path: root/fs/sysfs
implicit slab.h inclusion from percpu.h percpu.h is included by sched.h and module.h and thus ends up being included when building most .c files. percpu.h includes slab.h which in turn includes gfp.h making everything defined by the two files universally available and complicating inclusion dependencies. percpu.h -> slab.h dependency is about to be removed. Prepare for this change by updating users of gfp and slab facilities include those headers directly instead of assuming availability. As this conversion needs to touch large number of source files, the following script is used as the basis of conversion. http://userweb.kernel.org/~tj/misc/slabh-sweep.py The script does the followings. * Scan files for gfp and slab usages and update includes such that only the necessary includes are there. ie. if only gfp is used, gfp.h, if slab is used, slab.h. * When the script inserts a new include, it looks at the include blocks and try to put the new include such that its order conforms to its surrounding. It's put in the include block which contains core kernel includes, in the same order that the rest are ordered - alphabetical, Christmas tree, rev-Xmas-tree or at the end if there doesn't seem to be any matching order. * If the script can't find a place to put a new include (mostly because the file doesn't have fitting include block), it prints out an error message indicating which .h file needs to be added to the file. The conversion was done in the following steps. 1. The initial automatic conversion of all .c files updated slightly over 4000 files, deleting around 700 includes and adding ~480 gfp.h and ~3000 slab.h inclusions. The script emitted errors for ~400 files. 2. Each error was manually checked. Some didn't need the inclusion, some needed manual addition while adding it to implementation .h or embedding .c file was more appropriate for others. This step added inclusions to around 150 files. 3. The script was run again and the output was compared to the edits from #2 to make sure no file was left behind. 4. Several build tests were done and a couple of problems were fixed. e.g. lib/decompress_*.c used malloc/free() wrappers around slab APIs requiring slab.h to be added manually. 5. The script was run on all .h files but without automatically editing them as sprinkling gfp.h and slab.h inclusions around .h files could easily lead to inclusion dependency hell. Most gfp.h inclusion directives were ignored as stuff from gfp.h was usually wildly available and often used in preprocessor macros. Each slab.h inclusion directive was examined and added manually as necessary. 6. percpu.h was updated not to include slab.h. 7. Build test were done on the following configurations and failures were fixed. CONFIG_GCOV_KERNEL was turned off for all tests (as my distributed build env didn't work with gcov compiles) and a few more options had to be turned off depending on archs to make things build (like ipr on powerpc/64 which failed due to missing writeq). * x86 and x86_64 UP and SMP allmodconfig and a custom test config. * powerpc and powerpc64 SMP allmodconfig * sparc and sparc64 SMP allmodconfig * ia64 SMP allmodconfig * s390 SMP allmodconfig * alpha SMP allmodconfig * um on x86_64 SMP allmodconfig 8. percpu.h modifications were reverted so that it could be applied as a separate patch and serve as bisection point. Given the fact that I had only a couple of failures from tests on step 6, I'm fairly confident about the coverage of this conversion patch. If there is a breakage, it's likely to be something in one of the arch headers which should be easily discoverable easily on most builds of the specific arch. Signed-off-by: Tejun Heo <tj@kernel.org> Guess-its-ok-by: Christoph Lameter <cl@linux-foundation.org> Cc: Ingo Molnar <mingo@redhat.com> Cc: Lee Schermerhorn <Lee.Schermerhorn@hp.com>
2010-03-07sysfs: Kill unused sysfs_sb variable.Eric W. Biederman
Now that there are no more users we can remove the sysfs_sb variable. Acked-by: Tejun Heo <tj@kernel.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-07sysfs: Pass super_block to sysfs_get_inodeEric W. Biederman
Currently sysfs_get_inode magically returns an inode on sysfs_sb. Make the super_block parameter explicit and the code becomes clearer. Acked-by: Tejun Heo <tj@kernel.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-07sysfs: Implement sysfs_rename_linkEric W. Biederman
