path: root/fs/super.c
2012-08-04vfs: kill write_super and sync_supersArtem Bityutskiy
Finally we can kill the 'sync_supers' kernel thread along with the '->write_super()' superblock operation because all the users are gone. Now every file-system is supposed to self-manage own superblock and its dirty state. The nice thing about killing this thread is that it improves power management. Indeed, 'sync_supers' is a source of monotonic system wake-ups - it woke up every 5 seconds no matter what - even if there were no dirty superblocks and even if there were no file-systems using this service (e.g., btrfs and journalled ext4 do not need it). So it was wasting power most of the time. And because the thread was in the core of the kernel, all systems had to have it. So I am quite happy to make it go away. Interestingly, this thread is a left-over from the pdflush kernel thread which was a self-forking kernel thread responsible for all the write-back in old Linux kernels. It was turned into per-block device BDI threads, and 'sync_supers' was a left-over. Thus, R.I.P, pdflush as well. Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-08-01Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull second vfs pile from Al Viro: "The stuff in there: fsfreeze deadlock fixes by Jan (essentially, the deadlock reproduced by xfstests 068), symlink and hardlink restriction patches, plus assorted cleanups and fixes. Note that another fsfreeze deadlock (emergency thaw one) is *not* dealt with - the series by Fernando conflicts a lot with Jan's, breaks userland ABI (FIFREEZE semantics gets changed) and trades the deadlock for massive vfsmount leak; this is going to be handled next cycle. There probably will be another pull request, but that stuff won't be in it." Fix up trivial conflicts due to unrelated changes next to each other in drivers/{staging/gdm72xx/usb_boot.c, usb/gadget/storage_common.c} * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (54 commits) delousing target_core_file a bit Documentation: Correct s_umount state for freeze_fs/unfreeze_fs fs: Remove old freezing mechanism ext2: Implement freezing btrfs: Convert to new freezing mechanism nilfs2: Convert to new freezing mechanism ntfs: Convert to new freezing mechanism fuse: Convert to new freezing mechanism gfs2: Convert to new freezing mechanism ocfs2: Convert to new freezing mechanism xfs: Convert to new freezing code ext4: Convert to new freezing mechanism fs: Protect write paths by sb_start_write - sb_end_write fs: Skip atime update on frozen filesystem fs: Add freezing handling to mnt_want_write() / mnt_drop_write() fs: Improve filesystem freezing handling switch the protection of percpu_counter list to spinlock nfsd: Push mnt_want_write() outside of i_mutex btrfs: Push mnt_want_write() outside of i_mutex fat: Push mnt_want_write() outside of i_mutex ...
2012-07-31vmscan: remove obsolete shrink_control commentMinchan Kim
09f363c7 ("vmscan: fix shrinker callback bug in fs/super.c") fixed a shrinker callback which was returning -1 when nr_to_scan is zero, which caused excessive slab scanning. But 635697c6 ("vmscan: fix initial shrinker size handling") fixed the problem, again so we can freely return -1 although nr_to_scan is zero. So let's revert 09f363c7 because the comment added in 09f363c7 made an unnecessary rule. Signed-off-by: Minchan Kim <minchan@kernel.org> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Mikulas Patocka <mpatocka@redhat.com> Cc: Konstantin Khlebnikov <khlebnikov@openvz.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-07-31fs: Remove old freezing mechanismJan Kara
Now that all users are converted, we can remove functions, variables, and constants defined by the old freezing mechanism. BugLink: https://bugs.launchpad.net/bugs/897421 Tested-by: Kamal Mostafa <kamal@canonical.com> Tested-by: Peter M. Petrakis <peter.petrakis@canonical.com> Tested-by: Dann Frazier <dann.frazier@canonical.com> Tested-by: Massimo Morana <massimo.morana@canonical.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-31fs: Improve filesystem freezing handlingJan Kara
vfs_check_frozen() tests are racy since the filesystem can be frozen just after the test is performed. Thus in write paths we can end up marking some pages or inodes dirty even though the file system is already frozen. This creates problems with flusher thread hanging on frozen filesystem. Another problem is that exclusion between ->page_mkwrite() and filesystem freezing has been handled by setting page dirty and then verifying s_frozen. This guaranteed that either the freezing code sees the faulted page, writes it, and writeprotects it again or we see s_frozen set and bail out of page fault. This works to protect from page being marked writeable while filesystem freezing is running but has an unpleasant artefact of leaving dirty (although unmodified and writeprotected) pages on frozen filesystem resulting in similar problems with flusher thread as the first problem. This patch aims at providing exclusion between write paths and filesystem freezing. We implement a writer-freeze read-write semaphore in the superblock. Actually, there are three such semaphores because of lock ranking reasons - one for page fault handlers (->page_mkwrite), one for all other writers, and one of internal filesystem purposes (used e.g. to track running transactions). Write paths which should block freezing (e.g. directory operations, ->aio_write(), ->page_mkwrite) hold reader side of the semaphore. Code freezing the filesystem takes the writer side. Only that we don't really want to bounce cachelines of the semaphores between CPUs for each write