path: root/fs/squashfs
2016-10-07vfs: Remove {get,set,remove}xattr inode operationsAndreas Gruenbacher
These inode operations are no longer used; remove them. Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-06-07fs: have ll_rw_block users pass in op and flags separatelyMike Christie
This has ll_rw_block users pass in the operation and flags separately, so ll_rw_block can setup the bio op and bi_rw flags on the bio that is submitted. Signed-off-by: Mike Christie <mchristi@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Hannes Reinecke <hare@suse.com> Signed-off-by: Jens Axboe <axboe@fb.com>
2016-05-09romfs, squashfs: switch to ->iterate_shared()Al Viro
don't need to lock directory in ->llseek(), either Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-05-02Merge getxattr prototype change into work.lookupsAl Viro
The rest of work.xattr stuff isn't needed for this branch
2016-04-10xattr_handler: pass dentry and inode as separate arguments of ->get()Al Viro
... and do not assume they are already attached to each other Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2016-04-04mm, fs: remove remaining PAGE_CACHE_* and page_cache_{get,release} usageKirill A. Shutemov
Mostly direct substitution with occasional adjustment or removing outdated comments. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Michal Hocko <mhocko@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-04-04mm, fs: get rid of PAGE_CACHE_* and page_cache_{get,release} macrosKirill A. Shutemov
PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} macros were introduced *long* time ago with promise that one day it will be possible to implement page cache with bigger chunks than PAGE_SIZE. This promise never materialized. And unlikely will. We have many places where PAGE_CACHE_SIZE assumed to be equal to PAGE_SIZE. And it's constant source of confusion on whether PAGE_CACHE_* or PAGE_* constant should be used in a particular case, especially on the border between fs and mm. Global switching to PAGE_CACHE_SIZE != PAGE_SIZE would cause to much breakage to be doable. Let's stop pretending that pages in page cache are special. They are not. The changes are pretty straight-forward: - <foo> << (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>; - <foo> >> (PAGE_CACHE_SHIFT - PAGE_SHIFT) -> <foo>; - PAGE_CACHE_{SIZE,SHIFT,MASK,ALIGN} -> PAGE_{SIZE,SHIFT,MASK,ALIGN}; - page_cache_get() -> get_page(); - page_cache_release() -> put_page(); This patch contains automated changes generated with coccinelle using script below. For some reason, coccinelle doesn't patch header files. I've called spatch for them manually. The only adjustment after coccinelle is revert of changes to PAGE_CAHCE_ALIGN definition: we are going to drop it later. There are few places in the code where coccinelle didn't reach. I'll fix them manually in a separate patch. Comments and documentation also will be addressed with the separate patch. virtual patch @@ expression E; @@ - E << (PAGE_CACHE_SHIFT - PAGE_SHIFT) + E @@ expression E; @@ - E >> (PAGE_CACHE_SHIFT - PAGE_SHIFT) + E @@ @@ - PAGE_CACHE_SHIFT + PAGE_SHIFT @@ @@ - PAGE_CACHE_SIZE + PAGE_SIZE @@ @@ - PAGE_CACHE_MASK + PAGE_MASK @@ expression E; @@ - PAGE_CACHE_ALIGN(E) + PAGE_ALIGN(E) @@ expression E; @@ - page_cache_get(E) + get_page(E) @@ expression E; @@ - page_cache_release(E) + put_page(E) Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Acked-by: Michal Hocko <mhocko@suse.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-14kmemcg: account certain kmem allocations to memcgVladimir Davydov