Because of rename ordering problems we occassionally give false warnings about invalid sysfs operations. So using sysfs_rename create a sysfs_rename_link function that doesn't need strange workarounds. Cc: Benjamin Thery <benjamin.thery@bull.net> Cc: Daniel Lezcano <dlezcano@fr.ibm.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-07sysfs: Pack sysfs_dirent more tightly.Eric W. Biederman
Placing the 16bit s_mode between a pointer and a long doesn't pack well especailly on 64bit where we wast 48 bits. So move s_mode and declare it as a unsigned short. This is the sysfs backing store after all we don't need fields extra large just in case someday we want userspace to be able to use a larger value. Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-07sysfs: Serialize updates to the vfs inodeEric W. Biederman
The vfs depends upon filesystem methods to update the vfs inode. Sysfs adds to the normal number of places where the vfs inode is updated by also updatng the vfs inode in sysfs_refresh_inode. Typically the inode mutex is used to serialize updates to the vfs inode, but grabbing the inode mutex in sysfs_permission and sysfs_getattr causes deadlocks, because sometimes the vfs calls those operations with the inode mutex held. Therefore sysfs can not use the inode mutex to serial updates to the vfs inode. The sysfs_mutex is acquired in all of the routines where sysfs updates the vfs inode, and with a small change we can consistently protext sysfs vfs inode updates with the sysfs_mutex. To protect the sysfs vfs inode updates with the sysfs_mutex simply requires extending the scope of sysfs_mutex in sysfs_setattr over inode_setattr, and over inode_change_ok (so we have an unchanging inode when we perform the check). Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-07sysfs: Use one lockdep class per sysfs attribute.Eric W. Biederman
Acknowledge that the logical sysfs rwsem has one instance per sysfs attribute with different locking depencencies for different attributes. There is a sysfs idiom where writing to one sysfs file causes the addition or removal of other sysfs files. Lumping all of the sysfs attributes together in one lock class causes lockdep to generate lots of false positives. This introduces the requirement that non-static sysfs attributes need to be initialized with sysfs_attr_init or sysfs_bin_attr_init. Strictly speaking this requirement only exists when lockdep is enabled, and when lockdep is enabled we get a bit fat warning if this requirement is not met. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-07sysfs: Only take active references on attributes.Eric W. Biederman
If we exclude directories and symlinks from the set of sysfs dirents where we need active references we are left with sysfs attributes (binary or not). - Tweak sysfs_deactivate to only do something on attributes - Move lockdep initialization into sysfs_file_add_mode to limit it to just attributes. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: WANG Cong <xiyou.wangcong@gmail.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-07sysfs: Remove sysfs_get/put_active_twoEric W. Biederman
It turns out that holding an active reference on a directory is pointless. The purpose of the active references are to allows us to block when removing sysfs entries that have custom methods so we don't remove modules while running modular code and to keep those custom methods from accessing data structures after the files have been removed. Further sysfs_remove_dir remove all elements in the directory before removing the directory itself, so there is no chance we will remove a directory with active children. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Cc: Tejun Heo <tj@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-07Driver core: Constify struct sysfs_ops in struct kobj_typeEmese Revfy
