path: root/fs/super.c
2011-11-26vmscan: fix shrinker callback bug in fs/super.cMikulas Patocka
commit 09f363c7363eb10cfb4b82094bd7064e5608258b upstream. The callback must not return -1 when nr_to_scan is zero. Fix the bug in fs/super.c and add this requirement to the callback specification. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Cc: Dave Chinner <david@fromorbit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-07-25Merge branch 'for-3.1/core' of git://git.kernel.dk/linux-blockLinus Torvalds
* 'for-3.1/core' of git://git.kernel.dk/linux-block: (24 commits) block: strict rq_affinity backing-dev: use synchronize_rcu_expedited instead of synchronize_rcu block: fix patch import error in max_discard_sectors check block: reorder request_queue to remove 64 bit alignment padding CFQ: add think time check for group CFQ: add think time check for service tree CFQ: move think time check variables to a separate struct fixlet: Remove fs_excl from struct task. cfq: Remove special treatment for metadata rqs. block: document blk_plug list access block: avoid building too big plug list compat_ioctl: fix make headers_check regression block: eliminate potential for infinite loop in blkdev_issue_discard compat_ioctl: fix warning caused by qemu block: flush MEDIA_CHANGE from drivers on close(2) blk-throttle: Make total_nr_queued unsigned block: Add __attribute__((format(printf...) and fix fallout fs/partitions/check.c: make local symbols static block:remove some spare spaces in genhd.c block:fix the comment error in blkdev.h ...
2011-07-20vfs: increase shrinker batch sizeDave Chinner
Now that the per-sb shrinker is responsible for shrinking 2 or more caches, increase the batch size to keep econmies of scale for shrinking each cache. Increase the shrinker batch size to 1024 objects. To allow for a large increase in batch size, add a conditional reschedule to prune_icache_sb() so that we don't hold the LRU spin lock for too long. This mirrors the behaviour of the __shrink_dcache_sb(), and allows us to increase the batch size without needing to worry about problems caused by long lock hold times. To ensure that filesystems using the per-sb shrinker callouts don't cause problems, document that the object freeing method must reschedule appropriately inside loops. Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20superblock: add filesystem shrinker operationsDave Chinner
Now we have a per-superblock shrinker implementation, we can add a filesystem specific callout to it to allow filesystem internal caches to be shrunk by the superblock shrinker. Rather than perpetuate the multipurpose shrinker callback API (i.e. nr_to_scan == 0 meaning "tell me how many objects freeable in the cache), two operations will be added. The first will return the number of objects that are freeable, the second is the actual shrinker call. Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20superblock: introduce per-sb cache shrinker infrastructureDave Chinner
With context based shrinkers, we can implement a per-superblock shrinker that shrinks the caches attached to the superblock. We currently have global shrinkers for the inode and dentry caches that split up into per-superblock operations via a coarse proportioning method that does not batch very well. The global shrinkers also have a dependency - dentries pin inodes - so we have to be very careful about how we register the global shrinkers so that the implicit call order is always correct. With a per-sb shrinker callout, we can encode this dependency directly into the per-sb shrinker, hence avoiding the need for strictly ordering shrinker registrations. We also have no need for any proportioning code for the shrinker subsystem already provides this functionality across all shrinkers. Allowing the shrinker to operate on a single superblock at a time means that we do less superblock list traversals and locking and reclaim should batch more effectively. This should result in less CPU overhead for reclaim and potentially faster reclaim of items from each filesystem. Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20superblock: move pin_sb_for_writeback() to fs/super.cDave Chinner
The per-sb shrinker has the same requirement as the writeback threads of ensuring that the superblock is usable and pinned for the time it takes to run the work. Both need to take a passive reference to the sb, take a read lock on the s_umount lock and then only continue if an unmount is not in progress. pin_sb_for_writeback() does this exactly, so move it to fs/super.c and rename it to grab_super_passive() and exporting it via fs/internal.h for all the VFS code to be able to use. Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20inode: move to per-sb LRU locksDave Chinner
With the inode LRUs moving to per-sb structures, there is no longer a need for a global inode_lru_lock. The locking can be made more fine-grained by moving to a per-sb LRU lock, isolating the LRU operations of different filesytsems completely from each other. Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20inode: Make unused inode LRU per superblockDave Chinner