Mark those kmem allocations that are known to be easily triggered from userspace as __GFP_ACCOUNT/SLAB_ACCOUNT, which makes them accounted to memcg. For the list, see below: - threadinfo - task_struct - task_delay_info - pid - cred - mm_struct - vm_area_struct and vm_region (nommu) - anon_vma and anon_vma_chain - signal_struct - sighand_struct - fs_struct - files_struct - fdtable and fdtable->full_fds_bits - dentry and external_name - inode for all filesystems. This is the most tedious part, because most filesystems overwrite the alloc_inode method. The list is far from complete, so feel free to add more objects. Nevertheless, it should be close to "account everything" approach and keep most workloads within bounds. Malevolent users will be able to breach the limit, but this was possible even with the former "account everything" approach (simply because it did not account everything in fact). [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Vladimir Davydov <vdavydov@virtuozzo.com> Acked-by: Johannes Weiner <hannes@cmpxchg.org> Acked-by: Michal Hocko <mhocko@suse.com> Cc: Tejun Heo <tj@kernel.org> Cc: Greg Thelen <gthelen@google.com> Cc: Christoph Lameter <cl@linux.com> Cc: Pekka Enberg <penberg@kernel.org> Cc: David Rientjes <rientjes@google.com> Cc: Joonsoo Kim <iamjoonsoo.kim@lge.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-01-12Merge branch 'work.misc' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull misc vfs updates from Al Viro: "All kinds of stuff. That probably should've been 5 or 6 separate branches, but by the time I'd realized how large and mixed that bag had become it had been too close to -final to play with rebasing. Some fs/namei.c cleanups there, memdup_user_nul() introduction and switching open-coded instances, burying long-dead code, whack-a-mole of various kinds, several new helpers for ->llseek(), assorted cleanups and fixes from various people, etc. One piece probably deserves special mention - Neil's lookup_one_len_unlocked(). Similar to lookup_one_len(), but gets called without ->i_mutex and tries to avoid ever taking it. That, of course, means that it's not useful for any directory modifications, but things like getting inode attributes in nfds readdirplus are fine with that. I really should've asked for moratorium on lookup-related changes this cycle, but since I hadn't done that early enough... I *am* asking for that for the coming cycle, though - I'm going to try and get conversion of i_mutex to rwsem with ->lookup() done under lock taken shared. There will be a patch closer to the end of the window, along the lines of the one Linus had posted last May - mechanical conversion of ->i_mutex accesses to inode_lock()/inode_unlock()/inode_trylock()/ inode_is_locked()/inode_lock_nested(). To quote Linus back then: ----- | This is an automated patch using | | sed 's/mutex_lock(&\(.*\)->i_mutex)/inode_lock(\1)/' | sed 's/mutex_unlock(&\(.*\)->i_mutex)/inode_unlock(\1)/' | sed 's/mutex_lock_nested(&\(.*\)->i_mutex,[ ]*I_MUTEX_\([A-Z0-9_]*\))/inode_lock_nested(\1, I_MUTEX_\2)/' | sed 's/mutex_is_locked(&\(.*\)->i_mutex)/inode_is_locked(\1)/' | sed 's/mutex_trylock(&\(.*\)->i_mutex)/inode_trylock(\1)/' | | with a very few manual fixups ----- I'm going to send that once the ->i_mutex-affecting stuff in -next gets mostly merged (or when Linus says he's about to stop taking merges)" * 'work.misc' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (63 commits) nfsd: don't hold i_mutex over userspace upcalls fs:affs:Replace time_t with time64_t fs/9p: use fscache mutex rather than spinlock proc: add a reschedule point in proc_readfd_common() logfs: constify logfs_block_ops structures fcntl: allow to set O_DIRECT flag on pipe fs: __generic_file_splice_read retry lookup on AOP_TRUNCATED_PAGE fs: xattr: Use kvfree() [s390] page_to_phys() always returns a multiple of PAGE_SIZE nbd: use ->compat_ioctl() fs: use block_device name vsprintf helper lib/vsprintf: add %*pg format specifier fs: use gendisk->disk_name where possible poll: plug an unused argument to do_poll amdkfd: don't open-code memdup_user() cdrom: don't open-code memdup_user() rsxx: don't open-code memdup_user() mtip32xx: don't open-code memdup_user() [um] mconsole: don't open-code memdup_user_nul() [um] hostaudio: don't open-code memdup_user() ...