happening. So we implement the reader side of the semaphore as a per-cpu counter and the writer side is implemented using s_writers.frozen superblock field. [AV: microoptimize sb_start_write(); we want it fast in normal case] BugLink: https://bugs.launchpad.net/bugs/897421 Tested-by: Kamal Mostafa <kamal@canonical.com> Tested-by: Peter M. Petrakis <peter.petrakis@canonical.com> Tested-by: Dann Frazier <dann.frazier@canonical.com> Tested-by: Massimo Morana <massimo.morana@canonical.com> Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-07-30Merge tag 'writeback-proportions' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/wfg/linux Pull writeback updates from Wu Fengguang: "Use time based periods to age the writeback proportions, which can adapt equally well to fast/slow devices." Fix up trivial conflict in comment in fs/sync.c * tag 'writeback-proportions' of git://git.kernel.org/pub/scm/linux/kernel/git/wfg/linux: writeback: Fix some comment errors block: Convert BDI proportion calculations to flexible proportions lib: Fix possible deadlock in flexible proportion code lib: Proportions with flexible period
2012-07-14VFS: Pass mount flags to sget()David Howells
Pass mount flags to sget() so that it can use them in initialising a new superblock before the set function is called. They could also be passed to the compare function. Signed-off-by: David Howells <dhowells@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-06-09writeback: Fix some comment errorsWanpeng Li
Signed-off-by: Wanpeng Li <liwp@linux.vnet.ibm.com> Signed-off-by: Fengguang Wu <fengguang.wu@intel.com>
2012-03-24Merge tag 'module-for-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux Pull cleanup of fs/ and lib/ users of module.h from Paul Gortmaker: "Fix up files in fs/ and lib/ dirs to only use module.h if they really need it. These are trivial in scope vs the work done previously. We now have things where any few remaining cleanups can be farmed out to arch or subsystem maintainers, and I have done so when possible. What is remaining here represents the bits that don't clearly lie within a single arch/subsystem boundary, like the fs dir and the lib dir. Some duplicate includes arising from overlapping fixes from independent subsystem maintainer submissions are also quashed." Fix up trivial conflicts due to clashes with other include file cleanups (including some due to the previous bug.h cleanup pull). * tag 'module-for-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/paulg/linux: lib: reduce the use of module.h wherever possible fs: reduce the use of module.h wherever possible includecheck: delete any duplicate instances of module.h
2012-03-22Merge tag 'stable/for-linus-3.4' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/konrad/mm Pull cleancache changes from Konrad Rzeszutek Wilk: "This has some patches for the cleancache API that should have been submitted a _long_ time ago. They are basically cleanups: - rename of flush to invalidate - moving reporting of statistics into debugfs - use __read_mostly as necessary. Oh, and also the MAINTAINERS file change. The files (except the MAINTAINERS file) have been in #linux-next for months now. The late addition of MAINTAINERS file is a brain-fart on my side - didn't realize I needed that just until I was typing this up - and I based that patch on v3.3 - so the tree is on top of v3.3." * tag 'stable/for-linus-3.4' of git://git.kernel.org/pub/scm/linux/kernel/git/konrad/mm: MAINTAINERS: Adding cleancache API to the list. mm: cleancache: Use __read_mostly as appropiate. mm: cleancache: report statistics via debugfs instead of sysfs. mm: zcache/tmem/cleancache: s/flush/invalidate/ mm: cleancache: s/flush/invalidate/
2012-03-21Merge branch 'next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security Pull security subsystem updates for 3.4 from James Morris: "The main addition here is the new Yama security module from Kees Cook, which was discussed at the Linux Security Summit last year. Its purpose is to collect miscellaneous DAC security enhancements in one place. This also marks a departure in policy for LSM modules, which were previously limited to being standalone access control systems. Chromium OS is using Yama, and I believe there are plans for Ubuntu, at least. This patchset also includes maintenance updates for AppArmor, TOMOYO and others." Fix trivial conflict in <net/sock.h> due to the jumo_label->static_key rename. * 'next' of git://git.kernel.org/pub/scm/linux/kernel/git/jmorris/linux-security: (38 commits) AppArmor: Fix location of const qualifier on generated string tables TOMOYO: Return error if fails to delete a domain AppArmor: add const qualifiers to string arrays AppArmor: Add ability to load extended policy TOMOYO: Return appropriate value to poll(). AppArmor: Move path failure information into aa_get_name and rename AppArmor: Update dfa matching routines. AppArmor: Minor cleanup of d_namespace_path to consolidate error handling AppArmor: Retrieve the dentry_path for error reporting when path lookup fails AppArmor: Add const qualifiers to generated string tables AppArmor: Fix oops in policy unpack auditing AppArmor: Fix error returned when a path lookup is disconnected KEYS: testing wrong bit for KEY_FLAG_REVOKED TOMOYO: Fix mount flags checking order. security: fix ima kconfig warning AppArmor: Fix the error case for chroot relative path name lookup AppArmor: fix mapping of META_READ to audit and quiet flags AppArmor: Fix underflow in xindex calculation AppArmor: Fix dropping of allowed operations that are force audited AppArmor: Add mising end of structure test to caps unpacking ...