The inode unused list is currently a global LRU. This does not match the other global filesystem cache - the dentry cache - which uses per-superblock LRU lists. Hence we have related filesystem object types using different LRU reclaimation schemes. To enable a per-superblock filesystem cache shrinker, both of these caches need to have per-sb unused object LRU lists. Hence this patch converts the global inode LRU to per-sb LRUs. The patch only does rudimentary per-sb propotioning in the shrinker infrastructure, as this gets removed when the per-sb shrinker callouts are introduced later on. Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20btrfs: kill magical embedded struct superblockAl Viro
2011-07-20new helper: iterate_supers_type()Al Viro
Call the given function for all superblocks of given type. Function gets a superblock (with s_umount locked shared) and (void *) argument supplied by caller of iterator. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-12fixlet: Remove fs_excl from struct task.Justin TerAvest
fs_excl is a poor man's priority inheritance for filesystems to hint to the block layer that an operation is important. It was never clearly specified, not widely adopted, and will not prevent starvation in many cases (like across cgroups). fs_excl was introduced with the time sliced CFQ IO scheduler, to indicate when a process held FS exclusive resources and thus needed a boost. It doesn't cover all file systems, and it was never fully complete. Lets kill it. Signed-off-by: Justin TerAvest <teravest@google.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-06-03more conservative S_NOSEC handlingAl Viro
Caching "we have already removed suid/caps" was overenthusiastic as merged. On network filesystems we might have had suid/caps set on another client, silently picked by this client on revalidate, all of that *without* clearing the S_NOSEC flag. AFAICS, the only reasonably sane way to deal with that is * new superblock flag; unless set, S_NOSEC is not going to be set. * local block filesystems set it in their ->mount() (more accurately, mount_bdev() does, so does btrfs ->mount(), users of mount_bdev() other than local block ones clear it) * if any network filesystem (or a cluster one) wants to use S_NOSEC, it'll need to set MS_NOSEC in sb->s_flags *AND* take care to clear S_NOSEC when inode attribute changes are picked from other clients. It's not an earth-shattering hole (anybody that can set suid on another client will almost certainly be able to write to the file before doing that anyway), but it's a bug that needs fixing. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djm/tmem * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/djm/tmem: xen: cleancache shim to Xen Transcendent Memory ocfs2: add cleancache support ext4: add cleancache support btrfs: add cleancache support ext3: add cleancache support mm/fs: add hooks to support cleancache mm: cleancache core ops functions and config fs: add field to superblock to support cleancache mm/fs: cleancache documentation Fix up trivial conflict in fs/btrfs/extent_io.c due to includes
2011-05-26mm/fs: add hooks to support cleancacheDan Magenheimer
This fourth patch of eight in this cleancache series provides the core hooks in VFS for: initializing cleancache per filesystem; capturing clean pages reclaimed by page cache; attempting to get pages from cleancache before filesystem read; and ensuring coherency between pagecache, disk, and cleancache. Note that the placement of these hooks was stable from 2.6.18 to 2.6.38; a minor semantic change was required due to a patchset in 2.6.39. All hooks become no-ops if CONFIG_CLEANCACHE is unset, or become a check of a boolean global if CONFIG_CLEANCACHE is set but no cleancache "backend" has claimed cleancache_ops. Details and a FAQ can be found in Documentation/vm/cleancache.txt [v8: minchan.kim@gmail.com: adapt to new remove_from_page_cache function] Signed-off-by: Chris Mason <chris.mason@oracle.com> Signed-off-by: Dan Magenheimer <dan.magenheimer@oracle.com> Reviewed-by: Jeremy Fitzhardinge <jeremy@goop.org> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Rik Van Riel <riel@redhat.com> Cc: Jan Beulich <JBeulich@novell.com> Cc: Andreas Dilger <adilger@sun.com> Cc: Ted Ts'o <tytso@mit.edu> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <joel.becker@oracle.com> Cc: Nitin Gupta <ngupta@vflare.org>
2011-05-19VFS: trivial: fix comment on s_maxbytes value warning checkJeff Layton