2016-01-11Merge branch 'work.xattr' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs xattr updates from Al Viro: "Andreas' xattr cleanup series. It's a followup to his xattr work that went in last cycle; -0.5KLoC" * 'work.xattr' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: xattr handlers: Simplify list operation ocfs2: Replace list xattr handler operations nfs: Move call to security_inode_listsecurity into nfs_listxattr xfs: Change how listxattr generates synthetic attributes tmpfs: listxattr should include POSIX ACL xattrs tmpfs: Use xattr handler infrastructure btrfs: Use xattr handler infrastructure vfs: Distinguish between full xattr names and proper prefixes posix acls: Remove duplicate xattr name definitions gfs2: Remove gfs2_xattr_acl_chmod vfs: Remove vfs_xattr_cmp
2016-01-06fs: use block_device name vsprintf helperDmitry Monakhov
Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-12-30switch ->get_link() to delayed_call, kill ->put_link()Al Viro
2015-12-13xattr handlers: Simplify list operationAndreas Gruenbacher
Change the list operation to only return whether or not an attribute should be listed. Copying the attribute names into the buffer is moved to the callers. Since the result only depends on the dentry and not on the attribute name, we do not pass the attribute name to list operations. Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-12-08replace ->follow_link() with new method that could stay in RCU modeAl Viro
new method: ->get_link(); replacement of ->follow_link(). The differences are: * inode and dentry are passed separately * might be called both in RCU and non-RCU mode; the former is indicated by passing it a NULL dentry. * when called that way it isn't allowed to block and should return ERR_PTR(-ECHILD) if it needs to be called in non-RCU mode. It's a flagday change - the old method is gone, all in-tree instances converted. Conversion isn't hard; said that, so far very few instances do not immediately bail out when called in RCU mode. That'll change in the next commits. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-12-08don't put symlink bodies in pagecache into highmemAl Viro
kmap() in page_follow_link_light() needed to go - allowing to hold an arbitrary number of kmaps for long is a great way to deadlocking the system. new helper (inode_nohighmem(inode)) needs to be used for pagecache symlinks inodes; done for all in-tree cases. page_follow_link_light() instrumented to yell about anything missed. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-12-06vfs: Distinguish between full xattr names and proper prefixesAndreas Gruenbacher
Add an additional "name" field to struct xattr_handler. When the name is set, the handler matches attributes with exactly that name. When the prefix is set instead, the handler matches attributes with the given prefix and with a non-empty suffix. This patch should avoid bugs like the one fixed in commit c361016a in the future. Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com> Reviewed-by: James Morris <james.l.morris@oracle.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-11-13squashfs: xattr simplificationsAndreas Gruenbacher
Now that the xattr handler is passed to the xattr handler operations, we have access to the attribute name prefix, so simplify the squashfs xattr handlers a bit. Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com> Cc: Phillip Lougher <phillip@squashfs.org.uk> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-11-13xattr handlers: Pass handler to operations instead of flagsAndreas Gruenbacher
The xattr_handler operations are currently all passed a file system specific flags value which the operations can use to disambiguate between different handlers; some file systems use that to distinguish the xattr namespace, for example. In some oprations, it would be useful to also have access to the handler prefix. To allow that, pass a pointer to the handler to operations instead of the flags value alone. Signed-off-by: Andreas Gruenbacher <agruenba@redhat.com> Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-06-23fs: cleanup slight list_entry abuseRasmus Villemoes
list_entry is just a wrapper for container_of, but it is arguably wrong (and slightly confusing) to use it when the pointed-to struct member is not a struct list_head. Use container_of directly instead. Signed-off-by: Rasmus Villemoes <linux@rasmusvillemoes.dk> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2015-04-15VFS: normal filesystems (and lustre): d_inode() annotationsDavid Howells
that's the bulk of filesystem drivers dealing with inodes of their own Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2014-11-27Squashfs: Add LZ4 compression configuration optionPhillip Lougher
Add the glue code, and also update the documentation. Signed-off-by: Phillip Lougher <phillip@squashfs.org.uk>
