path: root/fs/stat.c
2011-03-15readlinkat(), fchownat() and fstatat() with empty relative pathnamesAl Viro
For readlinkat() we simply allow empty pathname; it will fail unless we have dfd equal to O_PATH-opened symlink, so we are outside of POSIX scope here. For fchownat() and fstatat() we allow AT_EMPTY_PATH; let the caller explicitly ask for such behaviour. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-15Add an AT_NO_AUTOMOUNT flag to suppress terminal automountDavid Howells
Add an AT_NO_AUTOMOUNT flag to suppress terminal automounting of automount point directories. This can be used by fstatat() users to permit the gathering of attributes on an automount point and also prevent mass-automounting of a directory of automount points by ls. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Ian Kent <raven@themaw.net> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-13Mark arguments to certain syscalls as being constDavid Howells
Mark arguments to certain system calls as being const where they should be but aren't. The list includes: (*) The filename arguments of various stat syscalls, execve(), various utimes syscalls and some mount syscalls. (*) The filename arguments of some syscall helpers relating to the above. (*) The buffer argument of various write syscalls. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: David S. Miller <davem@davemloft.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-23Add unlocked version of inode_add_bytes() functionDmitry Monakhov
Quota code requires unlocked version of this function. Off course we can just copy-paste the code, but copy-pasting is always an evil. Signed-off-by: Dmitry Monakhov <dmonakhov@openvz.org> Signed-off-by: Jan Kara <jack@suse.cz>
2009-04-20kill vfs_stat_fd / vfs_lstat_fdChristoph Hellwig
There's really no reason to keep vfs_stat_fd and vfs_lstat_fd with Oleg's vfs_fstatat. Use vfs_fstatat for the few cases having the directory fd, and switch all others to vfs_stat / vfs_lstat. Reviewed-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-04-20Separate out common fstatat code into vfs_fstatatOleg Drokin
This is a version incorporating Christoph's suggestion. Separate out common *fstatat functionality into a single function instead of duplicating it all over the code. Signed-off-by: Oleg Drokin <green@linuxhacker.ru> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-01-14[CVE-2009-0029] System call wrappers part 30Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 16Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 11Heiko Carstens
2009-01-14[CVE-2009-0029] System call wrappers part 10Heiko Carstens
2009-01-05inode->i_op is never NULLAl Viro
We used to have rather schizophrenic set of checks for NULL ->i_op even though it had been eliminated years ago. You'd need to go out of your way to set it to NULL explicitly _and_ a bunch of code would die on such inodes anyway. After killing two remaining places that still did that bogosity, all that crap can go away. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-07-26[PATCH] sanitize __user_walk_fd() et.al.Al Viro
* do not pass nameidata; struct path is all the callers want. * switch to new helpers: user_path_at(dfd, pathname, flags, &path) user_path(pathname, &path) user_lpath(pathname, &path) user_path_dir(pathname, &path) (fail if not a directory) The last 3 are trivial macro wrappers for the first one. * remove nameidata in callers. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-02-14Introduce path_put()Jan Blunck
* Add path_put() functions for releasing a reference to the dentry and vfsmount of a struct path in the right order * Switch from path_release(nd) to path_put(&nd->path) * Rename dput_path() to path_put_conditional() [akpm@linux-foundation.org: fix cifs] Signed-off-by: Jan Blunck <jblunck@suse.de> Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Acked-by: Christoph Hellwig <hch@lst.de> Cc: <linux-fsdevel@vger.kernel.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Steven French <sfrench@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-14Embed a struct path into struct nameidata instead of nd->{dentry,mnt}Jan Blunck
This is the central patch of a cleanup series. In most cases there is no good reason why someone would want to use a dentry for itself. This series reflects that fact and embeds a struct path into nameidata. Together with the other patches of this series - it enforced the correct order of getting/releasing the reference count on <dentry,vfsmount> pairs - it prepares the VFS for stacking support since it is essential to have a struct path in every place where the stack can be traversed - it reduces the overall code size: without patch series: text data bss dec hex filename 5321639 858418 715768 6895825 6938d1 vmlinux with patch series: text data bss dec hex filename 5320026 858418 715768 6894212 693284 vmlinux This patch: Switch from nd->{dentry,mnt} to nd->path.{dentry,mnt} everywhere. [akpm@linux-foundation.org: coding-style fixes] [akpm@linux-foundation.org: fix cifs] [akpm@linux-foundation.org: fix smack] Signed-off-by: Jan Blunck <jblunck@suse.de> Signed-off-by: Andreas Gruenbacher <agruen@suse.de> Acked-by: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Casey Schaufler <casey@schaufler-ca.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-12-08[PATCH] VFS: change struct file to use struct pathJosef "Jeff" Sipek
This patch changes struct file to use struct path instead of having independent pointers to struct dentry and struct vfsmount, and converts all users of f_{dentry,vfsmnt} in fs/ to use f_path.{dentry,mnt}. Additionally, it adds two #define's to make the transition easier for users of the f_dentry and f_vfsmnt. Signed-off-by: Josef "Jeff" Sipek <jsipek@cs.sunysb.edu> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-12-07[PATCH] vfs_getattr(): remove dead codeAndrew Morton