I originally intended to remove this warning in 2.6.34, but it's not in a high performance codepath and might help us to catch bugs later. Let's keep it, but fix the comment to allay confusion about its removal. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-03-24Merge branch 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-block: (65 commits) Documentation/iostats.txt: bit-size reference etc. cfq-iosched: removing unnecessary think time checking cfq-iosched: Don't clear queue stats when preempt. blk-throttle: Reset group slice when limits are changed blk-cgroup: Only give unaccounted_time under debug cfq-iosched: Don't set active queue in preempt block: fix non-atomic access to genhd inflight structures block: attempt to merge with existing requests on plug flush block: NULL dereference on error path in __blkdev_get() cfq-iosched: Don't update group weights when on service tree fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going away block: Require subsystems to explicitly allocate bio_set integrity mempool jbd2: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging fs: make fsync_buffers_list() plug mm: make generic_writepages() use plugging blk-cgroup: Add unaccounted time to timeslice_used. block: fixup plugging stubs for !CONFIG_BLOCK block: remove obsolete comments for blkdev_issue_zeroout. blktrace: Use rq->cmd_flags directly in blk_add_trace_rq. ... Fix up conflicts in fs/{aio.c,super.c}
2011-03-17vfs: split off vfsmount-related parts of vfs_kern_mount()Al Viro
new function: mount_fs(). Does all work done by vfs_kern_mount() except the allocation and filling of vfsmount; returns root dentry or ERR_PTR(). vfs_kern_mount() switched to using it and taken to fs/namespace.c, along with its wrappers. alloc_vfsmnt()/free_vfsmnt() made static. functions in namespace.c slightly reordered. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-17fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going awayJens Axboe
We don't have proper reference counting for this yet, so we run into cases where the device is pulled and we OOPS on flushing the fs data. This happens even though the dirty inodes have already been migrated to the default_backing_dev_info. Reported-by: Torsten Hilbrich <torsten.hilbrich@secunet.com> Tested-by: Torsten Hilbrich <torsten.hilbrich@secunet.com> Cc: stable@kernel.org Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-16vfs: bury ->get_sb()Al Viro
This is an ex-parrot. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-02-11vfs: call rcu_barrier after ->kill_sb()Boaz Harrosh
In commit fa0d7e3de6d6 ("fs: icache RCU free inodes"), we use rcu free inode instead of freeing the inode directly. It causes a crash when we rmmod immediately after we umount the volume[1]. So we need to call rcu_barrier after we kill_sb so that the inode is freed before we do rmmod. The idea is inspired by Aneesh Kumar. rcu_barrier will wait for all callbacks to end before preceding. The original patch was done by Tao Ma, but synchronize_rcu() is not enough here. 1. http://marc.info/?l=linux-fsdevel&m=129680863330185&w=2 Tested-by: Tao Ma <boyu.mt@taobao.com> Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Chris Mason <chris.mason@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-16sanitize vfsmount refcounting changesAl Viro
Instead of splitting refcount between (per-cpu) mnt_count and (SMP-only) mnt_longrefs, make all references contribute to mnt_count again and keep track of how many are longterm ones. Accounting rules for longterm count: * 1 for each fs_struct.root.mnt * 1 for each fs_struct.pwd.mnt * 1 for having non-NULL ->mnt_ns * decrement to 0 happens only under vfsmount lock exclusive That allows nice common case for mntput() - since we can't drop the final reference until after mnt_longterm has reached 0 due to the rules above, mntput() can grab vfsmount lock shared and check mnt_longterm. If it turns out to be non-zero (which is the common case), we know that this is not the final mntput() and can just blindly decrement percpu mnt_count. Otherwise we grab vfsmount lock exclusive and do usual decrement-and-check of percpu mnt_count. For fs_struct.c we have mnt_make_longterm() and mnt_make_shortterm(); namespace.c uses the latter in places where we don't already hold vfsmount lock exclusive and opencodes a few remaining spots where we need to manipulate mnt_longterm. Note that we mostly revert the code outside of fs/namespace.c back to what we used to have; in particular, normal code doesn't need to care about two kinds of references, etc. And we get to keep the optimization Nick's variant had bought us... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-13Merge branch 'for-2.6.38/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.38/core' of git://git.kernel.dk/linux-2.6-block: (43 commits) block: ensure that completion error gets properly traced blktrace: add missing probe argument to block_bio_complete block cfq: don't use atomic_t for cfq_group block cfq: don't use atomic_t for cfq_queue block: trace event block fix unassigned field block: add internal hd part table references block: fix accounting bug on cross partition merges kref: add kref_test_and_get bio-integrity: mark kintegrityd_wq highpri and CPU intensive block: make kblockd_workqueue smarter Revert "sd: implement sd_check_events()" block: Clean up exit_io_context() source code. Fix compile warnings due to missing removal of a 'ret' variable fs/block: type signature of major_to_index(int) to major_to_index(unsigned) block: convert !IS_ERR(p) && p to !IS_ERR_NOR_NULL(p) cfq-iosched: don't check cfqg in choose_service_tree() fs/splice: Pull buf->ops->confirm() from splice_from_pipe actors cdrom: export cdrom_check_events() sd: implement sd_check_events() sr: implement sr_check_events() ...