2014-11-27Squashfs: add LZ4 compression supportPhillip Lougher
Add support for reading file systems compressed with the LZ4 compression algorithm. This patch adds the LZ4 decompressor wrapper code. Signed-off-by: Phillip Lougher <phillip@squashfs.org.uk>
2014-08-06fs/squashfs/super.c: logging cleanupFabian Frederick
- Convert printk to pr_foo() - Add pr_fmt for future logging entries - Coalesce formats Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: Phillip Lougher <phillip@squashfs.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-08-06fs/squashfs/file_direct.c: replace count*size kmalloc by kmalloc_arrayFabian Frederick
kmalloc_array() manages count*sizeof overflow. Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: Phillip Lougher <phillip@squashfs.org.uk> Cc: Joe Perches <joe@perches.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-04fs/squashfs/squashfs.h: replace pr_warning by pr_warnFabian Frederick
Update the last pr_warning callsite in fs branch Signed-off-by: Fabian Frederick <fabf@skynet.be> Cc: Phillip Lougher <phillip@squashfs.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-03-13fs: push sync_filesystem() down to the file system's remount_fs()Theodore Ts'o
Previously, the no-op "mount -o mount /dev/xxx" operation when the file system is already mounted read-write causes an implied, unconditional syncfs(). This seems pretty stupid, and it's certainly documented or guaraunteed to do this, nor is it particularly useful, except in the case where the file system was mounted rw and is getting remounted read-only. However, it's possible that there might be some file systems that are actually depending on this behavior. In most file systems, it's probably fine to only call sync_filesystem() when transitioning from read-write to read-only, and there are some file systems where this is not needed at all (for example, for a pseudo-filesystem or something like romfs). Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Cc: linux-fsdevel@vger.kernel.org Cc: Christoph Hellwig <hch@infradead.org> Cc: Artem Bityutskiy <dedekind1@gmail.com> Cc: Adrian Hunter <adrian.hunter@intel.com> Cc: Evgeniy Dushistov <dushistov@mail.ru> Cc: Jan Kara <jack@suse.cz> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Anders Larsen <al@alarsen.net> Cc: Phillip Lougher <phillip@squashfs.org.uk> Cc: Kees Cook <keescook@chromium.org> Cc: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Cc: Petr Vandrovec <petr@vandrovec.name> Cc: xfs@oss.sgi.com Cc: linux-btrfs@vger.kernel.org Cc: linux-cifs@vger.kernel.org Cc: samba-technical@lists.samba.org Cc: codalist@coda.cs.cmu.edu Cc: linux-ext4@vger.kernel.org Cc: linux-f2fs-devel@lists.sourceforge.net Cc: fuse-devel@lists.sourceforge.net Cc: cluster-devel@redhat.com Cc: linux-mtd@lists.infradead.org Cc: jfs-discussion@lists.sourceforge.net Cc: linux-nfs@vger.kernel.org Cc: linux-nilfs@vger.kernel.org Cc: linux-ntfs-dev@lists.sourceforge.net Cc: ocfs2-devel@oss.oracle.com Cc: reiserfs-devel@vger.kernel.org
2013-11-24Squashfs: fix failure to unlock pages on decompress errorPhillip Lougher
Direct decompression into the page cache. If we fall back to using an intermediate buffer (because we cannot grab all the page cache pages) and we get a decompress fail, we forgot to release the pages. Reported-by: Roman Peniaev <r.peniaev@gmail.com> Signed-off-by: Phillip Lougher <phillip@squashfs.org.uk>
2013-11-20Squashfs: Check stream is not NULL in decompressor_multi.cPhillip Lougher
Fix static checker complaint that stream is not checked in squashfs_decompressor_destroy(). Reported-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Phillip Lougher <phillip@squashfs.org.uk> Reviewed-by: Minchan Kim <minchan@kernel.org>
2013-11-20Squashfs: Directly decompress into the page cache for file dataPhillip Lougher
This introduces an implementation of squashfs_readpage_block() that directly decompresses into the page cache. This uses the previously added page handler abstraction to push down the necessary kmap_atomic/kunmap_atomic operations on the page cache buffers into the decompressors. This enables direct copying into the page cache without using the slow kmap/kunmap calls. The code detects when multiple threads are racing in squashfs_readpage() to decompress the same block, and avoids this regression by falling back to using an intermediate buffer. This patch enhances the performance of Squashfs significantly when multiple processes are accessing the filesystem simultaneously because it not only reduces memcopying, but it more importantly eliminates the lock contention on the intermediate buffer. Using single-thread decompression. dd if=file1 of=/dev/null bs=4096 & dd if=file2 of=/dev/null bs=4096 & dd if=file3 of=/dev/null bs=4096 & dd if=file4 of=/dev/null bs=4096 Before: 629145600 bytes (629 MB) copied, 45.8046 s, 13.7 MB/s After: 629145600 bytes (629 MB) copied, 9.29414 s, 67.7 MB/s Signed-off-by: Phillip Lougher <phillip@squashfs.org.uk> Reviewed-by: Minchan Kim <minchan@kernel.org>