Constify struct sysfs_ops. This is part of the ops structure constification effort started by Arjan van de Ven et al. Benefits of this constification: * prevents modification of data that is shared (referenced) by many other structure instances at runtime * detects/prevents accidental (but not intentional) modification attempts on archs that enforce read-only kernel data at runtime * potentially better optimized code as the compiler can assume that the const data cannot be changed * the compiler/linker move const data into .rodata and therefore exclude them from false sharing Signed-off-by: Emese Revfy <re.emese@gmail.com> Acked-by: David Teigland <teigland@redhat.com> Acked-by: Matt Domsch <Matt_Domsch@dell.com> Acked-by: Maciej Sosnowski <maciej.sosnowski@intel.com> Acked-by: Hans J. Koch <hjk@linutronix.de> Acked-by: Pekka Enberg <penberg@cs.helsinki.fi> Acked-by: Jens Axboe <jens.axboe@oracle.com> Acked-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-07sysfs: Cache the last sysfs_dirent to improve readdir scalability v2Eric W. Biederman
When sysfs_readdir stops short we now cache the next sysfs_dirent to return to user space in filp->private_data. There is no impact on the rest of sysfs by doing this and in the common case it allows us to pick up exactly where we left off with no seeking. Additionally I drop and regrab the sysfs_mutex around filldir to avoid a page fault abritrarily increasing the hold time on the sysfs_mutex. v2: Returned to using INT_MAX as the EOF condition. seekdir is ambiguous unless all directory entries have a unique f_pos value. Fixes http://bugzilla.kernel.org/show_bug.cgi?id=14949 Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-03-07sysfs: Add sysfs_add/remove_files utility functionsAndi Kleen
Adding/Removing a whole array of attributes is very common. Add a standard utility function to do this with a simple function call, instead of requiring drivers to open code this. Signed-off-by: Andi Kleen <ak@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-02-16sysfs: sysfs_sd_setattr set iattrs unconditionallyEric W. Biederman
There is currently a bug in sysfs_sd_setattr inherited from sysfs_setattr in 2.6.32 where the first time we set the attributes on a sysfs file we allocate backing store but do not set the backing store attributes. Resulting in overly restrictive permissions on sysfs files. The fix is to simply modify the code so that it always executes when we update the sysfs attributes, as we did in 2.6.31 and earlier. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Tested-by: Jean Delvare <khali@linux-fr.org> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-04sysfs: Add lockdep annotations for the sysfs active referenceEric W. Biederman
Holding locks over device_del -> kobject_del -> sysfs_deactivate can cause deadlocks if those same locks are grabbed in sysfs show or store methods. The I model s_active count + completion as a sleeping read/write lock. I describe to lockdep sysfs_get_active as a read_trylock, sysfs_put_active as a read_unlock, and sysfs_deactivate as a write_lock and write_unlock pair. This seems to capture the essence for purposes of finding deadlocks, and in my testing gives finds real issues and ignores non-issues. This brings us back to holding locks over kobject_del is a problem that ideally we should find a way of addressing, but at least lockdep can tell us about the problems instead of requiring developers to debug rare strange system deadlocks, that happen when sysfs files are removed while being written to. Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-23Driver core: bin_attribute parameters can often be const*Phil Carmody
Many struct bin_attribute descriptors are purely read-only structures, and there's no need to change them. Therefore make the promise not to, which will let those descriptors be put in a ro section. Signed-off-by: Phil Carmody <ext-phil.2.carmody@nokia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11sysfs: sysfs_setattr remove unnecessary permission check.Eric W. Biederman
inode_change_ok already clears the SGID bit when necessary so there is no reason for sysfs_setattr to carry code to do the same, and it is good to kill the extra copy because when I moved the code last in certain corner cases the code will look at the wrong gid. Acked-by: Serge Hallyn <serue@us.ibm.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11sysfs: Factor out sysfs_rename from sysfs_rename_dir and sysfs_move_dirEric W. Biederman
These two functions do 90% of the same work and it doesn't significantly obfuscate the function to allow both the parent dir and the name to change at the same time. So merge them together to simplify maintenance, and increase testing. Acked-by: Tejun Heo <tj@kernel.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11sysfs: Propagate renames to the vfs on demandEric W. Biederman