2011-01-07fs: scale mntget/mntputNick Piggin
The problem that this patch aims to fix is vfsmount refcounting scalability. We need to take a reference on the vfsmount for every successful path lookup, which often go to the same mount point. The fundamental difficulty is that a "simple" reference count can never be made scalable, because any time a reference is dropped, we must check whether that was the last reference. To do that requires communication with all other CPUs that may have taken a reference count. We can make refcounts more scalable in a couple of ways, involving keeping distributed counters, and checking for the global-zero condition less frequently. - check the global sum once every interval (this will delay zero detection for some interval, so it's probably a showstopper for vfsmounts). - keep a local count and only taking the global sum when local reaches 0 (this is difficult for vfsmounts, because we can't hold preempt off for the life of a reference, so a counter would need to be per-thread or tied strongly to a particular CPU which requires more locking). - keep a local difference of increments and decrements, which allows us to sum the total difference and hence find the refcount when summing all CPUs. Then, keep a single integer "long" refcount for slow and long lasting references, and only take the global sum of local counters when the long refcount is 0. This last scheme is what I implemented here. Attached mounts and process root and working directory references are "long" references, and everything else is a short reference. This allows scalable vfsmount references during path walking over mounted subtrees and unattached (lazy umounted) mounts with processes still running in them. This results in one fewer atomic op in the fastpath: mntget is now just a per-CPU inc, rather than an atomic inc; and mntput just requires a spinlock and non-atomic decrement in the common case. However code is otherwise bigger and heavier, so single threaded performance is basically a wash. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: dcache per-bucket dcache hash lockingNick Piggin
We can turn the dcache hash locking from a global dcache_hash_lock into per-bucket locking. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2010-11-13block: clean up blkdev_get() wrappers and their usersTejun Heo
After recent blkdev_get() modifications, open_by_devnum() and open_bdev_exclusive() are simple wrappers around blkdev_get(). Replace them with blkdev_get_by_dev() and blkdev_get_by_path(). blkdev_get_by_dev() is identical to open_by_devnum(). blkdev_get_by_path() is slightly different in that it doesn't automatically add %FMODE_EXCL to @mode. All users are converted. Most conversions are mechanical and don't introduce any behavior difference. There are several exceptions. * btrfs now sets FMODE_EXCL in btrfs_device->mode, so there's no reason to OR it explicitly on blkdev_put(). * gfs2, nilfs2 and the generic mount_bdev() now set FMODE_EXCL in sb->s_mode. * With the above changes, sb->s_mode now always should contain FMODE_EXCL. WARN_ON_ONCE() added to kill_block_super() to detect errors. The new blkdev_get_*() functions are with proper docbook comments. While at it, add function description to blkdev_get() too. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Philipp Reisner <philipp.reisner@linbit.com> Cc: Neil Brown <neilb@suse.de> Cc: Mike Snitzer <snitzer@redhat.com> Cc: Joern Engel <joern@lazybastard.org> Cc: Chris Mason <chris.mason@oracle.com> Cc: Jan Kara <jack@suse.cz> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: KONISHI Ryusuke <konishi.ryusuke@lab.ntt.co.jp> Cc: reiserfs-devel@vger.kernel.org Cc: xfs-masters@oss.sgi.com Cc: Alexander Viro <viro@zeniv.linux.org.uk>
2010-11-13block: make blkdev_get/put() handle exclusive accessTejun Heo