2012-03-19Merge branch 'stable/cleancache.v13' into linux-nextKonrad Rzeszutek Wilk
* stable/cleancache.v13: mm: cleancache: Use __read_mostly as appropiate. mm: cleancache: report statistics via debugfs instead of sysfs. mm: zcache/tmem/cleancache: s/flush/invalidate/ mm: cleancache: s/flush/invalidate/
2012-02-28fs: reduce the use of module.h wherever possiblePaul Gortmaker
For files only using THIS_MODULE and/or EXPORT_SYMBOL, map them onto including export.h -- or if the file isn't even using those, then just delete the include. Fix up any implicit include dependencies that were being masked by module.h along the way. Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-02-13vfs: Provide function to get superblock and wait for it to thawJan Kara
In quota code we need to find a superblock corresponding to a device and wait for superblock to be unfrozen. However this waiting has to happen without s_umount semaphore because that is required for superblock to thaw. So provide a function in VFS for this to keep dances with s_umount where they belong. [AV: implementation switched to saner variant] Signed-off-by: Jan Kara <jack@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-02-14security: trim security.hAl Viro
Trim security.h Signed-off-by: Al Viro <viro@zeniv.linux.org.uk> Signed-off-by: James Morris <jmorris@namei.org>
2012-01-23mm: cleancache: s/flush/invalidate/Dan Magenheimer
Per akpm suggestions alter the use of the term flush to be invalidate. The next patch will do this across all MM. This change is completely cosmetic. [v9: akpm@linux-foundation.org: change "flush" to "invalidate", part 3] Signed-off-by: Dan Magenheimer <dan.magenheimer@oracle.com> Cc: Kamezawa Hiroyuki <kamezawa.hiroyu@jp.fujitsu.com> Cc: Jan Beulich <JBeulich@novell.com> Reviewed-by: Seth Jennings <sjenning@linux.vnet.ibm.com> Cc: Jeremy Fitzhardinge <jeremy@goop.org> Cc: Hugh Dickins <hughd@google.com> Cc: Johannes Weiner <hannes@cmpxchg.org> Cc: Nitin Gupta <ngupta@vflare.org> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Chris Mason <chris.mason@oracle.com> Cc: Rik Riel <riel@redhat.com> Cc: Andrew Morton <akpm@linux-foundation.org> [v10: Fixed fs: move code out of buffer.c conflict change] Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com>
2012-01-17wake up s_wait_unfrozen when ->freeze_fs failsKazuya Mio
dd slept infinitely when fsfeeze failed because of EIO. To fix this problem, if ->freeze_fs fails, freeze_super() wakes up the tasks waiting for the filesystem to become unfrozen. When s_frozen isn't SB_UNFROZEN in __generic_file_aio_write(), the function sleeps until FITHAW ioctl wakes up s_wait_unfrozen. However, if ->freeze_fs fails, s_frozen is set to SB_UNFROZEN and then freeze_super() returns an error number. In this case, FITHAW ioctl returns EINVAL because s_frozen is already SB_UNFROZEN. There is no way to wake up s_wait_unfrozen, so __generic_file_aio_write() sleeps infinitely. Signed-off-by: Kazuya Mio <k-mio@sx.jp.nec.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-01-06vfs: prevent remount read-only if pending removesMiklos Szeredi
If there are any inodes on the super block that have been unlinked (i_nlink == 0) but have not yet been deleted then prevent the remounting the super block read-only. Reported-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Tested-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-01-06vfs: protect remounting superblock read-onlyMiklos Szeredi