By teaching sysfs_revalidate to hide a dentry for a sysfs_dirent if the sysfs_dirent has been renamed, and by teaching sysfs_lookup to return the original dentry if the sysfs dirent has been renamed. I can show the results of renames correctly without having to update the dcache during the directory rename. This massively simplifies the rename logic allowing a lot of weird sysfs special cases to be removed along with a lot of now unnecesary helper code. Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11sysfs: Gut sysfs_addrm_start and sysfs_addrm_finishEric W. Biederman
With lazy inode updates and dentry operations bringing everything into sync on demand there is no longer any need to immediately update the vfs or grab i_mutex to protect those updates as we make changes to sysfs. Acked-by: Serge Hallyn <serue@us.ibm.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11sysfs: In sysfs_chmod_file lazily propagate the mode change.Eric W. Biederman
Now that sysfs_getattr and sysfs_permission refresh the vfs inode there is no need to immediatly push the mode change into the vfs cache. Reducing the amount of work needed and simplifying the locking. Acked-by: Tejun Heo <tj@kernel.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11sysfs: Implement sysfs_getattr & sysfs_permissionEric W. Biederman
With the implementation of sysfs_getattr and sysfs_permission sysfs becomes able to lazily propogate inode attribute changes from the sysfs_dirents to the vfs inodes. This paves the way for deleting significant chunks of now unnecessary code. While doing this we did not reference sysfs_setattr from sysfs_symlink_inode_operations so I added along with sysfs_getattr and sysfs_permission. Acked-by: Tejun Heo <tj@kernel.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11sysfs: Nicely indent sysfs_symlink_inode_operationsEric W. Biederman
Lining up the functions in sysfs_symlink_inode_operations follows the pattern in the rest of sysfs and makes things slightly more readable. Acked-by: Tejun Heo <tj@kernel.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11sysfs: Update s_iattr on link and unlink.Eric W. Biederman
Currently sysfs updates the timestamps on the vfs directory inode when we create or remove a directory entry but doesn't update the cached copy on the sysfs_dirent, fix that oversight. Acked-by: Tejun Heo <tj@kernel.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11sysfs: Fix locking and factor out sysfs_sd_setattrEric W. Biederman
Cleanly separate the work that is specific to setting the attributes of a sysfs_dirent from what is needed to update the attributes of a vfs inode. Additionally grab the sysfs_mutex to keep any nasties from surprising us when updating the sysfs_dirent. Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11sysfs: Simplify iattr time assignmentsEric W. Biederman
The granularity of sysfs time when we keep it is 1 ns. Which when passed to timestamp_trunc results in a nop. So remove the unnecessary function call making sysfs_setattr slightly easier to read. Acked-by: Tejun Heo <tj@kernel.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11sysfs: Simplify sysfs_chmod_file semanticsEric W. Biederman
Currently every caller of sysfs_chmod_file happens at either file creation time to set a non-default mode or in response to a specific user requested space change in policy. Making timestamps of when the chmod happens and notification of a file changing mode uninteresting. Remove the unnecessary time stamp and filesystem change notification, and removes the last of the explicit inotify and donitfy support from sysfs. Acked-by: Tejun Heo <tj@kernel.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11sysfs: Use dentry_ops instead of directly playing with the dcacheEric W. Biederman
Calling d_drop unconditionally when a sysfs_dirent is deleted has the potential to leak mounts, so instead implement dentry delete and revalidate operations that cause sysfs dentries to be removed at the appropriate time. Acked-by: Tejun Heo <tj@kernel.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11sysfs: Rename sysfs_d_iput to sysfs_dentry_iputEric W. Biederman