Over time, block layer has accumulated a set of APIs dealing with bdev open, close, claim and release. * blkdev_get/put() are the primary open and close functions. * bd_claim/release() deal with exclusive open. * open/close_bdev_exclusive() are combination of open and claim and the other way around, respectively. * bd_link/unlink_disk_holder() to create and remove holder/slave symlinks. * open_by_devnum() wraps bdget() + blkdev_get(). The interface is a bit confusing and the decoupling of open and claim makes it impossible to properly guarantee exclusive access as in-kernel open + claim sequence can disturb the existing exclusive open even before the block layer knows the current open if for another exclusive access. Reorganize the interface such that, * blkdev_get() is extended to include exclusive access management. @holder argument is added and, if is @FMODE_EXCL specified, it will gain exclusive access atomically w.r.t. other exclusive accesses. * blkdev_put() is similarly extended. It now takes @mode argument and if @FMODE_EXCL is set, it releases an exclusive access. Also, when the last exclusive claim is released, the holder/slave symlinks are removed automatically. * bd_claim/release() and close_bdev_exclusive() are no longer necessary and either made static or removed. * bd_link_disk_holder() remains the same but bd_unlink_disk_holder() is no longer necessary and removed. * open_bdev_exclusive() becomes a simple wrapper around lookup_bdev() and blkdev_get(). It also has an unexpected extra bdev_read_only() test which probably should be moved into blkdev_get(). * open_by_devnum() is modified to take @holder argument and pass it to blkdev_get(). Most of bdev open/close operations are unified into blkdev_get/put() and most exclusive accesses are tested atomically at the open time (as it should). This cleans up code and removes some, both valid and invalid, but unnecessary all the same, corner cases. open_bdev_exclusive() and open_by_devnum() can use further cleanup - rename to blkdev_get_by_path() and blkdev_get_by_devt() and drop special features. Well, let's leave them for another day. Most conversions are straight-forward. drbd conversion is a bit more involved as there was some reordering, but the logic should stay the same. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Neil Brown <neilb@suse.de> Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Acked-by: Mike Snitzer <snitzer@redhat.com> Acked-by: Philipp Reisner <philipp.reisner@linbit.com> Cc: Peter Osterlund <petero2@telia.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Jan Kara <jack@suse.cz> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andreas Dilger <adilger.kernel@dilger.ca> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <joel.becker@oracle.com> Cc: Alex Elder <aelder@sgi.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: dm-devel@redhat.com Cc: drbd-dev@lists.linbit.com Cc: Leo Chen <leochen@broadcom.com> Cc: Scott Branden <sbranden@broadcom.com> Cc: Chris Mason <chris.mason@oracle.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Cc: Joern Engel <joern@logfs.org> Cc: reiserfs-devel@vger.kernel.org Cc: Alexander Viro <viro@zeniv.linux.org.uk>
2010-10-29switch get_sb_ns() usersAl Viro
2010-10-29convert get_sb_nodev() usersAl Viro
2010-10-29convert get_sb_single() usersAl Viro
2010-10-29new helper: mount_bdev()Al Viro
... and switch of the obvious get_sb_bdev() users to ->mount() Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-29beginning of transtion: ->mount()Al Viro
eventual replacement for ->get_sb() - does *not* get vfsmount, return ERR_PTR(error) or root of subtree to be mounted. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-10-25split invalidate_inodes()Al Viro
Pull removal of fsnotify marks into generic_shutdown_super(). Split umount-time work into a new function - evict_inodes(). Make sure that invalidate_inodes() will be able to cope with I_FREEING once we change locking in iput(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-18fs: scale files_lockNick Piggin