Currently remouting superblock read-only is racy in a major way. With the per mount read-only infrastructure it is now possible to prevent most races, which this patch attempts. Before starting the remount read-only, iterate through all mounts belonging to the superblock and if none of them have any pending writes, set sb->s_readonly_remount. This indicates that remount is in progress and no further write requests are allowed. If the remount succeeds set MS_RDONLY and reset s_readonly_remount. If the remounting is unsuccessful just reset s_readonly_remount. This can result in transient EROFS errors, despite the fact the remount failed. Unfortunately hodling off writes is difficult as remount itself may touch the filesystem (e.g. through load_nls()) which would deadlock. A later patch deals with delayed writes due to nlink going to zero. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Tested-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-01-06vfs: keep list of mounts for each superblockMiklos Szeredi
Keep track of vfsmounts belonging to a superblock. List is protected by vfsmount_lock. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Tested-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-01-03vfs: fix the rest of sget() racesAl Viro
unfortunately, just checking MS_BORN after having grabbed ->s_umount in sget() is not enough; places that pick superblock from a list and grab s_umount shared need the same check in addition to checking for ->s_root; otherwise three-way race between failing mount, sget() and such list-walker can leave us with list-walker coming *second*, when temporary active ref grabbed by sget() (to be dropped when sget() notices that original mount has failed by checking MS_BORN) has lead to deactivate_locked_super() from failing ->mount() *not* doing ->kill_sb() and just releasing ->s_umount. Once sget() gets through and notices that MS_BORN had never been set it will drop the active ref and fs will be shut down and kicked out of all lists, but it's too late for something like sync_supers(). Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-01-03vfs: convert fs_supers to hlistAl Viro
2012-01-03trim fs/internal.hAl Viro
some stuff in there can actually become static; some belongs to pnode.h as it's a private interface between namespace.c and pnode.c... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-11-02vfs: ignore error on forced remountMiklos Szeredi
On emergency remount we want to force MS_RDONLY on the super block even if ->remount_fs() failed for some reason. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Tested-by: Toshiyuki Okajima <toshi.okajima@jp.fujitsu.com> Signed-off-by: Christoph Hellwig <hch@lst.de>
2011-10-31vmscan: fix shrinker callback bug in fs/super.cMikulas Patocka
The callback must not return -1 when nr_to_scan is zero. Fix the bug in fs/super.c and add this requirement to the callback specification. Signed-off-by: Mikulas Patocka <mpatocka@redhat.com> Cc: Dave Chinner <david@fromorbit.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-07-25Merge branch 'for-3.1/core' of git://git.kernel.dk/linux-blockLinus Torvalds
* 'for-3.1/core' of git://git.kernel.dk/linux-block: (24 commits) block: strict rq_affinity backing-dev: use synchronize_rcu_expedited instead of synchronize_rcu block: fix patch import error in max_discard_sectors check block: reorder request_queue to remove 64 bit alignment padding CFQ: add think time check for group CFQ: add think time check for service tree CFQ: move think time check variables to a separate struct fixlet: Remove fs_excl from struct task. cfq: Remove special treatment for metadata rqs. block: document blk_plug list access block: avoid building too big plug list compat_ioctl: fix make headers_check regression block: eliminate potential for infinite loop in blkdev_issue_discard compat_ioctl: fix warning caused by qemu block: flush MEDIA_CHANGE from drivers on close(2) blk-throttle: Make total_nr_queued unsigned block: Add __attribute__((format(printf...) and fix fallout fs/partitions/check.c: make local symbols static block:remove some spare spaces in genhd.c block:fix the comment error in blkdev.h ...
