commit 894c6350eaad7e613ae267504014a456e00a3e2a from the 3.2-stable branch.
We need to check the position and size of file writes against various
limits, using generic_write_check(). This was not being done for
the splice write path. It was fixed upstream by commit 8d0207652cbe
("->splice_write() via ->write_iter()") but we can't apply that.
CVE-2014-7822
Cc: Vinson Lee <vlee@twopensource.com>
Having this struct in module memory could Oops when if the module is
unloaded while the buffer still persists in a pipe.
Since sock_pipe_buf_ops is essentially the same as fuse_dev_pipe_buf_steal
merge them into nosteal_pipe_buf_ops (this is the same as
default_pipe_buf_ops except stealing the page from the buffer is not
allowed).
Reported-by: Al Viro <viro@zeniv.linux.org.uk>
Signed-off-by: Miklos Szeredi <mszeredi@suse.cz>
Cc: stable@vger.kernel.org
Pull second set of VFS changes from Al Viro:
"Assorted f_pos race fixes, making do_splice_direct() safe to call with
i_mutex on parent, O_TMPFILE support, Jeff's locks.c series,
->d_hash/->d_compare calling conventions changes from Linus, misc
stuff all over the place."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (63 commits)
Document ->tmpfile()
ext4: ->tmpfile() support
vfs: export lseek_execute() to modules
lseek_execute() doesn't need an inode passed to it
block_dev: switch to fixed_size_llseek()
cpqphp_sysfs: switch to fixed_size_llseek()
tile-srom: switch to fixed_size_llseek()
proc_powerpc: switch to fixed_size_llseek()
ubi/cdev: switch to fixed_size_llseek()
pci/proc: switch to fixed_size_llseek()
isapnp: switch to fixed_size_llseek()
lpfc: switch to fixed_size_llseek()
locks: give the blocked_hash its own spinlock
locks: add a new "lm_owner_key" lock operation
locks: turn the blocked_list into a hashtable
locks: convert fl_link to a hlist_node
locks: avoid taking global lock if possible when waking up blocked waiters
locks: protect most of the file_lock handling with i_lock
locks: encapsulate the fl_link list handling
locks: make "added" in __posix_lock_file a bool
Fix new kernel-doc warning in fs/splice.c:
Warning(fs/splice.c:1298): No description found for parameter 'opos'
Pull VFS updates from Al Viro,
Misc cleanups all over the place, mainly wrt /proc interfaces (switch
create_proc_entry to proc_create(), get rid of the deprecated
create_proc_read_entry() in favor of using proc_create_data() and
seq_file etc).
7kloc removed.
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (204 commits)
don't bother with deferred freeing of fdtables
proc: Move non-public stuff from linux/proc_fs.h to fs/proc/internal.h
proc: Make the PROC_I() and PDE() macros internal to procfs
proc: Supply a function to remove a proc entry by PDE
take cgroup_open() and cpuset_open() to fs/proc/base.c
ppc: Clean up scanlog
ppc: Clean up rtas_flash driver somewhat
hostap: proc: Use remove_proc_subtree()
drm: proc: Use remove_proc_subtree()
drm: proc: Use minor->index to label things, not PDE->name
drm: Constify drm_proc_list[]
zoran: Don't print proc_dir_entry data in debug
reiserfs: Don't access the proc_dir_entry in r_open(), r_start() r_show()
proc: Supply an accessor for getting the data from a PDE's parent
airo: Use remove_proc_subtree()
rtl8192u: Don't need to save device proc dir PDE
rtl8187se: Use a dir under /proc/net/r8180/
proc: Add proc_mkdir_data()
proc: Move some bits from linux/proc_fs.h to linux/{of.h,signal.h,tty.h}
proc: Move PDE_NET() to fs/proc/proc_net.c
git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal
Pull compat cleanup from Al Viro:
"Mostly about syscall wrappers this time; there will be another pile
with patches in the same general area from various people, but I'd
rather push those after both that and vfs.git pile are in."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/signal:
syscalls.h: slightly reduce the jungles of macros
get rid of union semop in sys_semctl(2) arguments
make do_mremap() static
sparc: no need to sign-extend in sync_file_range() wrapper
ppc compat wrappers for add_key(2) and request_key(2) are pointless
x86: trim sys_ia32.h
x86: sys32_kill and sys32_mprotect are pointless
get rid of compat_sys_semctl() and friends in case of ARCH_WANT_OLD_COMPAT_IPC
merge compat sys_ipc instances
consolidate compat lookup_dcookie()
convert vmsplice to COMPAT_SYSCALL_DEFINE
switch getrusage() to COMPAT_SYSCALL_DEFINE
switch epoll_pwait to COMPAT_SYSCALL_DEFINE
convert sendfile{,64} to COMPAT_SYSCALL_DEFINE
switch signalfd{,4}() to COMPAT_SYSCALL_DEFINE
make SYSCALL_DEFINE<n>-generated wrappers do asmlinkage_protect
make HAVE_SYSCALL_WRAPPERS unconditional
consolidate cond_syscall and SYSCALL_ALIAS declarations
teach SYSCALL_DEFINE<n> how to deal with long long/unsigned long long
get rid of duplicate logics in __SC_....[1-6] definitions
not used anymore
it's used only as a flag to distinguish normal pipes/FIFOs from the
internal per-task one used by file-to-file splice. And pipe->files
would work just as well for that purpose...