fs: scale files_lock Improve scalability of files_lock by adding per-cpu, per-sb files lists, protected with an lglock. The lglock provides fast access to the per-cpu lists to add and remove files. It also provides a snapshot of all the per-cpu lists (although this is very slow). One difficulty with this approach is that a file can be removed from the list by another CPU. We must track which per-cpu list the file is on with a new variale in the file struct (packed into a hole on 64-bit archs). Scalability could suffer if files are frequently removed from different cpu's list. However loads with frequent removal of files imply short interval between adding and removing the files, and the scheduler attempts to avoid moving processes too far away. Also, even in the case of cross-CPU removal, the hardware has much more opportunity to parallelise cacheline transfers with N cachelines than with 1. A worst-case test of 1 CPU allocating files subsequently being freed by N CPUs degenerates to contending on a single lock, which is no worse than before. When more than one CPU are allocating files, even if they are always freed by different CPUs, there will be more parallelism than the single-lock case. Testing results: On a 2 socket, 8 core opteron, I measure the number of times the lock is taken to remove the file, the number of times it is removed by the same CPU that added it, and the number of times it is removed by the same node that added it. Booting: locks= 25049 cpu-hits= 23174 (92.5%) node-hits= 23945 (95.6%) kbuild -j16 locks=2281913 cpu-hits=2208126 (96.8%) node-hits=2252674 (98.7%) dbench 64 locks=4306582 cpu-hits=4287247 (99.6%) node-hits=4299527 (99.8%) So a file is removed from the same CPU it was added by over 90% of the time. It remains within the same node 95% of the time. Tim Chen ran some numbers for a 64 thread Nehalem system performing a compile. throughput 2.6.34-rc2 24.5 +patch 24.9 us sys idle IO wait (in %) 2.6.34-rc2 51.25 28.25 17.25 3.25 +patch 53.75 18.5 19 8.75 So significantly less CPU time spent in kernel code, higher idle time and slightly higher throughput. Single threaded performance difference was within the noise of microbenchmarks. That is not to say penalty does not exist, the code is larger and more memory accesses required so it will be slightly slower. Cc: linux-kernel@vger.kernel.org Cc: Tim Chen <tim.c.chen@linux.intel.com> Cc: Andi Kleen <ak@linux.intel.com> Signed-off-by: Nick Piggin <npiggin@kernel.dk> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09no need for list_for_each_entry_safe()/resetting with superblock listAl Viro
just delay __put_super() a bit Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-08-09Fix sget() race with failing mountAl Viro
If sget() finds a matching superblock being set up, it'll grab an active reference to it and grab s_umount. That's fine - we'll wait for completion of foofs_get_sb() that way. However, if said foofs_get_sb() fails we'll end up holding the halfway-created superblock. deactivate_locked_super() called by foofs_get_sb() will just unlock the sucker since we are holding another active reference to it. What we need is a way to tell if superblock has been successfully set up. Unfortunately, neither ->s_root nor the check for MS_ACTIVE quite fit. Cheap and easy way, suitable for backport: new flag set by the (only) caller of ->get_sb(). If that flag isn't present by the time sget() grabbed s_umount on preexisting superblock it has found, it's seeing a stillborn and should just bury it with deactivate_locked_super() (and repeat the search). Longer term we want to set that flag in ->get_sb() instances (and check for it to distinguish between "sget() found us a live sb" and "sget() has allocated an sb, we need to set it up" in there, instead of checking ->s_root as we do now). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Cc: stable@kernel.org
2010-08-09vfs: don't hold s_umount over close_bdev_exclusive() callTejun Heo
Fix an obscure AB-BA deadlock in get_sb_bdev(). When a superblock is mounted more than once get_sb_bdev() calls close_bdev_exclusive() to drop the extra bdev reference while holding s_umount. However, sb->s_umount nests inside bd_mutex during __invalidate_device() and close_bdev_exclusive() acquires bd_mutex during blkdev_put(); thus creating an AB-BA deadlock. This condition doesn't trigger frequently. For this condition to be visible to lockdep, the filesystem must occupy the whole device (as __invalidate_device() only grabs bd_mutex for the whole device), the FS must be mounted more than once and partition rescan should be issued while the FS is still mounted. Fix it by dropping s_umount over close_bdev_exclusive(). Signed-off-by: Tejun Heo <tj@kernel.org> Reported-by: Ciprian Docan <docan@eden.rutgers.edu> Cc: Al Viro <viro@zeniv.linux.org.uk> Acked-by: Jens Axboe <axboe@kernel.dk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-06-29fs: fix superblock iteration racenpiggin@suse.de