2011-07-20vfs: increase shrinker batch sizeDave Chinner
Now that the per-sb shrinker is responsible for shrinking 2 or more caches, increase the batch size to keep econmies of scale for shrinking each cache. Increase the shrinker batch size to 1024 objects. To allow for a large increase in batch size, add a conditional reschedule to prune_icache_sb() so that we don't hold the LRU spin lock for too long. This mirrors the behaviour of the __shrink_dcache_sb(), and allows us to increase the batch size without needing to worry about problems caused by long lock hold times. To ensure that filesystems using the per-sb shrinker callouts don't cause problems, document that the object freeing method must reschedule appropriately inside loops. Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20superblock: add filesystem shrinker operationsDave Chinner
Now we have a per-superblock shrinker implementation, we can add a filesystem specific callout to it to allow filesystem internal caches to be shrunk by the superblock shrinker. Rather than perpetuate the multipurpose shrinker callback API (i.e. nr_to_scan == 0 meaning "tell me how many objects freeable in the cache), two operations will be added. The first will return the number of objects that are freeable, the second is the actual shrinker call. Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20superblock: introduce per-sb cache shrinker infrastructureDave Chinner
With context based shrinkers, we can implement a per-superblock shrinker that shrinks the caches attached to the superblock. We currently have global shrinkers for the inode and dentry caches that split up into per-superblock operations via a coarse proportioning method that does not batch very well. The global shrinkers also have a dependency - dentries pin inodes - so we have to be very careful about how we register the global shrinkers so that the implicit call order is always correct. With a per-sb shrinker callout, we can encode this dependency directly into the per-sb shrinker, hence avoiding the need for strictly ordering shrinker registrations. We also have no need for any proportioning code for the shrinker subsystem already provides this functionality across all shrinkers. Allowing the shrinker to operate on a single superblock at a time means that we do less superblock list traversals and locking and reclaim should batch more effectively. This should result in less CPU overhead for reclaim and potentially faster reclaim of items from each filesystem. Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20superblock: move pin_sb_for_writeback() to fs/super.cDave Chinner
The per-sb shrinker has the same requirement as the writeback threads of ensuring that the superblock is usable and pinned for the time it takes to run the work. Both need to take a passive reference to the sb, take a read lock on the s_umount lock and then only continue if an unmount is not in progress. pin_sb_for_writeback() does this exactly, so move it to fs/super.c and rename it to grab_super_passive() and exporting it via fs/internal.h for all the VFS code to be able to use. Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20inode: move to per-sb LRU locksDave Chinner
With the inode LRUs moving to per-sb structures, there is no longer a need for a global inode_lru_lock. The locking can be made more fine-grained by moving to a per-sb LRU lock, isolating the LRU operations of different filesytsems completely from each other. Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20inode: Make unused inode LRU per superblockDave Chinner
The inode unused list is currently a global LRU. This does not match the other global filesystem cache - the dentry cache - which uses per-superblock LRU lists. Hence we have related filesystem object types using different LRU reclaimation schemes. To enable a per-superblock filesystem cache shrinker, both of these caches need to have per-sb unused object LRU lists. Hence this patch converts the global inode LRU to per-sb LRUs. The patch only does rudimentary per-sb propotioning in the shrinker infrastructure, as this gets removed when the per-sb shrinker callouts are introduced later on. Signed-off-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-20btrfs: kill magical embedded struct superblockAl Viro
2011-07-20new helper: iterate_supers_type()Al Viro
Call the given function for all superblocks of given type. Function gets a superblock (with s_umount locked shared) and (void *) argument supplied by caller of iterator. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-07-12fixlet: Remove fs_excl from struct task.Justin TerAvest
fs_excl is a poor man's priority inheritance for filesystems to hint to the block layer that an operation is important. It was never clearly specified, not widely adopted, and will not prevent starvation in many cases (like across cgroups). fs_excl was introduced with the time sliced CFQ IO scheduler, to indicate when a process held FS exclusive resources and thus needed a boost. It doesn't cover all file systems, and it was never fully complete. Lets kill it. Signed-off-by: Justin TerAvest <teravest@google.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-06-03more conservative S_NOSEC handlingAl Viro
