path: root/fs/squashfs/xattr.h
2011-05-26Squashfs: update email addressPhillip Lougher
My existing email address may stop working in a month or two, so update email to one that will continue working. Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk>
2011-05-25Squashfs: add sanity checks to id reading at mount timePhillip Lougher
Fsfuzzer generates corrupted filesystems which throw a warn_on in kmalloc. One of these is due to a corrupted superblock no_ids field. Fix this by checking that the number of bytes to be read (and allocated) does not extend into the next filesystem structure. Also add a couple of other sanity checks of the mount-time id table structures. Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk>
2010-10-28Squashfs: fix function prototypePhillip Lougher
The fourth argument should be unsigned. Also add missing include so that the function prototype is defined in xattr_id.c This fixes a couple of sparse warnings. Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk>
2010-05-31Squashfs: Make XATTR config name consistent with other file systemsPhillip Lougher
Reported-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk>
2010-05-17squashfs: xattr_lookup sparse fixStephen Hemminger
Sparse detected that unsigned pointer was being passed as int pointer. Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> [fixed up to deal with code refactoring] Signed-off-by: Phillip Lougher <phillip@lougher.demon.co.uk>
2010-05-17squashfs: add xattr support configure optionPhillip Lougher
