,mnt}. Additionally, it adds two #define's to make the transition easier for users of the f_dentry and f_vfsmnt. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] struct seq_operations and struct file_operations constificationHelge Deller
- move some file_operations structs into the .rodata section - move static strings from policy_types[] array into the .rodata section - fix generic seq_operations usages, so that those structs may be defined as "const" as well [akpm@osdl.org: couple of fixes] Signed-off-by: Helge Deller <deller@gmx.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-23[PATCH] sem2mutex: fs/seq_file.cIngo Molnar
Semaphore to mutex conversion. The conversion was generated via scripts, and the result was validated automatically via a script as well. Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] allow callers of seq_open do allocation themselvesAl Viro
Allow caller of seq_open() to kmalloc() seq_file + whatever else they want and set ->private_data to it. seq_open() will then abstain from doing allocation itself. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] DocBook: fix some descriptionsMartin Waitz
Some KernelDoc descriptions are updated to match the current code. No code changes. Signed-off-by: Martin Waitz <tali@admingilde.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