Caching "we have already removed suid/caps" was overenthusiastic as merged. On network filesystems we might have had suid/caps set on another client, silently picked by this client on revalidate, all of that *without* clearing the S_NOSEC flag. AFAICS, the only reasonably sane way to deal with that is * new superblock flag; unless set, S_NOSEC is not going to be set. * local block filesystems set it in their ->mount() (more accurately, mount_bdev() does, so does btrfs ->mount(), users of mount_bdev() other than local block ones clear it) * if any network filesystem (or a cluster one) wants to use S_NOSEC, it'll need to set MS_NOSEC in sb->s_flags *AND* take care to clear S_NOSEC when inode attribute changes are picked from other clients. It's not an earth-shattering hole (anybody that can set suid on another client will almost certainly be able to write to the file before doing that anyway), but it's a bug that needs fixing. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-05-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/djm/tmem * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/djm/tmem: xen: cleancache shim to Xen Transcendent Memory ocfs2: add cleancache support ext4: add cleancache support btrfs: add cleancache support ext3: add cleancache support mm/fs: add hooks to support cleancache mm: cleancache core ops functions and config fs: add field to superblock to support cleancache mm/fs: cleancache documentation Fix up trivial conflict in fs/btrfs/extent_io.c due to includes
2011-05-26mm/fs: add hooks to support cleancacheDan Magenheimer
This fourth patch of eight in this cleancache series provides the core hooks in VFS for: initializing cleancache per filesystem; capturing clean pages reclaimed by page cache; attempting to get pages from cleancache before filesystem read; and ensuring coherency between pagecache, disk, and cleancache. Note that the placement of these hooks was stable from 2.6.18 to 2.6.38; a minor semantic change was required due to a patchset in 2.6.39. All hooks become no-ops if CONFIG_CLEANCACHE is unset, or become a check of a boolean global if CONFIG_CLEANCACHE is set but no cleancache "backend" has claimed cleancache_ops. Details and a FAQ can be found in Documentation/vm/cleancache.txt [v8: minchan.kim@gmail.com: adapt to new remove_from_page_cache function] Signed-off-by: Chris Mason <chris.mason@oracle.com> Signed-off-by: Dan Magenheimer <dan.magenheimer@oracle.com> Reviewed-by: Jeremy Fitzhardinge <jeremy@goop.org> Reviewed-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Al Viro <viro@ZenIV.linux.org.uk> Cc: Matthew Wilcox <matthew@wil.cx> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Mel Gorman <mel@csn.ul.ie> Cc: Rik Van Riel <riel@redhat.com> Cc: Jan Beulich <JBeulich@novell.com> Cc: Andreas Dilger <adilger@sun.com> Cc: Ted Ts'o <tytso@mit.edu> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <joel.becker@oracle.com> Cc: Nitin Gupta <ngupta@vflare.org>
2011-05-19VFS: trivial: fix comment on s_maxbytes value warning checkJeff Layton
I originally intended to remove this warning in 2.6.34, but it's not in a high performance codepath and might help us to catch bugs later. Let's keep it, but fix the comment to allay confusion about its removal. Signed-off-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Steve French <sfrench@us.ibm.com>
2011-03-24Merge branch 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.39/core' of git://git.kernel.dk/linux-2.6-block: (65 commits) Documentation/iostats.txt: bit-size reference etc. cfq-iosched: removing unnecessary think time checking cfq-iosched: Don't clear queue stats when preempt. blk-throttle: Reset group slice when limits are changed blk-cgroup: Only give unaccounted_time under debug cfq-iosched: Don't set active queue in preempt block: fix non-atomic access to genhd inflight structures block: attempt to merge with existing requests on plug flush block: NULL dereference on error path in __blkdev_get() cfq-iosched: Don't update group weights when on service tree fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going away block: Require subsystems to explicitly allocate bio_set integrity mempool jbd2: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging jbd: finish conversion from WRITE_SYNC_PLUG to WRITE_SYNC and explicit plugging fs: make fsync_buffers_list() plug mm: make generic_writepages() use plugging blk-cgroup: Add unaccounted time to timeslice_used. block: fixup plugging stubs for !CONFIG_BLOCK block: remove obsolete comments for blkdev_issue_zeroout. blktrace: Use rq->cmd_flags directly in blk_add_trace_rq. ... Fix up conflicts in fs/{aio.c,super.c}
2011-03-17vfs: split off vfsmount-related parts of vfs_kern_mount()Al Viro
new function: mount_fs(). Does all work done by vfs_kern_mount() except the allocation and filling of vfsmount; returns root dentry or ERR_PTR(). vfs_kern_mount() switched to using it and taken to fs/namespace.c, along with its wrappers. alloc_vfsmnt()/free_vfsmnt() made static. functions in namespace.c slightly reordered. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-03-17fs: assign sb->s_bdi to default_backing_dev_info if the bdi is going awayJens Axboe
We don't have proper reference counting for this yet, so we run into cases where the device is pulled and we OOPS on flushing the fs data. This happens even though the dirty inodes have already been migrated to the default_backing_dev_info. Reported-by: Torsten Hilbrich <torsten.hilbrich@secunet.com> Tested-by: Torsten Hilbrich <torsten.hilbrich@secunet.com> Cc: stable@kernel.org Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-03-16vfs: bury ->get_sb()Al Viro