Using dentry instead of d in the function name is what several other filesystems are doing and it seems to be a more readable convention. Acked-by: Tejun Heo <tj@kernel.org> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11sysfs: Update sysfs_setxattr so it updates secdata under the sysfs_mutexEric W. Biederman
The sysfs_mutex is required to ensure updates are and will remain atomic with respect to other inode iattr updates, that do not happen through the filesystem. Acked-by: Serge Hallyn <serue@us.ibm.com> Acked-by: Tejun Heo <tj@kernel.org> Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11sysfs: mark a locally-only used function staticStefan Richter
Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Acked-by: David P. Quigley <dpquigl@tycho.nsa.gov> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-11-05sysfs: Don't leak secdata when a sysfs_dirent is freed.Eric W. Biederman
While refreshing my sysfs patches I noticed a leak in the secdata implementation. We don't free the secdata when we free the sysfs dirent. This is a bug in 2.6.32-rc5 that we really should close. Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Acked-by: Serge Hallyn <serue@us.ibm.com> Signed-off-by: James Morris <jmorris@namei.org>
2009-10-14sysfs: Allow sysfs_notify_dirent to be called from interrupt context.Neil Brown
sysfs_notify_dirent is a simple atomic operation that can be used to alert user-space that new data can be read from a sysfs attribute. Unfortunately it cannot currently be called from non-process context because of its use of spin_lock which is sometimes taken with interrupts enabled. So change all lockers of sysfs_open_dirent_lock to disable interrupts, thus making sysfs_notify_dirent safe to be called from non-process context (as drivers/md does in md_safemode_timeout). sysfs_get_open_dirent is (documented as being) only called from process context, so it uses spin_lock_irq. Other places use spin_lock_irqsave. The usage for sysfs_notify_dirent in md_safemode_timeout was introduced in 2.6.28, so this patch is suitable for that and more recent kernels. Reported-by: Joel Andres Granados <jgranado@redhat.com> Signed-off-by: NeilBrown <neilb@suse.de> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-10-14sysfs: Allow sysfs_move_dir(..., NULL) again.Cornelia Huck
As device_move() and kobject_move() both handle a NULL destination, sysfs_move_dir() should do this as well (again) and fall back to sysfs_root in that case. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Cc: Phil Carmody <ext-phil.2.carmody@nokia.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-27const: mark struct vm_struct_operationsAlexey Dobriyan
* mark struct vm_area_struct::vm_ops as const * mark vm_ops in AGP code But leave TTM code alone, something is fishy there with global vm_ops being used. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-11Merge branch 'writeback' of git://git.kernel.dk/linux-2.6-blockLinus Torvalds
* 'writeback' of git://git.kernel.dk/linux-2.6-block: writeback: check for registered bdi in flusher add and inode dirty writeback: add name to backing_dev_info writeback: add some debug inode list counters to bdi stats writeback: get rid of pdflush completely writeback: switch to per-bdi threads for flushing data writeback: move dirty inodes from super_block to backing_dev_info writeback: get rid of generic_sync_sb_inodes() export
2009-09-11writeback: add name to backing_dev_infoJens Axboe
This enables us to track who does what and print info. Its main use is catching dirty inodes on the default_backing_dev_info, so we can fix that up. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2009-09-10sysfs: Add labeling support for sysfsDavid P. Quigley
This patch adds a setxattr handler to the file, directory, and symlink inode_operations structures for sysfs. The patch uses hooks introduced in the previous patch to handle the getting and setting of security information for the sysfs inodes. As was suggested by Eric Biederman the struct iattr in the sysfs_dirent structure has been replaced by a structure which contains the iattr, secdata and secdata length to allow the changes to persist in the event that the inode representing the sysfs_dirent is evicted. Because sysfs only stores this information when a change is made all the optional data is moved into one dynamically allocated field. This patch addresses an issue where SELinux was denying virtd access to the PCI configuration entries in sysfs. The lack of setxattr handlers for sysfs required that a single label be assigned to all entries in sysfs. Granting virtd access to every entry in sysfs is not an acceptable solution so fine grained labeling of sysfs is required such that individual entries can be labeled appropriately. [sds: Fixed compile-time warnings, coding style, and setting of inode security init flags.] Signed-off-by: David P. Quigley <dpquigl@tycho.nsa.gov> Signed-off-by: Stephen D. Smalley <sds@tycho.nsa.gov> Signed-off-by: James Morris <jmorris@namei.org>
