path: root/fs/signalfd.c
2009-01-14[CVE-2009-0029] System call wrappers part 31Heiko Carstens
2008-07-24flag parameters: check magic constantsUlrich Drepper
This patch adds test that ensure the boundary conditions for the various constants introduced in the previous patches is met. No code is generated. [akpm@linux-foundation.org: fix alpha] Signed-off-by: Ulrich Drepper <drepper@redhat.com> Acked-by: Davide Libenzi <davidel@xmailserver.org> Cc: Michael Kerrisk <mtk.manpages@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24flag parameters: NONBLOCK in signalfdUlrich Drepper
This patch adds support for the SFD_NONBLOCK flag to signalfd4. The additional changes needed are minimal. The following test must be adjusted for architectures other than x86 and x86-64 and in case the syscall numbers changed. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ #include <fcntl.h> #include <signal.h> #include <stdio.h> #include <unistd.h> #include <sys/syscall.h> #ifndef __NR_signalfd4 # ifdef __x86_64__ # define __NR_signalfd4 289 # elif defined __i386__ # define __NR_signalfd4 327 # else # error "need __NR_signalfd4" # endif #endif #define SFD_NONBLOCK O_NONBLOCK int main (void) { sigset_t ss; sigemptyset (&ss); sigaddset (&ss, SIGUSR1); int fd = syscall (__NR_signalfd4, -1, &ss, 8, 0); if (fd == -1) { puts ("signalfd4(0) failed"); return 1; } int fl = fcntl (fd, F_GETFL); if (fl == -1) { puts ("fcntl failed"); return 1; } if (fl & O_NONBLOCK) { puts ("signalfd4(0) set non-blocking mode"); return 1; } close (fd); fd = syscall (__NR_signalfd4, -1, &ss, 8, SFD_NONBLOCK); if (fd == -1) { puts ("signalfd4(SFD_NONBLOCK) failed"); return 1; } fl = fcntl (fd, F_GETFL); if (fl == -1) { puts ("fcntl failed"); return 1; } if ((fl & O_NONBLOCK) == 0) { puts ("signalfd4(SFD_NONBLOCK) does not set non-blocking mode"); return 1; } close (fd); puts ("OK"); return 0; } ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ Signed-off-by: Ulrich Drepper <drepper@redhat.com> Acked-by: Davide Libenzi <davidel@xmailserver.org> Cc: Michael Kerrisk <mtk.manpages@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24flag parameters: signalfdUlrich Drepper
This patch adds the new signalfd4 syscall. It extends the old signalfd syscall by one parameter which is meant to hold a flag value. In this patch the only flag support is SFD_CLOEXEC which causes the close-on-exec flag for the returned file descriptor to be set. A new name SFD_CLOEXEC is introduced which in this implementation must have the same value as O_CLOEXEC. The following test must be adjusted for architectures other than x86 and x86-64 and in case the syscall numbers changed. ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ #include <fcntl.h> #include <signal.h> #include <stdio.h> #include <unistd.h> #include <sys/syscall.h> #ifndef __NR_signalfd4 # ifdef __x86_64__ # define __NR_signalfd4 289 # elif defined __i386__ # define __NR_signalfd4 327 # else # error "need __NR_signalfd4" # endif #endif #define SFD_CLOEXEC O_CLOEXEC int main (void) { sigset_t ss; sigemptyset (&ss); sigaddset (&ss, SIGUSR1); int fd = syscall (__NR_signalfd4, -1, &ss, 8, 0); if (fd == -1) { puts ("signalfd4(0) failed"); return 1; } int coe = fcntl (fd, F_GETFD); if (coe == -1) { puts ("fcntl failed"); return 1; } if (coe & FD_CLOEXEC) { puts ("signalfd4(0) set close-on-exec flag"); return 1; } close (fd); fd = syscall (__NR_signalfd4, -1, &ss, 8, SFD_CLOEXEC); if (fd == -1) { puts ("signalfd4(SFD_CLOEXEC) failed"); return 1; } coe = fcntl (fd, F_GETFD); if (coe == -1) { puts ("fcntl failed"); return 1; } if ((coe & FD_CLOEXEC) == 0) { puts ("signalfd4(SFD_CLOEXEC) does not set close-on-exec flag"); return 1; } close (fd); puts ("OK"); return 0; } ~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~~ [akpm@linux-foundation.org: add sys_ni stub] Signed-off-by: Ulrich Drepper <drepper@redhat.com> Acked-by: Davide Libenzi <davidel@xmailserver.org> Cc: Michael Kerrisk <mtk.manpages@googlemail.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-24flag parameters: anon_inode_getfd extensionUlrich Drepper
This patch just extends the anon_inode_getfd interface to take an additional parameter with a flag value. The flag value is passed on to get_unused_fd_flags in anticipation for a use with the O_CLOEXEC flag. No actual semantic changes here, the changed callers all pass 0 for now. [akpm@linux-foundation.org: KVM fix] Signed-off-by: Ulrich Drepper <drepper@redhat.com> Acked-by: Davide Libenzi <davidel@xmailserver.org> Cc: Michael Kerrisk <mtk.manpages@googlemail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-01[PATCH] sanitize anon_inode_getfd()Al Viro
a) none of the callers even looks at inode or file returned by anon_inode_getfd() b) any caller that would try to look at those would be racy, since by the time it returns we might have raced with close() from another thread and that file would be pining for fjords. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-11signalfd: fix for incorrect SI_QUEUE user data reportingDavide Libenzi
Michael Kerrisk found out that signalfd was not reporting back user data pushed using sigqueue: http://groups.google.com/group/linux.kernel/msg/9397cab8551e3123 The following patch makes signalfd report back the ssi_ptr and ssi_int members of the signalfd_siginfo structure. Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Acked-by: Michael Kerrisk <mtk.manpages@googlemail.com> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06fs/signalfd.c should #include <linux/syscalls.h>Adrian Bunk
Every file should include the headers containing the prototypes for its global functions (in this case sys_signalfd()). Signed-off-by: Adrian Bunk <bunk@kernel.org> Cc: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-03Fix a small number of "memeber" typoes.Robert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-17rename signalfd_siginfo fieldsDavide Libenzi