2013-11-20Squashfs: Restructure squashfs_readpage()Phillip Lougher
Restructure squashfs_readpage() splitting it into separate functions for datablocks, fragments and sparse blocks. Move the memcpying (from squashfs cache entry) implementation of squashfs_readpage_block into file_cache.c This allows different implementations to be supported. Signed-off-by: Phillip Lougher <phillip@squashfs.org.uk> Reviewed-by: Minchan Kim <minchan@kernel.org>
2013-11-20Squashfs: Generalise paging handling in the decompressorsPhillip Lougher
Further generalise the decompressors by adding a page handler abstraction. This adds helpers to allow the decompressors to access and process the output buffers in an implementation independant manner. This allows different types of output buffer to be passed to the decompressors, with the implementation specific aspects handled at decompression time, but without the knowledge being held in the decompressor wrapper code. This will allow the decompressors to handle Squashfs cache buffers, and page cache pages. This patch adds the abstraction and an implementation for the caches. Signed-off-by: Phillip Lougher <phillip@squashfs.org.uk> Reviewed-by: Minchan Kim <minchan@kernel.org>
2013-11-20Squashfs: add multi-threaded decompression using percpu variablePhillip Lougher
Add a multi-threaded decompression implementation which uses percpu variables. Using percpu variables has advantages and disadvantages over implementations which do not use percpu variables. Advantages: * the nature of percpu variables ensures decompression is load-balanced across the multiple cores. * simplicity. Disadvantages: it limits decompression to one thread per core. Signed-off-by: Phillip Lougher <phillip@squashfs.org.uk>
2013-11-20squashfs: Enhance parallel I/OMinchan Kim
Now squashfs have used for only one stream buffer for decompression so it hurts parallel read performance so this patch supports multiple decompressor to enhance performance parallel I/O. Four 1G file dd read on KVM machine which has 2 CPU and 4G memory. dd if=test/test1.dat of=/dev/null & dd if=test/test2.dat of=/dev/null & dd if=test/test3.dat of=/dev/null & dd if=test/test4.dat of=/dev/null & old : 1m39s -> new : 9s * From v1 * Change comp_strm with decomp_strm - Phillip * Change/add comments - Phillip Signed-off-by: Minchan Kim <minchan@kernel.org> Signed-off-by: Phillip Lougher <phillip@squashfs.org.uk>
2013-11-20Squashfs: Refactor decompressor interface and codePhillip Lougher
The decompressor interface and code was written from the point of view of single-threaded operation. In doing so it mixed a lot of single-threaded implementation specific aspects into the decompressor code and elsewhere which makes it difficult to seamlessly support multiple different decompressor implementations. This patch does the following: 1. It removes compressor_options parsing from the decompressor init() function. This allows the decompressor init() function to be dynamically called to instantiate multiple decompressors, without the compressor options needing to be read and parsed each time. 2. It moves threading and all sleeping operations out of the decompressors. In doing so, it makes the decompressors non-blocking wrappers which only deal with interfacing with the decompressor implementation. 3. It splits decompressor.[ch] into decompressor generic functions in decompressor.[ch], and moves the single threaded decompressor implementation into decompressor_single.c. The result of this patch is Squashfs should now be able to support multiple decompressors by adding new decompressor_xxx.c files with specialised implementations of the functions in decompressor_single.c Signed-off-by: Phillip Lougher <phillip@squashfs.org.uk> Reviewed-by: Minchan Kim <minchan@kernel.org>
2013-09-06Squashfs: add corruption check for type in squashfs_readdir()Phillip Lougher
We read the type field from disk. This value should be sanity checked for correctness to avoid an out of bounds access when reading the squashfs_filetype_table array. Signed-off-by: Phillip Lougher <phillip@squashfs.org.uk>
2013-09-06Squashfs: add corruption check in get_dir_index_using_offset()Phillip Lougher
We read the size (of the name) field from disk. This value should be sanity checked for correctness to avoid blindly reading huge amounts of unnecessary data from disk on corruption. Note, here we're not actually reading the name into a buffer, but skipping it, and so corruption doesn't cause buffer overflow, merely lots of unnecessary amounts of data to be read. Signed-off-by: Phillip Lougher <phillip@squashfs.org.uk>