default_file_splice_from() ends up calling vfs_write() (via very convoluted
callchain). It's an overkill, since we already have done rw_verify_area()
in the caller by the time we call vfs_write() we are under set_fs(KERNEL_DS),
so access_ok() is also pointless. Add a new helper (__kernel_write()),
use it instead of kernel_write() in there.
commit 35f9c09fe9c72e (tcp: tcp_sendpages() should call tcp_push() once)
added an internal flag : MSG_SENDPAGE_NOTLAST meant to be set on all
frags but the last one for a splice() call.
The condition used to set the flag in pipe_to_sendpage() relied on
splice() user passing the exact number of bytes present in the pipe,
or a smaller one.
But some programs pass an arbitrary high value, and the test fails.
The effect of this bug is a lack of tcp_push() at the end of a
splice(pipe -> socket) call, and possibly very slow or erratic TCP
sessions.
We should both test sd->total_len and fact that another fragment
is in the pipe (pipe->nrbufs > 1)
Many thanks to Willy for providing very clear bug report, bisection
and test programs.
Reported-by: Willy Tarreau <w@1wt.eu>
Bisected-by: Willy Tarreau <w@1wt.eu>
Tested-by: Willy Tarreau <w@1wt.eu>
There is no reason to pass the nr_pages_dirtied argument, because
nr_pages_dirtied value from the caller is unused in
balance_dirty_pages_ratelimited_nr().
Signed-off-by: Namjae Jeon <linkinjeon@gmail.com>
Signed-off-by: Vivek Trivedi <vtrivedi018@gmail.com>
Cc: Wu Fengguang <fengguang.wu@intel.com>
There are several entry points which dirty pages in a filesystem. mmap
(handled by block_page_mkwrite()), buffered write (handled by
__generic_file_aio_write()), splice write (generic_file_splice_write),
truncate, and fallocate (these can dirty last partial page - handled inside
each filesystem separately). Protect these places with sb_start_write() and
sb_end_write().
->page_mkwrite() calls are particularly complex since they are called with
mmap_sem held and thus we cannot use standard sb_start_write() due to lock
ordering constraints. We solve the problem by using a special freeze protection
sb_start_pagefault() which ranks below mmap_sem.
BugLink: https://bugs.launchpad.net/bugs/897421
Tested-by: Kamal Mostafa <kamal@canonical.com>
Tested-by: Peter M. Petrakis <peter.petrakis@canonical.com>
Tested-by: Dann Frazier <dann.frazier@canonical.com>
Tested-by: Massimo Morana <massimo.morana@canonical.com>
Dave Jones reported a kernel BUG at mm/slub.c:3474! triggered
by splice_shrink_spd() called from vmsplice_to_pipe()
commit 35f3d14dbbc5 (pipe: add support for shrinking and growing pipes)
added capability to adjust pipe->buffers.
Problem is some paths don't hold pipe mutex and assume pipe->buffers
doesn't change for their duration.
Fix this by adding nr_pages_max field in struct splice_pipe_desc, and
use it in place of pipe->buffers where appropriate.
splice_shrink_spd() loses its struct pipe_inode_info argument.
Reported-by: Dave Jones <davej@redhat.com>
Cc: Tom Herbert <therbert@google.com>
Cc: stable <stable@vger.kernel.org> # 2.6.35
Tested-by: Dave Jones <davej@redhat.com>
Pull vfs changes from Al Viro.