2009-07-28sysfs: fix hardlink count on device_movePeter Oberparleiter
Update directory hardlink count when moving kobjects to a new parent. Fixes the following problem which occurs when several devices are moved to the same parent and then unregistered: > ls -laF /sys/devices/css0/defunct/ > total 0 > drwxr-xr-x 4294967295 root root 0 2009-07-14 17:02 ./ > drwxr-xr-x 114 root root 0 2009-07-14 17:02 ../ > drwxr-xr-x 2 root root 0 2009-07-14 17:01 power/ > -rw-r--r-- 1 root root 4096 2009-07-14 17:01 uevent Signed-off-by: Peter Oberparleiter <oberpar@linux.vnet.ibm.com> Cc: stable <stable@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-07-08Free the memory allocated by memdup_user() in fs/sysfs/bin.cCatalin Marinas
Commit 1c8542c7bb replaced kmalloc() with memdup_user() in the write() function but also dropped the kfree(temp). The memdup_user() function allocates memory which is never freed. Signed-off-by: Catalin Marinas <catalin.marinas@arm.com> Cc: Parag Warudkar <parag.warudkar@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-15Sysfs: fix possible memleak in sysfs_follow_linkArmin Kuster
There is the possiblity of a memory leak if a page is allocated and if sysfs_getlink() fails in the sysfs_follow_link. Signed-off-by: Armin Kuster <akuster@mvista.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-05-28sysfs: file.c: use create_singlethread_workqueue()Andrew Morton
We don't need a kernel thread per CPU for this application. Acked-by: Alex Chiang <achiang@hp.com> Cc: Lai Jiangshan <laijs@cn.fujitsu.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-04-20sysfs: use memdup_user()Li Zefan
Remove open-coded memdup_user(). Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2009-04-16sysfs: sysfs poll keep the poll rule of regular file.KOSAKI Motohiro
Currently, following test programs don't finished. % ruby -e ' Thread.new { sleep } File.read("/sys/devices/system/cpu/cpu0/cpufreq/scaling_available_frequencies") ' strace expose the reason. ... open("/sys/devices/system/cpu/cpu0/cpufreq/scaling_available_frequencies", O_RDONLY|O_LARGEFILE) = 3 ioctl(3, SNDCTL_TMR_TIMEBASE or TCGETS, 0xbf9fa6b8) = -1 ENOTTY (Inappropriate ioctl for device) fstat64(3, {st_mode=S_IFREG|0444, st_size=4096, ...}) = 0 _llseek(3, 0, [0], SEEK_CUR) = 0 select(4, [3], NULL, NULL, NULL) = 1 (in [3]) read(3, "1400000 1300000 1200000 1100000 1"..., 4096) = 62 select(4, [3], NULL, NULL, NULL Because Ruby (the scripting language) VM assume select system-call against regular file don't block. it because SUSv3 says "Regular files shall always poll TRUE for reading and writing". see http://www.opengroup.org/onlinepubs/009695399/functions/poll.html it seems valid assumption. But sysfs_poll() don't keep this rule although sysfs file can read and write always. This patch restore proper poll behavior to sysfs. /sys/block/md*/md/sync_action polling application and another sysfs updating sensitive application still can use POLLERR and POLLPRI. Cc: Neil Brown <neilb@suse.de> Signed-off-by: KOSAKI Motohiro <kosaki.motohiro@jp.fujitsu.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-04-16sysfs: don't use global workqueue in sysfs_schedule_callback()Alex Chiang