2013-09-06Squashfs: fix corruption checks in squashfs_readdir()Phillip Lougher
The dir_count and size fields when read from disk are sanity checked for correctness. However, the sanity checks only check the values are not greater than expected. As dir_count and size were incorrectly defined as signed ints, this can lead to corrupted values appearing as negative which are not trapped. Signed-off-by: Phillip Lougher <phillip@squashfs.org.uk>
2013-09-06Squashfs: fix corruption checks in squashfs_lookup()Phillip Lougher
2013-09-06Squashfs: fix corruption check in get_dir_index_using_name()Phillip Lougher
Patch "Squashfs: sanity check information from disk" from Dan Carpenter adds a missing check for corruption in the "size" field while reading the directory index from disk. It, however, sets err to -EINVAL, this value is not used later, and so setting it is completely redundant. So remove it. Errors in reading the index are deliberately non-fatal. If we get an error in reading the index we just return the part of the index we have managed to read - the index isn't essential, just quicker. Signed-off-by: Phillip Lougher <phillip@squashfs.org.uk>
2013-09-05Squashfs: Optimized uncompressed buffer loopManish Sharma
Merged the two for loops. We might get a little gain by overlapping wait_on_bh and the memcpy operations. Signed-off-by: Manish Sharma <manishrma@gmail.com> Signed-off-by: Phillip Lougher <phillip@squashfs.org.uk>
2013-08-29Squashfs: sanity check information from diskDan Carpenter
We read the size of the name from the disk, but a larger name than expected would cause memory corruption. Signed-off-by: Dan Carpenter <dan.carpenter@oracle.com> Signed-off-by: Phillip Lougher <phillip@squashfs.org.uk>
2013-06-29[readdir] convert squashfsAl Viro
2013-03-11fs: Limit sys_mount to only request filesystem modules. (Part 3)Eric W. Biederman
Somehow I failed to add the MODULE_ALIAS_FS for cifs, hostfs, hpfs, squashfs, and udf despite what I thought were my careful checks :( Add them now. Signed-off-by: "Eric W. Biederman" <ebiederm@xmission.com>
2013-02-22new helper: file_inode(file)Al Viro
2012-10-02Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs update from Al Viro: - big one - consolidation of descriptor-related logics; almost all of that is moved to fs/file.c (BTW, I'm seriously tempted to rename the result to fd.c. As it is, we have a situation when file_table.c is about handling of struct file and file.c is about handling of descriptor tables; the reasons are historical - file_table.c used to be about a static array of struct file we used to have way back). A lot of stray ends got cleaned up and converted to saner primitives, disgusting mess in android/binder.c is still disgusting, but at least doesn't poke so much in descriptor table guts anymore. A bunch of relatively minor races got fixed in process, plus an ext4 struct file leak. - related thing - fget_light() partially unuglified; see fdget() in there (and yes, it generates the code as good as we used to have). - also related - bits of Cyrill's procfs stuff that got entangled into that work; _not_ all of it, just the initial move to fs/proc/fd.c and switch of fdinfo to seq_file. - Alex's fs/coredump.c spiltoff - the same story, had been easier to take that commit than mess with conflicts. The rest is a separate pile, this was just a mechanical code movement. - a few misc patches all over the place. Not all for this cycle, there'll be more (and quite a few currently sit in akpm's tree)." Fix up trivial conflicts in the android binder driver, and some fairly simple conflicts due to two different changes to the sock_alloc_file() interface ("take descriptor handling from sock_alloc_file() to callers" vs "net: Providing protocol type via system.sockprotoname xattr of /proc/PID/fd entries" adding a dentry name to the socket) * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (72 commits) MAX_LFS_FILESIZE should be a loff_t compat: fs: Generic compat_sys_sendfile implementation fs: push rcu_barrier() from deactivate_locked_super() to filesystems btrfs: reada_extent doesn't need kref for refcount coredump: move core dump functionality into its own file coredump: prevent double-free on an error path in core dumper usb/gadget: fix misannotations fcntl: fix misannotations ceph: don't abuse d_delete() on failure exits hypfs: ->d_parent is never NULL or negative vfs: delete surplus inode NULL check switch simple cases of fget_light to fdget new helpers: fdget()/fdput() switch o2hb_region_dev_write() to fget_light() proc_map_files_readdir(): don't bother with grabbing files make get_file() return its argument vhost_set_vring(): turn pollstart/pollstop into bool switch prctl_set_mm_exe_file() to fget_light() switch xfs_find_handle() to fget_light() switch xfs_swapext() to fget_light() ...