list_for_each_entry_safe is not suitable to protect against concurrent modification of the list. 6754af6 introduced a race in sb walking. list_for_each_entry can use the trick of pinning the current entry in the list before we drop and retake the lock because it subsequently follows cur->next. However list_for_each_entry_safe saves n=cur->next for following before entering the loop body, so when the lock is dropped, n may be deleted. Signed-off-by: Nick Piggin <npiggin@suse.de> Cc: Christoph Hellwig <hch@infradead.org> Cc: John Stultz <johnstul@us.ibm.com> Cc: Frank Mayhar <fmayhar@google.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-05-30Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jack/linux-fs-2.6: quota: Convert quota statistics to generic percpu_counter ext3 uses rb_node = NULL; to zero rb_root. quota: Fixup dquot_transfer reiserfs: Fix resuming of quotas on remount read-write pohmelfs: Remove dead quota code ufs: Remove dead quota code udf: Remove dead quota code quota: rename default quotactl methods to dquot_ quota: explicitly set ->dq_op and ->s_qcop quota: drop remount argument to ->quota_on and ->quota_off quota: move unmount handling into the filesystem quota: kill the vfs_dq_off and vfs_dq_quota_on_remount wrappers quota: move remount handling into the filesystem ocfs2: Fix use after free on remount read-only Fix up conflicts in fs/ext4/super.c and fs/ufs/file.c
2010-05-27fs/super: fix kernel-doc warningRandy Dunlap
Fix fs/super.c kernel-doc warning and function notation: Warning(fs/super.c:957): No description found for parameter 'sb' Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Alexander Viro <viro@zeniv.linux.org.uk> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-24quota: explicitly set ->dq_op and ->s_qcopChristoph Hellwig
Only set the quota operation vectors if the filesystem actually supports quota instead of doing it for all filesystems in alloc_super(). [Jan Kara: Export dquot_operations and vfs_quotactl_ops] Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-24quota: move unmount handling into the filesystemChristoph Hellwig
Currently the VFS calls into the quotactl interface for unmounting filesystems. This means filesystems with their own quota handling can't easily distinguish between user-space originating quotaoff and an unount. Instead move the responsibily of the unmount handling into the filesystem to be consistent with all other dquot handling. Note that we do call dquot_disable a lot later now, e.g. after a sync_filesystem. But this is fine as the quota code does all its writes via blockdev's mapping and that is synced even later. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-24quota: move remount handling into the filesystemChristoph Hellwig
Currently do_remount_sb calls into the dquot code to tell it about going from rw to ro and ro to rw. Move this code into the filesystem to not depend on the dquot code in the VFS - note ocfs2 already ignores these calls and handles remount by itself. This gets rid of overloading the quotactl calls and allows to unify the VFS and XFS codepaths in that area later. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Jan Kara <jack@suse.cz>
2010-05-21vfs: add lockdep annotation to s_vfs_rename_key for ecryptfsRoland Dreier