"A lot of misc stuff. The obvious groups:
* Miklos' atomic_open series; kills the damn abuse of
->d_revalidate() by NFS, which was the major stumbling block for
all work in that area.
* ripping security_file_mmap() and dealing with deadlocks in the
area; sanitizing the neighborhood of vm_mmap()/vm_munmap() in
general.
* ->encode_fh() switched to saner API; insane fake dentry in
mm/cleancache.c gone.
* assorted annotations in fs (endianness, __user)
* parts of Artem's ->s_dirty work (jff2 and reiserfs parts)
* ->update_time() work from Josef.
* other bits and pieces all over the place.
Normally it would've been in two or three pull requests, but
signal.git stuff had eaten a lot of time during this cycle ;-/"
Fix up trivial conflicts in Documentation/filesystems/vfs.txt (the
'truncate_range' inode method was removed by the VM changes, the VFS
update adds an 'update_time()' method), and in fs/btrfs/ulist.[ch] (due
to sparse fix added twice, with other changes nearby).
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (95 commits)
nfs: don't open in ->d_revalidate
vfs: retry last component if opening stale dentry
vfs: nameidata_to_filp(): don't throw away file on error
vfs: nameidata_to_filp(): inline __dentry_open()
vfs: do_dentry_open(): don't put filp
vfs: split __dentry_open()
vfs: do_last() common post lookup
vfs: do_last(): add audit_inode before open
vfs: do_last(): only return EISDIR for O_CREAT
vfs: do_last(): check LOOKUP_DIRECTORY
vfs: do_last(): make ENOENT exit RCU safe
vfs: make follow_link check RCU safe
vfs: do_last(): use inode variable
vfs: do_last(): inline walk_component()
vfs: do_last(): make exit RCU safe
vfs: split do_lookup()
Btrfs: move over to use ->update_time
fs: introduce inode operation ->update_time
reiserfs: get rid of resierfs_sync_super
reiserfs: mark the superblock as dirty a bit later
Btrfs has to make sure we have space to allocate new blocks in order to modify
the inode, so updating time can fail. We've gotten around this by having our
own file_update_time but this is kind of a pain, and Christoph has indicated he
would like to make xfs do something different with atime updates. So introduce
->update_time, where we will deal with i_version an a/m/c time updates and
indicate which changes need to be made. The normal version just does what it
has always done, updates the time and marks the inode dirty, and then
filesystems can choose to do something different.
I've gone through all of the users of file_update_time and made them check for
errors with the exception of the fault code since it's complicated and I wasn't
quite sure what to do there, also Jan is going to be pushing the file time
updates into page_mkwrite for those who have it so that should satisfy btrfs and
make it not a big deal to check the file_update_time() return code in the
generic fault path. Thanks,
Signed-off-by: Josef Bacik <josef@redhat.com>
The core branch is behind driver commits that we want to build
on for 3.5, hence I'm pulling in a later -rc.
Linux 3.4-rc5
Documentation/feature-removal-schedule.txt
It seems there is no fundamental reason to limit vmsplice()
SPLICE_F_GIFT to page aligned chunks.
All helpers are prepared to cope with offsets in page.
This limitation makes vmsplice() API very impractical in the zero-copy
land.
Cc: Changli Gao <xiaosuo@gmail.com>
Cc: Miklos Szeredi <mszeredi@suse.cz>
commit 2f533844242 (tcp: allow splice() to build full TSO packets) added
a regression for splice() calls using SPLICE_F_MORE.
We need to call tcp_flush() at the end of the last page processed in
tcp_sendpages(), or else transmits can be deferred and future sends
stall.
Add a new internal flag, MSG_SENDPAGE_NOTLAST, acting like MSG_MORE, but
with different semantic.
For all sendpage() providers, its a transparent change. Only
sock_sendpage() and tcp_sendpages() can differentiate the two different
flags provided by pipe_to_sendpage()
Reported-by: Tom Herbert <therbert@google.com>
Cc: Nandita Dukkipati <nanditad@google.com>
Cc: Neal Cardwell <ncardwell@google.com>
Cc: Yuchung Cheng <ycheng@google.com>
Cc: H.K. Jerry Chu <hkchu@google.com>
Cc: Maciej Żenczykowski <maze@google.com>
Cc: Mahesh Bandewar <maheshb@google.com>
Cc: Ilpo Järvinen <ilpo.jarvinen@helsinki.fi>
Signed-off-by: Eric Dumazet <eric.dumazet@gmail>com>
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux
Pull cleanup of fs/ and lib/ users of module.h from Paul Gortmaker:
"Fix up files in fs/ and lib/ dirs to only use module.h if they really
need it.
