path: root/fs/squashfs/Makefile
2011-07-22Squashfs: Make ZLIB compression support optionalPhillip Lougher
Squashfs now supports XZ and LZO compression in addition to ZLIB. As such it no longer makes sense to always include ZLIB support. In particular embedded systems may only use LZO or XZ compression, and the ability to exclude ZLIB support will reduce kernel size. Signed-off-by: Phillip Lougher <phillip@squashfs.org.uk>
2011-01-13Squashfs: Add XZ compression configuration optionPhillip Lougher
Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk>
2010-08-05Squashfs: Add LZO compression supportChan Jeong
Signed-off-by: Chan Jeong <chan.jeong@lge.com> Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk>
2010-05-31Squashfs: Make XATTR config name consistent with other file systemsPhillip Lougher
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk>
2010-05-17squashfs: add xattr support configure optionPhillip Lougher
2010-05-17squashfs: add support for xattr readingPhillip Lougher
Add support for listxattr and getxattr. Also add xattr definitions. Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk>
2010-05-17squashfs: add xattr id supportPhillip Lougher
This patch adds support for mapping xattr ids (stored in inodes) into the on-disk location of the xattrs themselves. Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk>
2010-01-20Squashfs: add a decompressor frameworkPhillip Lougher
This adds a decompressor framework which allows multiple compression algorithms to be cleanly supported. Also update zlib wrapper and other code to use the new framework. Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk>
2010-01-20Squashfs: move zlib decompression wrapper code into a separate filePhillip Lougher
2009-05-13Squashfs: cody tidying, remove commented out line in MakefilePhillip Lougher
2009-01-05Squashfs: MakefilesPhillip Lougher