2012-10-02fs: push rcu_barrier() from deactivate_locked_super() to filesystemsKirill A. Shutemov
There's no reason to call rcu_barrier() on every deactivate_locked_super(). We only need to make sure that all delayed rcu free inodes are flushed before we destroy related cache. Removing rcu_barrier() from deactivate_locked_super() affects some fast paths. E.g. on my machine exit_group() of a last process in IPC namespace takes 0.07538s. rcu_barrier() takes 0.05188s of that time. Signed-off-by: Kirill A. Shutemov <kirill.shutemov@linux.intel.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-09-21userns: Convert squashfs to use kuid/kgid where appropriateEric W. Biederman
Cc: Phillip Lougher <phillip@squashfs.org.uk> Acked-by: Serge Hallyn <serge.hallyn@canonical.com> Signed-off-by: Eric W. Biederman <ebiederm@xmission.com>
2012-07-14stop passing nameidata to ->lookup()Al Viro
Just the flags; only NFS cares even about that, but there are legitimate uses for such argument. And getting rid of that completely would require splitting ->lookup() into a couple of methods (at least), so let's leave that alone for now... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-03-28Merge tag 'squashfs-updates' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/pkl/squashfs-next Pull squashfs updates from Phillip Lougher: "Add an extra mount time sanity check, plus some code cleanups and bug fixes." * tag 'squashfs-updates' of git://git.kernel.org/pub/scm/linux/kernel/git/pkl/squashfs-next: Squashfs: add mount time sanity check for block_size and block_log match Squashfs: fix f_pos check in get_dir_index_using_offset Squashfs: get rid of obsolete definitions in header file Squashfs: remove redundant length initialisation in squashfs_lookup Squashfs: remove redundant length initialisation in squashfs_readdir Squashfs: update comment removing reference to zlib only Squashfs: use define instead of constant
2012-03-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile 1 from Al Viro: "This is _not_ all; in particular, Miklos' and Jan's stuff is not there yet." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (64 commits) ext4: initialization of ext4_li_mtx needs to be done earlier debugfs-related mode_t whack-a-mole hfsplus: add an ioctl to bless files hfsplus: change finder_info to u32 hfsplus: initialise userflags qnx4: new helper - try_extent() qnx4: get rid of qnx4_bread/qnx4_getblk take removal of PF_FORKNOEXEC to flush_old_exec() trim includes in inode.c um: uml_dup_mmap() relies on ->mmap_sem being held, but activate_mm() doesn't hold it um: embed ->stub_pages[] into mmu_context gadgetfs: list_for_each_safe() misuse ocfs2: fix leaks on failure exits in module_init ecryptfs: make register_filesystem() the last potential failure exit ntfs: forgets to unregister sysctls on register_filesystem() failure logfs: missing cleanup on register_filesystem() failure jfs: mising cleanup on register_filesystem() failure make configfs_pin_fs() return root dentry on success configfs: configfs_create_dir() has parent dentry in dentry->d_parent configfs: sanitize configfs_create() ...