This is an ex-parrot. Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-02-11vfs: call rcu_barrier after ->kill_sb()Boaz Harrosh
In commit fa0d7e3de6d6 ("fs: icache RCU free inodes"), we use rcu free inode instead of freeing the inode directly. It causes a crash when we rmmod immediately after we umount the volume[1]. So we need to call rcu_barrier after we kill_sb so that the inode is freed before we do rmmod. The idea is inspired by Aneesh Kumar. rcu_barrier will wait for all callbacks to end before preceding. The original patch was done by Tao Ma, but synchronize_rcu() is not enough here. 1. http://marc.info/?l=linux-fsdevel&m=129680863330185&w=2 Tested-by: Tao Ma <boyu.mt@taobao.com> Signed-off-by: Boaz Harrosh <bharrosh@panasas.com> Cc: Nick Piggin <npiggin@kernel.dk> Cc: Al Viro <viro@zeniv.linux.org.uk> Cc: Chris Mason <chris.mason@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-16sanitize vfsmount refcounting changesAl Viro
Instead of splitting refcount between (per-cpu) mnt_count and (SMP-only) mnt_longrefs, make all references contribute to mnt_count again and keep track of how many are longterm ones. Accounting rules for longterm count: * 1 for each fs_struct.root.mnt * 1 for each fs_struct.pwd.mnt * 1 for having non-NULL ->mnt_ns * decrement to 0 happens only under vfsmount lock exclusive That allows nice common case for mntput() - since we can't drop the final reference until after mnt_longterm has reached 0 due to the rules above, mntput() can grab vfsmount lock shared and check mnt_longterm. If it turns out to be non-zero (which is the common case), we know that this is not the final mntput() and can just blindly decrement percpu mnt_count. Otherwise we grab vfsmount lock exclusive and do usual decrement-and-check of percpu mnt_count. For fs_struct.c we have mnt_make_longterm() and mnt_make_shortterm(); namespace.c uses the latter in places where we don't already hold vfsmount lock exclusive and opencodes a few remaining spots where we need to manipulate mnt_longterm. Note that we mostly revert the code outside of fs/namespace.c back to what we used to have; in particular, normal code doesn't need to care about two kinds of references, etc. And we get to keep the optimization Nick's variant had bought us... Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2011-01-13Merge branch 'for-2.6.38/core' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'for-2.6.38/core' of git://git.kernel.dk/linux-2.6-block: (43 commits) block: ensure that completion error gets properly traced blktrace: add missing probe argument to block_bio_complete block cfq: don't use atomic_t for cfq_group block cfq: don't use atomic_t for cfq_queue block: trace event block fix unassigned field block: add internal hd part table references block: fix accounting bug on cross partition merges kref: add kref_test_and_get bio-integrity: mark kintegrityd_wq highpri and CPU intensive block: make kblockd_workqueue smarter Revert "sd: implement sd_check_events()" block: Clean up exit_io_context() source code. Fix compile warnings due to missing removal of a 'ret' variable fs/block: type signature of major_to_index(int) to major_to_index(unsigned) block: convert !IS_ERR(p) && p to !IS_ERR_NOR_NULL(p) cfq-iosched: don't check cfqg in choose_service_tree() fs/splice: Pull buf->ops->confirm() from splice_from_pipe actors cdrom: export cdrom_check_events() sd: implement sd_check_events() sr: implement sr_check_events() ...
2011-01-07fs: scale mntget/mntputNick Piggin
The problem that this patch aims to fix is vfsmount refcounting scalability. We need to take a reference on the vfsmount for every successful path lookup, which often go to the same mount point. The fundamental difficulty is that a "simple" reference count can never be made scalable, because any time a reference is dropped, we must check whether that was the last reference. To do that requires communication with all other CPUs that may have taken a reference count. We can make refcounts more scalable in a couple of ways, involving keeping distributed counters, and checking for the global-zero condition less frequently. - check the global sum once every interval (this will delay zero detection for some interval, so it's probably a showstopper for vfsmounts). - keep a local count and only taking the global sum when local reaches 0 (this is difficult for vfsmounts, because we can't hold preempt off for the life of a reference, so a counter would need to be per-thread or tied strongly to a particular CPU which requires more locking). - keep a local difference of increments and decrements, which allows us to sum the total difference and hence find the refcount when summing all CPUs. Then, keep a single integer "long" refcount for slow and long lasting references, and only take the global sum of local counters when the long refcount is 0. This last scheme is what I implemented here. Attached mounts and process root and working directory references are "long" references, and everything else is a short reference. This allows scalable vfsmount references during path walking over mounted subtrees and unattached (lazy umounted) mounts with processes still running in them. This results in one fewer atomic op in the fastpath: mntget is now just a per-CPU inc, rather than an atomic inc; and mntput just requires a spinlock and non-atomic decrement in the common case. However code is otherwise bigger and heavier, so single threaded performance is basically a wash. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2011-01-07fs: dcache per-bucket dcache hash lockingNick Piggin