For Michael Kerrisk request, the following patch renames signalfd_siginfo fields in order to keep them consistent with the siginfo_t ones. Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-09-20signalfd simplificationDavide Libenzi
This simplifies signalfd code, by avoiding it to remain attached to the sighand during its lifetime. In this way, the signalfd remain attached to the sighand only during poll(2) (and select and epoll) and read(2). This also allows to remove all the custom "tsk == current" checks in kernel/signal.c, since dequeue_signal() will only be called by "current". I think this is also what Ben was suggesting time ago. The external effect of this, is that a thread can extract only its own private signals and the group ones. I think this is an acceptable behaviour, in that those are the signals the thread would be able to fetch w/out signalfd. Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-08-22signalfd: make it group-wide, fix posix-timers schedulingOleg Nesterov
With this patch any thread can dequeue its own private signals via signalfd, even if it was created by another sub-thread. To do so, we pass "current" to dequeue_signal() if the caller is from the same thread group. This also fixes the scheduling of posix timers broken by the previous patch. If the caller doesn't belong to this thread group, we can't handle __SI_TIMER case properly anyway. Perhaps we should forbid the cross-process signalfd usage and convert ctx->tsk to ctx->sighand. Signed-off-by: Oleg Nesterov <oleg@tv-sign.ru> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Davide Libenzi <davidel@xmailserver.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Cc: Roland McGrath <roland@redhat.com> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: <stable@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-26tiny signalfd cleanupUlrich Drepper
This is probably a leftover from a time when the return wasn't there yet. Now the extra assignment is just irritating. Signed-off-by: Ulrich Drepper <drepper@redhat.com> Cc: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-06-28avoid spurious POLLIN returns in signalfdDavide Libenzi
The new code in kernel/signal.c does not allow fetching private signals from another task. This patch avoid spurious POLLIN returns from a signalfd poll(2) operation. Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-23signalfd: retrieve multiple signals with one read() callDavi Arnaut
Gathering signals in bulk enables server applications to drain a signal queue (almost full of realtime signals) more efficiently by reducing the syscall and file look-up overhead. Very similar to the sigtimedwait4() call described by Niels Provos, Chuck Lever, and Stephen Tweedie in a paper entitled "Analyzing the Overload Behavior of a Simple Web Server". The paper lists more details and advantages. Signed-off-by: Davi E. M. Arnaut <davi@haxent.com.br> Acked-by: Davide Libenzi <davidel@xmailserver.org> Cc: Oleg Nesterov <oleg@tv-sign.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11signal/timer/event: signalfd coreDavide Libenzi
This patch series implements the new signalfd() system call. I took part of the original Linus code (and you know how badly it can be broken :), and I added even more breakage ;) Signals are fetched from the same signal queue used by the process, so signalfd will compete with standard kernel delivery in dequeue_signal(). If you want to reliably fetch signals on the signalfd file, you need to block them with sigprocmask(SIG_BLOCK). This seems to be working fine on my Dual Opteron machine. I made a quick test program for it: http://www.xmailserver.org/signafd-test.c The signalfd() system call implements signal delivery into a file descriptor receiver. The signalfd file descriptor if created with the following API: int signalfd(int ufd, const sigset_t *mask, size_t masksize); The "ufd" parameter allows to change an existing signalfd sigmask, w/out going to close/create cycle (Linus idea). Use "ufd" == -1 if you want a brand new signalfd file. The "mask" allows to specify the signal mask of signals that we are interested in. The "masksize" parameter is the size of "mask". The signalfd fd supports the poll(2) and read(2) system calls. The poll(2) will return POLLIN when signals are available to be dequeued. As a direct consequence of supporting the Linux poll subsystem, the signalfd fd can use used together with epoll(2) too. The read(2) system call will return a "struct signalfd_siginfo" structure in the userspace supplied buffer. The return value is the number of bytes copied in the supplied buffer, or -1 in case of error. The read(2) call can also return 0, in case the sighand structure to which the signalfd was attached, has been orphaned. The O_NONBLOCK flag is also supported, and read(2) will return -EAGAIN in case no signal is available. If the size of the buffer passed to read(2) is lower than sizeof(struct signalfd_siginfo), -EINVAL is returned. A read from the signalfd can also return -ERESTARTSYS in case a signal hits the process. The format of the struct signalfd_siginfo is, and the valid fields depends of the (->code & __SI_MASK) value, in the same way a struct siginfo would: struct signalfd_siginfo { __u32 signo; /* si_signo */ __s32 err; /* si_errno */ __s32 code; /* si_code */ __u32 pid; /* si_pid */ __u32 uid; /* si_uid */ __s32 fd; /* si_fd */ __u32 tid; /* si_fd */ __u32 band; /* si_band */ __u32 overrun; /* si_overrun */ __u32 trapno; /* si_trapno */ __s32 status; /* si_status */ __s32 svint; /* si_int */ __u64 svptr; /* si_ptr */ __u64 utime; /* si_utime */ __u64 stime; /* si_stime */ __u64 addr; /* si_addr */ }; [akpm@linux-foundation.org: fix signalfd_copyinfo() on i386] Signed-off-by: Davide Libenzi <davidel@xmailserver.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