These are trivial in scope vs the work done previously. We now have
things where any few remaining cleanups can be farmed out to arch or
subsystem maintainers, and I have done so when possible. What is
remaining here represents the bits that don't clearly lie within a
single arch/subsystem boundary, like the fs dir and the lib dir.
Some duplicate includes arising from overlapping fixes from
independent subsystem maintainer submissions are also quashed."
Fix up trivial conflicts due to clashes with other include file cleanups
(including some due to the previous bug.h cleanup pull).
* tag 'module-for-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux:
lib: reduce the use of module.h wherever possible
fs: reduce the use of module.h wherever possible
includecheck: delete any duplicate instances of module.h
Acked-by: Benjamin LaHaise <bcrl@kvack.org>
Signed-off-by: Cong Wang <amwang@redhat.com>
For files only using THIS_MODULE and/or EXPORT_SYMBOL, map
them onto including export.h -- or if the file isn't even
using those, then just delete the include. Fix up any implicit
include dependencies that were being masked by module.h along
the way.
Move invalidate_bdev, block_sync_page into fs/block_dev.c. Export
kill_bdev as well, so brd doesn't have to open code it. Reduce
buffer_head.h requirement accordingly.
Removed a rather large comment from invalidate_bdev, as it looked a bit
obsolete to bother moving. The small comment replacing it says enough.
Signed-off-by: Nick Piggin <npiggin@suse.de>
Cc: Al Viro <viro@ZenIV.linux.org.uk>
Copy __generic_file_splice_read() and generic_file_splice_read() from
fs/splice.c to shmem_file_splice_read() in mm/shmem.c. Make
page_cache_pipe_buf_ops and spd_release_page() accessible to it.
Cc: Jens Axboe <jaxboe@fusionio.com>
Add and use wakeup_pipe_readers() to consolidate duplicated codes.
Signed-off-by: Namhyung Kim <namhyung@gmail.com>
Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
* 'for-2.6.38/core' of git://git.kernel.dk/linux-2.6-block: (43 commits)
block: ensure that completion error gets properly traced
blktrace: add missing probe argument to block_bio_complete
block cfq: don't use atomic_t for cfq_group
block cfq: don't use atomic_t for cfq_queue
block: trace event block fix unassigned field
block: add internal hd part table references
block: fix accounting bug on cross partition merges
kref: add kref_test_and_get
bio-integrity: mark kintegrityd_wq highpri and CPU intensive
block: make kblockd_workqueue smarter
Revert "sd: implement sd_check_events()"
block: Clean up exit_io_context() source code.
Fix compile warnings due to missing removal of a 'ret' variable
fs/block: type signature of major_to_index(int) to major_to_index(unsigned)
block: convert !IS_ERR(p) && p to !IS_ERR_NOR_NULL(p)
cfq-iosched: don't check cfqg in choose_service_tree()
fs/splice: Pull buf->ops->confirm() from splice_from_pipe actors
cdrom: export cdrom_check_events()
sr: implement sr_check_events()
This patch pulls calls to buf->ops->confirm() from all actors passed
(also indirectly) to splice_from_pipe_feed().
Is avoiding the call to buf->ops->confirm() while splice()ing to
/dev/null is an intentional optimization? No other user does that
and this will remove this special case.
Against current linux.git 6313e3c21743cc88bb5bd8aa72948ee1e83937b6.
Signed-off-by: Michał Mirosław <mirq-linux@rere.qmqm.pl>
And in particular, use it in 'pipe_fcntl()'.
The other pipe functions do not need to use the 'careful' version, since
they are only ever called for things that are already known to be pipes.
The normal read/write/ioctl functions are called through the file
operations structures, so if a file isn't a pipe, they'd never get
called. But pipe_fcntl() is special, and called directly from the
generic fcntl code, and needs to use the same careful function that the
splice code is using.
Cc: Dave Jones <davej@redhat.com>
.. and change it to take the 'file' pointer instead of an inode, since
that's what all users want anyway.
The renaming is preparatory to exporting it to other users. The old
'pipe_info()' name was too generic and is already used elsewhere, so
before making the function public we need to use a more specific name.