A sysfs attribute using sysfs_schedule_callback() to commit suicide may end up calling device_unregister(), which will eventually call a driver's ->remove function. Drivers may call flush_scheduled_work() in their shutdown routines, in which case lockdep will complain with something like the following: ============================================= [ INFO: possible recursive locking detected ] 2.6.29-rc8-kk #1 --------------------------------------------- events/4/56 is trying to acquire lock: (events){--..}, at: [<ffffffff80257fc0>] flush_workqueue+0x0/0xa0 but task is already holding lock: (events){--..}, at: [<ffffffff80257648>] run_workqueue+0x108/0x230 other info that might help us debug this: 3 locks held by events/4/56: #0: (events){--..}, at: [<ffffffff80257648>] run_workqueue+0x108/0x230 #1: (&ss->work){--..}, at: [<ffffffff80257648>] run_workqueue+0x108/0x230 #2: (pci_remove_rescan_mutex){--..}, at: [<ffffffff803c10d1>] remove_callback+0x21/0x40 stack backtrace: Pid: 56, comm: events/4 Not tainted 2.6.29-rc8-kk #1 Call Trace: [<ffffffff8026dfcd>] validate_chain+0xb7d/0x1260 [<ffffffff8026eade>] __lock_acquire+0x42e/0xa40 [<ffffffff8026f148>] lock_acquire+0x58/0x80 [<ffffffff80257fc0>] ? flush_workqueue+0x0/0xa0 [<ffffffff8025800d>] flush_workqueue+0x4d/0xa0 [<ffffffff80257fc0>] ? flush_workqueue+0x0/0xa0 [<ffffffff80258070>] flush_scheduled_work+0x10/0x20 [<ffffffffa0144065>] e1000_remove+0x55/0xfe [e1000e] [<ffffffff8033ee30>] ? sysfs_schedule_callback_work+0x0/0x50 [<ffffffff803bfeb2>] pci_device_remove+0x32/0x70 [<ffffffff80441da9>] __device_release_driver+0x59/0x90 [<ffffffff80441edb>] device_release_driver+0x2b/0x40 [<ffffffff804419d6>] bus_remove_device+0xa6/0x120 [<ffffffff8043e46b>] device_del+0x12b/0x190 [<ffffffff8043e4f6>] device_unregister+0x26/0x70 [<ffffffff803ba969>] pci_stop_dev+0x49/0x60 [<ffffffff803baab0>] pci_remove_bus_device+0x40/0xc0 [<ffffffff803c10d9>] remove_callback+0x29/0x40 [<ffffffff8033ee4f>] sysfs_schedule_callback_work+0x1f/0x50 [<ffffffff8025769a>] run_workqueue+0x15a/0x230 [<ffffffff80257648>] ? run_workqueue+0x108/0x230 [<ffffffff8025846f>] worker_thread+0x9f/0x100 [<ffffffff8025bce0>] ? autoremove_wake_function+0x0/0x40 [<ffffffff802583d0>] ? worker_thread+0x0/0x100 [<ffffffff8025b89d>] kthread+0x4d/0x80 [<ffffffff8020d4ba>] child_rip+0xa/0x20 [<ffffffff8020cebc>] ? restore_args+0x0/0x30 [<ffffffff8025b850>] ? kthread+0x0/0x80 [<ffffffff8020d4b0>] ? child_rip+0x0/0x20 Although we know that the device_unregister path will never acquire a lock that a driver might try to acquire in its ->remove, in general we should never attempt to flush a workqueue from within the same workqueue, and lockdep rightly complains. So as long as sysfs attributes cannot commit suicide directly and we are stuck with this callback mechanism, put the sysfs callbacks on their own workqueue instead of the global one. This has the side benefit that if a suicidal sysfs attribute kicks off a long chain of ->remove callbacks, we no longer induce a long delay on the global queue. This also fixes a missing module_put in the error path introduced by sysfs-only-allow-one-scheduled-removal-callback-per-kobj.patch. We never destroy the workqueue, but I'm not sure that's a problem. Reported-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Tested-by: Kenji Kaneshige <kaneshige.kenji@jp.fujitsu.com> Signed-off-by: Alex Chiang <achiang@hp.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-04-01mm: page_mkwrite change prototype to match fault: fix sysfsHugh Dickins
Fix warnings and return values in sysfs bin_page_mkwrite(), fixing fs/sysfs/bin.c: In function `bin_page_mkwrite': fs/sysfs/bin.c:250: warning: passing argument 2 of `bb->vm_ops->page_mkwrite' from incompatible pointer type fs/sysfs/bin.c: At top level: fs/sysfs/bin.c:280: warning: initialization from incompatible pointer type Expects to have my [PATCH next] sysfs: fix some bin_vm_ops errors Signed-off-by: Hugh Dickins <hugh@veritas.com> Cc: Nick Piggin <npiggin@suse.de> Cc: "Eric W. Biederman" <ebiederm@aristanetworks.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-03-27Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs-2.6: (37 commits) fs: avoid I_NEW inodes Merge code for single and multiple-instance mounts Remove get_init_pts_sb() Move common mknod_ptmx() calls into caller Parse mount options just once and copy them to super block Unroll essentials of do_remount_sb() into devpts vfs: simple_set_mnt() should return void fs: move bdev code out of buffer.c constify dentry_operations: rest constify dentry_operations: configfs constify dentry_operations: sysfs constify dentry_operations: JFS constify dentry_operations: OCFS2 constify dentry_operations: GFS2 constify dentry_operations: FAT constify dentry_operations: FUSE constify dentry_operations: procfs constify dentry_operations: ecryptfs constify dentry_operations: CIFS constify dentry_operations: AFS ...