> ============================================= > [ INFO: possible recursive locking detected ] > 2.6.31-2-generic #14~rbd3 > --------------------------------------------- > firefox-3.5/4162 is trying to acquire lock: > (&s->s_vfs_rename_mutex){+.+.+.}, at: [<ffffffff81139d31>] lock_rename+0x41/0xf0 > > but task is already holding lock: > (&s->s_vfs_rename_mutex){+.+.+.}, at: [<ffffffff81139d31>] lock_rename+0x41/0xf0 > > other info that might help us debug this: > 3 locks held by firefox-3.5/4162: > #0: (&s->s_vfs_rename_mutex){+.+.+.}, at: [<ffffffff81139d31>] lock_rename+0x41/0xf0 > #1: (&sb->s_type->i_mutex_key#11/1){+.+.+.}, at: [<ffffffff81139d5a>] lock_rename+0x6a/0xf0 > #2: (&sb->s_type->i_mutex_key#11/2){+.+.+.}, at: [<ffffffff81139d6f>] lock_rename+0x7f/0xf0 > > stack backtrace: > Pid: 4162, comm: firefox-3.5 Tainted: G C 2.6.31-2-generic #14~rbd3 > Call Trace: > [<ffffffff8108ae74>] print_deadlock_bug+0xf4/0x100 > [<ffffffff8108ce26>] validate_chain+0x4c6/0x750 > [<ffffffff8108d2e7>] __lock_acquire+0x237/0x430 > [<ffffffff8108d585>] lock_acquire+0xa5/0x150 > [<ffffffff81139d31>] ? lock_rename+0x41/0xf0 > [<ffffffff815526ad>] __mutex_lock_common+0x4d/0x3d0 > [<ffffffff81139d31>] ? lock_rename+0x41/0xf0 > [<ffffffff81139d31>] ? lock_rename+0x41/0xf0 > [<ffffffff8120eaf9>] ? ecryptfs_rename+0x99/0x170 > [<ffffffff81552b36>] mutex_lock_nested+0x46/0x60 > [<ffffffff81139d31>] lock_rename+0x41/0xf0 > [<ffffffff8120eb2a>] ecryptfs_rename+0xca/0x170 > [<ffffffff81139a9e>] vfs_rename_dir+0x13e/0x160 > [<ffffffff8113ac7e>] vfs_rename+0xee/0x290 > [<ffffffff8113c212>] ? __lookup_hash+0x102/0x160 > [<ffffffff8113d512>] sys_renameat+0x252/0x280 > [<ffffffff81133eb4>] ? cp_new_stat+0xe4/0x100 > [<ffffffff8101316a>] ? sysret_check+0x2e/0x69 > [<ffffffff8108c34d>] ? trace_hardirqs_on_caller+0x14d/0x190 > [<ffffffff8113d55b>] sys_rename+0x1b/0x20 > [<ffffffff81013132>] system_call_fastpath+0x16/0x1b The trace above is totally reproducible by doing a cross-directory rename on an ecryptfs directory. The issue seems to be that sys_renameat() does lock_rename() then calls into the filesystem; if the filesystem is ecryptfs, then ecryptfs_rename() again does lock_rename() on the lower filesystem, and lockdep can't tell that the two s_vfs_rename_mutexes are different. It seems an annotation like the following is sufficient to fix this (it does get rid of the lockdep trace in my simple tests); however I would like to make sure I'm not misunderstanding the locking, hence the CC list... Signed-off-by: Roland Dreier <rdreier@cisco.com> Cc: Tyler Hicks <tyhicks@linux.vnet.ibm.com> Cc: Dustin Kirkland <kirkland@canonical.com> Cc: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-21Introduce freeze_super and thaw_super for the fsfreeze ioctlJosef Bacik
Currently the way we do freezing is by passing sb>s_bdev to freeze_bdev and then letting it do all the work. But freezing is more of an fs thing, and doesn't really have much to do with the bdev at all, all the work gets done with the super. In btrfs we do not populate s_bdev, since we can have multiple bdev's for one fs and setting s_bdev makes removing devices from a pool kind of tricky. This means that freezing a btrfs filesystem fails, which causes us to corrupt with things like tux-on-ice which use the fsfreeze mechanism. So instead of populating sb->s_bdev with a random bdev in our pool, I've broken the actual fs freezing stuff into freeze_super and thaw_super. These just take the super_block that we're freezing and does the appropriate work. It's basically just copy and pasted from freeze_bdev. I've then converted freeze_bdev over to use the new super helpers. I've tested this with ext4 and btrfs and verified everything continues to work the same as before. The only new gotcha is multiple calls to the fsfreeze ioctl will return EBUSY if the fs is already frozen. I thought this was a better solution than adding a freeze counter to the super_block, but if everybody hates this idea I'm open to suggestions. Thanks, Signed-off-by: Josef Bacik <josef@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-21Trim includes in fs/super.cAl Viro
2010-05-21Move grabbing s_umount to callers of grab_super()Al Viro
2010-05-21Take statfs variants to fs/statfs.cAl Viro
2010-05-21new helper: iterate_supers()Al Viro
... and switch the simple "loop over superblocks and do something" loops to it. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2010-05-21Bury __put_super_and_need_restart()Al Viro
2010-05-21In get_super() and user_get_super() restarts are unconditionalAl Viro
If superblock had been still alive, we would've returned it... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