SPLICE_F_NONBLOCK is clearly documented to only affect blocking on the
pipe. In __generic_file_splice_read(), however, it causes an EAGAIN
if the page is currently being read.
This makes it impossible to write an application that only wants
failure if the pipe is full. For example if the same process is
handling both ends of a pipe and isn't otherwise able to determine
whether a splice to the pipe will fill it or not.
We could make the read non-blocking on O_NONBLOCK or some other splice
flag, but for now this is the simplest fix.
CC: stable@kernel.org
No real bugs I believe, just some dead code, and some
shut up code.
Cc: Eric Paris <eparis@redhat.com>
check f_mode for seekable file
As a seekable file is allowed without a llseek function, so the old way isn't
work any more.
Signed-off-by: Changli Gao <xiaosuo@gmail.com>
fs/splice.c | 6 ++----
1 file changed, 2 insertions(+), 4 deletions(-)
direct_splice_actor() shouldn't use sd->pos, as sd->pos is for file reading,
file->f_pos should be used instead.
fs/splice.c | 3 ++-
1 file changed, 2 insertions(+), 1 deletion(-)
mapping_gfp_mask() is not supposed to store allocation contex details,
only page location details. So mapping_gfp_mask should be applied to the
pagecache page allocation, wheras normal (kernel mapped) memory should be
used for surrounding allocations such as radix-tree nodes allocated by
add_to_page_cache. Context modifiers should be applied on a per-callsite
basis.
So change splice to follow this convention (which is followed in similar
code patterns in core code).
This patch adds F_GETPIPE_SZ and F_SETPIPE_SZ fcntl() actions for
growing and shrinking the size of a pipe and adjusts pipe.c and splice.c
(and relay and network splice) usage to work with these larger (or smaller)
pipes.
file.
files.
necessary.
* ia64 SMP allmodconfig
* s390 SMP allmodconfig
* alpha SMP allmodconfig
the specific arch.
sendfile(2) was reworked with the splice infrastructure, but it still
checks f_op.sendpage() instead of f_op.splice_write() wrongly. Although
if f_op.sendpage() exists, f_op.splice_write() always exists at the same
time currently, the assumption will be broken in future silently. This
patch also brings a side effect: sendfile(2) can work with any output
file. Some security checks related to f_op are added too.
* 'for-2.6.32' of git://git.kernel.dk/linux-2.6-block: (29 commits)
block: use blkdev_issue_discard in blk_ioctl_discard
Make DISCARD_BARRIER and DISCARD_NOBARRIER writes instead of reads
block: don't assume device has a request list backing in nr_requests store
block: Optimal I/O limit wrapper
cfq: choose a new next_req when a request is dispatched
Seperate read and write statistics of in_flight requests
aoe: end barrier bios with EOPNOTSUPP
block: trace bio queueing trial only when it occurs
block: enable rq CPU completion affinity by default
cfq: fix the log message after dispatched a request
block: use printk_once
cciss: memory leak in cciss_init_one()
splice: update mtime and atime on files
block: make blk_iopoll_prep_sched() follow normal 0/1 return convention
cfq-iosched: get rid of must_alloc flag
block: use interrupts disabled version of raise_softirq_irqoff()
block: fix comment in blk-iopoll.c
block: adjust default budget for blk-iopoll
block: fix long lines in block/blk-iopoll.c
block: add blk-iopoll, a NAPI like approach for block devices
IS_SYNC inode
Introduce new function for generic inode syncing (vfs_fsync_range) and use
it from fsync() path. Introduce also new helper for syncing after a sync
write (generic_write_sync) using the generic function.
Use these new helpers for syncing from generic VFS functions. This makes
O_SYNC writes to block devices acquire i_mutex for syncing. If we really
care about this, we can make block_fsync() drop the i_mutex and reacquire
it before it returns.
CC: Evgeniy Polyakov <zbr@ioremap.net>
CC: ocfs2-devel@oss.oracle.com
CC: Joel Becker <joel.becker@oracle.com>
CC: Felix Blyakher <felixb@sgi.com>
CC: xfs@oss.sgi.com
CC: Anton Altaparmakov <aia21@cantab.net>
CC: linux-ntfs-dev@lists.sourceforge.net
CC: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp>
CC: linux-ext4@vger.kernel.org
CC: tytso@mit.edu
Acked-by: Christoph Hellwig <hch@lst.de>