2009-03-27constify dentry_operations: sysfsAl Viro
2009-03-24sysfs: fix some bin_vm_ops errorsHugh Dickins
Commit 86c9508eb1c0ce5aa07b5cf1d36b60c54efc3d7a "sysfs: don't block indefinitely for unmapped files" in linux-next crashes the PowerMac G5 when X starts up. It's caught out by the way powerpc's pci_mmap of legacy_mem uses shmem_zero_setup(), substituting a new vma->vm_file whose private_data no longer points to the bin_buffer (substitution done because some versions of X crash if that mmap fails). The fix to this is straightforward: the original vm_file is fput() in that case, so this mmap won't block sysfs at all, so just don't switch over to bin_vm_ops if vm_file has changed. But more fixes made before realizing that was the problem:- It should not be an error if bin_page_mkwrite() finds no underlying page_mkwrite(). Check that a file already mmap'ed has the same underlying vm_ops _before_ pointing vma->vm_ops at bin_vm_ops. If the file being mmap'ed is a shmem/tmpfs file, don't fail the mmap on CONFIG_NUMA=y, just because that has a set_policy and get_policy: provide bin_set_policy, bin_get_policy and bin_migrate. Signed-off-by: Hugh Dickins <hugh@veritas.com> Acked-by: Eric Biederman <ebiederm@aristanetworks.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24sysfs: only allow one scheduled removal callback per kobjAlex Chiang
The only way for a sysfs attribute to remove itself (without deadlock) is to use the sysfs_schedule_callback() interface. Vegard Nossum discovered that a poorly written sysfs ->store callback can repeatedly schedule remove callbacks on the same device over and over, e.g. $ while true ; do echo 1 > /sys/devices/.../remove ; done If the 'remove' attribute uses the sysfs_schedule_callback API and also does not protect itself from concurrent accesses, its callback handler will be called multiple times, and will eventually attempt to perform operations on a freed kobject, leading to many problems. Instead of requiring all callers of sysfs_schedule_callback to implement their own synchronization, provide the protection in the infrastructure. Now, sysfs_schedule_callback will only allow one scheduled callback per kobject. On subsequent calls with the same kobject, return -EAGAIN. This is a short term fix. The long term fix is to allow sysfs attributes to remove themselves directly, without any of this callback hokey pokey. [cornelia.huck@de.ibm.com: s390 ccwgroup bits] Reported-by: vegard.nossum@gmail.com Signed-off-by: Alex Chiang <achiang@hp.com> Acked-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-03-24sysfs: don't block indefinitely for unmapped files.Eric W. Biederman
Modify sysfs bin files so that we can remove the bin file while they are still mapped. When the kobject is removed we unmap the bin file and arrange for future accesses to the mapping to receive SIGBUS. Implementing this prevents a nasty DOS when pci devices are hot plugged and unplugged. Where if any of their resources were mmaped the kernel could not free up their pci resources or release their pci data structures. [akpm@linux-foundation.org: remove unused var] Signed-off-by: Eric W. Biederman <ebiederm@aristanetworks.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Acked-by: Tejun Heo <tj@kernel.org> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