We can turn the dcache hash locking from a global dcache_hash_lock into per-bucket locking. Signed-off-by: Nick Piggin <npiggin@kernel.dk>
2010-11-13block: clean up blkdev_get() wrappers and their usersTejun Heo
After recent blkdev_get() modifications, open_by_devnum() and open_bdev_exclusive() are simple wrappers around blkdev_get(). Replace them with blkdev_get_by_dev() and blkdev_get_by_path(). blkdev_get_by_dev() is identical to open_by_devnum(). blkdev_get_by_path() is slightly different in that it doesn't automatically add %FMODE_EXCL to @mode. All users are converted. Most conversions are mechanical and don't introduce any behavior difference. There are several exceptions. * btrfs now sets FMODE_EXCL in btrfs_device->mode, so there's no reason to OR it explicitly on blkdev_put(). * gfs2, nilfs2 and the generic mount_bdev() now set FMODE_EXCL in sb->s_mode. * With the above changes, sb->s_mode now always should contain FMODE_EXCL. WARN_ON_ONCE() added to kill_block_super() to detect errors. The new blkdev_get_*() functions are with proper docbook comments. While at it, add function description to blkdev_get() too. Signed-off-by: Tejun Heo <tj@kernel.org> Cc: Philipp Reisner <philipp.reisner@linbit.com> Cc: Neil Brown <neilb@suse.de> Cc: Mike Snitzer <snitzer@redhat.com> Cc: Joern Engel <joern@lazybastard.org> Cc: Chris Mason <chris.mason@oracle.com> Cc: Jan Kara <jack@suse.cz> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: KONISHI Ryusuke <konishi.ryusuke@lab.ntt.co.jp> Cc: reiserfs-devel@vger.kernel.org Cc: xfs-masters@oss.sgi.com Cc: Alexander Viro <viro@zeniv.linux.org.uk>
2010-11-13block: make blkdev_get/put() handle exclusive accessTejun Heo
Over time, block layer has accumulated a set of APIs dealing with bdev open, close, claim and release. * blkdev_get/put() are the primary open and close functions. * bd_claim/release() deal with exclusive open. * open/close_bdev_exclusive() are combination of open and claim and the other way around, respectively. * bd_link/unlink_disk_holder() to create and remove holder/slave symlinks. * open_by_devnum() wraps bdget() + blkdev_get(). The interface is a bit confusing and the decoupling of open and claim makes it impossible to properly guarantee exclusive access as in-kernel open + claim sequence can disturb the existing exclusive open even before the block layer knows the current open if for another exclusive access. Reorganize the interface such that, * blkdev_get() is extended to include exclusive access management. @holder argument is added and, if is @FMODE_EXCL specified, it will gain exclusive access atomically w.r.t. other exclusive accesses. * blkdev_put() is similarly extended. It now takes @mode argument and if @FMODE_EXCL is set, it releases an exclusive access. Also, when the last exclusive claim is released, the holder/slave symlinks are removed automatically. * bd_claim/release() and close_bdev_exclusive() are no longer necessary and either made static or removed. * bd_link_disk_holder() remains the same but bd_unlink_disk_holder() is no longer necessary and removed. * open_bdev_exclusive() becomes a simple wrapper around lookup_bdev() and blkdev_get(). It also has an unexpected extra bdev_read_only() test which probably should be moved into blkdev_get(). * open_by_devnum() is modified to take @holder argument and pass it to blkdev_get(). Most of bdev open/close operations are unified into blkdev_get/put() and most exclusive accesses are tested atomically at the open time (as it should). This cleans up code and removes some, both valid and invalid, but unnecessary all the same, corner cases. open_bdev_exclusive() and open_by_devnum() can use further cleanup - rename to blkdev_get_by_path() and blkdev_get_by_devt() and drop special features. Well, let's leave them for another day. Most conversions are straight-forward. drbd conversion is a bit more involved as there was some reordering, but the logic should stay the same. Signed-off-by: Tejun Heo <tj@kernel.org> Acked-by: Neil Brown <neilb@suse.de> Acked-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp> Acked-by: Mike Snitzer <snitzer@redhat.com> Acked-by: Philipp Reisner <philipp.reisner@linbit.com> Cc: Peter Osterlund <petero2@telia.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Heiko Carstens <heiko.carstens@de.ibm.com> Cc: Jan Kara <jack@suse.cz> Cc: Andrew Morton <akpm@linux-foundation.org> Cc: Andreas Dilger <adilger.kernel@dilger.ca> Cc: "Theodore Ts'o" <tytso@mit.edu> Cc: Mark Fasheh <mfasheh@suse.com> Cc: Joel Becker <joel.becker@oracle.com> Cc: Alex Elder <aelder@sgi.com> Cc: Christoph Hellwig <hch@infradead.org> Cc: dm-devel@redhat.com Cc: drbd-dev@lists.linbit.com Cc: Leo Chen <leochen@broadcom.com> Cc: Scott Branden <sbranden@broadcom.com> Cc: Chris Mason <chris.mason@oracle.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Cc: Joern Engel <joern@logfs.org> Cc: reiserfs-devel@vger.kernel.org Cc: Alexander Viro <viro@zeniv.linux.org.uk>