As Mikulas points out, (1 << anything) won't be evaluating to zero. This code is long-dead. Cc: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03[PATCH] VFS: Make filldir_t and struct kstat deal in 64-bit inode numbersDavid Howells
These patches make the kernel pass 64-bit inode numbers internally when communicating to userspace, even on a 32-bit system. They are required because some filesystems have intrinsic 64-bit inode numbers: NFS3+ and XFS for example. The 64-bit inode numbers are then propagated to userspace automatically where the arch supports it. Problems have been seen with userspace (eg: ld.so) using the 64-bit inode number returned by stat64() or getdents64() to differentiate files, and failing because the 64-bit inode number space was compressed to 32-bits, and so overlaps occur. This patch: Make filldir_t take a 64-bit inode number and struct kstat carry a 64-bit inode number so that 64-bit inode numbers can be passed back to userspace. The stat functions then returns the full 64-bit inode number where available and where possible. If it is not possible to represent the inode number supplied by the filesystem in the field provided by userspace, then error EOVERFLOW will be issued. Similarly, the getdents/readdir functions now pass the full 64-bit inode number to userspace where possible, returning EOVERFLOW instead when a directory entry is encountered that can't be properly represented. Note that this means that some inodes will not be stat'able on a 32-bit system with old libraries where they were before - but it does mean that there will be no ambiguity over what a 32-bit inode number refers to. Note similarly that directory scans may be cut short with an error on a 32-bit system with old libraries where the scan would work before for the same reasons. It is judged unlikely that this situation will occur because modern glibc uses 64-bit capable versions of stat and getdents class functions exclusively, and that older systems are unlikely to encounter unrepresentable inode numbers anyway. [akpm: alpha build fix] Signed-off-by: David Howells <dhowells@redhat.com> Cc: Trond Myklebust <trond.myklebust@fys.uio.no> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-04-28[PATCH] powerpc: Wire up *at syscallsAndreas Schwab
Wire up *at syscalls. This patch has been tested on ppc64 (using glibc's testsuite, both 32bit and 64bit), and compile-tested for ppc32 (I have currently no ppc32 system available, but I expect no problems). Signed-off-by: Andreas Schwab <schwab@suse.de> Signed-off-by: Paul Mackerras <paulus@samba.org>
2006-02-11[PATCH] fstatat64 supportUlrich Drepper
The *at patches introduced fstatat and, due to inusfficient research, I used the newfstat functions generally as the guideline. The result is that on 32-bit platforms we don't have all the information needed to implement fstatat64. This patch modifies the code to pass up 64-bit information if __ARCH_WANT_STAT64 is defined. I renamed the syscall entry point to make this clear. Other archs will continue to use the existing code. On x86-64 the compat code is implemented using a new sys32_ function. this is what is done for the other stat syscalls as well. This patch might break some other archs (those which define __ARCH_WANT_STAT64 and which already wired up the syscall). Yet others might need changes to accomodate the compatibility mode. I really don't want to do that work because all this stat handling is a mess (more so in glibc, but the kernel is also affected). It should be done by the arch maintainers. I'll provide some stand-alone test shortly. Those who are eager could compile glibc and run 'make check' (no installation needed). The patch below has been tested on x86 and x86-64. Signed-off-by: Ulrich Drepper <drepper@redhat.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Andi Kleen <ak@muc.de> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-18[PATCH] vfs: *at functions: coreUlrich Drepper
Here is a series of patches which introduce in total 13 new system calls which take a file descriptor/filename pair instead of a single file name. These functions, openat etc, have been discussed on numerous occasions. They are needed to implement race-free filesystem traversal, they are necessary to implement a virtual per-thread current working directory (think multi-threaded backup software), etc. We have in glibc today implementations of the interfaces which use the /proc/self/fd magic. But this code is rather expensive. Here are some results (similar to what Jim Meyering posted before). The test creates a deep directory hierarchy on a tmpfs filesystem. Then rm -fr is used to remove all directories. Without syscall support I get this: real 0m31.921s user 0m0.688s sys 0m31.234s With syscall support the results are much better: real 0m20.699s user 0m0.536s sys 0m20.149s The interfaces are for obvious reasons currently not much used. But they'll be used. coreutils (and Jeff's posixutils) are already using them. Furthermore, code like ftw/fts in libc (maybe even glob) will also start using them. I expect a patch to make follow soon. Every program which is walking the filesystem tree will benefit. Signed-off-by: Ulrich Drepper <drepper@redhat.com> Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Cc: Christoph Hellwig <hch@lst.de> Cc: Al Viro <viro@ftp.linux.org.uk> Acked-by: Ingo Molnar <mingo@elte.hu> Cc: Michael Kerrisk <mtk-manpages@gmx.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
